List of budget subwoofers ($300 and less) - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 410Likes
post #1801 of 2653 Old 01-04-2016, 12:52 PM
Dom Di Stroia's Avatar
Quoted: 206 Post(s)
Liked: 110
Originally Posted by Sam Schulz View Post
Would 4 Dayton sub 1500s be enough to pressurize an 8,000+ cubic feet space?
At moderate levels of output, maybe.
At higher levels, distortion may be perceptible.
Some things to consider (albeit not scientific):
"Some of the questions below ask you to assign a number on a scale. Go ahead and estimate for in-between situations.
Your Room:
____ Room volume. 0 point for 1000 cu ft; 1 point for 2000 cu ft; 2 points for 4000 cu ft; 3 points for 8000 cu ft; 4 points for 12,000 cu ft.
____ 0 points for a reflective room; 1 point for an absorptive room.
____ 0 points for subwoofer placement in a corner & on the floor (near three room boundaries); 1 point if near two room boundaries; 2 points if near only one (usually the floor); 4 points if outdoors.
____ 0 points of room is enclosed; 1 if open doors and hallways; 3 if room is very open (or if outdoors.)
____ Room score. Sum of above four scores.
Your listening style:
____ How loud will the bass be at its loudest? 0 point if comfortable; 3 points if your wife tells you to turn it down; 6 points if you keep saying ”What did you say?”; 10 points if you know the cops on a first-name basis.
____ How demanding is whatever you listen to? 0 point for string quartets; 3 points for jazz; 6 points for rock & roll; 10 points for hip-hop.
____ Listening style score. Sum of the above two scores."
Source:
http://www.aperionaudio.com/blog/how...se-a-subwoofer
Dom Di Stroia is offline
post #1802 of 2653 Old 01-04-2016, 01:25 PM
Quoted: 108 Post(s)
Liked: 63
Originally Posted by Transmaniacon View Post
Not sure of a guide for it, but it's pretty straightforward.
Set your sub gain (volume) to about 9 o'clock, Audyssey states 12 o'clock in it's setup but that's usually too high.
On the sub, there is a crossover dial, turn this to the highest point, this disengages the sub low-pass filter and let's your receiver handle the bass management.
Leave the phase at 0.
Run Audyssey and see what it comes back with for your level. You ideally want to be somewhere between 0 and -3dB. If it comes back and says -6 or more, your sub gain is too high, turn it down a bit and run Audyssey again. If it comes back +3 or more, turn the sub gain up slightly and repeat. Once you have the proper level set, you need to leave that dial alone. You can add more bass in Audyssey by bumping up the sub trim level 3-6dB.
Depending on your front speakers, Audyssey will likely set a crossover between 60 and 100Hz. You want your front speakers set to small regardless of what they are. This should get you going with the sub, just make sure you have a good location for it before doing all this. I recommend the "sub crawl" method which can be found on YouTube. Placement is half the battle.
OK, Klipsch Sub 12 arrived today and I followed your method. Thank you.
The good news, sub crawl clearly sounded best in the corner that seemed like the most normal placement.
Audyssey is being a little strange though. Receiver is an Onkyo TX NR509 and fronts are the Pioneer FS51 with the CS21 center. (set to small)
With the sub gain at 9 o clock, it sets the sub level at -9db. Minimum on the knob is about 7 o clock. Maybe it's a psychological thing, but I'd prefer that gain closer to 12. I feel like I'm leaving a lot on the table. Do I just bump the trim level on the receiver up to -3db or can I increase the gain too?
Crossover currently at 80, would 100 or 120 be worth trying?
Thanks for any help.
pitpat is offline
post #1803 of 2653 Old 01-04-2016, 02:57 PM - Thread Starter
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2097
Yup, it's psychological. Not every manufacturer sets their gain outputs the same. For example, PSA and JTR are known for having a gain structure that requires you to set the dial beyond the midway point. That's not wrong, of course, just their preferred way of doing it. The only thing that really matters is tuning it to what works best for your particular situation.
If Audyssey dropped the AVR trim to -9dB than it's telling you the sub is loud, by its standard. However, Audyssey is notorious for setting things on the weak side so most people adjust up anyway (myself included). Try upping the trim to -5dB and see if that sounds better to you, with the key words being "sounds better to you". In the end that's the only thing that matters. Adjustments are there for you to... well, adjust. So long as you aren't pushing anything to the extreme you should be fine.
Not if your goal is to have the sub output more.
Dom Di Stroia and pitpat like this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #1804 of 2653 Old 01-05-2016, 11:24 AM
Nay_Sayer's Avatar
Quoted: 13 Post(s)
Newegg now has the Polk Audio PSW505 for $169 w/free shipping..
http://www.newegg.com/Product/Produc...egg_0105_24202
ray0414 and Dom Di Stroia like this.
Nay_Sayer is offline
post #1805 of 2653 Old 01-06-2016, 05:20 AM
Bond 007's Avatar
Quoted: 2660 Post(s)
Liked: 2112
Klipsch K100 SW $129 with promo code at Frys.
afterlife2 and Dom Di Stroia like this.
Bond 007 is offline
post #1806 of 2653 Old 01-06-2016, 04:24 PM
Nay_Sayer's Avatar
Quoted: 13 Post(s)
The JBL ES250P is on sale for $199 + free shipping..
http://www.jbl.com/ES250PBK.html?CJPID=CJ
I just pulled the trigger on a pair..
Dom Di Stroia likes this.
post #1807 of 2653 Old 01-06-2016, 04:32 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
After Christmas sales? Seems like a lot of companies are offering some pretty compelling prices.
ray0414 likes this.
post #1808 of 2653 Old 01-06-2016, 04:45 PM
dlca1's Avatar
Quoted: 87 Post(s)
Liked: 31
Have no idea if any good.
Adding to the list of sales.
Frys has the Klipsch Reference 12" on sale for $197 with code.
dlca1 is offline
post #1809 of 2653 Old 01-06-2016, 05:16 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
No need to discern value - that's up to the person looking to purchase one. Including the code would be helpful though.
post #1810 of 2653 Old 01-06-2016, 05:18 PM
Quoted: 679 Post(s)
Liked: 286
the code is in your the email flyer
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #1811 of 2653 Old 01-06-2016, 05:27 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
What email flyer is that? I never get anything from Frys.
post #1812 of 2653 Old 01-06-2016, 05:28 PM
Quoted: 679 Post(s)
Liked: 286
go to thier website and subscribe, they send at least 1 flyer a day, with some real good deals
service - directv
(slow build out)
mdram is offline
post #1813 of 2653 Old 01-06-2016, 06:48 PM
dlca1's Avatar
Quoted: 87 Post(s)
Liked: 31
It is kind of a gimmicky, but you have to go to the Fry's website, sign-up and they email you with various ads which includes a personal unique code. You provide your personal code when you checkout (either at the store or online).
The Klipsch Reference-12 is $197 (with code) through 1/9/16. Regular price $449. Frys ads are sometimes regional. I'm in Northern California.
dlca1 is offline
post #1814 of 2653 Old 01-06-2016, 07:20 PM
magic bus's Avatar
Quoted: 38 Post(s)
+1
Jim Im surprised your not aware of these, some of the most cut throat speaker deals around. Infinity, Klipsch, Polk etc.. Also some very good deals on AVR's, sometimes 50% off. Denon, Yamaha, Sony, etc... Also great deals on computers, Tv's, cables etc..
Ive been chipping away at upgrading my system, and getting a lot of bang for my buck.
I seriously think they may be losing money on some of the stuff they ship out.. I just got a delivery today, probably another tomorrow...
Free Form Classic Rock http://ourmusicalroots.net/
AVR Denon S700W, which sucks because it continues to malfunction at one year old. Currently the face is blacked out! Mains Wharfedale Diamond 10.1, Center BIC FH6, Polk audio TL2 Blackstone surrounds, Subs 2 Klipsch Sub12HG , Sangean HD tuner, Sony Blu Ray player,
magic bus is offline
post #1815 of 2653 Old 01-06-2016, 07:52 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
There are no Fry's near me so I never really consider them when it comes time to buy anything. Shame too because it seems as though they run some pretty decent sales from time-to-time.
post #1816 of 2653 Old 01-06-2016, 08:01 PM
magic bus's Avatar
Quoted: 38 Post(s)
My closest is 250 miles away. Everything Ive bought has been shipped, and they ship free, fast and with a fair return policy
Dom Di Stroia and mdram like this.
post #1817 of 2653 Old 01-07-2016, 02:35 PM
MIX_MASTER_ICE's Avatar
Quoted: 1427 Post(s)
Liked: 1203
Polk PSW505 is $169 at amazon.com right now. That's one of the few popular budget subs I've never auditioned/owned. My curiosity has finally gotten the best of me, so I ordered one. We'll see how it stacks up against the best budget sub, IMO, the klipsch sub-12.
MIX_MASTER_ICE is online now
post #1818 of 2653 Old 01-07-2016, 06:06 PM
magic bus's Avatar
Quoted: 38 Post(s)
That thing looks impressive. The price cut seems ridiculous. Do you know what it was selling for before? The power rating, slot port and 5 year warranty seem legit.
ray0414 likes this.
post #1819 of 2653 Old 01-07-2016, 06:09 PM
Quoted: 679 Post(s)
Liked: 286
specs look a lot like the sub12hg
service - directv
(slow build out)
mdram is offline
post #1820 of 2653 Old 01-07-2016, 06:21 PM
Liked: 1203
The PSW505 has been up and down price wise for the past few years. It has often been around $200 and occasionally in the $150-$180 range. Otherwise it's priced a lot more at times, which wouldn't make any sense to pay more.
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Primus P363's, JBL 550P sub. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Jamo J110 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
post #1821 of 2653 Old 01-07-2016, 06:21 PM
Quoted: 42 Post(s)
Liked: 1
Any thoughts on the klipsch r12sw? It keeps going on sale for $197 at frys
Daemun is offline
post #1822 of 2653 Old 01-07-2016, 06:27 PM
Liked: 1203
On paper it has a much less powerful amp than the sub-12. For some reason frys has really been pushing the r12sw lately and quit running the sub-12 on sale. Perhaps they weren't selling many of the r12sw subs and needed to start moving some of their inventory.
post #1823 of 2653 Old 01-07-2016, 08:46 PM
ray0414's Avatar
Quoted: 10180 Post(s)
Liked: 9165
I purchased the PSW505 last week.
i had an older sony 12" with 90W rms and i also have hte polk PSW110 (10" with 100w rms)
I replaced the sony. HUGE upgrade. this thing is pretty loud. it blows away both of my current subs including hte PSW110 which is currently somehow 249 on amazon right now.
Last night i noticed that it dropped down to 169. Debating whether to get another one, i said screw it. bought a 2nd one for 169. also emailed amazon support, and they are price adjjusting my first sub since it literally got delivered on monday, which was $249,so now i got both subs for 169. cant wait to have both going at once. for 340, im not sure how much better you can get.
ray0414 is offline
post #1824 of 2653 Old 01-08-2016, 04:34 AM
magic bus's Avatar
Quoted: 38 Post(s)
Id say your gonna be a happy boy.
post #1825 of 2653 Old 01-08-2016, 10:43 AM
KennyLSU's Avatar
Quoted: 119 Post(s)
Liked: 45
When I bought my Sub-12 from them last month they pushed hard for the R12SW saying how it was a better sub. Generally I get sound advice from Fry's employees because they are supposed to go through technical training on the department they work in, but this guy must have not paid attention. I provided him what I learned from here and his final words were "well it's your money".
KennyLSU is offline
post #1826 of 2653 Old 01-10-2016, 10:09 AM
Liked: 1203
One thing those who already own the Polk PSW10 can try is adding polyfill to the inside of the cabinet. Remove that guard first, which I think makes only a slight improvement, but a bigger improvement is adding polyfill. There already is a couple of sheets inside, but fill the back side, behind the piece of wood dividing the amp from the driver. Add a little around the driver as far up inside as you can reach and by the port. Don't pack it in there, just loosely and not totally filled. It made a substantial difference in my PSW10 for reducing port noise. I decided to go ahead and get a PSW505 and also add polyfill to it, as it has been known to have port noise issues, as well.
post #1827 of 2653 Old 01-10-2016, 05:34 PM
CTM Audi's Avatar
Quoted: 87 Post(s)
Trying to find a good HT only sub, games and movie use, no music. Trying to be around $200, but could wait a bit and go to $300 if worth it.
Onkyo receiver, and infinity primus speakers. 15x15x8 L shape room (5x5 is a closet).
Reliability and warranty are strong selling points for me.
I see the Klipsch R12-SW for under $200 at frys often, and the Polk PSW505 for $160. And Crutchfield has the Primus PS312 for $330 which I could maybe stretch for, rated 400w RMS and 5 year warranty.
CTM Audi is offline
post #1828 of 2653 Old 01-10-2016, 05:50 PM
Liked: 1203
I see the Klipsch R12-SW for under $200 at frys often, and the Polk PWS505 for $160. And Crutchfield has the Primus PS312 for $330 which I could maybe stretch for, rated 400w RMS and 5 year warranty.
It's not really possible to get a good home theater sub for $300 or less. The Klipsch sub-12 is a great sub when on sale for $199, but its been a little while since it was on sale. Even that sub, which has strong output, doesn't offer up much under 25Hz. You have to get closer to $500 for a true HT sub. Like the RBH I-12 or SVS PB-1000.
post #1829 of 2653 Old 01-10-2016, 06:09 PM
CTM Audi's Avatar
Quoted: 87 Post(s)
Then why is there a sticky thread on budget subs $300 and under?
I get that spending more will get a huge bump up, but I don't need huge sound really. I'm nearly ok with the output level of the Onkyo HTIB sub I have, just want something cleaner and less slap happy. I cant imagine a $200-300 12' ~300w sub not making a huge improvement over the 10" onkyo 120W (max, unknown rms) Ive been using for 6 years.
CTM Audi is offline
post #1830 of 2653 Old 01-10-2016, 06:42 PM
Liked: 1203
Sure, something like the Klipsch sub-12 will be a very noticeable improvement over a 10" HTIB sub, but that still doesn't mean it's a quality home theater sub. This is a budget sub thread, so you have to expect some limitations when you are dealing with budget subs.
A quality home theater sub will get you strong output down to around 20Hz or better. Budget subs aren't really capable of delivering the really low LFE, which is a key factor for home theater. A quality sub will also be more accurate, clean and linear. All of these aspects are also something budget subs have a hard time with.
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
