The New Master List of BASS in Movies with Frequency Charts - Page 573 - AVS Forum | Home Theater Discussions And Reviews
 7096Likes
post #17161 of 27499 Old 06-10-2014, 11:02 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Originally Posted by JWagstaff View Post
You are misunderstanding volume levels. If you have it calibrated, -15 in your room is 100% identical (volume wise) to any other room in the world if they are also listening at -15. All receiver's calibrate to the same level at a certain listening position. Reference level (0 dB) is identical volume for you and for MK, room has no impact (unless you have not set your receiver up). I think some people find -15 to -10 getting too loud if your speakers are low end/commercial / dome tweeters. You need high efficiency pro theater speakers to really listen loud without distortion.
Not true. Not every receiver calibrates to true reference level. I have gone through 3 Denon receivers and only one of them calibrated to where 0 db was reference. The other 2 were WAY too loud at 0 db.
wth718 is offline
post #17162 of 27499 Old 06-10-2014, 11:27 AM
JewDaddy's Avatar
Quoted: 180 Post(s)
Liked: 90
I'm wanting to demo Pacific Rim in 3D this evening to my buddy and I was wondering if anyone knows the best scene to also show off the capabilities of my SVS PB-12 Ultra sub. Something that truly shows some awesome bass. Thanks!
JewDaddy is offline
post #17163 of 27499 Old 06-10-2014, 11:44 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
You're supposed to do it manually. Just in the past few years receivers have done it on their own....
http://www.acousticfrontiers.com/home-theater-blog/2013/3/14/thx-reference-level
JWagstaff is offline
post #17164 of 27499 Old 06-10-2014, 11:46 AM
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
The dream sequence of the little girl.
Marantz 7702 Atmos
MKtheater is online now
post #17165 of 27499 Old 06-10-2014, 11:50 AM
raistline's Avatar
Quoted: 35 Post(s)
Liked: 25
The entire Hong Kong fight with the level 3 (or was it 4) Kaiju .biggrin.gif
raistline is offline
post #17166 of 27499 Old 06-10-2014, 11:56 AM
MKtheater's Avatar
Liked: 1123
Except for the first Kaiju which was 3 the rest were 4 until the last.
Marantz 7702 Atmos
post #17167 of 27499 Old 06-10-2014, 11:59 AM
JewDaddy's Avatar
Quoted: 180 Post(s)
Liked: 90
Is there a specific scene that shows off really really deep bass?
JewDaddy is offline
post #17168 of 27499 Old 06-10-2014, 12:01 PM
JT78681's Avatar
Quoted: 1379 Post(s)
Liked: 911
The server scene in the movie Pulse.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #17169 of 27499 Old 06-10-2014, 12:02 PM
MKtheater's Avatar
Liked: 1123
Not for that ported sub. Pacific rim is perfect for it.
Marantz 7702 Atmos
post #17170 of 27499 Old 06-10-2014, 12:06 PM
JT78681's Avatar
Liked: 911
Ah didn't realize it was the same guy further up asking specifically about Pacific Rim.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #17171 of 27499 Old 06-10-2014, 12:10 PM
JewDaddy's Avatar
Quoted: 180 Post(s)
Liked: 90
No problem. I was just hoping someone would know a specific scene that rocks the bass in Pacific Rim
JewDaddy is offline
post #17172 of 27499 Old 06-10-2014, 12:33 PM
javanpohl's Avatar
Quoted: 537 Post(s)
Liked: 272
Originally Posted by wyattroa View Post
This. The more they trip the weaker they get and will trip more often. Which could actually lead to the breaker failing completely and causing a fire. It might be time to replace the breaker.
That's good to know, my microwave breaker pops fairly often.
javanpohl is offline
post #17173 of 27499 Old 06-10-2014, 12:34 PM
javanpohl's Avatar
Quoted: 537 Post(s)
Liked: 272
The little Japanese girl flashback scene hits the hardest I think. And it's just a damn good demo scene. The opening scene is great too but it doesn't dig as deep from what I can tell.
post #17174 of 27499 Old 06-10-2014, 12:46 PM
JewDaddy's Avatar
Quoted: 180 Post(s)
Liked: 90
Awesome! Thanks
JewDaddy is offline
post #17175 of 27499 Old 06-10-2014, 12:47 PM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
I'm talking about receivers that used Audyssey MultiEq calibration. One of those models (AVR-888) had that feature, but still didn't put it at reference. Additionally, aren't there some receivers out now that don't even utilize the -X db volume setting?
wth718 is offline
post #17176 of 27499 Old 06-10-2014, 01:30 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
Originally Posted by notnyt View Post
Damn.. I hate being wrong! The last time this happened to me was the Irene scene a few months back playing at -9 MV. Same thing popped the breakers. I was concerned about it so I contacted my electrician that installed all my 20amp circuit 2 years ago. He came by the house checked everything. But notice where each of my subs was plugged in he ask what was the specs of the subs amps. So I showed him the specs at speaker powers website. Then he said I should be fine, not unless I'm really using all that power then yea it'll trip. But thing is that he said I could go with 30amp breakers. But I know he wired it with 12 gauge. Ain't that to small? Anyway, Pop told me something similar too. That if the subs are capable, then it takes a lot of power to produce in the low end region. I don't know, maybe I should add filters.
rhed is offline
post #17177 of 27499 Old 06-10-2014, 01:33 PM
notnyt's Avatar
Quoted: 2218 Post(s)
Liked: 2028
While its not code, you can prob get away with swapping the breakers to 30a if you're using 12gauge wire. Understand the risks here, 12g solid wire is not rated for 30a in wall, but if its just quick peaks from subwoofer amps only, you're not likely to ever see an issue.
notnyt is offline
post #17178 of 27499 Old 06-10-2014, 01:42 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
Thanks notnyt.. Well guess I gotta call my electrician back and swap out the breakers..
rhed is offline
post #17179 of 27499 Old 06-10-2014, 01:44 PM
notnyt's Avatar
Liked: 2028
What amps are you running?
notnyt is offline
post #17180 of 27499 Old 06-10-2014, 01:46 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
Btw, can anyone graph the heli scene in LS? I think it was between 20:00-22:00.
rhed is offline
post #17181 of 27499 Old 06-10-2014, 01:53 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
nube is offline
post #17182 of 27499 Old 06-10-2014, 01:57 PM
conquritall's Avatar
Over the weekend I had a chance to watch the new Robocop and lone survivor. Although I really e njoyedd Robocop lone survivor was the better movie all the wsy around. Especially in the bass department. Have not heard such well placed audio in my theater since enders game. It lives up to the hype for sure.
conquritall is offline
post #17183 of 27499 Old 06-10-2014, 01:57 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
It's the Speaker Power sp1-4000. Which JTR uses on the S2 and OS. I got 4 of em.
rhed is offline
post #17184 of 27499 Old 06-10-2014, 01:58 PM
derrickdj1's Avatar
Quoted: 890 Post(s)
Liked: 598
For piece of mind, get the electrician to put in 10 guage wire.
derrickdj1 is offline
post #17185 of 27499 Old 06-10-2014, 01:59 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
Originally Posted by nube View Post
Most such requests are already fulfilled at Data-Bass, if people would just check. smile.gif Here's yours:
http://data-bass.ipbhost.com/index.php?/topic/213-lone-survivor-execution-and-recommendation-poll/
HOLY CRAP! 6hz? Well that friggin explains my poppers! Thanks nube..
rhed is offline
post #17186 of 27499 Old 06-10-2014, 02:03 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
It's the duration that's popping your breakers. You have four amps each trying to pull more current than your breakers can do, and for almost a full minute. As mentioned before, you really need 30A runs to have those S2 live up to their potential on scenes that demand it.
nube is offline
post #17187 of 27499 Old 06-10-2014, 02:13 PM
notnyt's Avatar
Liked: 2028
How many circuits are you running them on? dedicated for each?
notnyt is offline
post #17188 of 27499 Old 06-10-2014, 02:17 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
Yes each.. Except for 1 which shares it with a AVR atm.
rhed is offline
post #17189 of 27499 Old 06-10-2014, 02:23 PM
MKtheater's Avatar
Liked: 1123
Are you running hot? How big is your room again?
Marantz 7702 Atmos
post #17190 of 27499 Old 06-10-2014, 02:27 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 478
I REALLY thought 20amps would've been enough 2 years ago. But, I never anticipated ever running that much power. Or that much subs. Or that size drivers. I actually thought I was going to run up to 4 Def Tech SC reference. Which I still have my dual SC Refs in my storage room collecting dust. Damn, I hate poor planning. Now more money to be spent. Oh well live and learn. Anyway Thanks guys for your help..
rhed is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
