X-Men First Class - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 09-19-2011, 03:55 PM
Eternal Velocity's Avatar
Quoted: 30 Post(s)
Liked: 61
Originally Posted by saprano View Post
I believe theres no such thing as too much bass, i was just going by what brian said. He makes the subs, he must know what he's talking about.
I would ask him "Why do you think that, Brian?"
You think i should still be considering the rythmic F12? I don't know what kind of clean output it has at 20hz. You hardly see reviews for it.
x-max = 17.8mm
sd = 530cm
= 0.94 L of volume displacement
Assuming the amp is adequately powered, at 20hz, that's about 100db @ 1m (barely perceptable, and 15db lower than reference levels, although it's possible your room does you a big favour)... remember though that this would be with the little 12" driver working as hard as it possibly can, and there might be a powerful, unexpected 15hz tone that comes out of nowhere to push it even harder
Four would do about 12db more I believe, although slightly less if you optimally space them correctly rather than colocate them, but probably significantly more in your small room. Now all of a sudden that 100db at 20hz sounds less like.. well... sound because it's 20hz and isn't supposed to have a sound.
Then you'll probably never need more bass, or better sounding bass, in that particular room, and possibly other HT rooms.
Then you can focus on getting main speakers that excel, rather than trying yet again to find bass nirvana with a flawed approach.
I don't think i have the space for multiple subs.
Then make space... you'll thank yourself later and never be on an endless "chase to find a sub that sounds good unequivocally".
http://forums.audioholics.com/forums...0&postcount=13
The only spot i could maby put a second sub is in the back left corner of the room, which has a doorway, and behind my LP. Which the sub would have to be up against the wall. Isnt there certain positions you have to locate multiple subs?
No, there isn't! That's what's great about multiple subs, you set them up well and they "dissapear" and integrate to give best response. Obviously having subs in all four corners will maximize excitation of modes and give you the most output, but basically if you can find a place to put it, put it there!
http://www.audioholics.com/tweaks/ge...-bass/two-subs
In fact a three or four sub setup will be orders of magnitude less sensitive about placement than a single sub.
Of course you do want similar time delays if they're different distances apart from the primary seating position, but something like a miniDSP ($150) can do that for you. Is that a big investmentÉ
Eternal Velocity is offline
Old 09-19-2011, 05:09 PM
kesando's Avatar
Liked: 31
Just picked up First Class Today from Best Buy for $17.99. Will check it out this weekend
kesando is offline
Old 09-21-2011, 04:55 PM
Auditor55's Avatar
He is in favor of going with 2 smaller subs over one bigger sub in the scenario he explained.
Auditor55 is offline
Old 09-29-2011, 10:44 AM
ja.jo's Avatar
Quoted: 32 Post(s)
Liked: 26
I watched this the other day and really enjoyed the LFE. Extremely powerful but tight. The magneto scenes are the best IMHO.
Check your levels!
/ Jacob
ja.jo is offline
Old 10-03-2011, 05:15 PM
Danknowsnothing's Avatar
Watched this over the weekend. During the Magneto scenes my crappy sub was making clicking noises. I was hoping it'd break so I'd have an excuse to replace it heheheh. Out of curiosity, what failure would clicking indicate?
Danknowsnothing is offline
Old 10-03-2011, 05:29 PM
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
It is already failing you just have to accept it!
Marantz 7702 Atmos
MKtheater is online now
Old 10-03-2011, 05:43 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
Reading all of this makes me wonder if my two small sealed subs will be adequate.....
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
Old 10-04-2011, 07:31 AM
rwheelwright's Avatar
Quoted: 100 Post(s)
Liked: 33
I watched this the other night but I didn't watch it was a great amount of volume since my g/f was in the room but I do remember that with my sub2 it sounded pretty freakin awesome! I'm gonna have to rewatch and listen more carefully.
rwheelwright is offline
Old 10-09-2011, 01:12 AM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
The LFE in this movie was crazy! I think it should be in the ***** category. And to answer my previous post, yes my sealed subs were adequate
K5/SS is offline
Old 10-09-2011, 09:21 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Originally Posted by ninja12 View Post
I found a couple of spare hours yesterday to watch this movie. The overall mix was good. The bass was present when it needed to be but nothing exceptional. I would say WOTW, Hulk, 9, and a few other movies that I can't think of off the top of my head has much deeper bass. Like I said, the overall mix for this movie was good. Just my .02.
+1
I thought it was very good, too, but not as important to the narrative as the 5 star (and some 4 1/2 star) movies I have seen from the master bass movie list. It was fun to "notice" the effects, but the bass in X-Men did not create the same visceral immersion into the movie for me as in other movies. Using an Outlaw LFM-1 EX on ME.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 10-09-2011, 03:40 PM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
Insane bass using ULS-15. WOW had insane bass during the Pod and Bridge destruction scenes. First Class had insane bass throughout the movie. Amazing.
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
Old 10-09-2011, 05:11 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Posted in the Master List thread and thought I'd post i here. Yes, tons of low end... demo quality bass that just don't quit and all the way down to 3 Hz. Great stuff.
Originally Posted by bossobass View Post
X-Men; 1st Class
Sound design: Craig Berkey, who worked on the first Transformers movie, I am Legend and was sound designer for I, Robot and X2...oh, and Hanna, as well!:
http://www.imdb.com/name/nm0075389/
Get ready, here comes a truckload, and I left a truckload on the table as well. This is a great bass flick. It's up there with any and all top bass flicks. Great mix and lots of low end to 3 Hz. Some of it hurt me and some of it shook my room off its center of gravity.
If you respond to this post, PLEASE do NOT hit the 'quote' button because of the length of this post.
To identify the chapter/scene, see the urls for the graphs. And, these are in chronological order.
Bosso
bossobass is offline
Old 10-10-2011, 02:24 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I have to say that, after a decade of spirited debate, it's been great to read an intelligent poster who had his "eureka" moment, gets it and posts the information for others to absorb. Great stuff, FOH.
The debates over the years and that continue to this day of "Less filling!"... "Tastes great!" over this alignment vs that alignment have always been polluted with nonsense about which sounds "better, faster, tighter", etc. In fact, it has nothing to do with all of that and all of that only ever served to cloud the basic truths.
Tom Nousaine said it years ago... "Bass is bass". I've grown to love those simple, indisputable, black-and-white basic statements. Alignment is irrelevant if the reproduction is flat, clean at the desired playback level and properly calibrated with the rest of the system.
BTW, I also love that you've taken up the use of the word "system". Since the SW signal is never input directly into a box of whatever alignment with a driver in it, the low end is, by default, always handled by a system of components.
To the excellent post on PVG, I would make a simple correction; "Room Gain" is a phenomenon that comprises 2 elements: 1) Boundary Gain and 2) PVG. Boundary Gain results from reinforcement of the pressure waves from the driver (or horn mouth, or port, or passive radiators), which is the original point source, that result from additional point sources created by the reflective surfaces according to the placement of the sub in close proximity to boundaries.
So, the Room Gain phenomenon consists of an area of purely PVG, an area of transition, which is an interaction of PVG and BG and an area of purely BG.
As you mentioned, the PVG+BG are free lunch. LOTS of free lunch. Conventional wisdom says "There is no free lunch" and "There is no replacement for displacement". BG can add a theoretical +18dB and PVG can add a theoretical +18dB. That's an increase equivalent to adding 7 more of your subwoofer with no cost in space or $$. Sounds like free lunch to me. That's also an increase equivalent to adding 63 more of your drivers to your existing driver. Sounds like quite the replacement for displacement to me.
I discovered early on that the only way to properly utilize PVG was with the alignment that has the shallowest roll off with the least THD. Sealed wins. It's just a simple fact of life. All other alignments are band pass contraptions that have steeper roll off with much higher THD out of band (down low).
As you mentioned, there is a second advantage to the sealed alignment and PVG. This would be the fact that PVG happens to coincide nicely with reduction of harmonics as a percentage of the fundamental.
For example, if you see +9dB of gain per octave in your room, beginning at 30 Hz. At 8 Hz, say your sub gives 50% THD from HD2 (16 Hz) + HD3 (24 Hz) + HD4 (32 Hz) + HD5 (40 Hz) at ground plane.
PVG boosts the fundamental of 8 Hz by +18dB, but boosts the harmonics less, reducing their levels as a percentage. 2HD (16 Hz) is boosted by only +8dB, 3HD (24 Hz) is only boosted by +4dB, 3HD and 4HD & 5HD (32 Hz & 40 Hz) are not boosted at all. Essentially, this reduces the THD through 5HD from 50% to 10% and, since 2HD is still in the infrasonic range, the THD in the range of hearing is even less.
For those who might argue against this example, I took it from one of Sir Edward's reviews:
Unfortunately, it's not as simple as purchasing a bang for buck ID sealed sub. As you mention, it is a system that's required and starting with a 2nd order alignment doesn't assure you're ending with a 2nd order alignment.
Essential requirements for digging deep include having a signal chain that provides the signal as well, without rolling off too early, and an amplifier that can provide the juice below 20 HZ, as amplifiers tend to behave differently in the subsonic realm than their specs might indicate.
Warp, notnyt and others have done it right and are enjoying the results, room size notwithstanding (after all, 1/2 wave at 5 Hz is 110 feet, so I doubt room size matters for anyone at single digits). I've enjoyed it for many years now. I've asked many folks if and what difference they sense playing scenes with and without <20 Hz many times (mostly because it's great fun) and I only ever engaged in the debates with folks like the legendary Callas to keep the record straight, FWIW.
Thanks for the great post, I thoroughly enjoyed it.
Bosso
Bosso,
I missed this first time around, I thank you for the kind words. After decades in this hobby, it's a real pleasure discovering new things, and interacting with others with like interests. I must credit you with my huge smack of the forehead (certainly a "eureka" moment) when I read you post months ago regarding PVG, and the manner in which PVG boosts fundamental more-so than the upper harmonics. Wham, that hit me bigtime,...good stuff. Conversely, it makes quality large venue LF that much more impressive
Thanks again for the kind words
BTW; my floor ripples in waves too, despite the un-importance of the infra-range and genius PHD's claiming PVG being non-existent
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 06-30-2012, 11:10 AM
Sousa86's Avatar
i too must say x-men:fc really suprised me in the bass depo..
i thought i'd do a small experiment with multiple subs vs 1. first i just left my single fi q18 to play the scenes with magento..nice bass but continue reading..
i then took my diy ho sub and placed it in the room as well..did some lvl matching and replayed all the bass heavy scenes..and WOW! a really big difference!
pretty much anytime the x-men use their powers there is a rumble involved haha especially magneto's scenes! wink.gif
the second sub was a dual dayton HO 85l box with a o-audio 500w amp, even when its not really cranked i was able to tell an immediate difference in how the bass response changed entirely biggrin.gif
it can be best described as room/couch throbbing bass..very tactile and very natural sounding.
so +10 to any multiple sub system and for those of you who haven't taken the dive into multiple sub bass..i say jump in..ears first! biggrin.gif
it was truly a "Great Scott!!" moment haha
James Bond: I think I'll call it a Vesper.
Vesper Lynd: Because of the bitter aftertaste?
James Bond: No, because once you've tasted it, that's all you want to drink.
- CASINO ROYALE
Sousa86 is offline
