DALI or SVS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 63 Old 08-28-2011, 02:58 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
So im based in China and just happens that DALI is a client of mine. I am looking for a HT duty subwoofer. DALI has suggested me their new DALI E12F for a fair price.
I dont know however how they are for HT? Will they really hit the bottom that I am looking for for my HT?
On the other hand I can also get my hands on an SVS SB12NSD for about 1000RMB extra.
I should tell u all that I dont have any DALI today. I have 100% Cerwin Vega at home powered with QCS & DUSSUN V6i.
Hope you can advise what I should go for!
januza is online now
post #2 of 63 Old 08-28-2011, 05:09 AM
Svendsen's Avatar
I don't think you can compare Dali subs and SVS - although I know Dali also makes a few very expensive subs (which I have not heard) - svs are in an entirely different league - especially in regards to HT.
But, what's your system - which cerwin vega speakers do you have - Having balance in the system is an advantage - it certainly is so if you want to have a subwoofer that can keep up with your system.
No waste, grab a bar, get saw on.
Svendsen is offline
post #3 of 63 Old 08-28-2011, 05:15 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Hej Svendsen
I'm currently running CLS15 as front, CLSC6 as center and CLS6 as rear.
post #4 of 63 Old 08-28-2011, 05:20 AM
Svendsen's Avatar
If that was me, I would be looking at larger and more powerfull subs than the two you mentioned in the original post - fx something ported from the svs-range.
Svendsen is offline
post #5 of 63 Old 08-28-2011, 05:25 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Really ? I kinda have limited options for subs here. What would u suggest ? I'm open ears :-)
post #6 of 63 Old 08-28-2011, 06:31 AM
Liked: 62
What's the "fair price" for the DALI? I see they go for around 480 pounds, which is about $780 or so dollars. 1000RMB seems to be an extra $156 for the SVS, totaling $936 if I have my conversions right.
What size room are we talking (H/W/D)? That'll be the big determination.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #7 of 63 Old 08-28-2011, 06:58 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
DALI is around USD 850 and SVS is around 1000.
My room is huge.. Its a high ceiling living room around 900sqm, 5.5 meters high. I know I can get my hands on a PB12-Plus but need wait a few month but for that price I can get 2 DALIs
post #8 of 63 Old 08-28-2011, 07:15 AM
Liked: 62
900 square meter floorplan by 5.5 meter high ceilings? Is that correct?
I'm getting somewhere around 5000 cubic meters for the room. That's not just huge, that's gigantic. Are you sure those figures are right?
If that's the size of the living room, either sub is going to find it near impossible to do anything in there.
Tulpa is offline
post #9 of 63 Old 08-28-2011, 07:20 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Oh sorry. It's 900square feet. My bad. Its a shared living /dining room.
post #10 of 63 Old 08-28-2011, 07:36 AM
Liked: 62
That comes out to about 16,200 cubic feet, which is huge (but not hanger size, fortunately.) You definitely want two of either of the subs.
Tulpa is offline
post #11 of 63 Old 08-28-2011, 07:47 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
based on the specs alone, the Dali won't hit as hard as the SVS. The SVS will go deeper and give you more output in the lower bass zone.
But I would recommend you wait a bit until SVS releases their PB12-NSD. That sub is a much bigger sub and will give you bass down to 20Hz. Compare that to the SB12 which starts dropping at 25Hz and the Dali which is probably even higher around 28-30Hz.
The European site for SVS says it's shipping end of September.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #12 of 63 Old 08-28-2011, 05:48 PM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
So what's the diff between PB12-NSD and PB12-Plus
The PB12-plus have received awesome reviews is much more expensive but might be worth the extra money
post #13 of 63 Old 08-28-2011, 07:57 PM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
The way I look at the difference is:
NSD - good
Plus - better
Ultra - best
With the plus, the driver has more heavy-duty quality of construction and capability
The amp on the PB12-Plus has twice the power with a few more adjustments, and the cabinet is larger which provides higher sensitivity
Basically you will get higher output with less distortion, and a bit deeper bass extension as well. Even if you don't use all the output capability, the sub is less strained which results in cleaner sound quality
As long as the sub's large cabinet itself fits well into your living space,
I would say the PB12 is well worth the price, so if you can afford it, you won't regret it.
post #14 of 63 Old 08-28-2011, 08:30 PM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Ultra is above my budget.. But I think the 12-Plus might fit.... :-)
post #15 of 63 Old 08-28-2011, 10:27 PM
Liked: 62
Good to hear. In that size of a room, you'll probably need it.
Tulpa is offline
post #16 of 63 Old 08-31-2011, 06:50 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Just found out that I can get both the PB12-Plus and PC12-Plus here.. The PC12-Plus is around 200USD cheaper than the PB12-Plus.. Any advise on which is better?
post #17 of 63 Old 08-31-2011, 07:08 AM
Svendsen's Avatar
Talk to SVS or your retailer - but they should have quite similar performance. I have the pc12-plus and I'm very happy with it. The cylinder is easier to move and takes up less floorspace than the pb12 - but the pb12 lets you see the driver get a workout and looks more traditionally like a subwoofer.
Svendsen is offline
post #18 of 63 Old 09-01-2011, 05:49 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Hej Svendsen
where did u buy in Denmark?
post #19 of 63 Old 09-01-2011, 06:42 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
SVS has always said their cylinders are basically equal to their box subs, and they have the advantage they take up less horizontal space and are much easier to move.
I personally prefer the looks of a big box sub though with their nice finishes.
post #20 of 63 Old 09-01-2011, 10:53 AM
Svendsen's Avatar
Hej Svendsen
L-Sound in Norway is the European dealer, and I bought through them - the prices are in euros and taxes are included.
Call and talk to them - send them a sketch of your room, I think they provide a high level of service.
Svendsen is offline
post #21 of 63 Old 09-28-2011, 09:52 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Guess who just ordered the PB 13 Ultra in black oak :-)
post #22 of 63 Old 09-28-2011, 10:12 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
who?
post #23 of 63 Old 09-28-2011, 10:16 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
Oh my god it's me!!!!!
I cannot believe I got ok from wifey!! So freaking excited to get it and play it.
I have never had such a sub before.
post #24 of 63 Old 09-28-2011, 11:03 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
Congrats!
i have not heard the dali subs...but i have heard dali icon 6 towers. they are really good. I have the PSB image T6 and I felt the dali's were better off.
ShaQBlogs is offline
post #25 of 63 Old 09-28-2011, 11:37 AM
Svendsen's Avatar
Congratulation - I Think you made a great choice.
Svendsen is offline
post #26 of 63 Old 09-28-2011, 12:34 PM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
First you were considering the SB12NSD (their smallest sub) and you ended up buying the PB13U, their biggest box sub. You did very, very well.
post #27 of 63 Old 09-29-2011, 07:46 AM - Thread Starter
januza's Avatar
Quoted: 309 Post(s)
Liked: 202
thank you very much.. My wife actually agreed that we might as well go all the way instead of something that I would upgrade after a year or 2.
Nice wifey!!
post #28 of 63 Old 09-29-2011, 08:53 PM
Elfather's Avatar
She will soon regret her generousity once that GIANTIC box shows up in your door step lol. Congrats!
Elfather is offline
post #29 of 63 Old 09-29-2011, 09:50 PM
audiophile15's Avatar
isnt dali usually a musical sub?
in australia we usually dont get much in the way of audio stores and the only place that sells dali stuff is jb hi fi. the sub they had there was sealed and wasnt any good for movies it was very musical.
i wonder if theyre range do any good movie subs
audiophile15 is offline
post #30 of 63 Old 09-29-2011, 09:59 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Your based in China and you have limited options ???
I was thinking that CHINA would be heaven for Audio/Electronics enthusiast in terms of pricing and choices
qguy is offline
