List of budget subwoofers ($300 and less) - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 335Likes
post #2431 of 2456 Old 03-15-2017, 01:36 PM
TheCarFather's Avatar
Quoted: 58 Post(s)
Liked: 71
Originally Posted by tknx View Post
The small size requirement is because it is going under a computer desk.
I run a Dayton SUB-1000 under my computer desk, I've had it for almost 2yrs now. It's been a great little sub, perfect for computer duties. If called upon it can provide floor shaking output, I was impressed for the low price. Although with that being said, it doesn't play much under 30hz, but that's typical for a sub costing around $100.
My BIC F12's provide more output and easily reach down to 25hz, but they are bigger and twice the price.
TheCarFather is offline
post #2432 of 2456 Old 03-16-2017, 08:52 AM
Liked: 0
I am in the process of moving and looking at options for a replacement sub. I currently have a tsc t-250 sub and it has worked great. I am looking to see if there are any +-$300 options that would be a noticable upgrade.
I have seen many options like the Jamo and BIC 12" subs and have no idea if it would even be an upgrade. Any advice?
TWAR is offline
post #2433 of 2456 Old 03-16-2017, 05:08 PM
Liked: 0
I may have posted my orig post in the wrong spot (saw this link but thought it was for a list of cheap subs - not advice )
I am putting together a budget home theater for a 12x12 room in my basement. I was planning on purchasing a Polk Audio PSW108 sub, per Crutchfield's recommendation. However, I came across a Klipsch SW-450 sub for a similar price at Amazon. On paper they appear to be a lot more bang for your buck, but I gather it is an older model, so are cheaper. I tried to post a link showing a feature comparison, but don't have enough posts to link. Here is general comparison of features:
PSW108/SW-450
Watts: 50/200
Low-Pass Crossover Freq: 80-160 Hz/ 40-150
Frequency Response 40-160 Hz/ 28-120 Hz
I will be using a Denon AVR-S510BT receiver and Polk TL150 satellite speakers. This will be 100% used for movies. I don't need wall shaking bass, but would like a decent home theater sound. Would the Sw-450 be overkill? Would the PSW108 pair better with the Polk Satellite speakers? Does it really matter? I appreciate any recommendations!
slcdawg is offline
post #2434 of 2456 Old 03-16-2017, 06:33 PM - Thread Starter
JimWilson's Avatar
Quoted: 1425 Post(s)
Liked: 1867
PSW108/SW-450
Watts: 50/200
If the manufacturers specifications are accurate - which isn't a given - than the only choice between the Polk and Klipsch sub may very well be the Polk. That's due to the limitations of your speakers though, and not some inherent benefit to that particular subwoofer.
The TL150's speakers use what Polk optimistically calls a woofer, but at 2.5" it's barely a midrange really. If you keep the volume low, on a good day it might have acceptable output to 120Hz. That means your subwoofer will need to handle everything below that, a big ask for something in the budget category. The Klipsch is maxed out by 120Hz, so the lowest the speakers can go is the highest the subwoofer can. That's not a recipe for success.
The Polk PSW108 supposedly can reach 160Hz, but sadly can only manage an anemic 40Hz on the lower end. That leaves a lot to be desired if you only want to play music, but if HT is in your plans it's simply not acceptable. You might be better off considering something like the SVS SB12-NSD. It can reach high enough to work with tiny speakers, yet play low enough to enjoy movies.
Dom Di Stroia likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #2435 of 2456 Old 03-16-2017, 06:37 PM
steve1106's Avatar
Quoted: 591 Post(s)
Liked: 339
PSW108/SW-450
Watts: 50/200
I use a couple of the Polk PSW10 subs up front and they are good for movies/TV/sports, but I did add in a spare BIC F12 to the back of the room to get it out of the way.
http://www.avsforum.com/forum/15-gen...eap-build.html
My width limited HT: Epson HC2000; Screen - 151.5" 16:9/TV or 143.5" 2.35:1/HT at a seating distance of 13/15 feet; Yamaha RXV675 for 7.3; Speakers - Infinity Primus; Subs - 2 Polk PSW10s, 1 BIC F12; Headphones - 4 JVC wireless; Sony 3D Blu-ray player/six pairs 3D glasses.
steve1106 is online now
post #2436 of 2456 Old 03-16-2017, 06:45 PM
Liked: 0
How do you think 2 PSW10's by themselves would be? I could get 2 of those for my price range.
slcdawg is offline
post #2437 of 2456 Old 03-16-2017, 06:56 PM
steve1106's Avatar
Quoted: 591 Post(s)
Liked: 339
I replaced the BIC F12 with the PSW10 and only added the second one months later to raise my towers. They had all the bass I need for movies and I only added the BIC F12 back in to put it to use after sticking it in the garage for months to get rid of a chemical smell it had from day one.
ID:	2031097   Click image for larger version
post #2438 of 2456 Old 03-16-2017, 07:20 PM
Liked: 0
Thank you for the info on the Freq range. That makes sense and I will look for a larger range.
slcdawg is offline
post #2439 of 2456 Old 03-20-2017, 03:15 PM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
Aperion Audio is having a sale and some of the subs are now below the $300 mark.
cyesp likes this.
artur9 is offline
post #2440 of 2456 Old 04-06-2017, 10:20 AM
Nay_Sayer's Avatar
Quoted: 13 Post(s)
Klipsch Sub-12HG Synergy Series 12" 300W Subwoofer $199
http://www.buydig.com/shop/product/K...content=227502
Dom Di Stroia and jasonsong like this.
Nay_Sayer is offline
post #2441 of 2456 Old 04-21-2017, 09:44 AM
majorsfool's Avatar
I just spent all week reading the 80+ pages of this thread for insight into buying a budget subwoofer. I want to thank Jim and all the posters with their stories.
I happen to find a CL deal for a sub no longer manufactured and MSRP out of the $300 limit(Boston XB8), that I'm taking a gamble on. Worse case, I use it upstairs in the game room if it cannot "fill" my basement HT. Then I'll be back to keep up on any <$300 sales and recommendations.
Just wanted to let you'all know that ppl are reading.
Majors -=- Wedoca '17
majorsfool is offline
post #2442 of 2456 Old 04-21-2017, 12:28 PM - Thread Starter
JimWilson's Avatar
Liked: 1867
Thank you for the kind words. You are very tenacious - this is a long thread.
Fingers crossed it works for you!
post #2443 of 2456 Old 04-24-2017, 10:17 AM
majorsfool's Avatar
Yep, listened to late 80's-early 90's bass CD's til 6am Then watched Tron Legacy again, but with 100% more BOOM. Being in a concrete basement definitely loose some resonance (I think that is the term).
When I first hooked it up, it seems I had a bad RCA(?) cord...it works for composite video on a vid capture setup I had but apparently not for this subwoofer. I needed something long since my avr is on a high self. So now that I'm waiting for Monoprice to ship me something, I just coupled two 6' randoms together.
Of course 3 days after I picked up the CL find, a local friend offered to sell me his older Velodyne ULD-15, which I had borrowed years ago. Might have to double up...can't have too much bass.
post #2444 of 2456 Old 04-24-2017, 10:49 AM - Thread Starter
JimWilson's Avatar
Liked: 1867
Doubling up is good. Trying to do it with completely different subwoofers, not so much. That will be a tough challenge to integrate both of them so their summed output is balanced. It will take differences in proximity and some trial-and-error with adjustments. You probably won't be able to do it by ear, so unless you have measurement equipment you might want to rethink that.
post #2445 of 2456 Old 04-27-2017, 12:17 AM
Liked: 1
I ordered the Jamo 110 (I almost ordered the 12 inch but I just don't need it in my small apartment) for $190. From what I can see, it's the Klipsch R110SW. But goes one or two hz lower.
Anyone have this guy?
Nick Johnson is offline
post #2446 of 2456 Old 05-17-2017, 04:31 PM
Liked: 0
I everyone!
I was looking for a budget sub and found this thread.
I'm looking for a sub for a pair of Q acoustics 3020 paired with a Denon AVR-X 1300. I would like SVS but I'm trying to not spend 600€ on a sub.
I've heard about HSU and BIC, they seem to offer good deals but are difficult to find here. I like a deep and accurate bass, not looking for a boomy one. It is for music and movies. Can I get something with this budget or I should save for the SVS?
Salty Peanuts is offline
post #2447 of 2456 Old 05-17-2017, 04:32 PM
Liked: 0
Originally Posted by Salty Peanuts View Post
I everyone!
I didn't mentioned it but I'm trying to keep under the 300€. Thank you.
post #2448 of 2456 Old 05-17-2017, 05:12 PM - Thread Starter
JimWilson's Avatar
Liked: 1867
Where is "here"? Without knowing where you're located it will be difficult to make suggestions as most of the people reading this are in the US and Canada.
post #2449 of 2456 Old 05-17-2017, 06:16 PM
Liked: 0
You're right I'm in southern Europe. It is easy to get it from any EU store with an online store but from other continent is far more complicated.
post #2450 of 2456 Old 05-18-2017, 06:19 AM - Thread Starter
JimWilson's Avatar
Liked: 1867
If you can afford the SVS that would be a good option. They make some nice subwoofers, and I know they have distributors all over the world. Since you can't get HSU or BIC, what other company's are available to you? Are you able to get anything from XTZ?
post #2451 of 2456 Old 05-18-2017, 01:07 PM
Dom Di Stroia's Avatar
Quoted: 195 Post(s)
Liked: 99
I everyone!
Jamo J-12?
https://translate.google.ca/translat...-text=&act=url
http://www.jamo.com/speakers/subwoofer/?sku=J12SUB
A/VR: Sony STR-DE598 (6.1 channels)
L/R + C: 2 x Polk Audio TSx220B + 1 x Boston Acoustics CS 26 II
Subs: BIC RtR RtR-12S + Polk Audio PSW110
Surrounds: 2 x Klipsch Reference R-15M + 1 x Boston Acoustics CS 26 II
Monitor: LG 24EA53V-P (Panel: LG Display AH-IPS)
Display: Sony BRAVIA KDL-48W600B (Panel: S-LCD S-PVA)
Dom Di Stroia is offline
post #2452 of 2456 Old 05-18-2017, 05:19 PM
Liked: 0
Originally Posted by Dom Di Stroia View Post
Jamo J-12?
It seems that there's a XTZ distributor around here. It has a crap site but they're here and in other countries around. Jafo is even better, they are sold by Amazon.
Those anyone have any experience with them? Klipsch has also a few subs within this budget. I've heard both good and bad reviews about their models (like the R-110SW).
Any feedback will be good.
About brands, I have available most of brands. From SVS, Martin Logan, ELAC, Klipsch, Dayton, Boston Acoustics...
Thank you again.
post #2453 of 2456 Old 05-18-2017, 05:33 PM - Thread Starter
JimWilson's Avatar
Liked: 1867
I have a lot of experience with XTZ, not only reviewing their products but I own them as well (AAMOF, I'm listening to some of their speakers at this very moment). They make excellent stuff. If the local distributor has a crappy site you can check out their main site at this link.
As mentioned, SVS deserves consideration. About the only Martin Logan you're likely to get for 300 is the Dynamo 300, but from what I understand it's discontinued so you would have to act fast. Dayton has a good inexpensive unit with the SUB-1200.
post #2454 of 2456 Old 05-19-2017, 07:03 AM
jasonsong's Avatar
Quoted: 430 Post(s)
Liked: 163
The deal seems to be over on their website but their ebay page still sells them for $219. I just picked up one to match what I have.
I thought about the Dayton 15inch at the same price range but I like the Klipsch being more powerful. 300w RMS vs 150w RMS.
7.2: Yamaha RX-A830 | Klipsch Synergy F30 + C20 + Sub12x2 + Onkyo HTIB Surrounds | Epson HC2040 Silver Ticket 120 inch Grey Screen
5.1: Yamaha RX-V475 | Mirage Omni 550 Onkyo HTIB Center + Surrounds + 12 inch Sub | Samsung 55 inch Smart 3DTV
jasonsong is online now
post #2455 of 2456 Old 05-19-2017, 07:08 AM
Quoted: 195 Post(s)
Liked: 99
Thank you again.
Jamo assets are owned by Klipsch Group, and the new Jamo products are engineered by Klipsch. The Jamo J-12 is analogous to the Klipsch R-12SW.
Also: the Dayton SUB-1200 is a proven budget sub.
post #2456 of 2456 Old Today, 03:31 PM
Liked: 0
Any reason why the Klipsch Sub-12HG isn't on the OP?
GamerKingFaiz is online now
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
