The New Master List of BASS in Movies with Frequency Charts - Page 823 - AVS Forum | Home Theater Discussions And Reviews
 7110Likes
post #24661 of 27514 Old 05-11-2016, 11:29 AM
raynist's Avatar
Quoted: 1325 Post(s)
Liked: 1252
Originally Posted by Brian Fineberg View Post
look again...the peak of avg is at 38Hz @ -40.0 so the -50.0 is at 13Hz
hence it extends to 13Hz
I see the average drops -10 for the first time from the peak at 17/18, it does come back up again a bit lower and then drops again at 13hz
raynist is offline
post #24662 of 27514 Old 05-11-2016, 12:06 PM
Point Source
beastaudio's Avatar
Quoted: 3559 Post(s)
Liked: 2870
Red line, not green line bro!
beastaudio is offline
post #24663 of 27514 Old 05-11-2016, 12:17 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
It's deceiving because it's actually a dip, but the first time the red line hits -50dB at a lower frequency than when it was at -40dB is around 17Hz.
UN78HU9000FXZA(TS01)/SEK-3500U || UDP-203 (fw: 38-0222)
Denon AVR-X4200W || Atmos/DTS:X 5.1.4:
Fronts = Klipsch R-3650-WII (x2), Surrounds = Klipsch G12 (x2)
Center = Klipsch RP-160M, Sub = HSU VTF-3 Mk 5,
TFs = Klipsch R-2650-C (x2), TRs = Polk RC80i (x2)
UN65JS9500FXZA (TS01) || UBD-K8500 || Chromecast Ultra
galonzo is offline
post #24664 of 27514 Old 05-11-2016, 12:28 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
it doesnt matter the first time it dips...its the highest frequency it hits -50
Brian Fineberg is offline
post #24665 of 27514 Old 05-11-2016, 12:47 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
I was just saying that since it's a dip, it looks deceiving. I thought it was -10dB coming from the peak frequency; so wherever it peaked, you go to the left from there to get the first time it hits 10dB lower, which would be around the dip at 17Hz. Of course, it could be like you're saying (the lowest frequency that is first hit at 10dB lower than the peak frequency).
galonzo is offline
post #24666 of 27514 Old 05-11-2016, 12:48 PM
Liked: 3515
2. Extension - The same bass-managed digital signal above is analyzed with Spectrum Lab, with Nuttall windowing, and either a 1 second or 2 second integration time (the longer the integration time, the higher the resolution, at the cost of dynamic peaks, but for the extension category, it is a moot point). Extension is determined as the -10dB point from the overall peak of EITHER the Peak (green) or Average (red) trace, whichever is higher. The ratings are as follows:
5 Stars - <10Hz extension
4 Stars - <15Hz extension
3 Stars - <20Hz extension
2 Stars - <25Hz extension
1 Star - >25Hz extension
post #24667 of 27514 Old 05-11-2016, 12:54 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
so it does say "from the overall peak", which implies you go from the peak, down (to the left).
edit: You're right @Brian Fineberg , here it is:
Spoiler!
galonzo is offline
post #24668 of 27514 Old 05-11-2016, 01:01 PM
Liked: 3515
are you not reading what I wrote? im not sure i can explain it any better
post #24669 of 27514 Old 05-11-2016, 01:02 PM
Liked: 3515
Spoiler!
lol. I know I was right...i wasn't guessing..i was trying to educate
galonzo likes this.
post #24670 of 27514 Old 05-11-2016, 01:28 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
I only read it once when it was first published, and it sounded like you go to the next closest "peak" @-10dB when they say "from the overall peak". At any rate, it is from whichever is higher, which you said you thought it was from whichever is lower; in this case it appears they're both at 38Hz anyway.
galonzo is offline
post #24671 of 27514 Old 05-11-2016, 01:35 PM
raynist's Avatar
Liked: 1252
I always had problems with that going from the overall peak. You could have a huge peak at 45 hz that would then show the movie as a 22hz movie. Where another movie has 15hz extension that is just as loud as the movie with 22hz extension but it doesn't have that huge peak so gets a better rating.
could it be done by picking a -db point for all movies, say the -50 point and anything below that is considered not audible and thus have a more concrete way of judging the extension.
raynist is offline
post #24672 of 27514 Old 05-11-2016, 01:38 PM
Liked: 3515
yes...but the avg has a Lower Hz -10db ...this is getting tedious..
when I said lower i wasnt referring to Db i was referring to Hz...I think you arent grasping what the x and y axis represent on the graphs
post #24673 of 27514 Old 05-11-2016, 01:41 PM
Liked: 3515
same thing with the dynamics rating...TIH gets punished in this category cause it has too much bass??
they admit the system has flaws...buts its head and shoulder above here where its..."that movie had the baddest craziest bass evaaa!!" and getting a 5 star rating
post #24674 of 27514 Old 05-11-2016, 01:42 PM
raynist's Avatar
Liked: 1252
Yeah - that is weird too!
I just like looking at the graphs to quickly tell if it has deep bass.
Brian Fineberg likes this.
raynist is offline
post #24675 of 27514 Old 05-11-2016, 01:44 PM
Liked: 3515
hahah exactly the same here
post #24676 of 27514 Old 05-11-2016, 02:02 PM
Point Source
beastaudio's Avatar
Liked: 2870
I'm pretty positive that every new movie release has more bass than the previous movie released. Bass just keeps going up and up and up. It's great though, so this way every movie you watch is basically the best bass movie you've ever seen.
post #24677 of 27514 Old 05-11-2016, 02:25 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
No it's the -10 of either the peak or avg whichever is lower.
So I read it as a 13hz movie
It says:
I understand you meant whichever has the lower peak (in Hz) at -10dB for each, but their example clearly shows that they are going by whichever peak is at a higher frequency (in the case of Transformers 2, the green is at 123Hz (it's even labeled on their graph) while the peak average (red) is around 37Hz; which would put the -10db for the average around the same frequency as the -10 for the green, but they clearly label the green -10 peak as the extension calculation. For Deadpool, both peaks are at 38Hz, so who knows which they'd go by there.
edit: here's their example again, for convenience:
Spoiler!
Last edited by galonzo; 05-11-2016 at 02:27 PM. Reason: added graph again for convenience
galonzo is offline
post #24678 of 27514 Old 05-11-2016, 02:37 PM
Liked: 3515
this is my last time...the higher peak is yes 38Hz...so that is the HIGH WATER mark...it is at -40Db...so that means you have to find the lowest frequency in EITHER graph (peak or avg...whichever extends lower in Hz) which is at -50.
the avg is a lower frequency at -50 (13Hz) so that is the measurement you use.
post #24679 of 27514 Old 05-11-2016, 06:37 PM
pennynike1's Avatar
Quoted: 306 Post(s)
Liked: 136
I went out and bought my first 4K Ultra HD blu ray yesterday and picked up Deadpool. Of course, that disc won't play in the PS3 or PS4, so I watched the DTS 7.1 mix. Can I just say that Superhero landing gives me so much life? I bought the movie to hear it, and it certainly didn't dissapoint. In fact, the entire battle with Angel Dust and Colossus at the end, as well as Negasonic Teenage Warhead are just incredible! I wish the entire movie was like this, but I will take what I can get
BornSlippyZ and azz7686 like this.
pennynike1 is offline
post #24680 of 27514 Old 05-11-2016, 06:54 PM
Alan P's Avatar
Quoted: 4729 Post(s)
Liked: 3370
Originally Posted by dominguez1 View Post
Cool, that would be great if you could.
One example is during the first part of the movie when Christian Bale is negotiating with the banks to setup credit swap on mortgages. They cut in and out of a Ludicrous song.
It was way tactile with the mbm...to much for the screen action, imo. But if you turned off the image and just listened to the song, the tactile response would have been perfect. With the screen action, it just seemed out if place.
I listened without the mbm, and it was less tactile, and seemed to blend better with what was going on. Still on the hot side though I think.
OK, I checked out that scene, and yes, I agree the bass is over-exaggerated...but I think it sounds like the bass line from most hip-hop music; too hot and a bit "electronic" sounding.
That being said, it was a bold editorial choice, but I liked it...I liked it a lot.
BTW, I'm an editor for a living.
Just FYI, I do NOT have a MBM.
dominguez1 likes this.
Alan P is offline
post #24681 of 27514 Old 05-11-2016, 08:45 PM
BornSlippyZ's Avatar
Quoted: 1642 Post(s)
Liked: 1321
This was my first UHD purchase as well and like you my equipment won't play the UHD disc but I might as well future proof now for a few dollars more. I thought the 7.1 mix was pretty damn good and sounds way better, especially the bass than my local cinema!
Kind of a different bass movie but,
I was also trying to figure out what Fast and Furious film has the most bass and I remembered that FF3 Tokyo Drift probably had more than the others. I was correct and since going to duel subs the impact of that movie was felt! Not a 4 but a healthy 3 imo. I wish the latest ones got the mix like FF3 did.
BornSlippyZ is offline
post #24682 of 27514 Old 05-11-2016, 09:20 PM
dominguez1's Avatar
Quoted: 928 Post(s)
Liked: 654
Awesome AP, thanks for doing that!
dominguez1 is offline
post #24683 of 27514 Old 05-12-2016, 05:52 AM
lizrussspike's Avatar
Quoted: 523 Post(s)
Liked: 651
@pennynike1
Good Call. That was an excellent scene for sure with some great bass moments! Within the first 20 minutes on the freeway wasn't too bad either.
lizrussspike is offline
post #24684 of 27514 Old 05-12-2016, 08:09 AM
Point Source
beastaudio's Avatar
Liked: 2870
Well, one more vote for deadpool. I couldn't just "compromise" with the DTS-MA 7.1 on the BD so I went and got the Sammy 8500 UHD player so I could get the full atmos treatment. I am glad I did! What a well done surround mix, and oh yea there was a few bass moments that were very fun. Not going to win any bass-fest awards, but when it was needed, it was definitely there. bullet effects flying all over the place. Great stuff!
post #24685 of 27514 Old 05-12-2016, 08:42 AM
Hopinater's Avatar
Quoted: 1828 Post(s)
Liked: 4490
You got a new player to watch the Atmos version? I LIKE IT!
Now that my friends is how it's done! No holds barred true commitment to the pursuit of great audio.
beastaudio likes this.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #24686 of 27514 Old 05-12-2016, 08:45 AM
Liked: 3515
thats what I did ( bought the UHD player strictly for more atmos titles)...and it ended up costing me another 3k...cause I said well why not have a 4k PJ too?
lol
cmdrdredd likes this.
post #24687 of 27514 Old 05-12-2016, 09:24 AM
Point Source
beastaudio's Avatar
Liked: 2870
Was NOT a purchase I wanted to make just yet, I wanted to wait for the Panny unit which is darn slick, or for the vaporware oppo that might never come out, but this player's price fit the bill for the time being. You gotta do what you gotta do in this neverending pursuit
post #24688 of 27514 Old 05-12-2016, 09:33 AM
cmdrdredd's Avatar
Quoted: 2530 Post(s)
Liked: 2382
Oppo says 2017 for their unit.
So anyone care to share a couple scenes from deadpool that have some good overhead audio going on? As I mentioned previously it wasn't obvious to me like some other movies with stuff hovering above or with rain etc. Just want to give these scenes a second listen.
Samsung 55JS9000, Denon AVR-X2200w 5.1.2, PS4 Pro, Gaming PC(SLI 970s), Philips BDP7501 UHD Player, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #24689 of 27514 Old 05-12-2016, 10:11 AM
Quoted: 523 Post(s)
Liked: 651
lol
@Brian Fineberg
Which 4K PJ did you get?
post #24690 of 27514 Old 05-12-2016, 10:12 AM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 584 Post(s)
Liked: 622
Okay, same here (last time); I believe all of the confusion came from when you first (correctly) said it's the lowest -10dB frequency here (and I was incorrectly disputing it):
No it's the -10 of either the peak or avg whichever is lower. So I read it as a 13hz movie
Then I explained how I could have confused the dip as the mark, to which you flipped and said:
which doesn't make any sense, since the highest frequency at -50 is around 78Hz,
Spoiler!
then you quoted their explanation that also says to use the higher peak to calculate extension:
[snip]Extension is determined as the -10dB point from the overall peak of EITHER the Peak (green) or Average (red) trace, whichever is higher...
And then they show this in their example I posted, but then they use the deepest -10 mark for most other movies anyway (as you suggest).
For example, they have X-men3 calculated at 9Hz, but the higher frequency peak is the red at 40Hz, which would make the extension at -10dB around 18Hz by their method above:
Spoiler!
At least we all agree that we like to see the graphs to see how deep a movie gets
galonzo is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
