Official Power Sound Audio Subwoofer Thread - Page 1012 - AVS Forum | Home Theater Discussions And Reviews
 31350Likes
post #30331 of 36985 Old 12-19-2016, 05:45 PM
mattboyer's Avatar
Quoted: 32 Post(s)
Liked: 52
Originally Posted by ss nimrod View Post
Okay I know I saw this question answered in this thread, but I can't find it.
The V1800 is not seeing / getting enough juice from the AVR to take it out of the standby mode if i remember correctly?
The receiver is not/sometimes picking up the sub...
Ran the Room correction once, didn't see the sub. Rebot the AV receiver, sub "clicked" on, Re-ran the room correction, AVR recognized the Sub on the first pass, did not recognized the sub in the next two passes, no sub listed on the AVR.
The V1800 is set per instructions, left LFE input, gain, cross over, etc. red light is "on" on the amp
I did send a message to PSA, just looking to get the sub running tonight
If you've got a splitter you can plug in both the L/R inputs to get a little extra boost in to the amp to maybe help trigger it. I'd also check that you have your speakers set to small and subwoofer on/enabled to make sure it's sending the right signal to your sub.
It really shouldn't take much to wake it up it so there could be a setting off right now.
Also check your LFE setting in the AVR and crank up its output until you get it triggering. You can also turn up your AVR's listening volume. If I listen to music quietly it doesn't kick on the sub, but if I go loud...
Enjoying Atmos, DTS:X, & a quad dose of PSA these days.
mattboyer is offline
post #30332 of 36985 Old 12-19-2016, 05:45 PM
zeuspaul's Avatar
Quoted: 73 Post(s)
Liked: 82
Is the power set to on or auto? If you just want to run the auto setup putting the switch to on should let you do that. Once you get it set up you can address the auto on issue. What AVR do you have?
PSA MTM-210T front, MTM-210C center
PSA MTM-210T surrounds, PSA MT-110 rears, Atmos / Canton bookshelf x2, PSA MT-110 x2
PSA V1800 , PSA V1801
Marantz SR7009 AVR & Emotiva A-100 stereo amp
Panasonic 65ST60 Plasma, Oppo BDP 93, DirecTV, HBO, Starz, Showtime
zeuspaul is offline
post #30333 of 36985 Old 12-19-2016, 05:52 PM
Kini62's Avatar
Quoted: 1717 Post(s)
Liked: 1532
If you have an RCA splitter try running it to both left and right inputs. Don't know what AVR you have but if it has two sub outs they may be just one actual sub internally connected in which case you could run another RCA to the right input to achieve the same thing as using a splitter/y adapter.
Also, you could just leave the sub on and not in auto standby until you get the auto standby function sorted.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #30334 of 36985 Old 12-19-2016, 06:10 PM
Quoted: 73 Post(s)
Liked: 370
Thanks for the replies.
I missed my window to calibrate the sub, my wife came home, we have 2 rescue dogs, an 80 pound pit bull and a 100 pound Cane Corso.
The dogs are very happy (and spoiled) to see their mommy so the noise level in the house is far to high now.
Did switch the sub to on and we'll see where that goes.
In terms of a AVR, have an Onkyo TX-SR705.
Will talk to Tom at PSA tomorrow, I'm sure he'll get me where I need to be
ss nimrod is offline
post #30335 of 36985 Old 12-19-2016, 07:22 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
How come I read this thread and want more subs. Eh now I want 2 more xv15s
Holiday121 is offline
post #30336 of 36985 Old 12-20-2016, 06:07 AM
Bill Kentucky's Avatar
Quoted: 274 Post(s)
Liked: 262
There's some magical property in this thread. I'm not sure what page it crept in on, but it works it's magic on you by the time you're done reading.
newc33 likes this.
__________________________
Current setup: PSA MT-110 L/R, PSA MT-110c center, PSA MT-110sr surround, Dual PSA v3600 subs, Denon x4200w Receiver
Bill Kentucky is offline
post #30337 of 36985 Old 12-20-2016, 06:32 AM
Quoted: 80 Post(s)
Liked: 51
Hey everyone! I posted here a while back while I was mulling over some PSA subs, but couldn't make a decision as there were hang ups in my condo construction and I had no idea where my cable was going to be. Now that is is nearing it's end (hopefully!), I wanted to come back and ask for some advice. Please see the pictures I've attached to see where the TV is going to be roughly mounted (shown by the red star in the floor plan- will prob be closer to middle of the wall) and where I'm thinking the sub should go (shown by the blue star in floor plan and bump out in room). The pictures from inside the condo are also attached.
I had always been debating between the 15V and the V1500, but that was before I realized I was going to have about ~16ft ceilings. That's a ton of space to fill with bass, especially since it is open to the kitchen, and entryway. Many folks have said I should go with 2 subs, but I wouldn't be able to afford that out of the gate- it would have to be later, if at all, and would also have to pass the WAF (or in this case girlfriend).
Keeping in mind that I might go dual down the line, does the V1500 really offer *that* much more than the 15V? Should I be looking at maybe an S1500 or S1800 instead? I also don't want to be a *huge* jerk to my neighbors, though that might be unavoidable .
Appreciate your thoughts!
Name:	Family Room1.jpg
ID:	1842825   Click image for larger version
Name:	Family Room2.jpg
ID:	1842833   Click image for larger version
Name:	Floor Layout.PNG
Marantz SR5010, Chane A5s, Chane A2.4, UN65KS8000
AudioNewGuy is online now
post #30338 of 36985 Old 12-20-2016, 06:41 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
The 15v is a bit smaller and does not give up much...maybe 1-2db below 20hz and a little extension. It's the better buy right now while on sale for 899.00. Single S15/1800 would not be wise for that space with action oriented movies at spirited levels. You need a T18HT for that space for sealed and even then I would still opt for a V3600i.
Da hell with the Neighbors!!
ahblaza, newc33, Hopinater and 1 others like this.
basshead81 is offline
post #30339 of 36985 Old 12-20-2016, 07:04 AM
Quoted: 274 Post(s)
Liked: 262
I think the 15v makes a nicer looking end table too, helps with the WAF. Dual 15v gets my vote!
vardo and AudioNewGuy like this.
post #30340 of 36985 Old 12-20-2016, 07:23 AM
Quoted: 67 Post(s)
Hi, I still can't decide between the v1800 and the s3000i, I was wondering if the v1800 is able to go deep enough to play some scenes like the beginning of Edge of Tomorrow or the deep charge scene in U-571 or the server room in Pulse.... Or I need to go sealed to play those? Thanks in advance.
Jonathan P.
Jonathan Pacheco Vasquez is offline
post #30341 of 36985 Old 12-20-2016, 07:29 AM
Quoted: 80 Post(s)
Liked: 51
Thanks guys! So, I'm still learning what you fine folks mean when referring to extension and what typical hz levels are- I'm a bit of a noob! So with that said, how low do movies typically get- you know for explosion & gunfire scenes, etc? Does that level change if it is standard definition versus cable HD, Blu-Ray and 4K?
** edits-- really the only way to describe what I like in terms of bass, is feeling my butt rumble in my seat, feeling that "punch" in your chest during a fight scene or the deep hit on a rap song. I imagine the 15V and V1500 would both get to those levels?
post #30342 of 36985 Old 12-20-2016, 07:36 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Jonathan P.
yes the v1800 will go deep enough...sealed has the potential to dig deeper but you still need enough output to make use of the extension...room gain can help depending how large the room is look up the equal loudness curve.
post #30343 of 36985 Old 12-20-2016, 07:42 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
punch in your chest is centered around 80hz, rap music is mainly 40-60hz, rumble in the seat is 25-35hz....20hz and lower is a added weight that adds pressure and vibrations through out the room. most bass is above 30hz, but it's nice to have a sub that is strong to 16hz that way it can handle some off those deep passages without much strain...hence why ported is very popular in most HT rooms that utilize 1-2 subs for the extra efficiency down around port tune.
ss nimrod and AudioNewGuy like this.
post #30344 of 36985 Old 12-20-2016, 07:57 AM
Quoted: 80 Post(s)
Liked: 51
Thanks Basshead!! Lastly, just so I can have all my bases covered- my speakers are rated as below:
Frequency Response: 50Hz-25kHz +/- 3dB
Low Frequency cutoff: 41Hz -6dB
Does this mean, when I do add the sub to my collection- I would want to set the crossover (where the sub starts doing more and more work for the lower frequencies right) at about 80hz?
Really appreciate all the help!
post #30345 of 36985 Old 12-20-2016, 08:23 AM
Hopinater's Avatar
Quoted: 2284 Post(s)
Liked: 5680
Yes… What you will want to do is make sure you set your speakers to small (even if they are towers) and then set your cross over at 80Hz. You can also experiment with others cross overs like 90 or 100 and see if you like that better.
I agree with Basshead, I would not look at the sealed subs in your situation due to all the open area you have and I would probably go with the 15V especially at it's current price.
When it comes to movies and bass you will really kick yourself if you settle for subs that can't go down to at least 20 (and preferably 16) Hz. It may not account for the majority of the movie material but when it's there you really want to have subs that allow you to enjoy it.
AudioNewGuy likes this.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
post #30346 of 36985 Old 12-20-2016, 08:43 AM
Quoted: 67 Post(s)
Thats a really nice info to have... Thanks. I was always wondering what frequencies affect "what" in my room because some times I feel my chair moving and some times the room is the one rumbling or the windows in the next room.
post #30347 of 36985 Old 12-20-2016, 08:53 AM
Quoted: 67 Post(s)
Thanks, the room is a dedicated room 2400cf. Right know I have an XS15se but want something bigger with more tactile feel something that hat really punch you during the movie, the room usage is 90-95% movies so maybe ported is the way to go... I was afraid to loose those low frequencies but if the ported V1800 is capable of that is a really good candidate for my upgrade.
post #30348 of 36985 Old 12-20-2016, 09:00 AM
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1234
Jonathan P.
I've had several ported and sealed subs. You won't gain much going sealed if your room is large and or open. In fact you will lose performance in most cases. What was your room size again? And is it open? To benefit from a s3000i you will probably need a smaller sealed room medium sealed at the most.
The v1800 should be fine with EOT. You will defiantly hear it as most of what your hearing isn't actually 10hz content anyway. For instance I have played around with my rythmik lv12r and it plays the beginning of EOT with noticeable output. The v1800 will stomp the lv12r so I'm sure it would be plenty for you.
I havent seen u571 (ya and I consider myself a bass head ) so I can't comment on that. I'd have see a graph or know just how low it plays.
Do you have any prior subs?
EDIT- I missed bass heads response and your clarification on room size and prior subs.
I think the v1800 will be a great choice for you
Sent from my SAMSUNG-SM-G935A using Tapatalk
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
post #30349 of 36985 Old 12-20-2016, 09:01 AM
Hopinater's Avatar
Liked: 5680
Yeah that V1800 is no joke, it should give you some decent punch. If I were you I would contact Tom to see about getting in on the new V1801 and see what the introductory price will be. That sub looks to be geared to deliver more power below 30 Hz than the V1800.
post #30350 of 36985 Old 12-20-2016, 09:32 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
I think you would notice a substantial improvement. +6-8db in the 16-50hz range! It will basically have double the output...well worth the trade off of loosing a little extension.
post #30351 of 36985 Old 12-20-2016, 10:25 AM
lizrussspike's Avatar
Quoted: 659 Post(s)
Liked: 794
Originally Posted by Hopinater View Post
Okay the Oppo 203 has arrived. I know this is a PSA subwoofer thread but since some here are considering ordering this unit I'll leave a quick review.
First off let me state that this thing screams quality. The unit itself is built like a tank (made of metal not plastic) and looks neat and sharp.
The packaging is excellent, in fact I think it may be packaged with the same material that PSA uses for it's speakers and subs. If I didnt know better I would swear that this came from PSA. The player even comes in it's own Oppo carrying tote that can be reused for other things if you want.
The manual is a thick book printed on high quality paper and it is very very thorough. It covers everything… in detail. It should answer all your questions and then some.
The 203 comes with a certified 4 foot HDCP 2.2 HDMI cable which is good because this unit is larger than my last blu-ray player so I had to move it's location to a point that is a little farther from my receiver and the 2 foot cable I had could not reach. Nice unexpected touch which allowed me to play with this today instead of running out to buy a longer cable.
The remote does light up but it takes picking it up or a push of a button to make it do so. Once lit it stays lit for 5 seconds. If you decide that is annoying you can disable it with the push of two buttons.
It came with a data disc with the latest firmware update. I suggest using it right away before you do any set up or tweaking because they suggest resetting to factory defaults after you update so you might as well do it first before you tweak anything.
Once I set up the network connection I didn't really see a need to tweak anything else because the defaults seem to be what I would set things to. But I'll take a deeper look at that once I play with it more.
Once I had everything ready I threw in my new 4K UHD disc of "The Martian". My first impression is WOW! The picture is stunningly beautiful. The Samsung itself already does a nice job of up converting most pictures but the Oppo playing 4k content takes it to another level (as it should). The details and colors are absolutely incredible…. it's mesmerizing.
Regarding the audio… I feel like the audio on this player is better, markedly better, than my older Sony player. I may be imagining this because everything about the experience today was great but I really believe the audio is that much better. I don't know how to describe the improvement but it's there and it's obvious.
I've include a picture of the packaging, the bag and the Oppo 203 in it's new home (it's the one in the middle that says "Home Menu").
Nice review Hopinater! They are built like a tank. Makes me want to order one even more. Just the sort of thing that some us want to hear. I believe that Jeffrey has one coming as well. I too thought that upgrading to an Oppo(103d) made the PSA speakers appreciated even more. Looks like some bugs to fix, but have you tried anything from a server or PC for movies that you may or may not have backed up? Now you can work on your ATMOS.....
Hopinater likes this.
lizrussspike is offline
post #30352 of 36985 Old 12-20-2016, 10:38 AM
Tom Ames's Avatar
Quoted: 42 Post(s)
Liked: 70
I will second JD Smoothie. Send him a PM with what you want and your price range. He'll make it happen. He went above and beyond helping me a couple months ago. He must have taken customer service training from Tom, they're both the reason I bought from them (seriously, top notch service).
Third this.
I called him a couple of years back and after several minutes of very pleasant conversation, he advised me to order the out-going year's model (as it met my needs just as well) from Amazon which his company didn't stock any longer. Can't beat that for integrity!
ss nimrod likes this.
Tom Ames is offline
post #30353 of 36985 Old 12-20-2016, 12:48 PM
Kini62's Avatar
Liked: 1532
Read his review too. To me this is a lot like drug tests with placebos. Tell them it's helping or better and they believe it. Not saying the Oppo is not better in some ways over the typical blueray player but I would be interested in seeing a blind or double blind test for audio and video.
Unless the Oppo is running the darbee add on I can't "see " it having a better picture or audio than any other player.
We need a blueray player get together shoot out.
Schwa and hlnoiku like this.
Def Tech SC8000
Kini62 is offline
post #30354 of 36985 Old 12-20-2016, 02:47 PM
ahblaza's Avatar
Quoted: 1862 Post(s)
Liked: 2058
Yeah Russ mine will be here tomorrow, looking forward to getting it, customer service has been very good so far with Oppo and I don't have the player yet. Didn't hear about any bugs that you described, any particular areas that need debugging. I guess the firmware updates are done with the data disc or is that for initial setup and future upgrades are done via download?
I'm expecting the picture quality to be top notch via the new video processor with capabilties for both HDR10 now and Dolby Vision early 2017, I don't know of any players capable of both formats yet and only high end Sony TVs as well. I'm just excited that I have a universal player that can handle just about any format out there and have to start building my library soon. I also like the 7.1 analog outputs which are auto engaged by default and can down mix to 2.1 stereo analog. Thanks Jim for the pics and mini review.
Just curious is that legit with the Denon 4300 at Fry's, no good to me as I don't have one around here, I can get it at OneCall for $1200 but after hearing $799 that's crazy. If anybody talks to JD let me know what he can do, never mind I'll just do it
Hopinater and bear123 like this.
ahblaza is offline
post #30355 of 36985 Old 12-20-2016, 03:41 PM
Hopinater's Avatar
Liked: 5680
Well I can see where you're coming from but then again that's true for this whole hobby in a lot of cases. I will say that for me this was little to no money out of pocket so I don't feel particularly compelled to convince myself that it's a lot better than my Sony blu-ray which I really like and have moved to the upstairs set up. I also think you missed the point. I wasn't just reviewing the Oppo, I was reviewing the new 4K Oppo while it was playing a 4K disc. I'll put a 4k player playing 4K discs on a 4K TV up against a blu-ray playing blu-rays on a standard 1080P without a second of hesitation.
So if you're saying that Oppo blu-ray players aren't any better than a Sony or Samsung (or whatever) blu-ray player and therefore aren't worth the extra cash… I have no problem with that. We each decide where we want to invest our money. Some buy separates others think that's a waste. To each their own. But if you're trying to tell me that a blu-ray player can produce the same picture quality as a 4K player… I'll have to disagree. On that note, perhaps the Samsung 4K player does as good of a job as the Oppo, I hope it does. My point wasn't to say that Oppo was better than everybody else (and I'm pretty sure I didn't say that) my point was to share just how good of a job the Oppo does so those who are interested in the 203 can get some sort of idea about it. Personally I couldn't care less what 4K player anybody buys.
As far as build quality, I'll take the Oppo over the others from what I've seen.
post #30356 of 36985 Old 12-20-2016, 03:45 PM
Kini62's Avatar
Liked: 1532
So if you're saying that Oppo blu-ray players aren't any better than a Sony or Samsung (or whatever) blu-ray player and therefore aren't worth the extra cash… I have no problem with that. We each decide where we want to invest our money. Some buy separates others think that's a waste. To each their own. But if you're trying to tell me that a blu-ray player can produce the same picture quality of a 4K player… I'll have to disagree. Perhaps the Samsung 4K player does as good of a job as the Oppo, I hope it does. My point wasn't to say that Oppo was better than everybody else (and I'm pretty sure I didn't say that) my point was to share just how good of a job the Oppo does so those who are interested in the 203 can get some sort of idea about it. Personally I couldn't care less what 4K player anybody buys.
As far as build quality, I'll take the Oppo over the others.
missed the 4k part.
What TV do you have?
If my AVR "ever" dies I might make the move to 4K but don't want to do a projector and would like at least an 80" screen. So far the 80" and up are still a little pricey.
Def Tech SC8000
Kini62 is offline
post #30357 of 36985 Old 12-20-2016, 03:54 PM
Hopinater's Avatar
Liked: 5680
missed the 4k part.
I have the Samsung 65KS9000 which I got for a steal at a Crutchfield Tent sale. Kini I have to say that going to a 4K TV was the move I'm most happy with. It takes normal source material and upscales the brightness and vividness of the picture to a point where it almost appears to be 4k. I got my 4K TV while I still had an older AVR (Denon CI3313) and it worked fine with the new Samsung.
I was hoping to get a 75 to 80" 4K TV but as you said, they are pricey…outrageously pricey. I was hoping they would come down but they still hover up there in high cost. To give you an idea, I got the Samsung for $1500 where as a 80" would have cost exponentially more.
post #30358 of 36985 Old 12-20-2016, 03:56 PM
Hopinater's Avatar
Liked: 5680
@lizrussspike I haven't found a bug yet. I think they probably just made a firmware update because they tweaked something post production.
post #30359 of 36985 Old 12-20-2016, 04:01 PM
Kini62's Avatar
Liked: 1532
Costco had what seemed like a good deal on BF, a Samsung 75" 4K, not sure of the model for $2K.
My AVR won't pass a 4K signal but I guess the 4K upscaling would be a nice benefit. Now if only the Sony XB850 85" comes down to under $3K I'll be good. Like that'll ever happen anytime soon.
Def Tech SC8000
Kini62 is offline
post #30360 of 36985 Old 12-20-2016, 06:09 PM
ahblaza's Avatar
Liked: 2058
Thanks Jim, that's good to know, I think it's best to ask what this player doesn't do rather then what it does. That really looks good in your rack, very nice indeed.........
What are you using for 4K streaming, the 203 has an HDMI input for streaming devices to take advantage of the 203's audio and video internal processing.
https://www.oppodigital.com/blu-ray-...-Features.aspx
ahblaza is offline
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s7201 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
