Please Help: Subwoofer crossover/bypass settings - AVS Forum
post #1 of 7 Old 06-05-2011, 06:15 PM - Thread Starter
AGENT_P6's Avatar
I would like some help for optimal surround sound settings. I just bought a new subwoofer for my home theatre system as my old one had some weird vibrating problem. So here's the facts:
- I use my home theatre for mostly gaming, but also a lot of rock, classic rock, dance/techno music, as well as movies (just mentioning this because maybe settings would be different based on what you use it for)
- my receiver has an option to adjust the crossover frequency. I don't really know technically what this is for and with the above in mind, I need to know what setting I should use. Right now it is set at 150 Hz and it will let me choose the following settings: 60Hz, 80, 100, 120, and 150
-my new sub is a klipsch 8" and there's a dial for lowpass on the back ranging from 40Hz to 150Hz. I don't know what lowpass is but by ear it seems whatever the dial is set at it will only output frequencies BELOW that number. When I put it at 40 for a particular song I didn't really hear anything because I guess the bass guitar was playin a higher note than 40Hz
My feeling is that the receiver crossover determines what frequencies get sent to the sub and the lowpass is what the sub will accept and output. But tbh I know nothing on the matter and I'm probably far off the truth.
With what I plan on using the system for in mind, what settings would be best for me to use that would give me a happy medium yet not sound muddy or mess up my sub?
Thanx very much in advance
void adjustPrice{
if (hasAppleLogo == true){
price += 450;
AGENT_P6 is offline
post #2 of 7 Old 06-05-2011, 06:22 PM - Thread Starter
AGENT_P6's Avatar
Also, is it safe to have my playstation 3 on top of my sub since I don't have much room (I'm not worried about it falling off from the vibration but rather because it has a hard drive and I think magnetic fields can damage/erase hard drives)
void adjustPrice{
price += 450;
AGENT_P6 is offline
post #3 of 7 Old 06-05-2011, 06:36 PM
Richard Cohen's Avatar
You did not mention what your main speakers are. They will be the determining factor regarding the receiver cross over setting. In general this should be set at either 80hz or 100hz. If the main speakers are very small a higher setting on the receiver might apply but it will make it easier for you to locate the sub with your ears.
You should set the subwoofer crossover on the sub to either bypassed if you can or if you can't set it at 150hz. This will allow the receiver to handle the crossover without interference from the sub.
Regarding the play station I would put a mouse pad or some other isolation between the sub and the play station and then it should be fine.
Home Theater is GREAT
Richard Cohen is offline
post #4 of 7 Old 06-05-2011, 07:05 PM - Thread Starter
AGENT_P6's Avatar
Ok I checked the sub and it DOES have complete bypass available.
I have 7 speakers, 5 of which are http://montreal.kijiji.ca/c-cars-veh...dIdZ275764220# I don't know if this matters but the impedance is 4ohms.
My FL and FR are http://www.futureshop.ca/en-CA/produ.../10020386.aspx
Hope the links work...its tricky cuz I'm on my phone writing this.
Its a bit of a cut-and-paste bang up system right now but Im working on saving enough to be able to replace my tiny speakers with some better ones. Probably will get te matching Bose center speaker next.
So would you say 120 or 150 crossover and complete bypass on the sub would be best after seeing what the speakers look like? And because they are in fact really small.
Also there's a switch on the sub for "phase" it can be either 0 degrees or 180 degrees. It's set at 0 right now...should I leave it that way?
Thanx for the help guys, it honestly means a lot to me
void adjustPrice{
price += 450;
AGENT_P6 is offline
post #5 of 7 Old 06-06-2011, 07:45 AM
With the speakers set to small I would try 100 hz and the subwoofer set to bypass.
Regarding the phase if you can find some test tone mp3 sounds on the web and play a 100hz tone I would adjust the phase to what you sense as maximum output at your seating position. If you have a sound meter use that as well.
I would also see if you like the sound with all speakers set to large.
post #6 of 7 Old 06-06-2011, 01:41 PM - Thread Starter
AGENT_P6's Avatar
I tried setting the FL and FR (Bose ones) to large and I found it took away from the subwoofer which is a good thing because with them set to small the sub was overpowering. It felt like when they were set to large I achieved a fuller sound with a good balance with the sub. Also the sub on bypass seems to sound the best. I can only barely discern a difference when I tinker with the crossover so I just left it at 100Hz. Maybe my ears are just bad or maybe my test-song wasn't the best choice for a test song but it was pretty minute. Thanks for your help Richard
void adjustPrice{
price += 450;
AGENT_P6 is offline
post #7 of 7 Old 06-06-2011, 02:12 PM - Thread Starter
AGENT_P6's Avatar
Then again when I set the front speaker to large I can specifically hear high end bass tones come from the Bose and the lower bass from the sub. This is kind of weird for music because if a particular song has a baseline with high end bass and low end bass in the riff im hearing the sub just kick in for half of the riff and the Bose handles the other half. This causes a discrepancy in the volume of high end bass and low end bass since the Bose doesn't have the low end oomph that the sub does. Plus it's just weird hearing it switch back amd forth. With the speakers set to small it seems the frequency range of the sub is widened. I don't mean the sub's actual range specs but rather the range it outputs due to the speaker size setting.
In the end I think I'm actually gonna go with small front speakers especially for music and maybe switch to large for a movie or game because it sounds better on large for those but bad for music.
It's tricky stuff! Maybe it won't sound so finicky when I get a full set of good speakers.
void adjustPrice{
price += 450;
AGENT_P6 is offline
User Tag List
