The New Master List of BASS in Movies with Frequency Charts - Page 572 - AVS Forum | Home Theater Discussions And Reviews
 7154Likes
post #17131 of 27573 Old 06-09-2014, 01:29 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
Originally Posted by MKtheater View Post
You have limiters to protect, no? Meaning if the bass gets too crazy your amp will just limit? I did not realize I was sharing my projector with my bass amp so I will try the amp alone.
MK Theater.. Watched LS today. I too popped the breakers on the heli scene. Twice.. First was 3 of my S2's. Did the scene again and popped all 4 S2 each on a dedicated 20 amp line. Then I just came in this thread and read your post. Wow, that scene must be in the single digits.
rhed is offline
post #17132 of 27573 Old 06-09-2014, 01:34 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
Have any of you watched the excursion on your drivers on the heli scene of LS? Last time I seen my drivers dance like that was f@
rhed is offline
post #17133 of 27573 Old 06-09-2014, 01:49 AM
doomnaut's Avatar
Not my video but wow I need to get this disk.
doomnaut is offline
post #17134 of 27573 Old 06-09-2014, 02:29 AM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Originally Posted by kevings View Post
Watched Robocop last night… His footsteps, and his gun, were awesome LFE.
Also, The scene in the lobby of the building, with the ED-209 units was also pretty awesome.
Yes indeed !!!
This DTS 5.1 HD track has a really good mix and I was not disappointed !! Had some really good gun fire and I could feel the tactile sensation from the subs when Robo fired his guns !! Overall no slouch in the Bass dept. biggrin.gif
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #17135 of 27573 Old 06-09-2014, 05:40 AM
tvuong's Avatar
Quoted: 1793 Post(s)
Liked: 1087
Originally Posted by audiofan1 View Post
upcoming releases like Jack Ryan for 12.99 ? what gives are we finally looking at lower Bluray prices?
it's a very good movie IMO with good bass. The explosion toward the end had my couch shaking.
audiofan1 likes this.
tvuong is offline
post #17136 of 27573 Old 06-09-2014, 06:30 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Originally Posted by pajama sam View Post
I was just wondering if the bassheads in this thread make any use of Audysseys dynamic compression features or leave it off. I would think that the concept of dynamic compression would be antithetical to what people on this thread are looking for, but I'd appreciate a confirmation (or refutation). Thanks!
You shouldn't use dynamic compression unless you're listening quietly as it definitely lowers peaks. I believe dynamic EQ actually raises the bass level a bit so it could be beneficial. Watch with it on and then off at the same volume level and compare.
JWagstaff is offline
post #17137 of 27573 Old 06-09-2014, 06:34 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Originally Posted by jlpowell84 View Post
Gonna watch the whole LS movie tomm but I did demo the helicopter scene and it is pretty cool. Very realistic for sure. I can see yours MK how it made such a huge impression. I was actually thinking about all this after the Pompei talk and mixed feelings. That is our opinions will differ from not only what subs we have but also the volume we listen at. For example I listen at -15 in my room and that is as loud as you can stand it. Okay maybe -12. As we know soundtracks fluctuate so thats my range in my room. Reference would be WAAAYY to loud in my small room. But I do run my bass hot and a rising house curve. I Have +5db low shelf from mini dsp, PGM 2 which gives 3db boost below 45ish HZ, and a 4db sub trim bump post Audyssey. So for those who listen at reference and run hot with VERY capable sealed setups they will be impressive over some one has ported setups or like me who have a decent sealed setup but listen below reference. Although my bass may not be too far behind reference levels. But not there I know smile.gif
You are misunderstanding volume levels. If you have it calibrated, -15 in your room is 100% identical (volume wise) to any other room in the world if they are also listening at -15. All receiver's calibrate to the same level at a certain listening position. Reference level (0 dB) is identical volume for you and for MK, room has no impact (unless you have not set your receiver up). I think some people find -15 to -10 getting too loud if your speakers are low end/commercial / dome tweeters. You need high efficiency pro theater speakers to really listen loud without distortion.
post #17138 of 27573 Old 06-09-2014, 07:04 AM
dominguez1's Avatar
Quoted: 1112 Post(s)
Liked: 976
Huh?
Your subms have limiters in the amp to protect the driver from over excursion. Playing that scene at reference without audible distortion doesn't mean your are appropriately replicating the ulf on the disc because the limiters might be kicking in.
dominguez1 is offline
post #17139 of 27573 Old 06-09-2014, 07:43 AM
MKtheater's Avatar
Quoted: 1757 Post(s)
Liked: 1349
Yes, like the Sub1, look what happens when it gets turned up, it loses all the low end from compression but still playing the mid bass loud. The answer is to add more so the low end can keep up.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is offline
post #17140 of 27573 Old 06-09-2014, 10:06 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
+1
Audyssey's 'Dynamic EQ' boosts the lower end up at low volumes, so that you can hear the bass while still having the top end quite quiet - it's something to do with equal loudnes curves IIRC but I can't get more technical than that tongue.gif lol
As you turn the volume up, Dynamic EQ boost becomes less and less, until you are at Reference, at which point it is not boosting at all.
(In the AVR you should be able to set the Dynamic EQ level to either 0/Reference, -5, -10, or maybe -15, which is what the Dynamic EQ will use as your 'top volume' and therefore boost up to that point. This means you can use Dynamic EQ but if 0/Reference gives you a bit too much, you can go back into the menus and try a lower setting.)
'Dynamic Volume' is just another way of naming 'dynamic range compression' - the idea being that you can watch a movie late at night with the kids in bed, and rather than having it with full range dynamics like normal, so you have it at, say, -10dB so you can hear someone talking normally but then the bass kicks in and rattles all the doors in the house and wakes the kids up lol, it brings the bass down and the vocals up so they are all the same loudness, so you have a small dynamic range. This means that you can set the volume and not have to turn it down everytime an action sequence comes on!
pajama sam and eljaycanuck like this.
MemX is offline
post #17141 of 27573 Old 06-09-2014, 10:26 AM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
Ya I had experimented with it before at low volume levels and got tired of it quick. Just sounds unbalanced with too much bass and too hot of surrounds. This was a while back before I upgraded speakers
JBL Pro Cinema-JTR subwoofers-Sony projection-Elite AT screen-Denon AVR-Oppo BD player-Acoustimac panels-SeatCraft HT seating
MANCHESTER UNITED!!
Reddig is offline
post #17142 of 27573 Old 06-09-2014, 10:28 AM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
Re. DEQ - and FWIW - these graphs I took recently highlight it pretty well:
1. At reference, the black default curve is closely overlaid by the yellow DEQ curve (subs not hot). The green curve is the subs 6dB hot (no DEQ).
http://coolcrab.com/cal/images/05.jpg (full range)
http://coolcrab.com/cal/images/05a.jpg (zoom in on the subs)
2. At -10dB, the yellow DEQ curve almost overlays the green "subs hot" curve. The difference between DEQ and just running the subs hot is that DEQ boosts levels past the x-cover, tapering them off as the frequencies approach ~200-300Hz.
http://coolcrab.com/cal/images/06.jpg (full range)
http://coolcrab.com/cal/images/06a.jpg (zoom in on the subs)
eljaycanuck is offline
post #17143 of 27573 Old 06-09-2014, 11:32 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
Originally Posted by eljaycanuck View Post
Re. DEQ (and FWIW), these graphs I took recently highlight it very well:
1. At reference, the black default curve is overlaid by the yellow DEQ curve (subs not hot) essentially exactly. The green curve is the subs 6dB hot (no DEQ).
2. At -10dB, the yellow DEQ curve moves closer to the green "subs hot" curve. The difference between DEQ and just running the subs hot is that DEQ boosts levels past the x-cover, tapering them off as the frequencies approach ~200-300Hz.
I am going to link to them over on the UK AVForum (crediting you, of course) if that's ok, as they are a great illustration of how it works! smile.gif
MemX is offline
post #17144 of 27573 Old 06-09-2014, 11:37 AM
Liked: 1964
Thanks. I was just supplementing the excellent explanation you provided in your earlier post. cool.gif
post #17145 of 27573 Old 06-09-2014, 11:43 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
MemX is offline
post #17146 of 27573 Old 06-09-2014, 01:30 PM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Yes I understand all speakers and subs are calibrated to same levels. I have JTR Triple 8's up front. I know they are not flagship JTR's but They can play pretty loud without distortion. I don't claim to understand the concept here but it I turned up my 4520's volume to 0db nobody could stand the volume. I know that whether you do manual calibration or use something like Audyssey it will set the speakers to the same levels whether sitting 8ft or 14ft. Perhaps because I use Audyssey and DEQ. I notice that changes things a bit. I have also been in two professionally calibrated rooms last year and both were at -5db and are perceived as the same loudness of my room. anyone care to explain this? I am sure if I visited MK's theater (pun intended) that it would have a very similar perceived loudness
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #17147 of 27573 Old 06-09-2014, 01:38 PM
MKtheater's Avatar
Liked: 1349
I played the 888LP's to reference in room and it was loud and clear. I measured the THD to be 1% and under. There are only a handful of movies that have some scenes that might be considered too loud at reference. EQ and room treatments makes everything smoother and no surprise peaks at unwanted frequencies.
Marantz 7704
2 Outlaw 7140s
post #17148 of 27573 Old 06-09-2014, 02:02 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Well I think for most people 0 dB is too loud haha. It's not that bad if you are playing it with no distortion though.
post #17149 of 27573 Old 06-09-2014, 02:11 PM
MKtheater's Avatar
Liked: 1349
I still think different AVR's and or processor's calibrate differently or their auto EQ sucks and you have peaks for to loud. I have had many different ones and many AVR's with their auto calibrate and EQ's always seem to have their MV 0 dBs too loud. My SC-37 was close and my Sony STR-2800ES was superb at MV 0. Now anytime I manualy tweak the levels whether with DCX or the NanoAVR Master volume 0 dBs is perfect. It is meant to be loud and dynamic but not overbearing unless one is sensitive. This assumes a flat response or HF rolloff though and many auto EQ's do not reproduce a flat response. I am using only the NanoAvr right now and with it's set levels and can watch any movie at reference, some louder than otherwise of course. The room matters too and lots of echo or reflections can sound harsh at loud volumes.
Marantz 7704
2 Outlaw 7140s
post #17150 of 27573 Old 06-09-2014, 02:51 PM
javanpohl's Avatar
Quoted: 695 Post(s)
Liked: 378
I am sorry guys but you have no idea what you are missing! Good and the bad. I just watched Lone Survivor and I have never felt a more realistic helicopter ever. It was in my room! I have 8 20 amp breakers for my high sensitive system and it popped two of them. My screen was literally waving in the wind. Are you guys running reference with a LT boost? I am not kidding, this is my new bass demo! I will demo it just to show the breakers pop! Only movie to do so.
I feel like your system is always changing. What do you have for subs these days?
javanpohl is offline
post #17151 of 27573 Old 06-09-2014, 02:53 PM
MKtheater's Avatar
Liked: 1349
I have an 8x18 IB system within my baffle wall, same as my pic.
Marantz 7704
2 Outlaw 7140s
post #17152 of 27573 Old 06-09-2014, 07:00 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
out of curiosity...
with so much power behind the screen, does the screen move during high spl scenes?
kevings is offline
post #17153 of 27573 Old 06-09-2014, 07:09 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
out of curiosity...
http://www.avsforum.com/t/1333462/the-new-master-list-of-bass-in-movies-with-frequency-charts/17100#post_24807976
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #17154 of 27573 Old 06-09-2014, 09:13 PM
jlpowell84's Avatar
Liked: 915
Interesting. The nano ave does look pretty cool smile.gif I know DEQ does something to the volume as well. I had Audyssey turned of for a bit awhile ago and made it into the single digits watching movies. But back to -15ish or higher with an Audyssey cal again. anyway not sure how it all works. I just know that -15 to -10ish is as loud as anyone here could stand in my room, and that I run my bass hot lol!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #17155 of 27573 Old 06-09-2014, 10:14 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
So I played the heli scene again today. This time I turned off the house curve. Went up to -13 on the MV. During the drop scene part, all 4 S2's breakers popped again! lol! But, this time the breakers held on longer. That is just intense. Lfe from the blades just flutters my eardrums. The thumps from the blades just shakes my insides. I was afraid I was gonna get that nauseated feeling again..
rhed is offline
post #17156 of 27573 Old 06-09-2014, 11:17 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
That tingle means it's working 😁
ambesolman is offline
post #17157 of 27573 Old 06-09-2014, 11:20 PM
MKtheater's Avatar
Liked: 1349
I ran the scene again as well and this time turned down the curve 3 dBs per octave. I had a LT boost of 13 dBs at 10 hz and that what set off the breaker. Playing it at reference with subs calibrated flat and LT boost at 10 dBs or about an octave lowering of the F3 was just fine but the screen was moving so much it blurred the image a little(shaky cam effect). You have the same displacement as I do but my room is 1500 cubes.
Marantz 7704
2 Outlaw 7140s
post #17158 of 27573 Old 06-10-2014, 12:20 AM
raynist's Avatar
Liked: 1550
If you are popping your breakers at -13 it might be time to replace the breakers. I heard they weaken the more they pop.
mo949 likes this.
raynist is offline
post #17159 of 27573 Old 06-10-2014, 12:24 AM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2575
notnyt is offline
post #17160 of 27573 Old 06-10-2014, 06:26 AM
wyattroa's Avatar
Quoted: 166 Post(s)
Liked: 117
This. The more they trip the weaker they get and will trip more often. Which could actually lead to the breaker failing completely and causing a fire. It might be time to replace the breaker.
mo949 likes this.
Sub build http://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
