List of budget subwoofers ($300 and less) - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 410Likes
post #1891 of 2653 Old 02-09-2016, 12:27 PM
Liked: 1
A Newbie needing help choosing a budget Sub for music only.
The room is about 1500 cubic feet (maybe less) and the sub will be used for mixing music I've recorded on my DAW. Currently I have 3 pair of near field monitors all costing between $70 -$200 (Alesis Passive 6, Hosa Cue 5, and JBL Control 5. The Amp is a crown XLS1000 if that matters.
The Sub will under my desk in an area of about 24"H x 24" D x 20" W.
I don't need (or want) wall shaking floor pounding bass. I need the bass to be clean, tight, and accurate as recorded so when I mix it I'm getting an accurate representation to start with. This way when I play the music on various systems, it sounds good.
I might be able to fit a Dayton Sub-1200 I've read so much about but not sure it's the right one and might cramp how I sit at the PC.
The SVS PB-1000 has been recommended but I can't see spending $500 on a sub when the speakers are cheapies.
Between this forum and looking at reviews on the Internet, I've come across probably 25+ different Subs (8"--12") and at this point am totally confused.
Is there something out there under $300 that would fit my needs? Just found the Klipsch SW-450 for $188. Space is tight but maybe I can turn it sideways? What do you think?
VinnieC is offline
post #1892 of 2653 Old 02-09-2016, 01:48 PM - Thread Starter
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2097
Since you want something with decent sound quality, inexpensive, small and don't require very deep bass take a look at the ML Dynamo 300. It satisfies all your criteria, especially the first one since you can usually get it for around $150.
VinnieC likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #1893 of 2653 Old 02-09-2016, 01:55 PM
Liked: 1
Thanks Jim. That was near the top of my list along with the Polk PSW111 and Energy ESW-8 but a friend of mine said the 8" will never work because it can't produce low enough notes. He said he'd go for no less than a 12" but then compromised with 10". He also said if I had to go with 8" the SVS PB-1000 would be a good possibility except I really didn't want to spend $500 and not sure it's 3+X better than the ML. Am I selling myself short?
VinnieC is offline
post #1894 of 2653 Old 02-09-2016, 02:36 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
I'd definitely skip the PSW111 - that one is not known for stellar sound quality.
What type of music are you mixing? The Dynamo should be solid down to about 30Hz with a near-field placement like you're going to have.
Not sure if this was a typo, but just in case it isn't... the PB-1000 has a 10" driver, not 8".
post #1895 of 2653 Old 02-09-2016, 02:58 PM
Liked: 1
I either create an entire Jazz, Bossa Nova, or Samba composition, or record myself playing Sax/Flute with background music. I either use Acoustic Bass or Electric Bass and some synth stuff from my DAW. Also wanted to ask. Since the sub will be in a rather confined space, does it do anything to the sound like make it more pronounced or something like that ? And is that a good thing for a smaller Sub? I might be able to fit a 10" sub in that area if you think it would make that much of a difference.
VinnieC is offline
post #1896 of 2653 Old 02-09-2016, 03:41 PM
Quoted: 108 Post(s)
Liked: 63
http://slickdeals.net/f/8495079-polk...-free-shipping
Polk PSW505 on sale for $160 if anyone's interested
from Newegg on ebay
pitpat is offline
post #1897 of 2653 Old 02-09-2016, 04:30 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
Until you said "synth stuff" I still felt the Dynamo 300 would be a good fit, but depending upon what you do with that it may no longer be the case.
Corner loading a subwoofer tends to give it more output, but given its placement I'm not certain that would be of much benefit. A lot of people do that in their home theaters in order to avail themselves of the free additional output.
If you need more depth that the Dynamo can provide getting a sub with a larger driver is probably a good idea. I don't know of any good units within your price range though. Perhaps someone else can recommend one.
post #1898 of 2653 Old 02-09-2016, 04:53 PM
Bond 007's Avatar
Quoted: 2663 Post(s)
Liked: 2113
You sound very picky. Get an SVS SB1000 and never look back. Its very small, is very good quality, has a great warranty and the sound quality will probably blow your mind and be worth every penny.
Best thing is, in the very unlikely event you dont like it, you can return it for free.
afterlife2 and VinnieC like this.
Bond 007 is offline
post #1899 of 2653 Old 02-10-2016, 06:21 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
afterlife2 is offline
post #1900 of 2653 Old 02-10-2016, 06:40 AM - Thread Starter
JimWilson's Avatar
Liked: 2097
VinnieC? Sounds like a loan shark to me...
post #1901 of 2653 Old 02-10-2016, 08:31 AM
Liked: 1
And I'm in Joisey like you.
VinnieC is offline
post #1902 of 2653 Old 02-10-2016, 08:54 AM - Thread Starter
JimWilson's Avatar
Liked: 2097
What exit?
post #1903 of 2653 Old 02-10-2016, 05:02 PM
Liked: 1
Originally Posted by jimwilson View Post
what exit?
gsp 98
VinnieC is offline
post #1904 of 2653 Old 02-10-2016, 05:23 PM - Thread Starter
JimWilson's Avatar
Liked: 2097
gsp 98
Belmar eh? As a kid I spent my summers not too far from there; Bradley Beach.
post #1905 of 2653 Old 02-10-2016, 06:05 PM
Liked: 1
Actually exit 98 to rt 195 near freehold
VinnieC is offline
post #1906 of 2653 Old 02-11-2016, 06:36 AM
kgallerie's Avatar
Quoted: 64 Post(s)
Liked: 86
To me, this is the key point here. It sounds like the sub will be surrounded on all sides and not allow for proper ventilation of the port, so I would recommend trying to find a sub with a front port. These are pretty rare, but you can find them.
The Klipsch R110-SW would suit you well, but its in the $400 range. Or for a little more go with the PB or SB-1000.
VinnieC likes this.
kgallerie is offline
post #1907 of 2653 Old 02-11-2016, 08:24 AM
Bond 007's Avatar
Liked: 2113
He could face the port towards where he sits but thats another reason why I suggested the SB1000.
VinnieC likes this.
Bond 007 is offline
post #1908 of 2653 Old 02-11-2016, 10:50 AM
kgallerie's Avatar
Quoted: 64 Post(s)
Liked: 86
I suppose if its a down firing sub. But if its rear ported, that would be pretty ugly having the amp plate facing out.
Agreed, the SB1000 or the PB-1000 (front ported) would both be great options.
VinnieC likes this.
post #1909 of 2653 Old 02-12-2016, 08:46 AM
Liked: 1
Thank you all for your input. Since this is my first Sub, I decided to order the Dynamo 300 to get my feet wet. It is 1/3 the price of the SB or PB and I think it will serve the purpose well but if it doesn't, I'll be looking to upgrade. I need to have a starting point so this is it. I'll let you know how I like it. Thanks again to all who helped.
Dom Di Stroia likes this.
VinnieC is offline
post #1910 of 2653 Old 02-14-2016, 01:43 AM
MIX_MASTER_ICE's Avatar
Quoted: 1427 Post(s)
Liked: 1204
frys.com has the Klipsch sub-12hg on sale this week for $197 w/coupon code. Been a while since this one has been on sale. Very good budget sub.
Rashman, Dom Di Stroia and mdram like this.
MIX_MASTER_ICE is offline
post #1911 of 2653 Old 02-15-2016, 11:00 AM
KennyLSU's Avatar
Quoted: 119 Post(s)
Liked: 45
Was coming here to post that. I'm actually thinking about getting the R-15M Bookshelves and waiting on the R-25C to go on sale again. I think that would be a better LCR than what I have now. The Sub-12 has made me more interested in Klipsch.
KennyLSU is offline
post #1912 of 2653 Old 02-17-2016, 06:17 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Klipsch SW-112 Reference Series 12" Powered Subwoofer $180 after $20 Rebate + Free S&H
Buy Now ►
http://www.newegg.com/Product/Produc...2780073&cm_sp=
Newegg.com has Klipsch SW-112 Reference Series 12" Powered Subwoofer on sale for $199.99 - $20 rebate = $179.99. Shipping is free. Thanks Discombobulated
Deal Editor's Notes & Price Research:
Rebate limit 1 per household. - brisar
Has earned 4.5 stars overall (out of possible 5) based on 50 Amazon customer reviews. - brisar
post #1913 of 2653 Old 02-19-2016, 04:55 AM
Quoted: 679 Post(s)
Liked: 286
frys has the sub12 today for 197 in the email flyer
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #1914 of 2653 Old 02-19-2016, 06:38 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JBL ES250PBK 12" 400W Subwoofer $200 + Free Shipping
Promo Code = 200ES2
http://www.jbl.com/ES250PBK.html?utm...feb21&CJPID=CJ
post #1915 of 2653 Old 02-26-2016, 08:52 AM
Gu35's Avatar
Newegg - Klipsch Sub-12 for $199 (Free Shipping) w/ Promo Code
Source: Slickdeals
Promo Code: EMCEGGJ33
MIX_MASTER_ICE likes this.
Gu35 is offline
post #1916 of 2653 Old 03-01-2016, 11:02 AM
Liked: 1204
Klipsch sub-12 is actually on sale now for $199.99 at Amazon. http://www.amazon.com/dp/B003VIWK0G/...db67e00caf0INT
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Primus P363's, JBL 550P sub. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Jamo J110 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
post #1917 of 2653 Old 03-02-2016, 10:10 AM
Nay_Sayer's Avatar
Quoted: 13 Post(s)
Newegg has the Jamo J-12-DA 12-Inch Front Firing Woofer for $199. Has anyone auditioned this sub before?
http://www.newegg.com/Product/Produc...egg_0302_46782
Nay_Sayer is offline
post #1918 of 2653 Old 03-02-2016, 10:40 AM - Thread Starter
JimWilson's Avatar
Liked: 2097
I had picked up a SUB 650 a few years back, when they were being phased out and sold for peanuts. Mine turned out to have a problem with the amp - there was almost no deep bass - but there were no more to be had so they couldn't swap it for another. Jamo didn't want to repair it either, so I ended up with a refund. I didn't get to hear what it was truly capable of I'm afraid.
In the past I've contemplated reaching out to them for a review unit, but never followed through. I might someday. Either way, for $200 it doesn't look like bad deal. Newegg leaves out some key information - little things, like size and frequency response for example - and unfortunately that exact model doesn't appear on Jamo's website. The J 12 SUB looks very similar though, so you might be able to use those spec's. If so, the F3 is 27Hz. That means it probably won't be a deep bass monster, but with a little room gain it should be respectable.
post #1919 of 2653 Old 03-02-2016, 01:04 PM
Dom Di Stroia's Avatar
Quoted: 206 Post(s)
Liked: 110
The sub in question is the Jamo J 12 SUB, which appears on the Jamo website, and the suffix "DA" refers to the "dark apple" finish of the cabinet (the Newegg publication is imprecise):
http://www.jamo.com/speaker-types/su...rs/?sku=J12SUB
The driver might get similar performance to that of a Klipsch SUB-12. (Jamo is owned by the Klipsch Group.)
Newegg market image:
Source:
http://images17.newegg.com/is/image/...02-Z06?$S1280$
Dom Di Stroia is offline
post #1920 of 2653 Old 03-02-2016, 01:12 PM
Quoted: 679 Post(s)
Liked: 286
Originally Posted by Dom Di Stroia View Post
The sub in question appears on the Jamo website, and the suffix "DA" refers to the finish of the cabinet ("dark apple"):
i would put it closer to the reference 12, the amp is a 200/400, not the 300/600 in the sub-12
service - directv
(slow build out)
mdram is offline
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
