Budget sub for under $200? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 07-26-2011, 11:14 PM - Thread Starter
note235's Avatar
1. Under $200, would prefer $100, looking at the Polk PSW10
2. No size requirement.
3. Small room, about 500 sq. feet.
4. Split between 40% movie, 30% gaming, 30% music.
5. Not blasting loud but about average
6. Prefer black if possible, not a requirement though
7. None
My current setup is a 6.1 with a
2x Infinity Primus 362s for L/R
1x Infinity Primus 351 for Center
1x Polk M20 for back
and Polk Monitor 50 for left/right
i care the most about the Front 3 though
My receiver is a Onkyo TX606. Thanks!
note235 is offline
post #2 of 27 Old 07-26-2011, 11:23 PM
schan1269's Avatar
With the Infinity you have, the Polk 10 won't add anything to your system. The only thing it will add to is your electric bill. Your Infinity reach lower in bass than the 10 does.
At $200 and lower, the Lava subwoofer and BIC are it. Outside of BIC and Lava there is nothing else to look at. Even the BIC V80 is a better sub than the Polk 10, and it is smaller.
http://www.lavasubs.com/home-theater-subwoofers.html (if you can't afford their 10")
http://www.amazon.com/BIC-V-1220-430...1744306&sr=8-1 (or if you still want to spend less...)
http://www.amazon.com/BIC-V1020-Down...1744306&sr=8-3 (and if you still need a lesser sub)
http://www.amazon.com/BIC-AMERICA-V-...1744369&sr=1-1
schan1269 is offline
post #3 of 27 Old 07-26-2011, 11:24 PM - Thread Starter
note235's Avatar
I see, do you believe that I should add a sub or wait until more money is in hand?
note235 is offline
post #4 of 27 Old 07-26-2011, 11:28 PM
schan1269's Avatar
look at the post again, there are 5 options(the Lava 10 is over, the Lava 8 is in your budget).
Those 5(unless you look used on Ebay/Craigslist/Audiogon) are it...$200-ish and under.
post #5 of 27 Old 07-26-2011, 11:31 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
Wait until you have more to spend. Don't skimp out on the sub. It is a key component in your system.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #6 of 27 Old 07-27-2011, 05:44 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
Keep an eye out for a gently-used Energy S10.3. It's a great small sub!
Prices for units in good-to-mint condition should be in the $150-$200 range.
eljaycanuck is offline
post #7 of 27 Old 07-27-2011, 02:31 PM - Thread Starter
note235's Avatar
i see, where exactly would i find this, in the FS/FT section?
someone local is selling the s10 for cheap, $130 i think i should get that then?
note235 is offline
post #8 of 27 Old 07-27-2011, 03:08 PM
schan1269's Avatar
If it works, yes. The 10.3 is the current one, there was also a 10.2 and a 10(technically can be referred to as 10.1).
post #9 of 27 Old 07-27-2011, 03:27 PM
Liked: 1802
On this site, or on used-goods sites like Audiogon, kijiji, eBay, etc.
If it's in "good" or better cosmetic condition, and in 100% working condition, yes.
post #10 of 27 Old 07-27-2011, 03:32 PM
5seonds's Avatar
Is 500 ft2 considered small now?
5seonds is offline
post #11 of 27 Old 07-27-2011, 03:36 PM
schan1269's Avatar
I would hope "small" and "500sf" is a typo somewhere...
post #12 of 27 Old 07-28-2011, 12:35 PM - Thread Starter
note235's Avatar
ahh i thought compared to others 500 was small, but the buyer hasn't responded. Are the Energy ESW a notch below the XLS?
and would the XLS or the BIC if they are under $200?
thanks!
note235 is offline
post #13 of 27 Old 07-28-2011, 01:13 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
7. None
The BIC F12 would probably be your best bet, unless you find something used.
http://www.shopblt.com/cgi-bin/shop/...r_id=!ORDERID!
bladerunner6 is offline
post #14 of 27 Old 07-28-2011, 02:05 PM - Thread Starter
note235's Avatar
i see, i think ill get the F12 for around $170 then?
any noticable difference between
f12
v1220
d1210r?
thanks!
oh, a local buyer just conacted me about selling his energy xl s-8 for $100, does that seem like a better deal?thanks! its in great condition
note235 is offline
post #15 of 27 Old 07-28-2011, 02:41 PM
BillCinLR's Avatar
500 S.F. x 8' ceiling = 4,000 cu. ft. NOT a small room!
Bill C
BillCinLR is offline
post #16 of 27 Old 07-28-2011, 02:57 PM - Thread Starter
note235's Avatar
oh i see, what would be a small room haha?
note235 is offline
post #17 of 27 Old 07-28-2011, 03:21 PM
Liked: 1802
12' x 15' x 8' = 1,440 cu.ft. would be a small room.
post #18 of 27 Old 07-29-2011, 12:16 AM - Thread Starter
note235's Avatar
found energy xls-8 for $60, rooms smaller than my estimate, i think thats a good deal?
note235 is offline
post #19 of 27 Old 07-29-2011, 05:37 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
it's a good deal but that sub will not be enough for the room size.... if you add a second one it could be OK but don't expect deep extension.
get this: http://cgi.ebay.com/Energy-S-10-3-80...item3a64d9464a
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #20 of 27 Old 07-30-2011, 11:59 PM
Zuk109's Avatar
Quoted: 32 Post(s)
+1 on the Lava 10".
15% discount for AVS members.
Zuk109 is offline
post #21 of 27 Old 07-31-2011, 01:02 AM - Thread Starter
note235's Avatar
i see
i think that if i cut off the kitchen then the room becomes considerably smaller
i haven't bought it yet
around ~200 ft
but what is the discount code?
note235 is offline
post #22 of 27 Old 07-31-2011, 09:22 AM
floridapoolboy's Avatar
You can get the BIC right here at AVS. http://www.avscience.com/Store/shop....ered_Subwoofer
floridapoolboy is offline
post #23 of 27 Old 07-31-2011, 11:47 AM
TalkingRat's Avatar
Liked: 32
Maybe it's my West Coast location, but the shipping was a deal killer, at $92.
TalkingRat is offline
post #24 of 27 Old 07-31-2011, 01:16 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Cheaper at amazon cause shipping is included. Shopblt.com has the f12 for $185 shipped
crazyrob425 is offline
post #25 of 27 Old 07-31-2011, 01:43 PM
Wow, that shipping is high. Amazon sounds like a deal!
post #26 of 27 Old 07-31-2011, 04:14 PM - Thread Starter
note235's Avatar
haha yes for me i can use amazon and 2 day shipping for the F12 for around $170 or the Lava 10 for $20x or 8 for $16x
recommend?
thanks!
note235 is offline
post #27 of 27 Old 07-31-2011, 07:45 PM - Thread Starter
note235's Avatar
found the klipsch rw 10d for $200
waiting on the lava code, which one would you guys recommend?
note235 is offline
