The New Master List of BASS in Movies with Frequency Charts - Page 529 - AVS Forum | Home Theater Discussions And Reviews
 7112Likes
Old 04-01-2014, 06:00 PM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
nah...he gave "gravity" 5 stars for LFE...i'm pretty sure he's had other 5's
at the zenith of his nadir...
lefthandluke is offline
Old 04-01-2014, 11:57 PM
McStyvie's Avatar
Liked: 78
Originally Posted by J_Palmer_Cass View Post
The Obama administration has proposed a new EPA rule that would force the entertainment industry to go green. One requirement that is buried deep in the proposal is the requirement that no audio content can have frequencies below 20 Hz nor above 20 kHz for all new content produced after 4/1/2015. In addition, to enforce this requirement all DVD and Bluray players firmware would be required to add this feature to the existing mandatory Cinavia watermark system. This firmware update will be mandatory for all new and existing DVD and Bluray players.
http://en.wikipedia.org/wiki/Cinavia
The full story about this energy conservation requirement can be read in the link below.
http://www.blu-ray.com/news/EPA proposal for green Blu-ray
Ha!
D!ck...
You got me good...
I have a Welsh colleague who always says," that puts the d!ck in ridiculous" Your response reminded me of her lol.
McStyvie is offline
Old 04-02-2014, 04:44 AM
bear123's Avatar
Quoted: 1718 Post(s)
Liked: 2527
Originally Posted by AJ72 View Post
And just goes to show that if your EQ isn't right (as mine wasn't when I first watched the OHF scene and was a bit underwhelmed) that scene will be missed. The hottest parts are at 20Hz judging by the graph and that scene is spectacular.
Perhaps people with extremely capable systems with lots of ouput to 10 Hz and lower are simply feeling the effects of the 20 Hz content much better, but still not really getting much from below 16?  Personally, when watching a scene like this, I have no innate ability to pinpoint exactly which frequency is shaking my room.  But playing individual tones, at normal movie watching volume, under 16 = nothing, 16+ = rumble.  I cannot achieve reference level output to 10 Hz, but I am flat to 10 louder than what I listen.
I was discussing this with someone who insisted the stuff below 16 Hz was causing all kinds of shaking and rumbling in his room.  I asked him how he knew, and he posted a spectrograph of the WotW pod scene.  So I asked, how do you know it isn't all the 16-30 Hz content in that scene that you are really feeling.  He said its because he is flat to 11 Hz and thats where all the tactile feel is.  Seems to me like he thought thats what was doing it, therefore in his mind it was, but doesn't seem very conclusive to me.
After all, a lot of the DIY guys are focusing more and more on ported subs for better 15Hz and up output.  Starting to feel to me like this is where the action is.
bear123 is offline
Old 04-02-2014, 05:25 AM
AJ72's Avatar
Quoted: 134 Post(s)
Liked: 157
Bear I know what you're saying but I haven't enough listening experience with other subs capable of low level output to know whether I' missing out on anything or not. You may be opening a giant can of whoop ass!
I have Dual Captivators and there is a whole lot of house shaking going on during that OHF scene. Same goes for WWZ grenade scene. The Caps port tune is around 17-18Hz but never feels like I'm missing anything. Have only experience with a Triax to compare to. Never heard Submersive or anything close to Popalocks bass fortress. I know this will be debated until the cows come home (with regard to ELF) but watching WOTW pod emergence/lightning strikes through the Triax didn't reveal any new material I hadn't already experienced with the Captivators. Maybe other setups would but I'm so happy with the Caps that I'm not concerned about it.
AJ72 is offline
Old 04-02-2014, 05:33 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
watch a scene with lots of <16 and then one that is GREAt >16 and you will then understand what that feeling is of sub 16 feeling....(i.e. TIH vs Darla tap scene) I have seen so many scenes with both, I can usually tell you without graphing which movies hit low and which dont
Did you ever consider running a house curve? this boost the llower octaves so when listening at lower volumes you still get the higher spl of bass needed down there to get the feeling.
Yes I am FLAT to 10.5Hz, but I dont listen loud enough for that to make an impact (MVL -10db max)...so I institute a house curve which boosts those freq about 3db on a gentle rising curve (the lower they get the louder they will play so they can be felt)). I have found the perfect level using minidsp's loew shelf filter as to not allow over compression/distortion/limiter kicking in and loss of headroom for the upper frequencies..
Brian Fineberg is offline
Old 04-02-2014, 05:35 AM
bear123's Avatar
Liked: 2527
This is with no eq below 20.
A sweep done at -5(much louder than I listen)....might have been -10, I need to run a couple more sweeps this weekend.  My mic was clipping at this level so I could not go any higher so need to fix that issue but don't plan on sweeping too much higher...don't want to fry anything.
Brian if I ever add a 2nd XS30 I might do the house curve, but I am afraid I might not have the headroom with one.
bear123 is offline
Old 04-02-2014, 07:46 AM
tvuong's Avatar
Quoted: 1569 Post(s)
Liked: 905
Do you happen to have a graph showing your low shelf house curve?
tvuong is online now
Old 04-02-2014, 08:06 AM
Liked: 3515
Old 04-02-2014, 08:07 AM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Was this your center/sub? Or lfe?
current setup: Integra 50.4 avr, PSA 210t L/R, PSA 210, 4 volt 10's in slant box style, 3 svs pc13 ultras, epson 5030ub with 92" AT screen diy spandex cloth
jwtallguy is offline
Old 04-02-2014, 08:18 AM
bear123's Avatar
Liked: 2527
3.1
bear123 is offline
Old 04-02-2014, 08:32 AM
MKtheater's Avatar
Quoted: 1603 Post(s)
Liked: 1127
You seem to be calibrated too low.
Marantz 7702 Atmos
MKtheater is online now
Old 04-02-2014, 08:49 AM
bear123's Avatar
Liked: 2527
I think I will pick up a radio shack SPL to verify the mic is reading correctly.....started clipping at 95 db or so which should not be the case.
bear123 is offline
Old 04-02-2014, 08:51 AM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
3.1
Are you saying you ran a prologic sweep or channel 3 output with redirected bass?
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 974 Post(s)
Liked: 3000
Originally Posted by javanpohl View Post
Anybody notice that Ralph gave "Walking with Dinosaurs" 4 stars for LFE? I think that may be his highest yet. One scene " . . . will shake anything that's not tied down."
Greetings,
Technically you're both correct. I recently tweaked my review template, Here's how, and since making those changes the low frequency extension rating for Walking with dinosaurs is the highest I have given. As for Gravity which I reviewed prior to that, yes it received a rating of 5 in the LFE category. wink.gif
javanpohl and lefthandluke like this.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
Old 04-02-2014, 09:02 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
To follow up on what Ralph said, here's the direct link to his exact post talking about this new addition to his reviews:
http://www.avsforum.com/t/1121333/avs-forum-blu-ray-disc-reviews-general-discussion-thread/450#post_24422112
FYI, Walking With Dinosaurs does have some very serious low end content, but it's an atrociously bad movie. Measurements to follow @ d-b.com.
Ralph Potts and popalock like this.
nube is offline
Old 04-02-2014, 09:27 AM
bear123's Avatar
Liked: 2527
I ran a 5.5 second duration sine wave sweep from 10-300 Hz, generated by REW and transmitted to my AVR from my laptop via an HDMI cable with my front left, right, center, and both subwoofers playing, and recorded by a Umik-1 calibrated mic.
bear123 is offline
Old 04-02-2014, 09:39 AM
javanpohl's Avatar
Quoted: 537 Post(s)
Liked: 275
No, I'm talking about the new piece of criteria he has, the "non-rated element", which he didn't have in effect for his Gravity review.
Edit: whoops, didn't see that Ralph came on and cleared things up.
javanpohl is offline
Old 04-02-2014, 09:48 AM
Quoted: 137 Post(s)
Liked: 266
Originally Posted by Ralph Potts View Post
Greetings,
thanks Ralph...
til now I was not aware of the changes you've made...nicely done
Old 04-02-2014, 09:53 AM
Blu-ray Reviewer
Moderator
Quoted: 974 Post(s)
Liked: 3000
thanks Ralph...
Greetings,
Sure thing lefthadluke. Thanks to you and javanpohl for bringing it up. My apologies for taking the thread off topic..
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
Old 04-02-2014, 10:46 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
Greetings,
Ha! No worries. This thread spends more time off topic than on. I and many others that frequent this thread are happy to see the update to your methodology, and I would have missed it if you hadn't posted here.
pitviper33 is offline
Old 04-02-2014, 02:59 PM
audiofan1's Avatar
Quoted: 1657 Post(s)
Liked: 1683
Finally netflix is shipping me a copy "The Exorcism of Emily Rose" as I don't recall seeing it and the comments here about its bass peaked interest should be cool smile.gif
audiofan1 is offline
Old 04-02-2014, 05:34 PM
Quoted: 137 Post(s)
Liked: 266
a shout out to GPBurns for the heads-up on the "Marley" bluray...very cool
not only a great sounding disc (marley in dtshd ma) but historically eye-opening...to me anyway
if you've been to jamaica you cant help but feel marleys impact (first thing you see entering the airport is a huge poster of him)...but there is much more to his story than i ever knew
if you are even a casual fan pick up this disc...it is, as i said, very cool
Old 04-02-2014, 06:58 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
+1 on the Marley doc. The rare footage is really cool.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
Old 04-02-2014, 07:29 PM
asharris7's Avatar
Sorry for being stupid, whats OTH scene? What movie?
asharris7 is offline
Old 04-02-2014, 07:38 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
Do you mean ohf? Olympus has fallen, when the monument comes crashing down.
Mrkazador is offline
Old 04-02-2014, 07:56 PM
asharris7's Avatar
Oh ok, I'm sorry. Thanks
Old 04-02-2014, 08:22 PM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 287
Great you enjoyed it
I was really impressed with the disc - been fan for long time but a lot I did not know
love Jamaica too - try to go every year - red stripe and sun
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
Old 04-03-2014, 05:01 AM
Mongo171's Avatar
Quoted: 829 Post(s)
Liked: 1257
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 04-03-2014, 05:43 AM
McStyvie's Avatar
Liked: 78
Originally Posted by Mongo171 View Post
Only in Colorado and Washington...more to come.
McStyvie is offline
Old 04-03-2014, 08:32 AM
carp's Avatar
Quoted: 2549 Post(s)
Liked: 1816
I quickly surfed through the last few pages but didn't see.
What is the bass in the new Hobbit movie filtered at? I'm hoping not like the first one but expecting the same....frown.gif
carp is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
