The New Master List of BASS in Movies with Frequency Charts - Page 601 - AVS Forum | Home Theater Discussions And Reviews
 7139Likes
post #18001 of 27560 Old 09-20-2014, 03:17 AM
discone's Avatar
Quoted: 207 Post(s)
Liked: 208
Originally Posted by audiofan1 View Post
This is a movies with bass thread! while hard to remember at times 20-30hz is bass and is low bass frequencies and make no mistake about it ! Mid bass, upper bass, ELF/ULF is bass as well just another part of the beautiful bass rainbow and none of it should be discredited. if one has the gumption to go down deep in the rabbit hole , its good to know that there are tracks that dwell there , not all but there are plenty.
So 1-??? this is a movies with bass thread!
Enjoy
Thank's I plan to enjoy that is why I'm happy to hear good report's for this film no matter the range of bass. I like all bass and may never be able to go down into the rabbit hole to reach single digit's, but am happy for those that can.. It was stated no matter what the graphs said it is still a bass movie. I'm still learning here and have yet to take the time to fully interpret graphs. As mentioned in your take if you liked Pacific Rim then you'll like this.
I guess all I'm trying to garner from the post's for me is if my old friend Godzilla is taking a scenic stroll through downtown Tokyo I'm happy to know I'll get to experience it also.
audiofan1 likes this.
discone is offline
post #18002 of 27560 Old 09-20-2014, 03:56 AM
Follz20's Avatar
Liked: 34
Wowzers... Edge of Tomorrow DTSHD-MA 7.1:
Name:	Edge of Tomorrow.png
Follz20 is offline
post #18003 of 27560 Old 09-20-2014, 04:44 AM
AJ72's Avatar
Quoted: 134 Post(s)
Liked: 157
How accurate is that? Looks pretty good.
AJ72 is offline
post #18004 of 27560 Old 09-20-2014, 04:45 AM
kemiza's Avatar
Liked: 92
i just finished my second viewing of catws at full reference volume 0 instead of -5 for the first viewing .
Spoiler!
was just incredilbe and at this point we may beable to pronuce it king 5 star bass movie of the year! End of story! :d
catws?
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #18005 of 27560 Old 09-20-2014, 05:32 AM
raynist's Avatar
Quoted: 1414 Post(s)
Liked: 1353
Originally Posted by kemiza View Post
catws?
Captain American The Winter Soldier
I can't stand the abbreviations myself but it is also a pain to type such a long title.
raynist is offline
post #18006 of 27560 Old 09-20-2014, 08:12 AM
[unique]'s Avatar
Not sure how they mixed it, but at -30 db my pb13 nearly died using 10hz tuning.
Normally I never even use the subsonic filter even with audyssey dyn eq (and yes i watched all 5 bass rated movies..), but on this movie even with the subsonic filter on 10hz and dyneq OFF, the last note is way too loud and low.
!!Caution!! when playing this movie, its frigging low volume till the bass hits which is 30db louder than most other movies.
Especially for the people without subsonic filter, kinda amazed my bk xls200-DF didn't die since we watched the movie on that first at -15db, the peerless woofer hit the ground though.
If the cinema version is mixed similar, I sure hope they have subsonic filters or they can order new subwoofers all over.
Here is the spectrum from it (bear with me, first time i done this..not sure if volume is right..):
[unique] is offline
post #18007 of 27560 Old 09-20-2014, 08:38 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
That's why Godzilla got a and Edge of Tomorrow got a .
But, just note, as MrKazador did last week in reply, that those big spikes in Edge of Tomorrow are all at the very beginning. Impressive, but not enough to make the BR a bass monster by itself. More to come...
nube is offline
post #18008 of 27560 Old 09-20-2014, 08:58 AM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
How are you guys able to listen at 0 on the AVR? I get to -15 and it's getting too loud, you guys watch a full movie at 0 and your hearing is still ok?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #18009 of 27560 Old 09-20-2014, 09:14 AM
[unique]'s Avatar
It really depends on the movie, but usually i watch between -13 and -16.
-10 with quiet movies.
Btw i think i found why edge of tomorrow was that loud, they seem to have mixed the LFE content in 2 channels.
The center (?) channel is even louder than the LFE one, clearly clipping, even though its not reaching 1.0 for some reason. (probably to do with the dts offset value's, or something similar)
[unique] is offline
post #18010 of 27560 Old 09-20-2014, 09:21 AM
raynist's Avatar
Liked: 1353
I think if you have a fully treated room you can listen louder as there isn't as many reflections and ringing sounds
raynist is offline
post #18011 of 27560 Old 09-20-2014, 11:36 AM
audiofan1's Avatar
Quoted: 1663 Post(s)
Liked: 1691
I'm mostly a -10 to -17.5 type listener and save the louder levels (Reference or -5) for times when the action gets going (adrenaline rush). This can be on a content bases as well , some mixes have enough dynamic range ( your system as well) to sound pleasing at all levels with reference level being the calibrated spec for volume. If your system has the head room sometimes with the right source I'll even do +3db over reference level. now before anyone says I'm def I listen 95% of the time to classical & Jazz at -35 to -28 I've carefully insured I have adequate power on tap for clean playback . So if you haven't as mentioned above treat the room and strive for a system ( if you haven't already ) with matched amps and speakers regarding there power handling which can be achieved also by using a crossover to them say 80hz or so to increase headroom
If you know this stuff already disregard
audiofan1 is offline
post #18012 of 27560 Old 09-20-2014, 12:22 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
IMO, your question is almost impossible to answer because there are so many variables to what your -15 is to what my -15 is.
At your place -15 could represent 120DB output vs. someone else's -15 could represent 100DB output. That is an incredible difference between the 2.
with that said...I listen to -10 at my place and with heavy action type movies...I'm well over 120DB's output at that volume level...AND I LOVE IT!!!!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #18013 of 27560 Old 09-20-2014, 12:51 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
OMG...I can't wait !!!!
Thanks for sharing!
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #18014 of 27560 Old 09-20-2014, 01:04 PM
raynist's Avatar
Liked: 1353
Hmm, I am thinking you are wrong, or I don't understand reference volume. I thought the purpose of running audyssey or any other receiver setup software is to normalize the volume so that -10, -5 or 0 is the same from one room/system to the next. Now if you run your subs hot then the bass could be different.
raynist is offline
post #18015 of 27560 Old 09-20-2014, 01:29 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
I agree IF the systems are calibrated properly. My unit does not have audyssey.
I know that with my amp at 0 on the MVL there's no way I can reduce my output levels to have reference level.
You make me wonder how can I setup my receiver to be @ reference when having my volume set to 0.
I think I might have to start searching...
thanks for your response
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #18016 of 27560 Old 09-20-2014, 02:28 PM
Mongo171's Avatar
Quoted: 853 Post(s)
Liked: 1299
For us poor folk who don't have the money to invest in AI that's wrong some of the time, we set each speaker to register 75db from each speaker. Then, we break out the old abacus to figure out what MVL will coincide with 0db. Hell, 0 on my system is mute. 100 is wide open.
Mongo171 is online now
post #18017 of 27560 Old 09-20-2014, 02:43 PM
raynist's Avatar
Liked: 1353
I have seen some people use these for rca connections http://www.parts-express.com/harrison-labs-12-db-rca-line-level-audio-attenuator-pair--266-244
Here is one for XLR connections http://www.parts-express.com/in-line-xlr-attenuator-pad-20db--240-416
This will bring your gain down on the amps, but you may never get exact.
raynist is offline
post #18018 of 27560 Old 09-20-2014, 03:48 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
I have seen some people use these for rca connections http://www.parts-express.com/harriso...-pair--266-244
Here is one for XLR connections http://www.parts-express.com/in-line...-20db--240-416
thanks again for your response.
To be honest, I'm not going to worry about bringing it down so that 0 = reference.
I would much prefer to know at what volume equates to reference in my case and I believe I found that my amps -25 = reference.
That's fine by me as I now know that if I listen to -10MVL that I'm actually listening to +15DB OVER reference
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #18019 of 27560 Old 09-20-2014, 04:02 PM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
The new Transformers is a tour de force. Even the lossy version kiss serious a$$, so much that it puts Godzilla to shame.
SvtFoci is offline
post #18020 of 27560 Old 09-20-2014, 04:12 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Your AVR didn't come with any mic for setup? They all do unless your using a very old avr, this is to calibrate it, my 15 should be the same or very close to yours if you setup your AVR. Audssey is different than volume calbation, AVRs like Cambride 551R doesn't have room correct but still comes with a mic for volume setup and speaker distances.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #18021 of 27560 Old 09-20-2014, 05:03 PM
raynist's Avatar
Liked: 1353
Actually I remember why I saw people using these. It was because Audyssey couldnt set the levels of the speakers because of the gain in the amps and this couldn't eq the speakers.
raynist is offline
post #18022 of 27560 Old 09-20-2014, 05:26 PM
MKtheater's Avatar
Quoted: 1626 Post(s)
Liked: 1160
The problem comes from people with high sensitive speakers. The AVR can not go below -12 dBs automatically so it uses that as the lowest setting and can throw the levels way off as far as keeping 0 MV at reference. I have a pioneer elite reciever and t set my speakers 15 dBs too loud for 0 MV. So I I watch at 0 MV I am way over reference.
MKtheater is online now
post #18023 of 27560 Old 09-20-2014, 05:32 PM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 161
Originally Posted by discone View Post
Well I got to watch Oculus last night. As stated above it does have some nice bass. It does not have it all the time, but when it does it can be heard and felt. I know this since I got this new subwoofer and a good scare comes the wife grabs my arm much tighter.
The story well, that's another story! I'm a little bias as these are not my type of movies, but will say this is a movie you have to follow at all times to keep up with what is going on as they do a lot of flashbacks. If you take a bathroom break without putting it on pause you may get lost. Those who watch it can make their own decision if it was good or not. If a bass fan and need a filler movie while waiting for a new release then this would be ok for a rent IMO.
OK,
Rented it from Red Box and gave it spin today. You are spot on once again with your assessment on Oculus !! I really did enjoy the bass with this one. It hi, med and low !! Thanks for the suggestion and I'm glad I rented it. Although I would not suggest buying it, it's definitely worth a rental for the bass alone.
discone likes this.
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #18024 of 27560 Old 09-20-2014, 06:26 PM
discone's Avatar
Quoted: 207 Post(s)
Liked: 208
Originally Posted by Ray77085 View Post
OK,
YW! I'm happy to hear you were able to get some enjoyment from this film!!
Ray77085 likes this.
discone is offline
post #18025 of 27560 Old 09-20-2014, 08:57 PM
ambesolman's Avatar
Quoted: 1079 Post(s)
Liked: 909
Just watched the amazing Spider-Man 2 3d. Good flick! Sounded great on my setup. As others have mentioned, it could've used a little more midrange punch, but thought it was very good overall. The 3d was pretty good too. Can't wait until my sub is done so I can hit the 12hz stuff!
Sent using Tapatalk since the mobile version is still
ambesolman is offline
post #18026 of 27560 Old 09-20-2014, 09:08 PM
Kini62's Avatar
Quoted: 1501 Post(s)
Liked: 1362
Watched Godzilla 2014 last night streamed from iTunes. I liked the movie. To me is was vastly superior to Pacific Rim not only as a movie but the sound track was much better overall.
The bass was quite good other than the lack of depth on the foot steps and some of the monster on monster fight scenes. But overall a good use of the surrounds and good bass in most of the appropriate spots.
To me Pacific Rim was just one long bass note that tended to just drone on and on never changing and not really adding much to the movie. I don't recall the surround being used as well as in Godzilla either.
I'm betting that I would like the Godzilla sound track even better in DTS Master.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #18027 of 27560 Old 09-20-2014, 09:29 PM
cchunter's Avatar
Quoted: 505 Post(s)
Liked: 781
I also watched Godzilla the other day and was very disappointed. Horrible movie except for the audio. The black levels were really bad IMO. 90% of the movie was in the dark and maybe 10mn top of actual Godzilla footage. I also thought the acting was not very good. I'm glad I rented it and would never buy it even if it was in the budget bucket at Walmart for 5.00 lol.
5.1 Livingroom: Sony 65XBR850D 4K, Marantz SR7011, Klipsch RB75's Cherry, RC64II, RS52's Cherry, SVS SB13 Ultra, Oppo 203 UHD, Sony PS4, Panamax 5300PM
cchunter is offline
post #18028 of 27560 Old 09-20-2014, 09:34 PM
tvuong's Avatar
Quoted: 1588 Post(s)
Liked: 921
+1 and 3D looks gorgeous
tvuong is online now
post #18029 of 27560 Old 09-20-2014, 10:04 PM
basshead81's Avatar
Quoted: 199 Post(s)
Liked: 5596
Age of Extinction is the business! Best bass flick in a long time...Flawless!
Toe, audiofan1, billpan and 1 others like this.
basshead81 is offline
post #18030 of 27560 Old 09-20-2014, 11:27 PM
audiofan1's Avatar
Liked: 1691
^^^ This is all good to hear , i'm looking forward to this blind buy
Reddig likes this.
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
