The New Master List of BASS in Movies with Frequency Charts - Page 588 - AVS Forum | Home Theater Discussions And Reviews
 7139Likes
Old 08-18-2014, 12:31 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
Originally Posted by Cam Man View Post
Thank you. What I'm not finding is whether this is a line level measurement of the program content, or an acoustic measurement with a mic, etc..
I think it's all discussed over there, but it's no longer done either of the ways you mentioned. The old way was line level measurement to see what frequencies were recorded in the program content, and sometimes (for comparison's sake) an acoustic measurement with a mic to see how well your system was reproducing said content.
The new way, however, which everything at the Data-Bass.com site is based on, is to measure the digital program content directly off the discs themselves.
The bottom of the first post I linked you to, right below the last ranking of program content, says this specifically:
The old ranking system is at the bottom of this post. It used a lengthy (and lossy) signal chain (BluRay Player, Receiver, Soundcard in) to get the measurements which were then compensated afterwards for rolloff. Now there is no signal chain, all analysis is fully digital with no signal chain
nube is offline
Old 08-18-2014, 12:54 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 385 Post(s)
Liked: 410
Thanks again. Even reading that, I'm not sure I would have understood it to be what it really is.
In looking at most of these I see what is common to all mixes where a big impression is to be made with bass. The 30 Hz to 50 Hz range is where we really get the hitting power we hear and feel. That is where the mixers have appropriately mixed the highest amplitude in the event. My question to all, and I'd certainly like to see Filmmixer and others ring in on, is how much content below 30 Hz is intentional; not just stuff that falls down there because it's not even being monitored that low? In other words, is it a happy surprise for those who want to mine it, but otherwise unintended?
It makes me wonder why there is such passionate pursuit of subs that reach into the teens when there is so little there (content and amplitude).
Just askin'
Cam Man is offline
Old 08-18-2014, 01:14 PM
MKtheater's Avatar
Quoted: 1646 Post(s)
Liked: 1170
It is just accuracy. Low stuff happens all the time.
MKtheater is online now
Old 08-18-2014, 01:42 PM
Bassment's Avatar
Quoted: 940 Post(s)
Liked: 374
Bassment is offline
Old 08-18-2014, 01:56 PM
Mongo171's Avatar
Quoted: 864 Post(s)
Liked: 1299
Originally Posted by Bassment View Post
Why buy a ferrari that can go 200 when the speed limits are 65?
I'd rather be seen in a nice Ferrari cruising 65 than flooring it just to make 65 in a Kia.
Mongo171 is offline
Old 08-18-2014, 02:00 PM
Bassment's Avatar
Quoted: 940 Post(s)
Liked: 374
Bassment is offline
Old 08-18-2014, 02:16 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
Just askin'
You're hitting on a debate that has been ongoing here for at least 10 years, and is completely settled. I'll boil down the salient points so you don't have to wade through this and other threads' thousands of posts on the subject, although I feel like I've done this within even the last few months.
1) The content is intentional in almost all cases. Because we experience a huge amount of reasonably high-amplitude sounds below 20Hz in our daily lives (as proven in a whole slew of posts by bossobass, maxmercy, FOH, myself and others), it makes sense that these sounds are recorded and utilized in foley, sound design and mixing, especially to add a sense of realism and immersive quality to the mix.
The best of the best mixers and designers know this, and it is from these Academy Award-winning sound professionals that we have tons of content in these octaves. At this point in the march of technological progress, it is only when they are filtered out by design that we take note. There are a number of mixing studios that either do have or have had the capability to reproduce content significantly below 20Hz, most notably Skywalker.
Thusfar, out of over 300 movies maxmercy and I have measured, some 80% have a -10dB point below 20Hz, 62% have a -10dB point below 16Hz, and 50% have a -10dB point below 12Hz, and an astonishing 46% have a -10dB point below 10Hz. There is no possible way that's unintentional noise, especially when you look at graphs of the spectral content in most of these very low effects.
2) The range of 25-35Hz is where most of the resonant frequencies that excite objects (and our bodies) exist, but the octaves below that are what excite our home and home theater structures. This is part of the reason why content below 20Hz reproduced in rooms with suspended floors creates such an amazing effect. Above that, or in rooms on concrete slabs, not so much.
To your point, though, the Fletcher & Munson Equal Loudness Contours show that high-amplitude stuff in the bandwidth you noted will likely sound louder, and further research dictates that it may be perceived as "better" simply because of that apparent loudness.
3) I made a post a couple months ago about the limitations of presentations that cannot reproduce all of the content on the disc, no matter the amplitude. It informs some of your questions and supports some of my assertions. Please do read through it and all of the supporting links. It can be found here:
http://www.avsforum.com/forum/187-of...l#post25261937
4) Look up posts by bossobass on this and the Data-Bass.com forums, and specifically the keyword "intentional." You'll find a wealth of information and proof that has helped inform my own research on the subject.
Please read through all of the supporting material. Your inquiries and assertions have been addressed multiple times in the past, and if you fully immerse yourself in the supporting documentation I've pointed you to, you'll find that you won't have to ask this again, and you might even be able to educate the professionals you interact with in related areas of professional and personal interest.
Good luck!
nube is offline
Old 08-18-2014, 02:59 PM
Cam Man's Avatar
Quoted: 385 Post(s)
Liked: 410
First ... let me compliment you on the content and style of your post/response. It reminds me of posts back when I first joined AVS in 2000 and you might have considered this a "gentlemen's" forum. Styles do change.
I'll study your response and the references you made to your research and findings. I find it pretty interesting already. Further, I will share it with some colleagues in the industries who will also be very interested. Most of my background is in production rather than post-production, but I have a few folks who I wouldn't be surprised if they also have questions. Is the Data-bass.com forum or here the best place to ask those?
I will also save this post as a reference. Kinda like a sticky. Maybe it should be one.
Regarding Skywalker, I attended the THX training in 2002 when it was a full week up there. We had the pleasure of joining the Lucasfilm employee Friday night screening of Fellowship of the Ring in The Stag that week. Memorable!
Thanks again for the tremendous effort you have undertaken. That alone would be darned impressive.
Cheers
Janibrewski, nube and audiofan1 like this.
Cam Man is offline
Old 08-18-2014, 03:20 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
you'd be surprised how fast a Kia can go
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 08-18-2014, 03:28 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
Cheers
Hey it's my pleasure. Glad to hear of your experience with some of the best in the business. I'm betting that was fun and informative!
In the future, I think the signal-to-noise ratio here is pretty poor, so asking questions at Data-Bass is probably the best choice - though don't expect super quick responses because it's a much smaller forum. However, for its size, it has a lot of experienced posters. FilmMixer and a slew of other industry folks are members there.
nube is offline
Old 08-19-2014, 06:23 AM
Bassment's Avatar
Quoted: 940 Post(s)
Liked: 374
that's the equivalent of the 16 Polk sub set-up of cars.
Bassment is offline
Old 08-19-2014, 06:31 AM
Mongo171's Avatar
Quoted: 864 Post(s)
Liked: 1299
Talking
My grandson has a Hot Wheels just like that!
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 08-19-2014, 10:34 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Cheers
nube and everyone else who has contributed to the understanding and promotion of full-bandwidth audio content receive my full and hearty support
I am a mere noob on here and my knowledge is limited, but I do fully appreciate the difference between feeling the added 'weight' that is present in a full bandwidth mix, versus the lightweight (but usually mixed unbearably loud) filtered mixes.
A prime and easily demonstratable example of this is to watch two films from the same franchise back-to-back, one with a full bandwidth presentation and one where they have filtered the content. If you have access to a system that can play reference to under 10Hz, I would recommend watching the latest two Star Trek movies or the two Percy Jackson movies - in both cases the first movie was unfiltered and the second movie filtered. In both cases I have re-watched the first films many, many times because the audio is so enjoyable (even if the film is cheesy lol), whereas I have watched the second films perhaps twice at most, simply because the filtered mixes give me a headache!
Anyway, it would be great to see you over on the DB forum and I will be very interested to see what your colleagues in the industry have as their views on the subject. What would be awesome is if you could get some influential people together to visit any one of the gents who has a system that can play at Reference all the way down, so they can experience what a full bandwidth mix actually sounds and feels like on a system that is fully capable!
MemX is offline
Old 08-19-2014, 11:13 AM
Cam Man's Avatar
Quoted: 385 Post(s)
Liked: 410
I can almost already predict what the responses from industry professionals I've reached out to on this will be. Yes, there is the occasional film where the creators specifically want the designer to use infrasonic content, but not many.
I can also predict that they will say that if there is not such a requirement from the designer/creators, they don't monitor down that low, and that they will filter below 20Hz because they want to preserve headroom.
Finally, I bet that there will also be some who say that they don't filter it, but they also don't monitor it below 20Hz; that what goes down there is a coincidence.
It will be interesting to see if I'm right. I don't have a dog in the race either way. I don't actively seek content that low, although my system will render it to about 20Hz.
BTW, I did hear from one source describing a situation where LF content can end up in the LCR channels that was totally unintended. It was described as happening on mixing stages where the LCR stacks ran out of any reproduction capability at about 35Hz. Directors would holler for more bass from the LCR channels rather than the LFE, so mixers would start pumping a lot of <35Hz EQ on those channels that could very well be terrible if it could be monitored. I would suspect that this could be heard when we don't want to. I'll see if I can find any titles that might be affected by this. I got the feeling that this is somewhat old news; that most mixing systems are more capable now.
Janibrewski and audiofan1 like this.
Cam Man is offline
Old 08-19-2014, 12:53 PM
Rgdeuce's Avatar
Quoted: 128 Post(s)
Liked: 115
My son has one too.
And what's up Cam, Tucson in the house.
Rgdeuce is offline
Old 08-19-2014, 06:35 PM
Ray77085's Avatar
Quoted: 134 Post(s)
Liked: 161
Any takers on what this sounds like on your system with BASS ?? The Amazing Spider-Man 2.
Finished Noah and was pretty pleased overall with the bass. Outstanding acting in that one!!!
Finished Transcendence barely !!! Once and done, maybe not the right time as I was fatigued and dosing off.
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
Old 08-20-2014, 06:08 AM
discone's Avatar
Quoted: 207 Post(s)
Liked: 208
Originally Posted by wadec22 View Post
Watched Titan AE for the first time last night. Mediocre flick at best, but lots of great bass. Worth watching.
Just watched this yesterday and enjoyed the bass. As you stated mediocre, not the best story line and a little cheesy. Boy how animation has come a long way since 2000, if this movie was made today I'm sure it would have looked great.
discone is offline
Old 08-21-2014, 09:27 AM
Reefdvr27's Avatar
Quoted: 1567 Post(s)
Liked: 1046
Originally Posted by Reefdvr27 View Post
Gotta long wait as HTTYD2 is slated for December. I am looking forward to the entire summer catalog myself. Godzilla is at the top of the list.
I have to correct this, as HTTYD2 looks to be available November 11th. They must have moved it up.
buddhamus likes this.
Reefdvr27 is offline
Old 08-21-2014, 10:08 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
You can check out the graphs for TASM2 on data-bass
http://data-bass.ipbhost.com/index.p...scussion-poll/
MemX is offline
Old 08-21-2014, 10:18 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I'm completely out of touch - are the indications good at the cinema re: bass?
I think I will re-enact the scene of the dragon crash in the first one, with me being the dragon, if they mess the sound up on this sequel... lol
MemX is offline
Old 08-21-2014, 11:30 AM
ambesolman's Avatar
Quoted: 1083 Post(s)
Liked: 911
+1
ambesolman is offline
Old 08-21-2014, 04:12 PM
Ray77085's Avatar
Quoted: 134 Post(s)
Liked: 161
Thanks for the info. I'll be picking up my BD copy this weekend !!!
MY 5.4.4 SET UP.
Ray77085 is offline
Old 08-22-2014, 06:10 AM
AJ72's Avatar
Quoted: 134 Post(s)
Liked: 157
TASM2 not a bad bass flick but lacks in variety. A couple of scenes like when Gwen is falling could have been a great opportunity for an Oblivion like rope break bass sweep.
AJ72 is offline
Old 08-22-2014, 10:13 AM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
Regarding Titan AE, it was a movie that cost over $100 million to make and the original studio went broke. A second studio picked up the project half way through. I've seen this movie over 50 times because the sound is so incredible. My daughters loved watching this movie growing up. Great bass in the ice scene and great surrounds for a DTS movie.
sojodave is offline
Old 08-22-2014, 11:06 AM
Mrkazador's Avatar
Quoted: 261 Post(s)
Liked: 388
Most of the bass in the new Godzilla movie is at 30-50hz. There is some 20hz content but not very loud.
Mrkazador is offline
Old 08-22-2014, 11:09 AM
Bassment's Avatar
Quoted: 940 Post(s)
Liked: 374
Bassment is offline
Old 08-22-2014, 11:13 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
:conf used:
Pacific Rim all over again?
ambesolman likes this.
wth718 is offline
Old 08-22-2014, 11:35 AM
Mrkazador's Avatar
Quoted: 261 Post(s)
Liked: 388
Its very similar to Pacific Rim but not as loud.
Old 08-22-2014, 11:51 AM
raynist's Avatar
Quoted: 1425 Post(s)
Liked: 1362
Do you have a graph of it?
What source is it from?
raynist is online now
Old 08-22-2014, 11:54 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Well, damn! That was the one thing PR had going for it. I'm holding out hope that you viewed a downloaded copy that had the low end lopped off.
wth718 is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
