BIC PL-200 Audyssey settings. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-24-2011, 03:22 PM - Thread Starter
swt_guy's Avatar
Hi,
I am getting ready to run the Audyssey on my new Denon AVR-1912. I have BIC-PL 200 as the sub and Polk 85I as the front, center and the surrounds. I would like to know what should be the settings on the sub should be when I run the audyssey ? I am not sure what direct mode is. this is what I see in the DENON 1912 manual.
** When using a subwoofer with a direct mode
Set the direct mode to On and disable the volume adjustment
and crossover frequency setting.
** When using a subwoofer without a direct mode
Make the following settings:
Volume : 12 o'clock position
Crossover frequency : Maximum/Highest Frequency
Low pass filter : Off
Standby mode : Off
Please advice.
swt_guy is offline
post #2 of 6 Old 11-10-2012, 07:35 AM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 42
Sorry to bump old topic, but I would like to know also
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is online now
post #3 of 6 Old 11-11-2012, 02:34 PM
spddy101's Avatar
From the sounds of it, "direct mode" may be a feature on only specific subs and lets the receiver control volume 100%. The PL-200 doesn't have direct mode so I would just follow the second set of instructions. Many people suggest instead of putting the volume at the 12 o'clock position, put your subwoofer gain in a position such that Audyssey adjusts the sub level by less than +-1dB (this may take some trial and error).
spddy101 is offline
post #4 of 6 Old 02-18-2013, 07:50 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
I'm going to be going through the same thing w/ my Denon AVR-591 towards the end of the week.
So, volume at 12 o'clock and frequency at the highest point is what I should be doing?
Gaming hard from October thru April.
Samsung 60KS8000
Xbox One S
PS4 Pro
Astro A50s (2nd Gen)
s1njin is online now
post #5 of 6 Old 02-18-2013, 09:28 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Thats a good place to start, lets say you run the auto cal, and on the avr, it sets the trim to plus 10, that means that the subwoofers gain is to low, and visa bersa, if the avr sets the trim at -10, then the gain on the sub is to high, what you want to have is, find the right gain on the sub, so that the trim on the avr is at zero. Hope this helps.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #6 of 6 Old 02-18-2013, 12:07 PM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Thank you. So if the AVR is compensating for sub's 12 o'clock, play w/ the volume until the AVR isn't compensating one way or the other.
Do I always keep the frequency up to the highest point? Or is the frequency more a matter of taste?
Samsung 60KS8000
Xbox One S
PS4 Pro
