List of budget subwoofers ($300 and less) - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #2161 of 2421 Old 07-29-2016, 06:54 AM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
Originally Posted by JimWilson View Post
Not really. About the only other ones in your price range are the SUB-1200 and the Jamo J-12.
The PS38 is on sale so that's why I asked. Really liking the SUB-1200 looks and prize wise though do you think 120W would be enough, my old is 163w. Jamo is odd color and prize a bitter higher as well, and only 3 reviews on there. Thanks a bunch!
Best,
Main Living Room: Samsung 65 KS9800 + Audio: Onkyo HT-S6300 7.1
Other Living Room: Panasonic Plasma 55 + Onkyo Home Theater System 5.1
b0rnarian is offline
post #2162 of 2421 Old 07-29-2016, 07:07 AM
Quoted: 553 Post(s)
Liked: 224
last page of this thread has a member review of the jamo
Budget subwoofers discussions, opinions and questions thread
b0rnarian likes this.
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #2163 of 2421 Old 07-29-2016, 07:35 AM - Thread Starter
JimWilson's Avatar
Quoted: 1297 Post(s)
Liked: 1616
A good price doesn't always equate to a good deal. If your only criteria is cost then the PS38 might suffice, but if things like performance and capabilities are factored in it will fall well short of the mark.
Amp wattage has little bearing on performance if considered in isolation; they are so many other factors involved that you can't really make an assessment from one spec. That's like judging a cars 0-60 performance by horsepower alone. Without knowing how much the vehicle weighs, what type of transmission is being used, rear end gear, final drive ratio and the like there's no way to accurately discern overall performance.
Dom Di Stroia likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #2164 of 2421 Old 07-31-2016, 02:39 PM
laserjock II's Avatar
Quoted: 711 Post(s)
Liked: 385
@Nate Miller , this is a good place to get info for your question.
laserjock II is online now
post #2165 of 2421 Old 08-08-2016, 02:19 AM
Dom Di Stroia's Avatar
Quoted: 189 Post(s)
Liked: 97
Room specs?
Output levels?
Music? Movies? Gregorian chanting?
Did the amp of the "old" sub clip the output at high levels?
If the Jamo J-12-DA weren't such an "odd color", would it sound any better?
Jamo J-12-WHT (white finish) offer:
https://www.neweggbusiness.com/produ...=9b-86-427-004
Jamo J-12-BLK (black finish) offer:
https://www.amazon.com/Jamo-J-12-BLK.../dp/B00O7KJWF8
A/VR: Sony STR-DE598 (6.1 channels)
L/R + C: 2 x Polk Audio TSx220B + 1 x Boston Acoustics CS 26 II
Subs: BIC RtR RtR-12S + Polk Audio PSW110
Surrounds: 2 x Klipsch Reference R-15M + 1 x Boston Acoustics CS 26 II
Monitor: LG 24EA53V-P (Panel: LG Display AH-IPS)
Display: Samsung UN-46EH6000F CS01 (Panel: InnoLux S-MVA)
Dom Di Stroia is offline
post #2166 of 2421 Old 08-08-2016, 08:05 AM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
Exclamation
Originally Posted by Dom Di Stroia View Post
Room specs?
Output levels?
I may or may not need to replace my Onkyo Sub just yet. I re-ran auddessey the other day and the test and sound seemed fine on it but I just can't seem to get the settings on it right. I read the entire Auddessey calibration article somewhere on the forum with questions/answers etc. and still can't figure out what Hz to use on em.
After running the auddessey calibration, the Hz came out diff. and second time yet another set of Hz - I think im just dumb when it comes to audio and the meaning of it all. I did figure out the Multiplex setting should not be Main+sub, it should be just sub so that the main speakers arent being used for sub sounds. However, rest of the speakers are the same size so not sure why the reciever would put some of them on 80Hz and others on 150Hz (surround ones). Can somebody help me out?
PS: my room is 11ft wide and 25 long and sit about less than half way on the front side to the tv. I used the room/tv 95% for movies. Thank you!
Best,
post #2167 of 2421 Old 08-08-2016, 10:07 AM - Thread Starter
JimWilson's Avatar
Liked: 1616
What does that mean, "Hz came out diff"? Are you talking about the crossover point?
post #2168 of 2421 Old 08-08-2016, 10:18 AM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
Yes, IE: 120Hz vs 80Hz. please note that I am a complete newbie to Audio section. Thanks for your help.
Best,
post #2169 of 2421 Old 08-08-2016, 05:16 PM - Thread Starter
JimWilson's Avatar
Liked: 1616
Are you certain the speakers are all identical? It's very uncommon for the center, left/right and surrounds to be completely the same.
Even if they are the exact same thing, the difference in crossover points between speakers may potentially be due to their respective distance from the microphone when the measurement was taken. Identical speakers that are closer will tend to have a lower crossover point than those further away, due simply to the fact that those located a greater distance from the microphone have to provide more output in order to achieve the same sound pressure level. That, in turn, diminished their ability (headroom) because they're working harder to achieve the same volume level. Auto-EQ systems tend to compensate by increasing the crossover point, which will lower the stress put on a speaker by relieving it from playing frequencies that could cause distortion at higher output. It's a balancing acts of sorts.
post #2170 of 2421 Old 08-08-2016, 06:23 PM
Bond 007's Avatar
Quoted: 2380 Post(s)
Liked: 1918
And not just distance but location within the room. Middle of the room vs tight in a corner can affect xover. As well as furniture, drapes, glass, etc.
80 and 150 is pretty drastic for identical speakers though.
Bond 007 is online now
post #2171 of 2421 Old 08-08-2016, 07:06 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
How about a pic of your setup and the way the mic is setup?
afterlife2 is offline
post #2172 of 2421 Old 08-09-2016, 06:57 AM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
It's this system - http://www.crutchfield.com/S-UuSHBGC...-HT-S6300.html
At least they all look the same, and no other way to differentiate between them. PS: the front speakers are 80Hz, and the surround back ones came out to be 120Hz (both are the furthest from the seat). The closest surround speakers came to be 150Hz and thought that was weirdly a big difference between the speakers.
Best,
post #2173 of 2421 Old 08-09-2016, 09:05 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
I meant a pic of your home setup. Just change them all to 80hz. Adjust the bass with a jazz CD.
post #2174 of 2421 Old 08-09-2016, 10:22 AM
Quoted: 189 Post(s)
Liked: 97
Despite appearances, the 7 satellites are far from "identical".
The front 3 (LCR) are 2-way speakers, and the rear 4 feature "full-range" drivers.
post #2175 of 2421 Old 08-09-2016, 10:32 AM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
Thanks, any way to tell the difference since they are all the same size? I'll check the backside of them when I get home and see if it mentions that.
Best,
post #2176 of 2421 Old 08-09-2016, 12:05 PM - Thread Starter
JimWilson's Avatar
Liked: 1616
Dom is correct, they aren't the same. The website says this...
  • dual-woofer center speaker and two dual-woofer front speakers
  • four surround speakers with full-range drivers
What I didn't see is mention of how large those 'woofers' are, so they could be 2" or they could be 4". Given this was a full 7.1 system with AVR, for an MSRP of $650 (with an actual selling price probably closer to $500), my guess is they're 3" drivers. If so, I'm surprised any of them come back with an 80Hz crossover. The 120 and 150 you're seeing is far more plausible, and given the configuration I would definitely expect the surrounds to have a higher setting.
post #2177 of 2421 Old 08-09-2016, 12:14 PM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
What I didn't see is mention of how large those 'woofers' are, so they could be 2" or they could be 4". Given this was a full 7.1 system with AVR, for an MSRP of $650 (with an actual selling price probably closer to $50), my guess is they're 3" drivers. If so, I'm surprised any of them come back with an 80Hz crossover. The 120 and 150 you're seeing is far more plausible, and given the configuration I would definitely expect the surrounds to have a higher setting.
From the owner's manual -
Crossover Adjustment
(40/50/60/70/80/90/100/120/150/200 Hz)
I would think these apply to all Speakers...
Best,
post #2178 of 2421 Old 08-09-2016, 12:19 PM - Thread Starter
JimWilson's Avatar
Liked: 1616
That's a listing of what the receiver can do, not what your particular speakers are capable of.
post #2179 of 2421 Old 08-09-2016, 12:31 PM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
Talking
My bad. Does this help?
The Surround ones are listed as Full-Range Speakers and the Front ones are as follows:
• 4" (10 cm) Cone woofer
• 1" (2.5 cm) Balanced dome tweeter
• Max. input power: 130 W
• 6-ohm impedance
Best,
post #2180 of 2421 Old 08-09-2016, 01:15 PM
Quoted: 189 Post(s)
Liked: 97
• 6-ohm impedance
The rear 4 satellites feature cone drivers that are 8 cm (3-1/4") in diameter:
http://www.manualslib.com/manual/115...0.html?page=70 (see section entitled "Suround/Surround Back Speaker..." > "Drivers unit")
post #2181 of 2421 Old 08-09-2016, 01:38 PM
b0rnarian's Avatar
Quoted: 740 Post(s)
Liked: 255
http://www.manualslib.com/manual/115...0.html?page=70 (see section entitled "Suround/Surround Back Speaker... > Drivers unit")
Should I then set these speakers to Full Band or maybe around 100Hz? OR just stick with the crossover settings that the Receiver dialed-in after Auddessey calibration?
Best,
post #2182 of 2421 Old 08-09-2016, 03:05 PM
Bond 007's Avatar
Liked: 1918
Experiment and use what sounds best. You cant hurt anything.
post #2183 of 2421 Old 08-09-2016, 04:34 PM - Thread Starter
JimWilson's Avatar
Liked: 1616
Anything using a single 3" driver shouldn't really have a crossover below 120Hz, unless you listen at very low volumes. Physics won't let it play much below that point, at least not with any appreciable output (volume). That's probably why Audyseey set them for 150Hz. You can probably get away with 100Hz on the fronts.
post #2184 of 2421 Old 08-09-2016, 04:37 PM
Bond 007's Avatar
Liked: 1918
+1
post #2185 of 2421 Old 08-10-2016, 03:06 PM
Quoted: 189 Post(s)
Liked: 97
Should I then set these speakers to Full Band...
Only if you want to measure the distortion levels.
post #2186 of 2421 Old 08-31-2016, 12:54 PM
Ray
Ray's Avatar
Hey guys, been combing through this thread trying to figure out what I wanted. Thought I would ask for advice based on your experience. So far I think the ultra cheap Dayton Audio sub 8 looked good (for the price especially!)
Room Size: Living room (future), office (right now).
I'm in between living arrangements but plan on moving to a house with a proper living room in 2-3 months. I'd like it to be future proof.
Listening preferences: 90% music / 10% movies and videogames
I don't watch much tv or anything with my setup but will entertain guests every now and then.
Setup: 2.0 right now, only want to jump to 2.1.
I plan to eventually buy a new setup, but I'm undecided if I will move this setup to another room (with the sub) or go the future proof route and integrate the sub into a new setup. My current bookshelf speakers are active monitors and very anemic when it comes to bass. They will definitely be the first to go when I do a full upgrade next year.
Ray is offline
post #2187 of 2421 Old 08-31-2016, 02:40 PM
MIX_MASTER_ICE's Avatar
Quoted: 1224 Post(s)
Liked: 1007
Ray, what is your living room size the sub will be operating in within the next 2-3 months? What is your max budget to spend on a sub?
MIX_MASTER_ICE is offline
post #2188 of 2421 Old 08-31-2016, 03:54 PM - Thread Starter
JimWilson's Avatar
Liked: 1616
The least expensive subwoofer available with the smallest driver you can find isn't a recipe to make your purchase future proof. In reality all it will do is ensure you buy another subwoofer in the (immediate) future.
Ray, MIX_MASTER_ICE and mdram like this.
post #2189 of 2421 Old 08-31-2016, 04:15 PM
Ray
Ray's Avatar
Office is 11.5 x 14
I don't want to spend more than 250 dollars.
I am also willing to trade the "future proof" comment for "this will do for now" based on the price.
and to the other guy, yep, that dayton 8 was wishful thinking.
How are these:
https://www.amazon.com/dp/B008NCD2PC...subtag=WC78310
https://www.amazon.com/BIC-America-H...=bic+subwoofer
Also, one last thing, I'm not a basshead. I don't need skull shaking bass. I like bass, lots of it, but at a moderate volume and with plenty of texture.
Ray is offline
post #2190 of 2421 Old 08-31-2016, 04:27 PM
Liked: 1007
Office is 11.5 x 14
How are these:
Small room, so that's not an issue. For under $250 there are a few good budget subs to pick from. For around $200 the Bic F-12, Polk PSW505 and Dayton sub-1500 are all solid options. Newegg.com still has the Jamo J-12 in dark apple finish for $150. http://www.newegg.com/Product/Produc...-002-_-Product
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
