List of budget subwoofers ($300 and less) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 337Likes
Old 01-24-2013, 07:02 AM - Thread Starter
JimWilson's Avatar
Quoted: 1427 Post(s)
Liked: 1870
Originally Posted by gibbsy24 View Post
I'm having trouble deciding what sub to get. My budget is around $200.
I'm looking at the
BIC H-100,
BIC F-12
and Polk PSW505
I recall reading somewhere that the H-100 and F-12 are basically the same, is that true?
I would also like to add a second sub eventually, if that makes any difference in choosing.
Usage would be 60% music, 40% movies
There aren't any musical subwoofers that cost $200 I'm afraid, and seeing as how that's your top priority you may end up being dissatisfied with whatever you decide upon. If your budget is capped at $200 though then either of the BIC's would probably be better then the Polk.
The H-100 and F-12 are not the same. There isn't much that distinguish them, but BIC isn't selling two identical subwoofers.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 01-24-2013, 07:58 AM
Angler55's Avatar
Just a "for what it's worth" post that I laso put in the Klipsch sale thread.
Newegg has the Klipsch RW-12d on sale again for $299.99 and free shipping with the promo code.
Al
Angler55 is offline
Old 01-24-2013, 10:48 AM
gibbsy24's Avatar
Thanks for the answer. I'll probably be alright with the H-100 or F-12, since the only thing I can compare them to is a old 8 inch Onkyo sub that was in a home theater bundle.
gibbsy24 is offline
Old 01-24-2013, 12:41 PM - Thread Starter
JimWilson's Avatar
Liked: 1870
I think banging on a garbage can with a stick would probably be better. tongue.gif
Old 01-24-2013, 06:07 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2999
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 01-24-2013, 07:31 PM - Thread Starter
JimWilson's Avatar
Liked: 1870
Originally Posted by cel4145 View Post
I come up with a good one every once in a while...
Old 01-24-2013, 08:24 PM
Knight Operator's Avatar
Wow, well done, really well done! Recommend sticky admins!! maybe include the frequency response / sensitivity ?!
Knight Operator is offline
Old 01-27-2013, 06:41 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
sojodave is offline
Old 01-27-2013, 07:40 PM
Angler55's Avatar
I would have bought one of the Jamo Sub 650's if they had anymore in stock!
Dang!
Al
Angler55 is offline
Old 01-27-2013, 07:44 PM - Thread Starter
JimWilson's Avatar
Liked: 1870
Of those two I would probably go with the Jamo myself.
Old 01-31-2013, 07:29 AM
Necromancyr's Avatar
This is a great list. Big thing that would help is some kind of 'ranking' of them as well - what's crap, what's decent, etc. I'm in the market for a new sub now, and this list helps, but some kind of comparison would make things much clearer.
Necromancyr is offline
Old 01-31-2013, 07:45 AM
cel4145's Avatar
Liked: 2999
If that were possible, there wouldn't be nearly as much discussion here as there is smile.gif
Also, making a good sub choice is dependent somewhat on listening preferences (e.g., mainly HT vs. mainly music) and also the size of your room and how loud you expect to run it. What's your listening preferences? What's the size of your room?
cel4145 is offline
Old 01-31-2013, 07:57 AM - Thread Starter
JimWilson's Avatar
Liked: 1870
Charlie's right, there's no effective way to rate them I'm afraid - there are simply too many variables. See post 23.
Old 01-31-2013, 08:37 AM
Hrm...good point. Things that would be useful, from my perspective, is their size (of the woofer) and if there are reviews for the item.
I guess I'm figuring some of these are just crap and some are at least decent. Identifying the crap ones (for basically everything due to construction, etc.) would help to narrow things done.
Totally get the subjective/difficulty in that though...
Old 02-01-2013, 06:19 AM
Thoughts on the Polk PSW10? It's available for $80 today. I'm looking to replace my Onkyo 8" form a few years back...it works fairly decently (not sure if their speaker quality has gone down/up since mid 2000's or whats, was from an HTIB setup) but I just replaced the rest of my speakers with the Pioneer SP's (LCR are 22's, surround L/R are 21s, rear is still an older onkyo but....that's fine for now. Sub is the Onkyo one from the 760 HTIB...from 2003-2004 I believe.
(Room is a basement, finished, ~14x20 - which I know is meaningless in some regards but I'm debating on a 10" or 12" at this point so just providing for minimal context. Also, mostly used for TV/movies.)
Old 02-01-2013, 06:29 AM
cel4145's Avatar
Liked: 2999
Besides the fact that the PSW10 does not have a great reputation for SQ, it's not a great sub value at $100 even though it is popular around that price. Better to wait, spend a little more and get something better.
cel4145 is offline
Old 02-01-2013, 06:30 AM
Louquid's Avatar
Liked: 38
The PSW10 isn't bad for $80. It should have usable output down to around 35Hz, so it should sound decent for movies and music with slow bass.
I've compared the PSW10 to a Bic F12, and the only real advantages the F12 had over it was output and low end. Sound quality was pretty evenly matched. The F12 simply dug deeper, to around 27Hz and was possibly 40% louder.
Louquid is offline
Old 02-01-2013, 06:37 AM
eljaycanuck's Avatar
Quoted: 1302 Post(s)
Liked: 1930
IMO, the PSW10 is good for smaller rooms and/or at moderate volumes. Don't expect too much from it and you won't be disappointed. smile.gif
Given the size of your room and the $80 price-tag of the sub, you might consider getting two. You'll get a bit more output without having to push either sub too hard.
eljaycanuck is offline
Old 02-01-2013, 07:01 AM
Louquid's Avatar
Liked: 38
True. But if you're willing to buy two for $80, you might as well just pick up the Bic F12 or PSW505(if it's still ~$200).
Louquid is offline
Old 02-01-2013, 08:37 AM
True Louquid...that's a good point. Given my room size, not sure two subs are needed and would prefer higher SQ overall...definitely like a little 'kick' though in the bass for certain movies. And thanks for the input Eljay as well. I'm not seeing the PSW505 @ $200 anywhere, but I'll keep my eyes open. Such a difficult decision since reviews on many of these subs are 'they are great for the money' but not really 'it's better/worse than X in these areas".
Old 02-01-2013, 09:15 AM
Louquid's Avatar
Liked: 38
There will always be something better out there. Few people have what they consider the ideal subwoofer. It's hard to obtain both mentally and budget wise. No matter what you have or get, you'll always wonder if you can make an improvement. People say "good for the price" too often. All it really does it make everyone wonder if they should up their budget and see how much better performance they can get at a different price range.
The Bic F12 isn't perfect, but it's a good subwoofer. Period. Regardless of price. It is best used for movies or music with slow bass, as faster bass will result in a bit of lag. At high volumes the port can become a bit noisy, but only if it's too close to a wall. It has good low end extension as it was able to hit 27Hz in my room. The sound quality while doing this was quite good too. It was able to provide a some nice punch as well, causing plates to rattle at times. And I could feel the bass in my feet and in my couch during movies.
The PSW505 and Bic F12 are practically the same performance wise. The Polk may play 1hz deeper and have a slight edge with spl, but wouldn't warrant the extra $50 in my opinion.
Louquid is offline
Old 02-02-2013, 09:39 AM
Angler55's Avatar
Newegg has the Klipsch RW-12d on sale again for $299.99 with free shipping.
Al
Angler55 is offline
Old 02-04-2013, 06:40 PM
matrix_dot_ca's Avatar
I am seeing it as $349.99??? Is this a better deal than the BIC F12? I am deciding between the 2
matrix_dot_ca is offline
Old 02-04-2013, 06:52 PM
cel4145's Avatar
Liked: 2999
It went back up. Subscribe to their mailing list to get their specials.
The RW-12d is better class of sub, and it is easily an equal or better price/performance value at $300 (and probably at $350) as the BIC F12 is at $200.
cel4145 is offline
Old 02-04-2013, 07:14 PM - Thread Starter
JimWilson's Avatar
Liked: 1870
I agree with Charlie, that the RW-12d is better then the F12. Where I may diverge though is if you have a large room. In that case I'd probably go with dual F12's for $400 then a single RW-12d for $350. If you need lots of output the duals would trump the single in that case.
Old 02-07-2013, 06:23 AM
ProfD's Avatar
Quoted: 25 Post(s)
Hello! I am looking into purchasing a budget Subwoofer. Considing the following five:
Klipsch Reference RW-12d currently $349 + 50 off with promo code at Newegg
BIC America V-1220 12-Inch 430-Watt Down-Firing $185 @ amazon
BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer $187 @ amazon
Polk Audio PSW505 12-Inch Powered Subwoofer  $189 @ amazon
Klipsch Sub-12HG Synergy Series 12-Inch 300-Watt Subwoofer with High Gloss Trim (down-firing) $300 @ amazon
The sub will be in a small to medium sized basement room with home theater setup. I currently have a Denon AVR-1613 in the room.
I have a few questions: Will these sub's work properly with the AVR-1613? Is there any problems with the build quality on the RW-12d? (It sounds like several people are getting faulty ones delivered by newegg.) I have a small child so I thought "Down-Firing" might be a better choice, but does "Down-Firing" into a carpet kill the sound? How do these subwoofers compare from a value perspective?
Also I have Polk surround speakers is there any benefit to having all Polk stuff together (the subwoofer with Polk speaker)?
ProfD is offline
Old 02-07-2013, 07:20 PM
ProfD's Avatar
Quoted: 25 Post(s)
Plz disregard my previous question. I just went ahead and ordered the RW-12d for $299. Can't wait for it.
ProfD is offline
Old 02-08-2013, 07:05 AM
Dr. X's Avatar
Blending...
If you play music, this is crucial. So here is my dilemma.
My name is Nick and I have upgradeitis. I've been sober for... Actually I'm in the middle of a relapse and I need your collective advice.
I've owned many many subs over the years - SVS, Velodyne, and smaller names as well. For example, I currently use a pair of Velodyne HGS 18s in my basement. For context.
Now I'm upgrading my previously neglected family room and I want to start playing music in addition to HT. I'm going up the chain of Mirage omnipolar speakers (love them), and due to the WAF I'll probably stop at the OMD-5 bookshelves. Now: these don't really have any usable range below 80Hz, so what I'm really looking for is a pair of woofers to complete the lower end. Clean down to 35 Hz is fine. Do not need loud, but want fast & clean so as not to notice the transition from the bookshelves.
What I'm using currently is a pair of old Mirage nanosat subs. They fit the bill, but as I said upgradeitis has taken hold. What do y'all think about the Martin Logan Dynamo 300 for musicality and speed? Ignore the specs please.
Thanks in advance.
Dr. X is offline
Old 02-08-2013, 08:44 AM - Thread Starter
JimWilson's Avatar
Liked: 1870
ML usually makes pretty nice stuff, so they're probably solid for what they are (tiny subs with a small driver), but without knowing how large your room is it's a bit difficult to predict what type of output to expect. Also, what's your budget? There may be other alternatives available to you.
Old 02-08-2013, 09:46 PM
postrokfan's Avatar
Quoted: 563 Post(s)
Liked: 3375
I think you can get a Dynamo 300 at Audio Advisor for $130 (demo).
Living Room: B&W 804D2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
