Acoustic Research S115PS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2011, 09:40 PM - Thread Starter
Poolstick's Avatar
I have the Acoustic Research S115PS 15" sub that is not working. I have it in the shop but the tech says he needes a wiring diagram to repair power amp. Does anyone have any info on this amp? Thanks
Poolstick is offline
post #2 of 3 Old 08-14-2011, 07:06 AM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
I'm not going to tell you what to do with your cash,(Smile) but if I were you I would not waste money on that sub. I had the same exact sub and then I upgraded to a ID sub HSU (VTF-3.3) that kills the old sub. Not saying you should go that route, but the newer subs just simply blow away the AR's S115PS.
Good luck and it's something to think about.
My original post.
http://www.avsforum.com/avs-vb/showthread.php?t=1332240
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #3 of 3 Old 08-14-2011, 01:05 PM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Subwoofer repairs often run $200-300+ and are guaranteed 30-90 days.
If you do a large number of Google searches on 'Acoustic Research S115PS Service Manual' you may find a site that has the service manual that you can download for a fee of $15-25.
After my S115PS died, I gave it to a high school kid to see if he could repair it.
wwinkler is offline
