Floorstanding or bookshelf with a good sub? - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2011, 09:23 AM - Thread Starter
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I'm looking into getting 3 LCR speakers for my fronts and a good quality sub (HSU,Rhythmik,SVS,...). I'm considering getting 3 LCR's for all 3 or two floorstanders and a center. The room is 24'x16' 3500 ft^3.
The thing I like about bookshelf is I can put them on a shelf (duh). It means the floor is less cluttered.
Floorstanding seems like you get more bang (and bass) for the buck.
All things being equal, I would prefer bookshelf.
If I have a good sub, is there any advantage to having floorstanding speakers?
KidHorn is offline
Old 10-12-2011, 09:33 AM
flickhtguru's Avatar
Liked: 110
Other than the fact that some floorstanders have more drivers than their bookshelf counterparts and the fact that floorstanders will dig deeper in bass, no i guess there isn't an advantage. I want floorstanders because I want the extra head room for the bass and I love the look of floorstanders. Floorstanders may let you xover the speakers at say 60hz to the sub instead of maybe 80hz with LCRs.
Shawn
flickhtguru is offline
Old 10-12-2011, 10:43 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
It really depends on which standmount and which floorstander your comparing. generally If its from the same brand / series then the FS would have more mid bass, low bass would be the same as you would be cutting over to the sub.
qguy is offline
Old 10-13-2011, 05:12 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Because I had two ported 15" subwoofers in a relatively small HT room, I used bookshelves as my replacement for a large floorstanding system. The 10+ year old floorstanding went to a beach house.
Some bookshelves that you might consider are the SHO-10 or PRO-10 from Chase Home Theater (new models are scheduled), the new offerings from eD, or speakers like the JTR8s. All are very efficient and play very loudly.
The floorstanding from Klipsch, Polk, and Infinity (all recommended in this forum) will play louder than their closely related bookshelves.
wwinkler is offline
Old 10-13-2011, 06:34 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Then you will need sealed or front-ported bookshelves, as most bookshelves can not be placed on bookshelves due to rear ports and the need for distance to rear wall.
I have 3 Kef iQ3 front-ported bookshelves as my front with a Rythmik F12 sub and iQ1 as rears and it is wonderful.
rick240 is offline
Old 10-13-2011, 07:43 AM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
What is best for you is determined by your space. In other words what you have for available positioning of speakers. As others said, often times you get larger (or more) drivers in floor standing speakers, so you get a little more output in the mid bass and low end. This in turn helps to make sure that you do not have a hole in the response at the subwoofer crossover point. Another thing to consider when looking at floor standing speakers is the construction of the cabinet. With some companies, the difference between their book shelf speakers and their floor standing speakers is mainly just a larger cabinet. In these cases, you need to consider that the larger cabinet may not be braced as well as the smaller speaker.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 10-13-2011, 08:52 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
I would add that you have already sidestepped the problem that many people have with their budget allocation by asking this question. Prioritizing towers makes sense in a speaker setup where music will be a priority, but not as much for HT. I see a lot of people on the AVS speaker forum who are building a 5.1 setup primarily for HT who are not balancing the need for a strong center and good subwoofer in an HT setup. Many people who are doing that would be better to shift their spending to a slightly better speaker line by buying monitor/bookshelves with a better center (or LCR speakers), and then spend more money on the sub.
And I think part of this problem comes because they forget that when buying a sub, one is purchasing a speaker AND a built-in amplifier. Subs take a substantial portion of a budget.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 10-13-2011, 12:36 PM - Thread Starter
KidHorn's Avatar
Liked: 877
I'll check out the Kef's.
I was thinking of getting 3 energy RC-LCR's
http://www.energy-speakers.com/na-en...-lcr-overview/
and plug the rear ports
or
3 emotiva ERM 6.2
http://emotiva.com/erm62.shtm
They're sealed.
Both of these are on the large size for bookshelves so hopefully they'll have something in the 50-100Hz area. I'm not even sure if they would be called bookshelves, but as far as I'm concerned, if they can be placed on a bookshelf, they're bookshelves.
KidHorn is offline
