Polk PSW505 vs ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-15-2011, 02:23 PM - Thread Starter
Dextar's Avatar
Alright so I have had my mind set on the 505 for 230 shipped and have yet to read a negative review. Why isn't it pushed more for the price range?
Dextar is offline
post #2 of 11 Old 06-15-2011, 02:27 PM
schan1269's Avatar
Because of the BIC V1220, F12 and H100.
schan1269 is offline
post #3 of 11 Old 06-15-2011, 03:12 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
I hope you don't mean you've only read the amazon reviews. I wouldn't put much faith in those.
Check this out: http://www.hometheaterhifi.com/volum...er-4-2005.html
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #4 of 11 Old 06-15-2011, 05:04 PM
al2fast's Avatar
Had one, isn't horrible. Don't expect reference levels or much under 35hz. Don't be surprised to hear some port chuffing or sub bottoming on bass heavy movie scenes. It was alright with music imo, didn't seem to get overwhelmed with the rap to rock I listened to.
al2fast is offline
post #5 of 11 Old 06-15-2011, 09:09 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Though it's in-room response is flat from 25hz and up...
The Polk is said to be better on the music Bic are seen as HT only in general
crazyrob425 is offline
post #6 of 11 Old 06-15-2011, 10:47 PM - Thread Starter
Dextar's Avatar
So then stay away from the Polk and get a pl200??
I will rarely if ever use it for music, it will be used for HT only.
Dextar is offline
post #7 of 11 Old 06-15-2011, 11:46 PM
Quoted: 443 Post(s)
Liked: 337
Ht Bic has on lock
post #8 of 11 Old 06-16-2011, 12:15 AM
javygonx's Avatar
Quoted: 98 Post(s)
Liked: 27
Agreed. Take pl200 if you main purpose is ht. I have one and for the price it hits hard and sounds very very good. For music its just ok. As for ht and what you are going to pay for is excellent. You can get pl200 for like $275 not sure about shipping. But if you get the Polk cheaper than pl200 you can stick with Polk. Both have similar specs. Other recommendation is Lava12" but cost bit more.
javygonx is offline
post #9 of 11 Old 06-16-2011, 12:36 AM - Thread Starter
Dextar's Avatar
The polk is about $50 cheaper than the pl200. Plenty of people love the PL200 for HT and as I said that's all I will be using it for.
Dextar is offline
post #10 of 11 Old 06-16-2011, 11:44 AM
al2fast's Avatar
Spend the extra $50 on the PL. I had the 505 in a 5000 cu/ft room. Was sufficient for music, never got stressed. I could very easily find it's limits in HT which is why I upgraded.
al2fast is offline
post #11 of 11 Old 06-16-2011, 12:20 PM
Quoted: 443 Post(s)
Liked: 337
What did you upgrade to?
