The New Master List of BASS in Movies with Frequency Charts - Page 658 - AVS Forum | Home Theater Discussions And Reviews
 7142Likes
post #19711 of 27573 Old 01-22-2015, 08:56 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3516
Originally Posted by mantaraydesign View Post
So is the Conjuring the only horror movie with the best bass? Are there more horror movies in bluray with 5 star bass?
Any good bass in the Dawn of the Planet of the Apes in bluray?
yes to apes..
the Haunting is a very good horror bass flick
Brian Fineberg is offline
post #19712 of 27573 Old 01-22-2015, 09:02 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5834 Post(s)
Liked: 4835
Still not on blu-ray. Grrrr!
Scott Simonian is offline
post #19713 of 27573 Old 01-22-2015, 09:03 AM
mantaraydesign's Avatar
Quoted: 154 Post(s)
Liked: 34
Originally Posted by tvuong View Post
^^ Triangle
Originally Posted by Brian Fineberg View Post
yes to apes..
Thanks, will buy the Apes.
About the Haunting, is this movie in bluray or DVD? If it is in DVD, is it the DTS version or the regular Dolby Digital version?
mantaraydesign is offline
post #19714 of 27573 Old 01-22-2015, 09:05 AM
Liked: 3516
dvd dts version is the one i have...dot know if its out in BR
post #19715 of 27573 Old 01-22-2015, 09:09 AM
Quoted: 154 Post(s)
Liked: 34
post #19716 of 27573 Old 01-22-2015, 09:47 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Originally Posted by saprano View Post
No. The bass on bluray sounds more cleaner and controlled compared to the DVD version. The DVD is sometimes louder but lacks detail and sounds sloppy. I'm always comparing dvd to bluray. I've learned the characteristics of each when it comes to PQ and SQ.
Try it yourself.
I have and I disagree completely. Only way to eliminate psychoacoustics is a blind test. The bandwidth for LFE covers at most 1-120 Hz. For the rest of the audio spectrum 1-20,000 KHz is used. Big difference. DVDs can easily handle the LFE spectrum.
wth718 is offline
post #19717 of 27573 Old 01-22-2015, 10:02 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Like i said try some comparisons yourself. The difference is there. The bluray is clearly superior. Lossy vs lossless on bluray i find the same on some movies. It can be identical but there a few blurays where it's night and day. V for Vendetta is one example. The overall SQ is much better with the lossless track than the 384kbps DD. Then there others like Pirates of the Caribbean 1 to 3 i find there's no difference at all. And that's a Dolby Digital track at 640kbps vs a PCM track at a constant 6.9mbps.
home theater addict
saprano is offline
post #19718 of 27573 Old 01-22-2015, 10:04 AM
tvuong's Avatar
Quoted: 1748 Post(s)
Liked: 1042
Perhaps there is at least one movie that has better bass in DVD than BR. The Haunting and TitanAE DVDs have incredible bass.
tvuong is offline
post #19719 of 27573 Old 01-22-2015, 10:07 AM
Alan P's Avatar
Quoted: 5030 Post(s)
Liked: 3708
Master & Commander is reportedly better on DVD.
Alan P is offline
post #19720 of 27573 Old 01-22-2015, 10:09 AM
audiofan1's Avatar
Quoted: 1738 Post(s)
Liked: 1788
Originally Posted by raynist View Post
Interesting. The guys over at Data-bass say it IS filtered and similar to Riddick. Riddick did sound great but was obviously missing the ULF.
They also said perhaps it could have been filtered after it was mixed. If that was the case and I was FilmMixer I would be pissed.
Hopefully @FilmMixer can stop by again.
http://data-bass.ipbhost.com/index.p...-131#entry5784
Didn't Riddick have solid LFE down to 15hz ? That's a pretty respectable use of LFE and it did sound great. I'm really hoping "Fury" delivers as I plan a blind buy
audiofan1 is offline
post #19721 of 27573 Old 01-22-2015, 10:12 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
And then there's this. But still, some DVD's may be louder and not filtered but they don't have that.......cleanliness and sense of direction and space that the bluray versions have. Twister is yet another good example i find.
home theater addict
saprano is offline
post #19722 of 27573 Old 01-22-2015, 10:14 AM
Bass Enabler
Liked: 4835
640k DD can sound pretty damn good. The dvd rate 384 and 448 do not sound good and I can tell easily.
Yes they do! And both not on BD still. GGGrrrrr!!!
It actually sounds better on BD but the bass was neutered <30hz compared to the dvd version.
Riddick starts to roll off <30hz but it does have pretty decent LFE just not much ULF content. Expect similar from 'Fury'. It does have very hard hitting bass though.
post #19723 of 27573 Old 01-22-2015, 10:18 AM
raynist's Avatar
Quoted: 1524 Post(s)
Liked: 1487
Steep filter on that one, -10db point at 27hz
http://data-bass.ipbhost.com/index.php?/topic/98-riddick-unrated-execution-and-recommendation-poll-closed/#entry2498
raynist is offline
post #19724 of 27573 Old 01-22-2015, 10:18 AM
audiofan1's Avatar
Liked: 1788
^^^^ Can't complain about hard hitting bass! I'm sure the extra ULF grunt would have put this over the top !
post #19725 of 27573 Old 01-22-2015, 10:21 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
By definition, BR tracks will have higher bitrate audio than DVDs. Assuming that, and then assuming your contention that BR LFE is tighter/less sloppy, whatever because of the technical limitations of DVD, then you would NEVER have a DVD that sounds better for the LFE spectrum. That's not the case. Also, what "direction and space" are you hearing from the LFE portion of the track??
Again, I'm sure you do hear differences. But unless you're subjected to a blind test, you can't possibly know how much of it can be attributed to the psychological effect of KNOWING you're listening to a lossless track.
wth718 is offline
post #19726 of 27573 Old 01-22-2015, 10:28 AM
audiofan1's Avatar
Liked: 1788
Not to mention when the vast majority of AVR's and Pre's when DRC is applied its a max of 48khz from bluray regardless of the sampling rate that pretty much levels the playing field of using a higher sampling rate. Still to date IMHO 192/24 bit lossless from Akira and a few more, are the only movies that can boast a discernable difference in fidelity! That's of course if you turn Audyssey and the like off !
post #19727 of 27573 Old 01-22-2015, 10:59 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
What dvd's sound better than the bluray versions? None.
Haha. It just sounds more real to me. It has better presence. I'm mentioning alot of superlatives but that's the best way i can explain what i experience.
I'd love to do one. I'm sure i'll still be able to tell the difference.
home theater addict
saprano is offline
post #19728 of 27573 Old 01-22-2015, 11:09 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Umm, a couple were quoted on this very page. Again, we're not talking about the overall track, just the LFE.
That's part of your problem. You think that presence, direction, and "airiness" comes from your LFE channel--it doesn't. Those cues come from your speakers. If you're hearing direction from your subs, it's crossed too high.
wth718 is offline
post #19729 of 27573 Old 01-22-2015, 11:47 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Like I explained some dvd's are louder and unfiltered but the bluray still sounds better. Yes the LFE track.
No man I'm not talking about the speakers at all. I know the difference. The bass on the bluray is more realistic and well put together. You're going to have to compare for yourself to understand.
home theater addict
saprano is offline
post #19730 of 27573 Old 01-22-2015, 11:51 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
No man I'm not talking about the speakers at all. I know the difference. The bass on the bluray is more realistic and well put together. You're going to compare yourself to understand.
Lol. Ok, I guess you're just going to keep ignoring where I said that I had. Hey, if it sounds better to you, that's all that matters at the end of the day.
wth718 is offline
post #19731 of 27573 Old 01-22-2015, 12:41 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Where did you say you've done these comparisons?
Anyway yeah this is what I hear. Everyone has a different opinion on PQ and AQ. But I mean the bass quality on dvds and blurays should be readily apparent.
The last movie I tested was Iron Man 3. Same results.
home theater addict
saprano is offline
post #19732 of 27573 Old 01-22-2015, 01:22 PM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
here.
wth718 is offline
post #19733 of 27573 Old 01-22-2015, 05:45 PM
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 44
... well I would agree that the track with the higher bit rate(most typically found on blurays) would have better quality.... however the track with the deeper lfe tracks(non filtered, usually found on dvd copies, and not blurays) have "better" lfe(low frequency effects/extension). I think that's the argument, not weather or not someone's subjective listening experience tends to make them think one track is better than the other. Data is all I care about.
Vizio M501d-A2R(Calibrated), LG BD-330, Pioneer VSX-524-K, Custom DIY LCR Mains, DIY Sub ( Kicker 10c124, 2.25 ft3, 19 hz tune, powered by xm-sd46x(using only rear channel in bridge mode, 150watts), powered by 400w atx power supply.) Work in progress.
Gary147852 is offline
post #19734 of 27573 Old 01-22-2015, 05:58 PM
Oliver Deplace's Avatar
Quoted: 21 Post(s)
Liked: 34
If the mixes are different, which is often the case, between DVD and BD, there's a good chance they'll sound different (and contain different data).
I've compared Hellboy DVD to to its BD counterpart. On these tracks, the mixer remapped the vocals to a song, from L&R (DVD) to the CC (BD), and restored the vocals to the song that disappear from the DVD (at 25:20), then reappear (at 25:48).
If you have both discs (DVD 0 43396 01317 9 and BD 0 43396 19172 3), and want to hear the difference, turn off your CC, play the DVD from 25:14 to 26:39 and play the BD from 26:28 to 28:16. Then play both segments with the CC on.
To me, the difference was obvious when I first heard the BD (hence, my research). Sometimes, my CC can throw an image that is smaller and more forward than a dual-mono image, as it did in this case.
There may be others on these discs, but they didn't grab my attention.
My point is, once someone's put their mitts on the stems, there's a good chance they've made some changes. So, the differences you hear may have nothing to do with codecs or the colour of the laser's beam.
Oh, and in this instance, I might prefer the dual-mono on the DVD over that of the CC on the BD, that doesn't mean I'll say the DVD is superior to the BD. It's just my preference, and one that is likely to be system-dependent.
Gary147852 likes this.
Yo mama so fat, time slow when she near.
Oliver Deplace is offline
post #19735 of 27573 Old 01-22-2015, 06:54 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Originally Posted by Gary147852 View Post
... well I would agree that the track with the higher bit rate(most typically found on blurays) would have better quality.... however the track with the deeper lfe tracks(non filtered, usually found on dvd copies, and not blurays) have &quot;better&quot; lfe(low frequency effects/extension). I think that's the argument, not weather or not someone's subjective listening experience tends to make them think one track is better than the other. Data is all I care about.
I spoke about this above.
home theater addict
saprano is offline
post #19736 of 27573 Old 01-22-2015, 07:05 PM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
Since listening is subjective and open to our own biases...has someone measured a movie on DVD vs BD and show that the lfe is different? That is the ONLY WAY to settle this question...with SCIENCE!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #19737 of 27573 Old 01-22-2015, 07:30 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Yes blurays can have a different mix. Maby more for the older releases than recent ones. But there are lossy and lossless tracks on the same bluray that still sound different. The Patriot is another where the overall sound and LFE are better with the PCM track than the DD. I guess it depends because that's not always the case as i explained in my other post.
I even find that lossy on bluray has better quality to it than the same lossy on dvd. How about that.
home theater addict
saprano is offline
post #19738 of 27573 Old 01-22-2015, 07:46 PM
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 44
I think this thread is off topic by now.
post #19739 of 27573 Old 01-22-2015, 08:20 PM
raynist's Avatar
Liked: 1487
I think i did see a graph of this on data-bass.com for a movie.
raynist is offline
post #19740 of 27573 Old 01-22-2015, 08:37 PM
Trigen's Avatar
Quoted: 55 Post(s)
Early candidate for LFE movie of the year, imo.
If you loved the bass on Fury, You will love American Sniper (as long as the mixers did not change the mix for home use).
I would be surprised if it doesn't win the sound mixing (and editing) oscar.
Trigen is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
