List of budget subwoofers ($300 and less) - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 346Likes
post #1081 of 2482 Old 05-24-2014, 08:13 AM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
I too haven't had any problems with monoprice cables but then again for only $3-10 you've gotta expect a few bad apples along the way.
charmerci is offline
post #1082 of 2482 Old 05-24-2014, 10:43 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2999
Originally Posted by Bond 007 View Post
A lot of people have use those Monoprice cables and not had any problems.
I have had a Monoprice cable go bad. I also had some customer service issues with Monoprice, so I no longer buy directly from them (although I do buy Monoprice through Amazon). But I do think for a budget subwoofer that I would not recommend someone spend for a Blue Jeans Cable subwoofer cable. One can replace the cable a few times for what the Blue Jeans Cables cost.
However, Tartan Cable is Blue Jeans Cable's budget offerings that are comparable in price to Monoprice, if looking for a Monoprice alternative.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #1083 of 2482 Old 05-25-2014, 11:46 AM
mcarring's Avatar
Anybody heard of a Sound Dynamics THS-10 powered subwoofer? Is it any good? $40 at a pawn shop.
mcarring is offline
post #1084 of 2482 Old 05-25-2014, 12:30 PM
Bond 007's Avatar
Quoted: 2580 Post(s)
Liked: 2040
For $40 its worth a try. Have you Googled it?
Licence to Kill
Bond 007 is online now
post #1085 of 2482 Old 05-25-2014, 12:56 PM
mcarring's Avatar
Found some specs 100 watt amplifier, 400 watt peak. Just wondering if anybody had any experience with it.
mcarring is offline
post #1086 of 2482 Old 05-25-2014, 01:02 PM
Bond 007's Avatar
Liked: 2040
I assume its a 10". If you have a need for it buy it. If it works properly I dont see how you can go wrong.
Licence to Kill
post #1087 of 2482 Old 06-07-2014, 12:53 PM
MakubeX's Avatar
Hey Guys,
I've been reading up trying to figure out what sub to choose but I'm still not sure. The sole purpose of the sub is to have it combined with my headphones (Denon D2000) so I can feel the thump better while gaming (also some movies and TV shows but mainly gaming since this will be for my PC).
The setup will be: PC > Receiver > Headphones / Sub
My office is very small (13 x 9 feet) and the sub will be sitting about 3 feet next to me.
I'm trying to keep the budget around $200 but I'm flexible if it's worth it. Also, a very important caveat is that because I live in PR I need to buy the sub from Amazon (Prime eligible) so I don't get screwed with shipping cost.
At the moment my top candidates are:
I know other BIC subs like the F-12 and PL-200 have been recommended quite a bit but at the moment in Amazon they are either over $300 or not Prime eligible.
What do you guys recommend?
Note: I would like to keep the price as low as possible, of course. At first I was even going to go with ~$130 subs like the Martin Logan Dynamo 300 or Yamaha YST-SW216BL.
MakubeX is offline
post #1088 of 2482 Old 06-07-2014, 01:34 PM
Smallfry7's Avatar
Here is the Dayton Sub 1200 for $145 including shipping. Google for a $10 off coupon code.
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629
Smallfry7 is offline
post #1089 of 2482 Old 06-07-2014, 01:41 PM
MakubeX's Avatar
I've checked Parts-Express, the problem is the shipping cost to me is $204.85. That's why I'm keeping it restricted to Amazon.
MakubeX is offline
post #1090 of 2482 Old 06-07-2014, 02:34 PM
cel4145's Avatar
Liked: 2999
Originally Posted by MakubeX View Post
Hey Guys,
How are you planning on getting that to work? By default, the receiver will not send any audio to the speakers or sub once the headphones are plugged in.
And if you could figure out some way to make it work, what you really need to go with headphones is a tactile transducer, not a sub. For example, the ButtKicker gamer: http://www.thebuttkicker.com/gamer2
cel4145 is offline
post #1091 of 2482 Old 06-07-2014, 02:38 PM
MakubeX's Avatar
And if you could figure out some way to make it work, what you really need to go with headphones is a tactile inducer, not a sub. For example, the ButtKicker gamer: http://www.thebuttkicker.com/gamer2
I already got this to work. I did a trial run using the receiver and sub I have in my living room. I didn't use the headphones port on the receiver. I have an amp between my headphones and the source, so I simply connected my PC's sound card to the RCA input of the receiver and the headphone amp to the RCA out. Voila.
MakubeX is offline
post #1092 of 2482 Old 06-07-2014, 02:43 PM
cel4145's Avatar
Liked: 2999
Still, look into the tactile transducers. They are designed to add the effects you need.
cel4145 is offline
post #1093 of 2482 Old 06-07-2014, 02:46 PM
MakubeX's Avatar
Yeah, I know about the buttkicker, but thanks for the suggestion. I still want a sub for now but that may be the next step in the evolution. biggrin.gif
MakubeX is offline
post #1094 of 2482 Old 06-07-2014, 02:50 PM
cel4145's Avatar
Liked: 2999
Polk PSW505 might be your best bet. Or if you can go over budget, the BIC PL-200.
cel4145 is offline
post #1095 of 2482 Old 06-07-2014, 02:54 PM
MakubeX's Avatar
In your opinion, do you think the BIC PL-200 is worth the $74 over the Polk PSW505?
MakubeX is offline
post #1096 of 2482 Old 06-07-2014, 02:56 PM
basshead81's Avatar
Quoted: 225 Post(s)
Liked: 6225
A sub worth looking into is the Polk DSW660...some have reported finding them for under 300.00. If that is the case it could be the new Klipsch RW-12D replacement. I would expect it to be a significantly better sub then the PSW505. Much better driver and better extension. +/-3db 25-125hz.
basshead81 is offline
post #1097 of 2482 Old 06-07-2014, 03:00 PM
MakubeX's Avatar
This one? http://www.amazon.com/Polk-DSWPRO-12-inch-Wireless-Subwoofer/dp/B004FYA1NS/ref=sr_1_1?ie=UTF8&qid=1402178232&sr=8-1&keywords=Polk+DSW660
MakubeX is offline
post #1098 of 2482 Old 06-07-2014, 03:14 PM
Bond 007's Avatar
Liked: 2040
Interesting. Have you seen it for under $300?
Licence to Kill
post #1099 of 2482 Old 06-07-2014, 04:39 PM
cel4145's Avatar
Liked: 2999
cel4145 is offline
post #1100 of 2482 Old 06-07-2014, 05:00 PM
MakubeX's Avatar
Any opinions on the BIC RTR-EV1200?
MakubeX is offline
post #1101 of 2482 Old 06-07-2014, 10:17 PM
basshead81's Avatar
Quoted: 225 Post(s)
Liked: 6225
Yes I did during the friends and family sale last summer.
post #1102 of 2482 Old 06-08-2014, 12:16 PM
MakubeX's Avatar
Anyone got anything about the BIC RTR-EV1200?
MakubeX is offline
post #1103 of 2482 Old 06-09-2014, 04:16 AM
Transmaniacon's Avatar
Quoted: 1581 Post(s)
Liked: 1381
It's essentially the same as the BIC F-12, which is a very popular budget sub. For $200, it is a good buy for home theater bass, less so for music. If you are in a larger room or if it is open to other rooms, I would consider the BIC PL-200.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #1104 of 2482 Old 06-09-2014, 05:18 AM
MakubeX's Avatar
Thanks for the response. It's for a very small closed room (13' x 9').
I will use the sub mainly for HT (gaming actually) but I'm curious, what makes it not that good for music?
MakubeX is offline
post #1105 of 2482 Old 06-09-2014, 05:30 AM
Liked: 1381
That would be a fine choice for a small space like that. Generally budget subs sound a bit boomy, which is good for things like explosions and movie effects. Music requires more articulate bass, and you need to step up to something like a PB/SB-1000. I usually leave my F-12 off for music, it ends up just being a one-note thumper and my towers do a better job for music.
MakubeX likes this.
post #1106 of 2482 Old 06-09-2014, 05:51 AM
MakubeX's Avatar
Ah, I see. Thanks for the explanation.
MakubeX is offline
post #1107 of 2482 Old 06-09-2014, 09:48 AM - Thread Starter
JimWilson's Avatar
Quoted: 1442 Post(s)
Liked: 1896
Are those two models really that similar? They sure do look quite a bit different.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #1108 of 2482 Old 06-09-2014, 09:52 AM
Bond 007's Avatar
Liked: 2040
Did you say you were going to be testing some model of Bic sub in the future?
Licence to Kill
post #1109 of 2482 Old 06-09-2014, 10:00 AM
Liked: 1381
They have identical specifications, and use what looks to be the same amp. The drivers might be slightly different but I would wager they are pretty much the same. Also they have the same dimensions and weight.
post #1110 of 2482 Old 06-09-2014, 10:17 AM - Thread Starter
JimWilson's Avatar
Liked: 1896
Correct, the H-100.
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
