n00b sub speaker replacement Q - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-02-2011, 01:29 PM - Thread Starter
karrank%'s Avatar
Apologies if this has been posted elsewhere/already--couldn't find anything related.
Have an old KLH ASW10-120B sub (hope you didn't just spurt milk out your nose) whose speaker has just blown. EXTREMELY limited budget, so I disassembled to confirm that the baffle(?) between the cone and magnet has perforated. No busted caps or anything-- visual inspection of the amp didn't reveal any probs.
SO-- assuming I'm satisfied with this sub (I set the bar low around here as you might imagine) does anyone have recommendations for replacing the speaker? I was looking over at partsexpress and found a couple that would seem to fit the bill
http://www.parts-express.com/pe/show...number=295-486
http://www.parts-express.com/pe/show...number=295-202
The first one looks almost EXACTLY like the one I'm to replace.
-anyway, thanks for looking.
karrank% is offline
