Official Power Sound Audio Subwoofer Thread - Page 420 - AVS Forum | Home Theater Discussions And Reviews
 22425Likes
Old 07-03-2014, 12:18 PM
Alan P's Avatar
Quoted: 4694 Post(s)
Liked: 3321
Originally Posted by climber07 View Post
If they are stacked and the phase is 180 out, then yes, they are wired out of phase. Pop off the amp and check the wires.
But, do I have to?
Unless it would somehow improve the sound, I'd rather not go mucking about inside the subs.
Alan P is online now
Old 07-03-2014, 12:28 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Originally Posted by Alan P View Post
But, do I have to?
It's my OCD... LOL
Being a Marine and a tech, it would drive me absolutely crazy not knowing.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is online now
Old 07-03-2014, 12:31 PM
cableguy301's Avatar
Quoted: 75 Post(s)
Liked: 64
Originally Posted by Magibeg View Post
I actually haven't. I'll go buy one (I need another one anyway because I'm moving in about a week). Wouldn't be the first time I've been thwarted by a cable. I could also consider a Y split to plug into both inputs, i doubt it would help but i really want to cover all bases.
don't think its your cable if it works on the other sub..
what is the phase set at.. ? put at 0 or 180...
good luck eh.. did you ask tom?
Magibeg likes this.
cableguy301 is offline
Old 07-03-2014, 12:33 PM
Quoted: 75 Post(s)
Liked: 64
But, do I have to?
I have 2 subs going onto a truck soon .. going to be a long wait.. xs15se
is it a good Idea to sit them beside each other to check the phase?
cheers
Old 07-03-2014, 12:44 PM
Alan P's Avatar
Liked: 3321
Wouldn't be a bad idea, but I'm pretty sure my situation is the exception, not the rule.
Old 07-03-2014, 12:45 PM
Alan P's Avatar
Liked: 3321
It's my OCD... LOL
Yeah, you're right....I'll probably end up having to open 'em up.
Old 07-03-2014, 12:50 PM
Magibeg's Avatar
Quoted: 282 Post(s)
Liked: 129
Tried 0 and 180 for the phase but didn't appear to do anything. Talked to Tom this afternoon. He's a pretty awesome guy so I'm certain a solution will be found. I'm feeling optimistic for tonight!
Magibeg is offline
Old 07-03-2014, 01:20 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Magibeg,
After running your Audyssey calibration, did you check to make sure that your other speakers are set to "small"?
When I calibrate my system, my AVR sets my speakers to "large". After completing the calibration, I must go into the menu and change them to "small", otherwise my sub would not receive any re-directed bass from the other channels. This is an entirely separate menu from the crossover settings, so it could be easy to miss.
cableguy301 likes this.
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS4, PS3, Sony BDP-S6200,
Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
Old 07-03-2014, 01:53 PM
Magibeg's Avatar
Quoted: 282 Post(s)
Liked: 129
Originally Posted by tboe77 View Post
Magibeg,
I actually don't think I have that option but I'll double check with the manual. I recall only having the option to set my speakers to full range and then adjust at 10hz intervals. That could be an option with the Audyssey XT32
Magibeg is offline
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
I think most of the obvious stuff was sorted out when Magibeg said that he can unhook the XV15 and hook up the PL-200 and have instant bass. That tells me the cable is good and the audyssey settings are close enough. Might be a amp calibration issue.
basshead81 is offline
Old 07-03-2014, 01:56 PM
Quoted: 75 Post(s)
Liked: 64
yeah you need the speaker to be small.. even if they are large...
still would be lfe content to the sub tho...
cheers..
Magibeg likes this.
Old 07-03-2014, 02:00 PM
Magibeg's Avatar
Quoted: 282 Post(s)
Liked: 129
cheers..
Unfortunately they're not set to full range though, just the option is there. Choices for me and my limited version of audyssey are from full range to 120hz cross over i believe (with mine being set to 80hz).
edit - Checked my manual
Speaker Configuration
With these settings, you can specify which speakers are connected and a crossover frequency for each speaker. The following crossover frequencies can be specified: “Full Band”, “40Hz”, “50Hz”, “60Hz”, “70Hz”, “80Hz(THX)”, “90Hz”, “100Hz”, “120Hz”, “150Hz”, or “200Hz”. Specify “Full Band” for speakers that can output low frequency bass sounds adequately, for example, speakers with a good sized woofer. For smaller speakers, specify a crossover frequency."
Magibeg is offline
Old 07-03-2014, 02:19 PM
Alan P's Avatar
Liked: 3321
Yeah, on your AVR if it's set to anything other than "Full Band" they are set to "small". You got it right.
Magibeg likes this.
Old 07-03-2014, 02:33 PM
Billy p's Avatar
Quoted: 300 Post(s)
Liked: 662
Well I stopped by PSA this morning met Jim and exchanged my old drive units for the SE version. I didn't have a lot of time to stick around and met Tom but in the end it was nice to see the shop and check things out. I saw some interesting things while I was there...anyhow....I can't wait to get home and set up my XS30 with the new drivers...I didn't want to waste to much of Jim's time but I now see why he is called him the "quiet one"...lol.
I'll post some pics once we arrived home...this trip certainly had its bumps...but going from home to Boston with a stopover at friends in Longmeadow, MA then Fenway, Baltimore and finally Pittsburgh. Today we drove to Grove City for some shopping and Mineral Ridge OH...I'm beat. I'll take a cab this evenings game at PNC park....I estimate we've travelled about 2500 km so far and leaving for home tomorrow AM.
I hope you all have a great July 4th long weekend....
All the best...
Ps: This note is for Raynist...we checked out the Thai food place on Western Av and it was legit!!
Thanks again for the suggestion...
Bill....
dsrussell likes this.
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
Old 07-03-2014, 04:31 PM
raynist's Avatar
Quoted: 1256 Post(s)
Liked: 1194
All the best...
Bill....
Great!
I just ate there for lunch yesterday.
Enjoy the game tonight!! Let's go bucs!!
Billy p likes this.
raynist is offline
Old 07-03-2014, 05:08 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1037
Oh? Can you please explain these interesting little things in great full length detail
Reefdvr27 is offline
Old 07-03-2014, 05:36 PM
Kazz063's Avatar
Quoted: 56 Post(s)
Liked: 70
Originally Posted by ahblaza View Post
Karen what brand is your ET center and where did you get? How much ?
Thank you so much
Cheers Jeffrey
I had the ET unit made to order at a local furniture manufacturer cost me about $800, however I'm in Australia so that's probably of no help to you.
Cheers, Karen
Kazz063 is offline
Old 07-03-2014, 05:39 PM
Kazz063's Avatar
Quoted: 56 Post(s)
Liked: 70
Originally Posted by Reefdvr27 View Post
How do you like your mini split?
I wired one for my theater, however I won't be able to install it till last. Do you notice any noise that affects your audio? I really have no choice but to add a mini split as it will be very hard to run an AC line to my room. I actually like the idea of the unit as I can use it when needed. Also, how does the heat pump work? I have seen units on you tube that put out heat in -12 below 0.
The split a/c works quite well, I don't have any noticeable noise affecting the audio, but I only use it in summer for cooling, I have ducted gas heating for winter.
Kazz063 is offline
Old 07-03-2014, 05:41 PM
FattyMcButterPants's Avatar
Quoted: 875 Post(s)
Liked: 813
Well, it appears the amp on one of my xv15se's is dead... Tom helped me troubleshoot and they will be shipping one out ASAP (likely Saturday due to holiday tomorrow). Tom is great to deal with. Must say even with this hiccup I'm really impressed with their company and products.
This leads me to a question for all you experts out there. It occurred to me that instead of sitting around being grumpy about this situation, I can drag my outlaw lfm1-ex out of the bedroom and hook it up in the main room. I will for sure do 1 v 1 testing, but I am wondering, how would it mix with my other xv15se?
Any thoughts?
FattyMcButterPants is offline
Kazz063's Avatar
Quoted: 56 Post(s)
Liked: 70
Originally Posted by JT78681 View Post
Nice setup! Narly cat tree you got there.
Yep the cats love it.
Kazz063 is offline
Old 07-03-2014, 07:40 PM
Magibeg's Avatar
Quoted: 282 Post(s)
Liked: 129
Good news!
I talked to Tom and did some trouble shooting tonight and my XV15se is now pounding away properly. So as it turns out, my receiver and the sub didn't seem to play nicely with each other, however once we added a Y cable and plugged into both inputs the sub promptly blew my face off.
Without the Y cable i was able to run near max gain with +4dB hot on the receiver and it barely made a whimper, now with the Y cable I'm running -7.5dB at about 1:30 gain. I now understand why some of you were going so crazy when I was running this sub hot. If it was working properly it might have taken down the house!
So compared to my PL-200 now.... much much more powerful. It packs an incredible punch but remarkably is still less "boomy". Watched pieces of a couple of movies and you can really feel the force move through you. When I threw on some music it had the ability to be tight and musical still.
Very very happy! I can barely imagine what it must be like to have 2.. or more of them!
Mike Butny and flydeep like this.
Magibeg is offline
Old 07-03-2014, 08:17 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Good news!
I talked to Tom and did some trouble shooting tonight and my XV15se is now pounding away properly.... once we added a Y cable and plugged into both inputs the sub promptly blew my face off.
Nice! lol
bear123 is offline
Old 07-03-2014, 08:25 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Good news!
Glad you got it up and running brother.
Old 07-03-2014, 09:51 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 579
oh, trust me...you will know soon enough when that bug bites you again!
digler84 is offline
Old 07-04-2014, 07:26 AM
flydeep's Avatar
Quoted: 14 Post(s)
Liked: 41
Yep, start off with one, then two and three. Now you will keep wondering how would a 4th sound
Fronts: KEF Q900's, KEF 600c, Rear: Mirage OMD-15's, SW: PSA triple XS30se+miniDSP
AVR: Denon 3313CI, Amp: Emotiva XPA-5
Sources: HTPC (Jriver Media Center), Logitech Squeezebox Touch, PS3, Xbox 360,
TV: Sony KDL-55W900A
Unraid Server with 30TB+
flydeep is offline
Old 07-04-2014, 08:44 AM
leadliner's Avatar
Quoted: 36 Post(s)
i have had the same experience with mine, i guess its ok to use a y connector. the manual says to just plug in left/lfe. what gives..
leadliner is offline
Old 07-04-2014, 09:28 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
The "Y" splitter is recommended when the auto power on feature doesn't power the subwoofer on. Some AVR may output a lower level LFE signal (especially when calibrating) preventing the sub amp from powering on. My old JBL was like that.
INPUTS
The subwoofer INPUTS consist of LEFT/LFE and RIGHT RCA
jacks. You only need to use the LEFT/LFE connection if you are
using a receiver or processor with an LFE or subwoofer output.
You can use a Y-connector on the subwoofer if it doesn’t power
up in AUTO mode at low levels. (Please make sure to recalibrate
if you use a Y-connector.)
Old 07-04-2014, 10:50 AM
Magibeg's Avatar
Quoted: 282 Post(s)
Liked: 129
INPUTS
The interesting thing with my experience was that the amp WAS powering on. Unfortunately though the signal must have been very weak, enough to turn it on, but not enough to give any meaningful LFE experience. It still doesn't calibrate properly on the first pass of Audyssey which makes me think that down the road when I get a better receiver I might get the unexpected benefit of slightly more bass.
Magibeg is offline
Old 07-04-2014, 11:27 AM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Glad you got it sorted, Magibeg. How's your face?!?! (That comment gave me a good laugh!)
Chronic masticator.
tboe77 is offline
Old 07-04-2014, 11:33 AM
Tom Vodhanel's Avatar
Quoted: 1563 Post(s)
Liked: 4474
It is always okay to use a Y and hit both inputs on the sub. However it is usually not required to achieve maximum performance. In most cases using a Y split will double the input voltage as both inputs still receive the same voltage but it is summed before the amplification stage.
The variables here are,
1)The output voltage from the receiver's sub out RCA jack (and how this varies with both master volume and bass level control changes)
2)The input sensitivity of the subwoofer jack(which is controlled by the GAIN control on the sub---remember, the gain control is not a volume control)
3)The input impedance of the subwoofer jack(and how it relates to the impedance of the subwoofer output jack on the receiver).
In about 499 cases out of 500(estimate of course), a single mono cable to either input will provide all the "gain" needed to push our products to their full potential. A few times a year we'll run into one of these cases where something in the gain structure chain just isn't allowing the subwoofer to "see" enough input voltage to reach its performance capabilities.
I would say, as a rule of thumb, if you need to have our gain control set any higher than the "3 o;clock" positioning on the dial....try an inexpensive Y cable.
Tom V.
Power Sound Audio
shingles314 and Magibeg like this.
Tom Vodhanel is online now
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
