List of budget subwoofers ($300 and less) - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
post #2461 of 2482 Old 06-01-2017, 01:37 PM
Dom Di Stroia's Avatar
Quoted: 195 Post(s)
Liked: 100
Originally Posted by Leon O View Post
I just ordered a b-stock Emotiva BasX S8 for desk top use (100% music). Hopefully, I be able to provide some feedback in about a month.
Of course I now realize I also need a subwoofer cable. It seems as though Mediabridge and Monoprice seem to get the most recommendations as budget recommendations.
Are there any other budget subwoofer cables that I should consider, i.e. Tartan?
http://www.cablesalesusa.com/index.p...oducts_id=1285
Leon O likes this.
A/VR: Sony STR-DE598 (6.1 channels)
L/R + C: 2 x Polk Audio TSx220B + 1 x Boston Acoustics CS 26 II
Subs: BIC RtR RtR-12S + Polk Audio PSW110
Surrounds: 2 x Klipsch Reference R-15M + 1 x Boston Acoustics CS 26 II
Monitor: LG 24EA53V-P (Panel: LG Display AH-IPS)
Display: Sony BRAVIA KDL-48W600B (Panel: S-LCD S-PVA)
Dom Di Stroia is online now
post #2462 of 2482 Old 06-01-2017, 06:05 PM - Thread Starter
JimWilson's Avatar
Quoted: 1442 Post(s)
Liked: 1896
I've had good luck with Mediabridge.
yanks1 likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #2463 of 2482 Old 06-02-2017, 04:59 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
Monoprice and mediabridge are both good.
I've had an issue with some monoprice sub cables where they loosen up over time, so i picked up one of these locking type cables. Its a bit more expensive, but I really like the locking feature.
http://www.knukonceptz.com/home-thea...cable-2-meter/
Besides that one cable, I use monoprice, tartan or mediabridge.
kgallerie is online now
post #2464 of 2482 Old 06-02-2017, 05:01 AM
Quoted: 621 Post(s)
Liked: 252
i went mediabridge simply because i ordered it when i ordered the sub from amazon
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is online now
post #2465 of 2482 Old 06-02-2017, 07:42 AM
Bond 007's Avatar
Quoted: 2580 Post(s)
Liked: 2040
They fit way too tightly ime. I actually broke a connector in the back of my receiver once trying to twist one off.
sage11x likes this.
Bond 007 is offline
post #2466 of 2482 Old 06-02-2017, 01:07 PM
Leon O's Avatar
Quoted: 78 Post(s)
Liked: 57
I was feeling adventuresome, so I went with an Auvo. It has a ground wire. I don't plan to ground it, but it might be nice to have around in case one of my subs develops a hum. It would be a tool for trouble shooting.
Leon O is offline
post #2467 of 2482 Old 06-02-2017, 01:33 PM
sage11x's Avatar
Quoted: 962 Post(s)
Liked: 949
Yeah. I ordered a MediaBridge subwoofer cable last time to replace an old Monster cable that was too short. The connector is ridiculously stiff and the cable itself is too which makes it hard to make bends. When I recently needed to add a second cable I took the opportunity to replace the media bridge. Ordered two Amazon Basics cables based on my great experience with their HDMI cables. The Amazon Basics are much more flexible and have a nice, positive fit.
I avoid Monoprice. I know they're a sponsor but I've found their cables to be subpar. They typically just throw a ton of rubber insulation around a standard sized cable and call it a 'premium' cable.
If you want to avoid Amazon I'd check out bluejeancables. A little more expensive but very high quality.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #2468 of 2482 Old 06-02-2017, 05:42 PM - Thread Starter
JimWilson's Avatar
Liked: 1896
All told I have probably a dozen Mediabridge RCA cables, which includes various lengths and several Y adapters. Never had one of them that felt overly snug.
post #2469 of 2482 Old 06-02-2017, 07:29 PM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
is there a sub around the same price and goes as low as the bic america f12?
i have the f12 and its rated down to 25, but its boomy for music.
though im looking for 100% for ht. still im wondering if theres something similar that can handle music a little better.
Luisfc1972 is offline
post #2470 of 2482 Old 06-03-2017, 06:27 AM
sage11x's Avatar
Quoted: 962 Post(s)
Liked: 949
I wouldn't call them snug: more like 'semi-permanent'. Lol! I was sure I was going to damage the plugs on the back of my AVR and subwoofer trying to take them off!
Still better than mono-price though. Couldn't even get the rca plug on it was so tight. Took some pliers to try and gently expand them and the cheap pewter the plugs were made out of just flaked apart. Decided to cut the end off to see about fitting another rca plug and inside I found skimpiest coax I've ever seen surround by a massive outer rubber casing. Seriously, the cable was 90% outer casing.
sage11x is offline
post #2471 of 2482 Old 06-03-2017, 12:08 PM
Bond 007's Avatar
Liked: 2040
Same here.
Bond 007 is offline
post #2472 of 2482 Old 06-03-2017, 11:13 PM
MIX_MASTER_ICE's Avatar
Quoted: 1250 Post(s)
Liked: 1050
The Mediabridge cables can be a bit of a tight fit, but I've had good luck with them. Monoprice I would avoid completely. I've had a few and on one, the end connectors came apart and another one developed a short in it. Belkin makes good sub cables and I've bought a couple of this model and have been very happy. Plus it is inexpensive. https://www.amazon.com/Belkin-PureAV...ubwoofer+cable
They make shorter cables, but I think they are actually priced more than this 25ft cable right now. Even if you don't need 25ft. you can always roll up/tie off the extra. If you want a shorter length cable, the AmazonBasics 15ft. cable is currently only $4.45 as an add on item @amazon .com. https://www.amazon.com/dp/B01D5H8GYG...ding=UTF8&th=1
Leon O and Dom Di Stroia like this.
Game Room>Vivitek 1080p projector w/100" screen/ Hisense 65" 4K w/HDR10, Onkyo TX-NR656 receiver, Klipsch KF-28 L/R, KC-25 center, KB-15 sides, Loft 40 rears, RBH I-12/e (x2), I-12 (x2) subs. Living Room>Samsung 59" Plasma, Onkyo HT-RC560 receiver, Primus P363 L/R, P163 center, Polk RC60i in-wall rears, SVS PB12-NSD (x2) subs. PC set up> Pioneer VSX-524, Pioneer BS22, SVS PC12-NSD (x2) subs. Game Systems> PS4 Slim, PS4, PS3, XBox One S, XBox One, XBox 360, Wii.
MIX_MASTER_ICE is online now
post #2473 of 2482 Old 06-03-2017, 11:20 PM
Liked: 1050
Assuming a price of around 200 bones for the F12, you aren't going to get anything substantially better. This is budget sub territory, which means these subs will have similar flaws and shortcomings.
The Jamo J-112 has been available the past few months for under $200 and would be a step above the F12. However, it's now only available in white finish and priced at $219.99. In this price range it's about as good as it gets. I had a couple of them in dark apple finish, but recently sold them. http://www.ebay.com/itm/Jamo-a-Klips...YAAOSw4A5YnPIx
post #2474 of 2482 Old 06-05-2017, 06:34 AM
Quoted: 621 Post(s)
Liked: 252
possibly the sub12hg
its still found @ 200
best atm is 220 on ebay
https://www.ebay.com/i/311763065127?chn=ps&dispItem=1
Newbie789 likes this.
service - directv
(slow build out)
mdram is online now
post #2475 of 2482 Old 06-05-2017, 08:07 AM
Bond 007's Avatar
Liked: 2040
12HG will destroy the F12 in every way. Ive owned both.
Bond 007 is offline
post #2476 of 2482 Old 06-08-2017, 09:12 AM
Leon O's Avatar
Quoted: 78 Post(s)
Liked: 57
It is probably premature for me to comment, but I received the Emotiva BasX S8 two days ago. I set it up to accompany new desktop speakers (Airmotiv B1's). I found the sub integrated best using a 60hz crossover. Other than setting the crossover and level, I have not had time for critical tweaking and listening. I still in the process of breaking in the speakers/sub.
My FIRST impression is that the BasX S8 does a fine job at its task filling in the range from 30hz to 60hz. That additional support is enough to add the desired tight rumble in lower range of an electric bass. It also allowed for reasonably seamless transitions from the upper to lower ranges of the walking basslines of an upright bass. Tubas and orchestral bass drums also seem reasonably realistic. In my 14,000 cubic foot space, the BasX S8 has plenty of output to play at moderate levels (and get snide comments from the Mrs.). To be fair, my use is primarily desk top. Even so, I think in small to medium sized rooms, the little BasX sub will provide enough support to the low end for an enjoyable music experience.
It probably will not be the right choice for HT enthusiasts looking to maximize explosions, aircraft, deep bass sweeps etc.
Leon O is offline
post #2477 of 2482 Old 06-11-2017, 02:15 PM
Quoted: 27 Post(s)
Liked: 2
Where did you find B-Stock Emotiva? I must be missing it on the website
porkcereal is online now
post #2478 of 2482 Old 06-12-2017, 06:50 AM
Leon O's Avatar
Quoted: 78 Post(s)
Liked: 57
I emailed Emotiva directly through the sales link on the help page of the website. You can also call Emotiva to inquire.
I emailed with a couple questions and got a response to the first very quickly. A couple days later, I got a follow-up letting me know a b-stock became available. Given Emotiva's new pricing policy, the firm is remaining rigid with regard to is listed prices. B-stocks appear to be going at about a 10% discount. B-stocks can only be returned for warranty issues.
So far, few BasX S8 b-stocks have been available. I imagine it is because the S8 is so impressive for its price. Listening to Godsmack's self-titled album on CD, the S8 was very impactful. Listening nearfield in a 14,000 cubic foot space the cross over was set at 60hz and the subwoofer trim was a couple DB hot. I found the bass lines and various bass notes to be tight and powerfull with an intensity that matched the music.
Leon O is offline
post #2479 of 2482 Old 06-12-2017, 07:04 AM
Quoted: 27 Post(s)
Liked: 2
Cool, thanks. Thinking of going with 2 with the Phil aam setup.
Sent from my SAMSUNG-SM-G935A using Tapatalk
post #2480 of 2482 Old 06-12-2017, 09:26 AM
Leon O's Avatar
Quoted: 78 Post(s)
Liked: 57
With free shipping to you, you may want to order just one at first to see it it meets your needs. Otherwise you would have to pay to return two units.
While a second S8 should allow you to have nice, smoothed bass in a modest music system, for a mostly HT system you may want to consider some of the larger sub options that have more extension and output. The RSL Speedwoofer 10S and SVS NSD 12 have been selling around $400, the price of 2 BasX8's.
I am trying to be fully transparent because I have not tried the S8 with Movies, or even for music with my living room system. For 200 bucks, though, it performs above my expectations.
Leon O is offline
post #2481 of 2482 Old Yesterday, 06:35 PM - Thread Starter
JimWilson's Avatar
Liked: 1896
Updated/corrected/enhanced/fixed 3,256 links.
OK, so maybe that was an exaggeration. I did make a lot of changes though. If you find something broken let me know.
Dom Di Stroia likes this.
post #2482 of 2482 Old Today, 06:01 AM
Quoted: 195 Post(s)
Liked: 100
Last I checked, that AmazonBasics 15-ft. subwoofer cable was selling for USD 1.98:
https://www.amazon.com/dp/B01D5H8GYG/
Since May 19, 2017, the price has fallen gradually from USD 8.99:
https://camelcamelcamel.com/AmazonBa...uct/B01D5H8GYG
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
