The New Master List of BASS in Movies with Frequency Charts - Page 619 - AVS Forum | Home Theater Discussions And Reviews
 7153Likes
post #18541 of 27573 Old 10-21-2014, 03:46 PM
jcwhammie's Avatar
Quoted: 45 Post(s)
Liked: 48
Has anyone seen the movie The Rover? And if so does it have good bass and an overall good soundtrack? I reserved it at Redbox since there was nothing else worth getting that I haven't seen.
jcwhammie is offline
post #18542 of 27573 Old 10-21-2014, 04:31 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Originally Posted by discone View Post
Awesome!!! Glad to hear the sound from Godzilla was good for you! Maybe I needed to turn it up a little more to hear and feel the bass better. I had the volume set at my normal movie level. I did hear and feel some just not as much as I thought I should. When Godzilla made his first foot stomping appearance the bass was shaking our seats, but later as you stated the M.O.T.O.'s were giving more rumble. I'm a fan of the old Godzilla's and this was not to bad so I may have to pick this one up and do a revisit with the volume cranked up a bit more.
I'm looking forward to X-Men: DOFP and hope it does not put me to sleep!! I'll make sure the volume is up on this one. Will be bumping up First Class in my queue for a revisit before I watch the new one. If you do a revisit before I catch the new one and make it through without falling asleep please do a post of your thought's.
Sorry to hear about your ground hum from the sub. Hope the isolator takes care of that issue so you can go back to enjoying the movie's!
Yep,
If and when you have time I would suggest giving Godzilla another spin !! The bass is certainly there with a lot of most likely mid-bass. Turn the avr master volume up, let's say 5-db higher than your normal volume and that should do it.
Appears we might be heading towards another movies with no bass drought and so I will be giving X-Men: DOFP another spin and well rested prior !!
You will enjoy X-Men FC with your new sub and that's guaranteed !! I have all of the X-Men on BD and that one is the best so far bass wise.
As far as what I think is a ground loop issue, I will fiddle around this coming weekend in hopes to make it go away.
discone likes this.
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #18543 of 27573 Old 10-21-2014, 04:44 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Originally Posted by Hopinater View Post
I agree with you on that. Every time I read about someone tackling a hum in the system it's usually a ground loop and it goes one of two ways. They either solve it within 15 minutes or they end up ripping apart their entire system item by item trying to isolate the hum. So I really hope you find it fast and eliminate it so you don't have to go through all that frustration. Good luck, hope the isolator works for you.
I hope you are correct as I would like to get rid of it and make it go away within 15-mins. !!
It appears to be isolated to one of the lower end Klipsch RW-12d subs that's plugged into a cheap surge protector . The HSU subs are plugged into these Belkin PureAV® PF30 Home Theater Power Console.
MY 5.4.4 SET UP.
Ray77085 is offline
post #18544 of 27573 Old 10-21-2014, 05:22 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Originally Posted by 04rex View Post
I have also had some experience with a Hum. I have 4 Ultimax 15s conencted to a CV-5000. Believe me when i say in this case, wiring can definitely play a part in fixing it. Plus a ground loop isolator as well.
When i first hooked it all up, there was a really loud hum. To the point where it was almost louder than the voices. I couldn't take it at all and was worried as this was my first DIY project. At this point, i had cheap monoprice RCAs connected to the Amps. I had previously purchased some Master Series RCA cables at a really cheap price but never used them. So i decided to switch them out to see what would happen. Well, the new wires reduced the noise by 80%, if not more. I was actually shocked. The more expensive wires for once actually made a difference.
Although it took care of the majority of noise, there was still some noticeable Hum left. So i got a Ground Loop Isolator and that took care of the rest. Now, it is virtually silent. I say virtually because if you but your ear to the sub and put the volume high (with no content playing obviously) you can still hear a faint hum. But once you stand even 1 foot away, it is silent.
So my point is, wiring can also play a part in the Hum. But the Isolator should do the trick.
Many thanks for taking time to post your experience with what I think is my issue !! I did not notice the hum until a quite moment occurred during playback of a movie. Heck I thought it was part of the sound track for a moment. (LOL).
When you say you connected the Master Series cables are you talking about the Acoustic Research ? If so I have them and I love those locking ends. I have them all, sub cables, analog, component (not used anymore), and the 10-gauge speaker wire. Spent a good chunk of change on all of those back in the day and still use the majority of them. The sub with issue has a Blue Jean LC-1 Subwoofer Cable, 33 foot long that is also a quality made cable.
Anyway I'm going to fiddle around this weekend by moving subs around and changing the sub cables. I need to make certain it's not the sub-amp.
MY 5.4.4 SET UP.
Ray77085 is offline
post #18545 of 27573 Old 10-21-2014, 06:30 PM
osogovo's Avatar
Watched it a couple weeks ago,I don't recall anything special in the bass department,but I just finished The Purge Anarchy and I was very pleased with the soundtrack.Great use of the LFE and decent flick- a lot better than the first one.
Source- Blu ray
osogovo is offline
post #18546 of 27573 Old 10-21-2014, 06:47 PM
04rex's Avatar
Quoted: 134 Post(s)
Correct. Acoustic Research. The locking ends are definitely awesome. Since doing the sub cable, I changed all my RCA to MS. I wanted to get their speaker cable but it is hard to come by now. I wish they still made the cables. Good luck with everything.
04rex is offline
post #18547 of 27573 Old 10-21-2014, 08:39 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 182
Originally Posted by MemX View Post
Wow, if she wasn't already your wife I'd be saying you need to marry that woman right away! lol
Nice MemX, but I probably couldn't talk Her into it again. She knows me too well, and I've already used most of my best lines.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #18548 of 27573 Old 10-22-2014, 03:04 AM
discone's Avatar
Quoted: 207 Post(s)
Liked: 209
Yep,
A Bass drought????????? Say it isn't so!! I guess I'll add a flick or two each week to my queue so I don't suffer bad Bass withdraw symptoms.
Thanks for the heads up on First Class and I bumped it up so I may get it this weekend. Still have to wait till 11-11 to get DOFP though.
Ray77085 likes this.
discone is offline
post #18549 of 27573 Old 10-22-2014, 09:58 AM
red_5ive's Avatar
Quoted: 21 Post(s)
I haven't watched Oz: The Great and The Poweful blu-ray since it released, and I also only had a single 15" sub at the time. I watched it the other night, and holy smoke I'd forgotten how much of a blast-fest the final sequence was! And with 3 x 15" subs now it was pretty intense. I've added this one to my list of demo material.
Defeat of Deduct must go over Defense before Detail does.
red_5ive is offline
post #18550 of 27573 Old 10-22-2014, 10:06 AM
WayneJoy's Avatar
Quoted: 127 Post(s)
Liked: 83
I watched The Desolation of Smaug Extended from iTunes last night and my gut tells me that the bass was improved from the theatrical blu-ray. I haven't watched the theatrical version in a while, but the extended version pretty much gave me what I would have expected for the content of the movie.
WayneJoy is offline
post #18551 of 27573 Old 10-22-2014, 10:11 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
fury is going to have some awesome demo scenes for bass and surround when it comes out on blu-ray unless they mess up the audio really bad from the theatrical cut
Bassment is offline
post #18552 of 27573 Old 10-22-2014, 02:55 PM
FilmMixer's Avatar
Quoted: 1960 Post(s)
Liked: 2420
There is no filter on the 5.1 master for HT.
I didn't "mess" it up.
FilmMixer is offline
post #18553 of 27573 Old 10-22-2014, 02:59 PM
BornSlippyZ's Avatar
Quoted: 1803 Post(s)
Liked: 1493
Day one buy for me!
BornSlippyZ is online now
post #18554 of 27573 Old 10-22-2014, 03:09 PM
drewTT's Avatar
Quoted: 802 Post(s)
Liked: 821
***** movie. Nothing too interesting in terms of audio.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | roon
drewTT is offline
post #18555 of 27573 Old 10-22-2014, 03:30 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Awesome!!
A L Wong likes this.
Bassment is offline
post #18556 of 27573 Old 10-22-2014, 03:37 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Just check ebay or amazon occasionally and you may get lucky !! I agree they should have kept making the master series line. I was lucky to find a pair for my front wides and the center speaker a year or two ago. I already had the front right and left speakers connected.
To be honest I use to have darn near everything Acoustic Research from their subwoofer and speakers. Still use side surrounds.
MY 5.4.4 SET UP.
Ray77085 is offline
post #18557 of 27573 Old 10-22-2014, 03:46 PM
carp's Avatar
Quoted: 2829 Post(s)
Liked: 2134
What movie is HT? Thanks!!
carp is offline
post #18558 of 27573 Old 10-22-2014, 03:59 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
Yep, well I don't know of anymore block busters that are from the summer that on the way to BD.
Now these may turn out to be good, but IDK. Maleficent could be or Hercules both on BD 11/04/14 ???
I see from the previous post above that ,How to Train Your Dragon 2 doesn't have the deep slamming bass that HTTYD has. HTTYD is indeed a bass monster !!
I guess we shall see and hear. (LOL)
discone likes this.
MY 5.4.4 SET UP.
Ray77085 is offline
post #18559 of 27573 Old 10-22-2014, 04:04 PM
Ray77085's Avatar
Quoted: 137 Post(s)
Liked: 163
No movie but I think it's short for Home Theater.
MY 5.4.4 SET UP.
Ray77085 is offline
post #18560 of 27573 Old 10-22-2014, 04:08 PM
lefthandluke's Avatar
Quoted: 138 Post(s)
Liked: 282
carp...c'mon man!
buddhamus and audiofan1 like this.
lefthandluke is offline
post #18561 of 27573 Old 10-22-2014, 05:31 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
OMG! Thank you soooooooooooo much for thinking of us!!!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #18562 of 27573 Old 10-22-2014, 06:06 PM
jasonmichaelh's Avatar
Quoted: 170 Post(s)
Liked: 67
Just to clarify, he was talking about the HT mix for the movie Fury.
jasonmichaelh is offline
post #18563 of 27573 Old 10-22-2014, 06:09 PM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1063
Fury is in the theaters now, Film Mixer is referring to the Blu Ray HT version on Fury.
Reefdvr27 is offline
post #18564 of 27573 Old 10-22-2014, 06:09 PM
Reefdvr27's Avatar
Liked: 1063
The bad news is nothing under 35hz
post #18565 of 27573 Old 10-22-2014, 06:26 PM
carp's Avatar
Liked: 2134
Haha, well that's what I get for checking this thread very sporadically.
audiofan1 likes this.
carp is offline
post #18566 of 27573 Old 10-23-2014, 06:23 AM
beastaudio's Avatar
Quoted: 4122 Post(s)
Liked: 3459
You sir, are the man. Real tanks don't have a filter, so I am glad you went about this the "right" way, haha. Any 10hz or lower material make it into the mix?
beastaudio is offline
post #18567 of 27573 Old 10-23-2014, 07:10 AM
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1306
Well, if they actually recorded real tanks and they did not add a filter it has to be there!
MKtheater is online now
post #18568 of 27573 Old 10-23-2014, 11:19 AM
Kain's Avatar
Quoted: 1504 Post(s)
Liked: 441
Can someone tell me why some Blu-ray movies have the bass filtered? What is the point of filtering bass?
Kain is offline
post #18569 of 27573 Old 10-23-2014, 11:34 AM
beastaudio's Avatar
Liked: 3459
depends, some feel "no one" has the capability anyways below a certain point, but for the most part, commercial theater subs are already high passed between 20 and 30hz so they do their mixes accordingly. When the "HT" is done separately, they are leaving it the same as the commercial mix in some cases.
I think Avengers actually put the filter in so they could just go insane with the >30hz material and not worry about system limitation below that point. I think I remember someone mentioning something about that. I am not @FilmMixer though, he likely could give you the exact answer you are looking for.
post #18570 of 27573 Old 10-23-2014, 11:50 AM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
The theatrical and extended have the same LFE content, no difference.
Mrkazador is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
