SUBFEST 2011-HuskerOmaha and Desertdome's Subwoofer Showdown - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 553 Old 10-24-2011, 10:03 AM
desertdome's Avatar
Quoted: 1303 Post(s)
Liked: 1513
Here are the measurements for the Chase Home Theater SS18.2. Time to EQ = 6 minutes. Since the SS18.2 was the only sealed sub without its own amp it gave me a chance to try the Linkwitz Transform in JRiver. I was able to make adjustments on the fly while watching the RTA in order to get the flattest extension. The total time to EQ includes fiddling with the Linkwitz Transform. I'm sure it is at least as fast and easy to adjust as the Marchand Bassis.
For some reason REW did not remove the dip at 40 Hz. It removed it for all the other subs so I just reran the filters in REW for the measurement and now it gives me different filters and the dip is removed. At the time I thought it was because the sub was a single, but I see the dip was able to be EQ'd out somewhat from the other single subs.
High Impact AV
desertdome is offline
post #32 of 553 Old 10-24-2011, 10:04 AM
desertdome's Avatar
Liked: 1513
Here are the measurements for the dual JTR Speakers Captivator Pros. Total time to EQ = 3.75 minutes.
High Impact AV
post #33 of 553 Old 10-24-2011, 10:04 AM
desertdome's Avatar
Liked: 1513
Here are the measurements for the Seaton Submersive HP. Total time to EQ = 4.5 minutes.
High Impact AV
post #34 of 553 Old 10-24-2011, 10:05 AM
desertdome's Avatar
Liked: 1513
Here are the measurements for the Dual CHT VS18.1's. Total time to EQ = 4 minutes.
High Impact AV
post #35 of 553 Old 10-24-2011, 10:05 AM
desertdome's Avatar
Liked: 1513
Finally, the Danley DTS-10/JTR Speakers Growler measurements. Total time to EQ = 21 minutes. For the DTS-10 we used a 35 Hz low pass. The Growler had a 40 Hz high pass. We could adjust these on the fly to find the best interaction. We then matched the levels and finally had REW generate the EQ filters.
High Impact AV
post #36 of 553 Old 10-24-2011, 10:07 AM
Archaea's Avatar
Quoted: 3078 Post(s)
Liked: 2700
Originally Posted by flafonta View Post
There are some strange ratings of "1" and "4" for the Caps and Submersive on BlackHawk Down and Cloverfield. Looks like typos...
One of the guys marked every clip a 1 for BlackHawk down, because he said he didn't feel bass on any of the subs and didn't want to grade on what he didn't like/didn't hear/didn't feel. He was consitent and we double checked his score sheet when tallying to verify he didn't throw any of the scores. He consitently rated most things low across the board. Some people were generous with their scores, some people were stingy with their scores, but all seemed reasonable. We had three people double checking the scores as we transcribed them into excel - HuskerOmaha, KCNitro07, and myself. I doubt there were any typos, or we all three missed it. Greg has all the score sheets still and can verify anything as needed. We appreciate your observation and as Greg has said - he has no problem with any call outs like this.
Originally Posted by pbc View Post
Those were Craig's ratings...
ha, but no.
None of the vendors voted. Craig spent most of the time upstairs hanging out watching football because he didn't want to influence the ratings in any way, and sadly not many of the attendees were there all day to vote either.
I talked to him on a couple occassions and he asked me how this or that audition went, but he never provided any counter to my impressions - just absorbed them. He told some stories of some of the meets he had held in the past. He was very very cool about that from the beginning and it was very clear he felt none of the vendors should have any involvement.
Archaea is offline
post #37 of 553 Old 10-24-2011, 10:21 AM
BiGBADDABOOM's Avatar
Threw this together for my own amusement, thought I'd post it in case someone else wanted to look at the scores another way. Props on all the data acquired guys, sounds like it was a lot of fun. Can't wait to see some more pics?
Archaea likes this.
BiGBADDABOOM is offline
post #38 of 553 Old 10-24-2011, 10:32 AM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
ha, but no.
I think some of the problem with the black hawk down clip was that the bass in the track was like 10-15hz and could not be heard over the higher frequencies in the track.
stormwind13 is offline
post #39 of 553 Old 10-24-2011, 10:33 AM
carp's Avatar
Quoted: 2818 Post(s)
Liked: 2125
I'm surprised the Rythmic didn't score higher for music. I've never heard one but they have a very good reputation.
carp is offline
post #40 of 553 Old 10-24-2011, 12:06 PM
Matman1970's Avatar
Liked: 27
I believe it was a DIY build and Dr Spankenstein also mentioned there was a level problem that affected the Rythmic and was corrected after.
__________________________
Originally Posted by jagzjagz
Holy smokes. A simple question turned into a buck wild display of thoughts, gazillion graphs, multiple interpretations, philosophies, and overall mayhem!!
Matman1970 is offline
post #41 of 553 Old 10-24-2011, 12:09 PM
desertdome's Avatar
Liked: 1513
I just finished my post on "Method of EQing." At the end I noted that we had the levels too low for the BIC, Rhythmic, and eD. This could have affected some of the scores and regrettably can't be changed now. The room was also too big for the Rythmic. For example, there were several times the driver was moving back and forth with high excursion but we couldn't hear anything. It was like the sound was being sucked up. If you moved close it sounded very good. I thought it was very articulate for music, but I think its output capability in the room hurt its score.
I didn't participate in the scoring, but I had heard the playlist more than anyone since it is pretty much all I have listened to for the past week. I also picked out the first four music selections and had a good feel of what I was looking for. I think it took a few times of listening for the participants to get a feel of what the differences were and how subs handled the musical tracks.
High Impact AV
post #42 of 553 Old 10-24-2011, 01:18 PM - Thread Starter
HuskerOmaha's Avatar
Quoted: 65 Post(s)
Liked: 55
[quote=BiGBADDABOOM;21119876]Threw this together for my own amusement, thought I'd post it in case someone else wanted to look at the scores another way. Props on all the data acquired guys, sounds like it was a lot of fun. Can't wait to see some more pics?
Thanks for posting that, but can you modify with huge letters really distinguishing what you did more, like unofficial scores, etc? I'm just assuming someone will run with those second ones and assume those are the scores and not randomly assigned 10-9-8, etc.
Technosponge and his pictures are incoming. I'd rather have him post them, though I do have copies of all saved as well.
Desertdome, where is the post saved for explaining why you used Subdudes for your Turbos but none of the other subs got them; skewing the results to move your Turbos past the F20s?
HuskerOmaha is offline
post #43 of 553 Old 10-24-2011, 01:24 PM
Dr. Spankenstein's Avatar
Quoted: 101 Post(s)
Liked: 69
I was wondering HOW long it would take for that to bubble up.
You two are like an old married couple...
Do my ears hear the distant cry of: "DO OVER!"?
JVC X750R, 133" DaLite HP (2.8 gain), OPPO UDP 203
Denon X4300H, DIYSoundGroup Fusion 15 L/C/R, Mirage FS V2 Surround, Mirage Omnisat V1 Surround/Atmos
Dr. Spankenstein is offline
post #44 of 553 Old 10-24-2011, 01:32 PM
desertdome's Avatar
Liked: 1513
Based on some listening tests I did, the Turbos actually sounded worse in your tiny home theater when on the Subdudes. Seaton wanted me to run them that way to eliminate some of the competition for his Submersive. Since he designed the cabinet and driver, I acquiesced.
High Impact AV
post #45 of 553 Old 10-24-2011, 01:36 PM
I just dropped it to relieve confusion. It was interesting to glance at rankings to see how they fell without having to shuffle them in my head. I would also believe that humans are more precise at perceiving a preference of one versus another than they would assigning a numeric value to the relative performances. So it was another way of averaging the same data. If someone wants to see that they can PM me.
I'll keep an eye out for Technosponge's pictures then; looking forward to them, thanks!
What measurable difference would a Subdude have, was that obtained? I've always seen them as a way to decouple the sub and it's vibrations from the flooring/room. If anything, there'd be a subjective performance drop due to less tactile effects reaching listeners, no?
post #46 of 553 Old 10-24-2011, 02:52 PM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
The SubMersive HP has two modes/dsp. Anyone know which one was used at the Showdown?
The below quote was taken from the Seaton Sound Forum:
PGM SEL set to IN (program 1) = original SubMersive response: +/-3dB 19-200Hz
PGM SEL set to OUT (program 2) = secondary, extended SubMersive HP response: +/-3dB 15-200Hz.
Bunga99 is offline
post #47 of 553 Old 10-24-2011, 02:55 PM
yadfgp's Avatar
Quoted: 66 Post(s)
Liked: 68
Another mode question, . The new CHT VS18.1's have a 15hz mode and a 19hz mode right? Leaving 1 slot open gives you 15hz, leaving both open gives you 19hz? If so how'd you guys have them set up? Thanks!
yadfgp is offline
post #48 of 553 Old 10-24-2011, 02:59 PM
forin's Avatar
Quoted: 13 Post(s)
Liked: 24
Awesome write up!
About the DTS-10 problem, did it sound similar to this?
http://www.youtube.com/watch?v=JK7VR-LKD_A
Forin
forin is offline
post #49 of 553 Old 10-24-2011, 03:04 PM
desertdome's Avatar
Liked: 1513
I believe it was the 15 Hz tune.
We had both ports open.
High Impact AV
post #50 of 553 Old 10-24-2011, 03:18 PM
desertdome's Avatar
Liked: 1513
Here are all subs before EQ and after EQ:
High Impact AV
post #51 of 553 Old 10-24-2011, 03:20 PM
Curious about the identical roll-off on the sealed Chase vs the vented? VS & SS overlaid:
post #52 of 553 Old 10-24-2011, 03:33 PM
desertdome's Avatar
Liked: 1513
kwarny, I enjoyed the write up you just posted. I wish I could have listened from the front row.
High Impact AV
post #53 of 553 Old 10-24-2011, 03:44 PM
kwarny's Avatar
Thanks. I just wish I had a few more hours to proofread . I didn't really think the Rythmik sounded much different then it does at even lower volumes. Some say that it has a dry sound but I wouldn't really call it that. If I was girl and didn't get stuck with having to pay for an engagement ring, I would build three more boxes so I could have two push pull systems to see the difference it would make in HuskerOmaha's versus the dual CHT SS 18.1s. It just feels like I need to run an experiment to test my hypothesis haha.
The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge - Stephen Hawking
Kyle Bosso - SOB
kwarny is offline
post #54 of 553 Old 10-24-2011, 03:52 PM
desertdome's Avatar
Liked: 1513
The MCCA Turbos had the same rolloff. All three setups used Dayton SA1000 amps. It could be that the amp has a built-in high pass. I hooked up these subs myself to the amps and checked to make sure the subsonic filter was off. The Turbos' amps had been modified by Sandbagger to have a high pass, but the Daytons used with the CHT subs were stock amps.
The sealed amp had the bass boost on before we applied the Linkwitz Transform in JRiver. I wonder if the boost causes the amp to rolloff earlier. I'll have to experiment with my quad dual opposed sealed that I built using the MFW-15 drivers.
We had many other amps available (Face, Lab Gruppen, Behringer, Crown) but didn't have time to try any. We had wanted to try several different amps with the CHT SS.
High Impact AV
post #55 of 553 Old 10-24-2011, 04:10 PM
Mark Seaton's Avatar
Quoted: 682 Post(s)
Liked: 1838
Correct. It looked good with the standard mode to the teens, and I probably would have left it there if we were not EQ'ing the system with desertdome's setup, but the 2nd DSP mode gave a nicer starting point for the EQ below 20Hz. The difference in response of the two modes is only about 3.4-3.8dB below 20Hz.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #56 of 553 Old 10-24-2011, 04:31 PM
benclement11's Avatar
I'm a little surprised the Rythmik fared slightly better in the ranking than the BIC F12. I went from BIC F12 to Rythmik F15 and the difference seems quite a bit better...not even in the same league better.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #57 of 553 Old 10-24-2011, 06:38 PM - Thread Starter
Quoted: 65 Post(s)
Liked: 55
Kyle you are so confusing. Are you saying you are getting engaged? You are welcome to come over whenever and compare and we can try and measure-and then when we fail we can call Michael to come over and measure.
post #58 of 553 Old 10-24-2011, 06:39 PM - Thread Starter
Quoted: 65 Post(s)
Liked: 55
1) The Rythmik was a DIY box and not ID.
2) I scored them fairly close, I'm working on posting my results and write up
post #59 of 553 Old 10-24-2011, 06:50 PM
kwarny's Avatar
That is what I am saying. All of my money is focused on the ring now so no free cash. She did state tonight that she would love to buy 3 more kits sometime after Christmas. Haha that sounds about right. I know I won't ever bring a pair of my speakers up to your place after Saturday night .
Kyle Bosso - SOB
kwarny is offline
post #60 of 553 Old 10-24-2011, 07:30 PM
tesseract67's Avatar
I have the same sub set up as HO, in a different room. Bring your Rythmik, I have 3 pairs of mains to choose from and you can bring our own, too. You are invited, nothing formal, just listening and fun.
"Women and cats will do as they please, and men and dogs should relax and get used to the idea." -Robert A. Heinlein
tesseract67 is offline
