Official Power Sound Audio Subwoofer Thread - Page 1195 - AVS Forum | Home Theater Discussions And Reviews
 31362Likes
post #35821 of 36991 Old 08-15-2017, 02:49 PM
imureh's Avatar
Quoted: 793 Post(s)
Liked: 670
Originally Posted by climber07 View Post
Thank you very much.
Tom said the box is 41x27x60. That's going to be a tight turn for 300 lbs. The landing isn't very big.
I would unbox is downstairs and then take it up. The boxes are harder to grip and may shave off few inches that may come in handy. I did that with a couple of mine and it did help.
imureh is online now
post #35822 of 36991 Old 08-15-2017, 02:57 PM
chucky7's Avatar
Quoted: 1788 Post(s)
Liked: 1959
I would rather wear gloves. The box will protect it from scrapes and nicks.
climber07 likes this.
Panasonic TC-P55UT50
Pioneer SC-1222-K
Polk Audio LSiM703 / LSiM706c / RTiA3
JTR Captivator 1400
chucky7 is online now
post #35823 of 36991 Old 08-15-2017, 03:07 PM
chucky7's Avatar
Liked: 1959
This might be helpful... https://www.amazon.com/Forearm-Forkl...6GQ50878VG5ER8
Pioneer SC-1222-K
JTR Captivator 1400
post #35824 of 36991 Old 08-15-2017, 03:09 PM
subacabra's Avatar
Quoted: 520 Post(s)
Liked: 871
Until one knucklehead trips and takes the whole enchilada down the stairs with them lol
subacabra is online now
post #35825 of 36991 Old 08-15-2017, 03:13 PM
imureh's Avatar
Quoted: 793 Post(s)
Liked: 670
What would gloves do with an awkward shaped box? Whatever works for you dude. I found it easier without the box. The inches I saved prevented the subs from bumps.
post #35826 of 36991 Old 08-15-2017, 03:17 PM
Mike Butny's Avatar
Quoted: 565 Post(s)
Liked: 998
Originally Posted by ahblaza View Post
Exactly, and I just found out I'll have to use an appliance or furniture dolly to get it down the stairs as the bottom part of the box is just a shelf liner and won't support the weight of the sub, the pallet does that. It's a very intelligent way to ship these subs and makes for really easy unboxing, but then you have to deal with 300 pounds, that's 14 pounds less than double my weight. Yes I'm a strapping 157 pound soaking wet weakling.
So yes the smile was a knowing one of a fairy tale story..........
How many stairs? If you don't feel comfortable I would try and get a neighbor to come over, lay the box down and while you and your neighbor/helper is in front of the box, let the box slide down the stairs while you and your helper have your arms extended applying resistance. I know the S3600I is around 150lbs shipped? I can easily slide it down 10 wooden stairs.
You are going down stairs and not up? Correct?
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & S3000I subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is online now
post #35827 of 36991 Old 08-15-2017, 03:28 PM
chucky7's Avatar
Liked: 1959
In this case, the S7201 is going have to be carried upright. So the inches what you suggested will save won't matter that much.
Pioneer SC-1222-K
JTR Captivator 1400
post #35828 of 36991 Old 08-15-2017, 05:08 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Originally Posted by David Charles View Post
I'd like to see how the v3601 stacks up against the new 7201. I'm sure the new sub would beat it up bad above 40 hz, but would be interested to see how the ported sub fairs below 40 hz. With my v3601 being for sale for 1500.00 (local only), id be relatively inclined to see how the big brother would do in my rooms "sweet spot." Tempting
V3601 and S7201 will be close in the 15-40hz cea2010. Above and below that the S7201 should pull away. I give Tactile Response edge to the V3601, but the S7201 is not going to have no chance of vent noise...I think the S7201 would be a substantial upgrade being the V3601's vent noise is offensive to you.
healthnut likes this.
basshead81 is offline
post #35829 of 36991 Old 08-15-2017, 05:22 PM
gbreda's Avatar
Quoted: 461 Post(s)
Liked: 706
Maybe the S7201 should be shipped with one of these
Hell I have taken 500LB copiers up and down a flight of stairs by myself with these things. Although for climber, even with one of these things the tight landing is going to be a beatch
http://escalera.com/models/
gbreda is offline
post #35830 of 36991 Old 08-15-2017, 05:36 PM
ahblaza's Avatar
Quoted: 1862 Post(s)
Liked: 2058
Originally Posted by Mike Butny View Post
How many stairs? If you don't feel comfortable I would try and get a neighbor to come over, lay the box down and while in you and your neighbor/helper is in front of the box, let the box slide down the stairs while you and your helper have your arms extended applying resistance. I know the S3600I is around 150lbs shipped? I can easily slide it down 10 wooden stairs.
That's the problem, can't use the box to move the 7201, wanted to let Climber know as well. The main support for the sub is the pallet, it has a card board tray that it sits in with cardboard sides and a pull off top, so it's not really a box like the smaller subs are shipped in. I asked Jim how wide the box was so I could see if I could slide the whole thing down my stairs, about 13. He replied that I can't do it like that because of the way it's shipped. He did say I may be able to slide it down on the bottom tray with the help of at least two people. So there it is........I do have an appliance dolly like I said so I'm not worried and I won't be moving it anyway.
I guess once it's down here it must stay...........
ahblaza is offline
post #35831 of 36991 Old 08-15-2017, 05:53 PM
climber07's Avatar
Quoted: 595 Post(s)
Liked: 1938
300 lbs. UP 16 stairs for me man. I may wrap the cardboard around the sub and slide it from landing to landing at an angle. I'll engineer something.
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is online now
post #35832 of 36991 Old 08-15-2017, 06:01 PM
fastninja76's Avatar
Quoted: 236 Post(s)
Liked: 198
Just a though here...
Depending on how much time and energy it's going to cost you to do this without damaging anything, it might be worth a twelve pack and 100 bucks to pick up some help at the local home depot. Just sayin!
Sent from my SM-G950U using Tapatalk
Yamaha RX-A 1060
Emotiva BASX A3
Polk Audio RTi A9
Polk Audio CSi A6
PSA V1801
LG 55B6 OLED
fastninja76 is online now
post #35833 of 36991 Old 08-15-2017, 06:08 PM
torii's Avatar
Quoted: 1479 Post(s)
Liked: 794
I hope you are not planning on using wife and/or younger children to help...that sounds risky given the weight size of sub and that pic. Hope you find a safe way.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #35834 of 36991 Old 08-15-2017, 06:10 PM
subacabra's Avatar
Quoted: 520 Post(s)
Liked: 871
Alien Covenant up tonight. Sounding amazing even at somewhat lower volume bc lil guy is sleeping upstairs.
He told me I should watch Power Rangers instead lol
Nah
mdanderson and Mike Butny like this.
post #35835 of 36991 Old 08-15-2017, 07:13 PM
climber07's Avatar
Quoted: 595 Post(s)
Liked: 1938
Improvise, adapt, and overcome. We are a tough family. I will assure you all that I will exercise sound judgement with safety as a primary concern.
The good thing about the design of the S7201 is that all but one side (amp side) are strong and protected. Plus, the Baltic birch plywood is much more structurally stable and rigid than MDF.
ahblaza and torii like this.
post #35836 of 36991 Old 08-16-2017, 03:31 AM
femi's Avatar
Quoted: 138 Post(s)
Liked: 156
Hey @climber07 , have you thought about hiring some movers?
Your stairs are can of similar to my stairs & it was a pain moving 4 JTR OS LFU's(weight 225lbs each) up the stairs, a little easy down the stairs. Alot harder moving 2 Cap4000's(weight 265lbs each) up the stairs.
What help me and my friend was a dolly. I think it would had been alot easier if it was 3 of us moving them.
I hope you not planning on moving S7201(weight 300lbs) by yourself? If you are, please be careful because it could be dangerous for you and your family.
Anyway good luck with whatever way you come up with moving it and i can't wait to hear your impressions.
Femi
chucky7 and climber07 like this.
(2)JTR Cap 4000---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---Darbee Darblet DVP-5000---Harmony 1100 remote
femi is offline
post #35837 of 36991 Old 08-16-2017, 05:45 AM
mdameron's Avatar
Quoted: 77 Post(s)
Liked: 81
I had a bunch of fun (no sarcasm) testing the two 15Vs with REW last night. My first foray into REW.
1) Found best spot for sub 1
2) Found best spot for sub 2
3) Ran sweeps over and over, adjusting delay each time until I found the sweet spot in the FR.
Sound about right?
Unfortunately that took me to midnight so I didn't get to test it with a movie. I'll post the chart later. Best I could do is a slight null at 70hz. Audyssey might be able to fix that with EQ. But, I typically like a 60hz crossover on the mains anyway, so it may be a very minor issue.
And yeah... with no delay, I was getting epic cancellations. Quieter than single sub. And several sub placement spots in my room are awful, lol.
Mike Butny and Hopinater like this.
Denon 1911
LCR: Polk RTiA7, CSiA6
Front height: 8" Monoprice in-ceiling
Rear: 6.5" Monoprice in-ceiling
Sub: PSA 15V x2
mdameron is offline
post #35838 of 36991 Old 08-16-2017, 05:52 AM
Rolls Troyce's Avatar
Quoted: 18 Post(s)
Vent noise is why I avoid vented boxes in my car and house.
Hear: Front: SVS Ultra Towers, Center: SVS Ultra Center, Sides & Rear: SVS Ultra Bookshelves, 4 Ceilings: JBL Arena 81C
See: LeEco uMax85
Think: Denon AVR-X6300H
Feel: Power Sound Audio S7201
Rolls Troyce is offline
post #35839 of 36991 Old 08-16-2017, 06:10 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
I like ported and have never experienced vent noise with my 15v's. However some owners have experienced it with the slot vent on the 01 series subs running them really hot with heavy bass material below 20hz. That is why this S7201 should be awesome. V3601 level bass down low with no chance of port noise all the way up to it's limits.
If PSA would allow different placement option on the amp so you could lay it length ways with the manifold firing up I think more folks could accommodate this sub. I could place one directly behind my couch and I probably would of been on the preorder list for one. It's just too big to be placed anywhere else in my room otherwise.
Hopinater likes this.
post #35840 of 36991 Old 08-16-2017, 07:11 AM
Hopinater's Avatar
Quoted: 2284 Post(s)
Liked: 5680
I posted this over in the new S7201 thread but I meant to post it here so I'll just post it here as well.
I never really thought about it before but it just occurred to me that Tom really goes out of his way to keep us up to date on everything... from plans, to development, to orders. I think I've kind of just taken this for granted. But thinking back through the years he often posts where PSA stands with inventory, order status, etc. They certainly don't have to do this but they do and it's incredibly helpful if one is thinking about the timing for ordering a sub. Especially during pre-orders with the release of a new product.
I don't know of any other company that cares enough to take time out of their busy schedule to keep their customers this well informed. I also think it's really cool that Tom and Jim are always willing to keep us up to date visually, with the sharing of photos. I think this really builds a sense of trust with PSA.
Thanks to both Tom and Jim for taking the time to do all this.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #35841 of 36991 Old 08-16-2017, 07:20 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
I agree...just wish Tom would post his subwoofer pron pics in HD instead of Tater cam. lol
post #35842 of 36991 Old 08-16-2017, 07:28 AM
Hopinater's Avatar
Liked: 5680
Basshead I agree with you. I wouldn't have been in on the preorder because I've had zero port noise with the V3601's and I'm perfectly content. But for those who have, this sub could really be a great answer for them. And the icing on the cake is you get something like 6 to 8 dB increase over the V3601 above 40 Hz and it will also dig deeper (I better stop talking or I might order one).
I could also see where being able to stick the S7201 right behind a couch might possibly make accommodating a sub of this size much more doable for many more people. Just imagine, four 18" drivers right behind the MLP, firing right into the couch. How delicious is that? And correct me if I'm wrong but near field subs take some of the initial room interaction out of the equation as well. Sounds very tempting.
post #35843 of 36991 Old 08-16-2017, 09:48 AM
Tom Vodhanel's Avatar
Quoted: 2017 Post(s)
Liked: 5979
That would be a nice-to-have, agreed. But the math doesn't work out.
Tom V.
Power Sound Audio
“Quality isn't expensive, it is priceless" --- fortune cookie
Tom Vodhanel is online now
post #35844 of 36991 Old 08-16-2017, 09:49 AM
Liked: 5979
Sound about right?
If time allows post all of the FR. I bet many would find the before(major cancellations) as interesting as the after..
Tom V.
Power Sound Audio
ahblaza likes this.
post #35845 of 36991 Old 08-16-2017, 01:43 PM
gamelover360's Avatar
Quoted: 16 Post(s)
Originally mistakenly posted this in the 7201 thread. So I wanted to get this in the correct thread.
I am planning a living room 5.2.4 setup with a 65 inch tv. Still some time away but I like to plan ahead. It will be a 2700 square foot one story fairy open floor plan. Link to floor plan(http://www.highlandhomes.com/dfw/pro...-60s/270-543-A).
I am pretty sure that I will go with PSA dual subs. I am in a bit of a pickle, albeit an amazing pickle to be in. My wife is supportive of 4 floor standing towers for FR, FL, SR, and SL. 😲
The towers will be the Klipsch reference premiere with built in up firing speakers. She has also OK'ed dual subs.....with the stipulation that they both be on the front wall with the tv and front speakers or one front wall and one behind the couch "hidden" under a sofa table.
So I was looking at dual S3000i's figuring I could experiment with both up front or one front and one behind the couch.
But here is the kicker and the pickle ......she also OK'ed dual V3601's😱😱😋.
The thing is they would need to be on the front wall and behind the couch is a non starter. I could experiment a little with placement such as inside front towers or outside, but I lose the extra placement option of one behind the couch.
So you can see my predicament. The HT guy in me says be sensible and get the 3000i so you gain a placement option, but the sub lover reptilian part of my brain is like " dude, if your wife is allowing dual V3601's to enter your home, you need to make that happen.....who cares if they had to stay in the garage, they would be yours and on the premises! "
I will have a receiver with xt32 and SUB HT. I am really torn hear..... common sense of gaining one more placement option or take the dual refrigerators and run! If I go with the V3601's and there is a terrible null that audyssey can't compensate for I would be disappointed. On the other hand if I get the S3000i's and there isn't a
terrible null that audyssey can't compensate for I would be disappointed because I could have had two bass fridges flanking my mains!
Thoughts?
Mike Butny and sk373 like this.
gamelover360 is offline
post #35846 of 36991 Old 08-16-2017, 02:55 PM
mthomas47's Avatar
Quoted: 3358 Post(s)
Liked: 4904
So I was looking at dual 3000i's figuring I could experiment with both up front or one front and one behind the couch.
But here is the kicker and the pickle ......she also OK'ed dual 3601's😱😱😋.
So you can see my predicament. The HT guy in me says be sensible and get the 3000i so you gain a placement option, but the sub lover reptilian part of my brain is like " dude, if your wife is allowing dual 3601's to enter your home, you need to make that happen.....who cares if they had to stay in the garage, they would be yours and on the premises! "
I will have a receiver with xt32 and SUB HT. I am really torn hear..... common sense of gaining one more placement option or take the dual refrigerators and run! If I go with the 3601's and there is a terrible null that audyssey can't compensate for I would be disappointed. On the other hand if I get the 3000i's and there isn't a
Thoughts?
Hi,
As you said this is a pretty good pickle to be in. Does your wife have any sisters? In one respect, dual S3601's would seem like a no-brainer, but let me throw in another wrinkle. If the front-back arrangement yields a good frequency response, you might also really enjoy having a nearfield sub. Several recent posters have been talking about the benefits of being able to potentially put an S7201 nearfield, but I think that the same advantages would exist with a 3000i. I certainly enjoy having a nearfield sub.
If you are sure that you won't be able to fit an S3601 behind the sofa (perhaps on its side?) then flexibility in positioning for frequency response might not be the only factor to consider. The S3000i's might also offer the nearfield advantage. Of course, you could always get the S3601's for the front soundstage now, and hope to negotiate for a rear nearfield S3000i, or the equivalent (S1801?), later. Sorry for planting that evil thought.
Mike
Alan P likes this.
mthomas47 is online now
post #35847 of 36991 Old 08-16-2017, 03:30 PM
Alan P's Avatar
Quoted: 5083 Post(s)
Liked: 3771
I like how Mike thinks.
I just wanted to point out that testing with nearfield, dual-opposed designs has apparently found that the tactile response was greatly reduced (something to do with the science of DO subs that I don't fully understand). If you were to go with a nearfield sub at some point in the future, I would recommend a single driver design.
I would also be remiss if I did not recommend you getting ported subs over sealed.* That's a pretty large space to fill and ported will give tons more TR over sealed (if you enjoy that sort of thing) along with more headroom.
*You didn't specify which 3601 you were looking at, if it is indeed the "V", then nevermind. I assume it is the "S" since you are also considering the S3000.
Alan P is offline
post #35848 of 36991 Old 08-16-2017, 04:53 PM
Pulloutchamp's Avatar
Quoted: 301 Post(s)
Liked: 414
Everytime I see those lifters things , I cant help of thinking of these....lol
Sharp Aquos Q+ 70" UQ
Onkyo Tx-nr646
Klipsch RP-280F (F/R towers) RP-250C (Center)
Polk Towers (rear surround)
SVS Elevations (Front Height)
2 PSA V1801 1 PSA V1500 Xbox1
Pulloutchamp is offline
post #35849 of 36991 Old 08-16-2017, 05:24 PM
jarretc's Avatar
Quoted: 20 Post(s)
Liked: 163
Good thing you are not in Central Cali or I would take you up on that offer.......
Denon X4000
Power Sound Audio (MT-110 / MTM-210C / MT-110)
Oppo BDP-103
Dual Power Sound Audio Triaxes
Sony KDL60W630B
jarretc is offline
post #35850 of 36991 Old 08-16-2017, 07:04 PM
mdameron's Avatar
Quoted: 77 Post(s)
Liked: 81
Tom V.
Power Sound Audio
Here we go. Two shades of blue are the individual runs. The red is the combined response with no delay. The green is combined response with delay on the near sub.
I'm still playing with it though.
EDIT: OMG, and I am still learning. That 70 dip is likely due to a crossover LOL. I had everything else set to default (distance, audyssey off, levels, etc), but hadn't set all speakers to large yet. Basically disregard that graph LOL.
Denon 1911
Sub: PSA 15V x2
mdameron is offline
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s7201 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
