The New Master List of BASS in Movies with Frequency Charts - Page 575 - AVS Forum | Home Theater Discussions And Reviews
 4974Likes
post #17221 of 25611 Old 06-12-2014, 10:38 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
yea Edge of Tomorrow didn't stand out for sound in the theater - so that means it will be awesome on blu-ray... haha
JWagstaff is offline
post #17222 of 25611 Old 06-12-2014, 02:28 PM
derrickdj1's Avatar
Quoted: 709 Post(s)
Liked: 510
A 15 amp circuit can handle 30 amp for 10-20 sec.
derrickdj1 is offline
post #17223 of 25611 Old 06-12-2014, 04:17 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Originally Posted by Reefdvr27 View Post
Funny thing is now I have them on 2 different circuits both 15 amp 14/2 line and I have never popped either one of them ever !
Actually went out and checked my box and I have 1 circuit left! So I am actually going to run one more 10/2, 30 amp line and have each sub on it's own dedicated 30 amp circuit. I have 150' of 10/2 wire left over, so it will come in handy for this. I am actually glad I read this. Thanks Nube.
What are you going to plug into that 30 amp 125 volt receptacle?
You might want to research what type of outlet is allowed to be installed on a 30 amp 125 volt circuit. According to my code book 15 amp and 20 amp outlets are not allowed to be installed on a 30 amp circuit. You are required to use 30 amp receptacles on a 30 amp 125 volt circuit.
J_Palmer_Cass is offline
post #17224 of 25611 Old 06-12-2014, 05:26 PM
notnyt's Avatar
Quoted: 1511 Post(s)
Liked: 1546
It takes all of about 10 minutes to make an adapter.
notnyt is offline
post #17225 of 25611 Old 06-12-2014, 06:49 PM
jlpowell84's Avatar
Quoted: 1488 Post(s)
Liked: 661
Originally Posted by rhed View Post
Think I'm getting to the point where it's not even worth it no more for me chasing those low frequencies bro. It's either create structural damages or electrical damages. I haven't even fixed the crack on the ceiling yet. I've already put a 10hz filter through the dual core. JP, when my speakers arrive, I'm just gonna set them up and aim for a mor balanced sound. No more running hot or house curves. I just wanna enjoy. You know?
Yea totally I am there too. I have toned it down a bit to be "more balanced." I used to have it where if I played the scene from Looper near the end with the kid in the house I had to turn it down to like -30 because it was so ridiculous. But I really enjoy when the subtle things have impact. Like the very beginning of the OHF Washington monument scene. There is a jet that slashes from back left to front right. With a hot house curve the impact and feeling is just amazing! You feel it move through the room. I then "bypass" house curve and meh...So I have been on a journey to basically make all the classic 5 star scenes on the edge of almost unmanageable which in effect allows for all other more subtle content to have impact but doesn't leave me remote scrambling. I really think you toy with your house curve and leave it implemented but just tone it down a bit. I have my sub trim bumped a little and a little house curve. Works great! Prob like 8db hot or so. But music I have to have it like 15 hot to even get impact with the kick drum or other musical bass effects. Just the way it is I think.
FTW21 Ported Build
Volt 10 build
I miss Giants baseball!
jlpowell84 is online now
post #17226 of 25611 Old 06-13-2014, 08:40 AM
Quoted: 393 Post(s)
Liked: 118
It is not legal nor safe to use that adapter, so save the 10 minutes.
Just wondering, what class wiring does your subwoofer power amplifier specify to be used for the audio output wiring? Class 1, class 2 or class 3? The notation is located on the rear of the power amplifier.
post #17227 of 25611 Old 06-13-2014, 11:09 AM
notnyt's Avatar
Liked: 1546
notnyt is offline
post #17228 of 25611 Old 06-13-2014, 11:54 AM
Quoted: 393 Post(s)
Liked: 118
An adapter will not cut it, but it will work. Why not use a 50 amp circuit? More is better right?
At a minimum for safety purposes you also have to change the cord and plug on the equipment in question to 30 amp standards. As a note you void UL approval and warranty of the equipment in question when you make that type of change.
Then again, your amplifiers don't have UL approval so safety (fire in this case) is of no concern to you!
post #17229 of 25611 Old 06-13-2014, 12:04 PM
audiofan1's Avatar
Quoted: 1457 Post(s)
Liked: 1439
when did 20 amp circuits become not enough!
audiofan1 is online now
post #17230 of 25611 Old 06-13-2014, 12:04 PM
notnyt's Avatar
Liked: 1546
Depends on the cord on the equipment. Stranded cords are rated for higher current than solid in wall copper. A properly assembled adapter with the right components isn't going to be dangerous.
notnyt is offline
post #17231 of 25611 Old 06-13-2014, 01:32 PM
Quoted: 393 Post(s)
Liked: 118
Regardless, you still need a 30 amp equipment power cord (AKA 10 AWG) to use that 15 or 20 amp rated equipment on a 30 amp circuit. Even then, that still would be a fire hazard if that assembly was not as designed by the manufacturer.
Like I said, why not just go up to a 50 amp circuit.. Same logic, more power is better!
post #17232 of 25611 Old 06-13-2014, 01:34 PM
notnyt's Avatar
Liked: 1546
You don't need 10awg power cord to run 30a. 10awg for 30a is for solid in wall wiring.
Second, how does running a 50a circuit help you with the outlet issue.
notnyt is offline
post #17233 of 25611 Old 06-13-2014, 03:27 PM
Quoted: 393 Post(s)
Liked: 118
Per Table 400-5(A) of NEC, the requirement for flexible cords and cables, 2 conductors powered, the maximum allowable ampacity rating is 30 amps for 10 AWG flexible cord.
For 3 conductors powered (240 Volt line), the maximum allowable ampacity is 25 amps.
Same logic as going to a 30 amp line. You will never trip a breaker. Just spend 10 minutes and buy a bigger adapter!
post #17234 of 25611 Old 06-13-2014, 04:09 PM
notnyt's Avatar
Liked: 1546
I stand corrected.
notnyt is offline
post #17235 of 25611 Old 06-13-2014, 11:26 PM
tvuong's Avatar
Quoted: 1331 Post(s)
Liked: 735
Thanks for someone who mentioned Max Payne which I just finished watching- ton of deep loud bass. Enjoy the movie too
capricorn kid likes this.
tvuong is offline
post #17236 of 25611 Old 06-14-2014, 02:34 AM
toenail's Avatar
Originally Posted by ambesolman View Post
Just watched Metallica's Through the Never, my first concert bluray. F*****G awesome!!!
This 1000X
Just a really impressive sound mix that you can turn up dangerously loud. Not an LFE monster other than the pyro effects. Wish it had been a "concert only" dvd instead of mixing in plot. Regardless, an awesome watch when you really want to cut lose.
toenail is offline
post #17237 of 25611 Old 06-14-2014, 09:47 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
This 1000X
Loved it.
bori is offline
post #17238 of 25611 Old 06-14-2014, 09:52 PM
Torqdog's Avatar
Quoted: 106 Post(s)
Liked: 200
Finally was able to watch Lone Survivor this evening. Pretty much agree with what's already been said.......killer soundtrack and without a doubt, the best gunfire/combat audio yet. So much so that I would disagree with those who say this is not a reference track. If I'm gonna show someone what realistic combat looks and sounds like, this disc is now my #1 choice.....period. Granted it doesn't have the deep ULF bass that this thread is all about but sometimes ya gots to break away from it once in a while and appreciate a good soundtrack for frequencies beyond the 5 to 120 hz bandwidth.
There was one glaring problem I did have with the flick and it had to do with the screenplay. Early on there was a mention of a rattlesnake and then later in the movie as they are engaged in serious combat, one of the soldiers comes across a rattlesnake in the forest. Rattlesnakes are indigenous to North America ONLY and are NOT found in Afghanistan. Stupid and unnecessary. I still liked the movie a lot and will watch it again.
popalock likes this.
Torqdog is offline
post #17239 of 25611 Old 06-14-2014, 10:22 PM
rhed's Avatar
Quoted: 583 Post(s)
Liked: 412
I don't know about that not having ULF.
http://data-bass.ipbhost.com/index.p...sed/#entry3459
Best chopper audio for me anyway to date. Be careful though. Because 1.. That scene trip my 20 amp breakers. 2.. You might get into a argument with the wife when she finds her painting and picture frame on the wall in the other room on the floor.. 3.. Another recess light housing falls.. 4.. You start thinking that you need yoga classes to help you calm your crave for hot bass. And time to run flat instead cause your tearing things apart!
rhed is offline
post #17240 of 25611 Old 06-15-2014, 04:48 AM
TomC1315's Avatar
Quoted: 124 Post(s)
Liked: 138
"Finding Nemo" ... WOW !
Great LFE throughout the movie, along with an overall fine soundtrack, and then the "tapping on the fish tank scene" ... what a sound !
A dozen taps in all ...
That scene is right at the beginning of chapter 25, for easy replay ... it sounded incredible from my SVS PC12plus :-)
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / Dynamo700
TomC1315 is offline
post #17241 of 25611 Old 06-15-2014, 06:36 AM
tanwn1's Avatar
Quoted: 79 Post(s)
Anyone experience ULF that you feel like a wave is blowing the top of your hair ever so slightly? I felt it during the OHF monumental scene.
tanwn1 is offline
post #17242 of 25611 Old 06-15-2014, 09:57 AM
rhed's Avatar
Quoted: 583 Post(s)
Liked: 412
Attachment 118306
Aw yes.. The Darla tap..
rhed is offline
post #17243 of 25611 Old 06-15-2014, 10:06 AM
jlpowell84's Avatar
Liked: 661
Man I sure do love those gun shot impacts in The LS. very good soundtrack to go with my new Oppo BD103D and the Darbee processing. Great all around experience. And the ultra chopper bass scenes are very realistic and the bass is definitely there for me with my two Submersives (only :/) on a limited circuit. The windows and blind do pulsing effect and my reclining sofa gets a 4d vibration that adds to the realism. Not quite an IB 8x18 but still very nice
FTW21 Ported Build
Volt 10 build
post #17244 of 25611 Old 06-15-2014, 11:19 AM
audiofan1's Avatar
Liked: 1439
Good gravy! boy did my second watch since its release of Hitman deliver a room energizing experience!The gun shootouts where indeed incredible and the level was insane and as I remember I really liked the movie but this time on the upgraded gear it surely deserves its 4 star rating without question.
post #17245 of 25611 Old 06-15-2014, 11:26 AM
rhed's Avatar
Quoted: 583 Post(s)
Liked: 412
+1
rhed is offline
post #17246 of 25611 Old 06-15-2014, 04:23 PM
Ray77085's Avatar
Quoted: 129 Post(s)
Liked: 159
Just finished revisiting that movie again today and yes that Bass hits real hard !!! Good movie overall as well.
Ray77085 is offline
post #17247 of 25611 Old 06-15-2014, 04:29 PM
Ray77085's Avatar
Quoted: 129 Post(s)
Liked: 159
Well,
Looks like I'm going to add Hitman and Max Payne to the, do watch list !!
Ray77085 is offline
post #17248 of 25611 Old 06-15-2014, 07:38 PM
rhed's Avatar
Quoted: 583 Post(s)
Liked: 412
In the movies now to watch Edge of Tomorrow. Anyway seen the preview for Into the Storm. Seems like a ULF movie. Fingers crossed..
rhed is offline
post #17249 of 25611 Old 06-15-2014, 09:59 PM
McStyvie's Avatar
Liked: 78
The sound designers for ITS have a great pedigree. They also did Skyfall, and a couple others with great sound, though I can't remember which ones exactly now as I checked it several months ago.
McStyvie is offline
post #17250 of 25611 Old 06-15-2014, 10:15 PM
rhed's Avatar
Quoted: 583 Post(s)
Liked: 412
Thanks.. I really do hope so. Btw. Just finished EoT. Awesome movie. With all the choppers and gunshots. Only hope the bd version shines. As my local theater I went to sucked in the sound department. I should have spent more to go to the theater with the better sound. I had a awesome Fathers Day. Happy Fathers Day to all the fathers in avs.
rhed is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
