BIC America F12 vs. HSU STF-2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-10-2011, 02:40 PM - Thread Starter
bajaed's Avatar
Both of these subs have the feature(speaker outs) that meets my needs.
The BIC at $186 is considerably cheaper than the HSU at $349.
Is there a big difference in sound, especially with music? I have read that it is not as tight with music.
I would be placing either on an Auralex Subdude, would that help with music?.
bajaed is offline
post #2 of 16 Old 07-10-2011, 03:22 PM
cjsiv's Avatar
Liked: 40
I now own the STF-2 and previously had dual BIC F12s. The Hsu is much cleaner and tighter than the F12. Music is no comparison. The Hsu was noticeably better from the first minute I turned it on. If you are looking to spend under $200, I always recommend the BIC. It is a great budget sub. If you are looking to spend more, the Hsu is better in every way.
cjsiv is offline
post #3 of 16 Old 07-10-2011, 03:34 PM - Thread Starter
bajaed's Avatar
That's what I figured, so much for trying to save money!
Since you have the HSU, do you know if the spikes will fit on a 15x15 Auralex Subdude platform? I know it is 18" deep but I was hoping the front to back measurement on the tips of the spikes were 15" or less.
bajaed is offline
post #4 of 16 Old 07-10-2011, 03:37 PM
schan1269's Avatar
Just a dumb question...
Why do you need "speaker outs"?
Most people say "I need the high pass"...
Making sure you are buying either of these for the correct reason.
schan1269 is offline
post #5 of 16 Old 07-10-2011, 03:47 PM - Thread Starter
bajaed's Avatar
I just bought a Rogue Audio Cronus Magnum integrated tube amp. I have Energy RC-10 bookshelf speakers that have good bass for their size but could use the support of a sub.
The amp does not have a sub out so I need to run the L/R speaker outs from the amp into the sub, cross it over at 80hz. and run the L/R outputs to the RC-10's.
bajaed is offline
post #6 of 16 Old 07-10-2011, 04:09 PM
cjsiv's Avatar
Liked: 40
It is about 13.5" from spike tip to spike tip front to back. The Hsu made me want to go back and listen to my music collection all over again. The higher you set the crossover with the BIC, the more noticeable its faults. Mine sounded decent because I ran it with towers and crossed over at 60hz. When I ran it with sats while I was upgrading my mains I had to set it around 80-100 and it didn't sound as good handling more of the low end. That was my impression at least.
cjsiv is offline
post #7 of 16 Old 07-10-2011, 04:28 PM - Thread Starter
bajaed's Avatar
Sounds like I need to invest in the HSU. I was hoping for a break after buying my Rogue Cronus Magnum and Music Hall 7.1 but it would not be wise to support those with a sub that is not accurate.
Good to know it will fit on the subdude.
bajaed is offline
post #8 of 16 Old 07-10-2011, 05:53 PM
frostylou's Avatar
Quoted: 13 Post(s)
+1
I have a Bic 100 in my family room and a
STF-1 in my bedroom.
While the Bic is the best bang for the buck in the <200 range, the HSU is simply another class of tightness, musicality and accuracy.
frostylou is offline
post #9 of 16 Old 07-10-2011, 06:45 PM
leninGHOLA's Avatar
If you're comparing the two, the Hsu will be worth the extra cost.
leninGHOLA is offline
post #10 of 16 Old 07-11-2011, 09:19 AM
csgamer's Avatar
Liked: 29
What about with 100% movies, would there be noticeable difference in quality between bic f12 and hsu stf-2 on bass heavy action movies?
Not too concerned with SPL level, mostly sound quality as I'm living in a condo and moving into a townhouse. I hear if crossed over at 60hz, then bic f12 doesn't sound so bad. I would rather not spend extra, but if the bic is noticeably inferior, then spending extra on a subwoofer would be worth it.
csgamer is offline
post #11 of 16 Old 07-11-2011, 11:21 AM
frostylou's Avatar
Quoted: 13 Post(s)
As someone who has a Bic (and really does like it), and an STF-1, it is TOTALLY worth the extra money getting the HSU. It's just a whole nother thing.
post #12 of 16 Old 07-11-2011, 11:49 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
HSU the Smaller HSU will dip lower in the frequencies
crazyrob425 is offline
post #13 of 16 Old 08-17-2011, 11:36 PM
anonymouse99's Avatar
I wonder what the difference is between these HSU subs, besides cost:
1. UTF-1
2. UTF-2
3. VTF-1
Which would you choose between a UTF-2 and a VTF-1? I'm looking to watch movies, and also to listen to a bunch of music. Thanks!
anonymouse99 is offline
post #14 of 16 Old 08-18-2011, 03:10 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
The STF2 is basically the VTF1 except in low extension mode only. The STF1 is like them except it doesn't dig as low, it rolls off at 32 hz. For music a 32 hz is ok but some movies have content deeper than that. Then again, some movies have content deeper than what the STF2/VTF1 can do as well. If you like loudness above all, get the VTF1 and run it in max output mode.
shadyJ is offline
post #15 of 16 Old 08-18-2011, 11:08 AM
cacihome's Avatar
Quoted: 37 Post(s)
The VTF-1 is stronger than the STF-2...It uses a different driver...
Cacimar Hernandez
cacihome is offline
post #16 of 16 Old 08-18-2011, 04:06 PM
shadyJ's Avatar
Liked: 1352
I have read the driver magnet in the VTF1 is larger. Still I don't think the driver is going to be hugely different in terms of performance, at the most I think it'll offer a decibel or two more on the low end. It would be interesting to compare the closely.
shadyJ is offline
