Official Power Sound Audio Subwoofer Thread - Page 431 - AVS Forum | Home Theater Discussions And Reviews
 25924Likes
Old 07-24-2014, 03:11 PM
FattyMcButterPants's Avatar
Quoted: 885 Post(s)
Liked: 831
Originally Posted by Tom Vodhanel View Post
You'll get extension down to the 4hz to 7hz range with just *tons* of mid and upper bass slam factor. You'd probably be looking at 112-115dB all the way down to 10hz....mid and upper bass headroom? 121-127dB.
Which extension mode are you using with the 1ex?
Tom V.
Power Sound Audio
that sounds pretty insane, talk about beastly! I am running one port open right now. I measured with an spl meter and actually get more 20 hz output out of my dual xv15se's in the 6000+ cu ft living room that I do with the 1ex in the <1000 cu foot room in max extension mode.... By quite a bit too (4db or so). I find that interesting, and surprising.
FattyMcButterPants is offline
Old 07-24-2014, 03:30 PM
Tom Vodhanel's Avatar
Quoted: 1763 Post(s)
Liked: 5110
I'm not surprised. The 1ex is a good value at 599 to be sure....but it's really not comparable to the XV15se. (I know a few insist otherwise but their POV is based more on personal grudges than anything of value to other forum members imo).
In 1 port mode you might be running into quite a bit of ringing too.
http://www.data-bass.com/data?page=system&id=58
That hump in the response down low matched with the sharp "knee" is sort of worst case for a smaller room like yours. Instead of taking advantage of the room transfer function to get 5hz extension you may be getting into all sorts of audible ringing/decay issues.
If you have a chance to try a sealed sub that has a shallow rolloff I think you would like the effect. The sb2000, xs15, ect.
Tom V.
Power Sound Audio
ahblaza likes this.
Tom Vodhanel is online now
Old 07-24-2014, 05:51 PM
Quoted: 885 Post(s)
Liked: 831
Tom V.
Power Sound Audio
I was surprised for a few reasons 1) the outlaw is a larger sub than the xv15se (enclosure wise) 2) the room for the outlaw is 1/6 the size. Even subtracting the effect of dual xv15se, it still reaches higher spl at 20hz in a room 6x as large! Seems crazy out of a smaller box, even if the driver is bigger.
Couple questions for you:
1) I was not doing bursts testing, but rather a continuous 20hz sine wave for about 30 seconds (hopefully this isn't hurting the sub). Is there any sort of conversion to max burst performance? (ie +3db or what have you).
2) what are we considering when we claim things provide "extension" to a certain frequency? Is there some sort of standard spl value to consider something sufficiently extended?
Edit: in regards to trying sealed subs in the small room. I may just try that one day, but I won't lie, part of me fears this will lead to crazy upgrades in the big room trying to match it (something like dual stacks of Triax's!)
Old 07-24-2014, 09:25 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
Originally Posted by JT78681 View Post
I hate all you guys with your tiny rooms. I'm pushing well over 5000 cu ft in my open living room.
A couple more FV15HP's should help out with that! lol
climber07 likes this.
jbrown15 is offline
Old 07-24-2014, 10:40 PM
flydeep's Avatar
Liked: 41
Or add a triple xs30se. I will post my frequency response with the setup pictures when I get a chance soon but on a quick note - I have a 4300+ sqft room with extensions to rest of the home and I have a triple xs30se. I am loving it, especially for the music. It is like a hammer dropping with a thud and stopping abruptly right in front of you. No extraneous ringing, zilch... nada! It sounds wonderful. The couch, the cabinets and the wooden floor on your feet vibrate when you can't hear audible sounds and the room is dead silent, it feels like the room is awake. One thing that surprised me was when my wife asked why our wall hanged portrait in our second level bedroom was tilted. I knew the second level floors and walls were vibrating but didn't think the sub were capable of tilting the wall hanging picture. I feigned and asked her whether she moved them!
I try to keep a tab on this forum everyday, send me a pm if you have questions about my setup or user experience.
Fronts: KEF Q900's, KEF 600c, Rear: Mirage OMD-15's, SW: PSA triple XS30se(BASH)+miniDSP
AVR: Denon 3313CI, Amp: Emotiva XPA-5
PJ: Benq HT1075, Screen: STR-169150 Silver Ticket 4K 16:9, 150"(White)
Sources: HTPC (J River Media Center)
Unraid Server with 50TB+
flydeep is offline
Old 07-25-2014, 05:00 AM
JT78681's Avatar
Quoted: 1424 Post(s)
Liked: 952
I'm pretty sure my wife would have me admitted.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 07-25-2014, 08:09 AM
Robert760's Avatar
My room is 14×10 I wish I had a bigger room for more subs.
Robert760 is offline
Old 07-25-2014, 08:17 AM
Homebrew101's Avatar
Quoted: 53 Post(s)
Liked: 63
and I hate all guys with houses larger than 1000 sf
ahblaza and drwinlied like this.
Homebrew101 is offline
Old 07-25-2014, 09:35 AM
Liked: 5110
1)Ouch. Don't do that again, please. If you must use a steady state tone like a sine wave, please limit it to a few seconds. You are much better off using a ramped burst for max output checks anyway as those more closely simulate actual source material (film, music). RMS to PEAK = +3dB. But this assumes the amplifiers aren't in any sort of limiting mode and the voice coils aren't glowing hot. With 30 seconds worth of sines, hard to say.
2)usually is it the relationship to the bottom of the FR to the majority of the operating bandwidth.
Tom V.
Power Sound Audio
ahblaza likes this.
Old 07-25-2014, 09:41 AM
climber07's Avatar
Quoted: 338 Post(s)
Liked: 1349
Tom V.
Power Sound Audio
What about using those single freq sine waves as moderate levels (say 75dB) for longer periods? When doing a sub crawl and moving the mic around the room to find nulls and peaks, that change position with frequency, I was using those tones at moderate levels.
Is this okay?
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
Old 07-25-2014, 10:21 AM
Quoted: 885 Post(s)
Liked: 831
Tom V.
Power Sound Audio
Ha! I should clarify the thirty seconds included the ramp up and back down. Only maintained those levels for 5 seconds or less. It didn't register with me that it might not be a smart thing to do until afterwards.... On the plus side the xv15se's really handled it like champs and suffered no damage.
No harm / no foul, and lesson learned.
Old 07-25-2014, 10:34 AM
Liked: 5110
Is this okay?
In your case, 75dB should be okay for 20-30 seconds max. Then give the voice coil 30 seconds to cool down. This is being overly cautious...especially with stacked XV15s. In a typical room environment dual stacked XV15s would need < 1 watt to hit 75dB. Better safe than sorry though. We need to remember, one small mistake could easily damage the subwoofer(s). Let's say someone sets their SPL meter to A weighting accidentally....and keeps cranking up the 20hz signal wondering why the meter isn't reading. Byt the time they figure out the meter setting was wrong, the sub(s) may be damaged.
One sure sign things are heating up is if you smell sort of a chemical odor from the sub. That is the adhesives on the voice coil getting so hot they begin to outgas, coil deformation occurs soon afterwards, and then you get "scratching" as the cone moves in/out.
Sounds like a new "tip of the day" needs writing..
Tom V.
Power Sound Audio
ahblaza likes this.
Old 07-25-2014, 10:44 AM
Liked: 5110
The motors in the SE drivers are stout. We're around the 800w mark per the 426a standard if I remember correctly. That is basically pink noise, at 800 watts....for 8 hours straight..
I tend to be overly cautious as I would much rather have folks limit their "testing" rather than tell them their driver replacement won't be covered under warranty.
Tom V.
Power Sound Audio
Old 07-25-2014, 10:53 AM
climber07's Avatar
Quoted: 338 Post(s)
Liked: 1349
Wink
Tom V.
Power Sound Audio
It curious that you mention the 1W at 75dB typical. I have a Watts Up Pro that I connect to the wall. I didn't see more than 25 - 45W used while playing some fairly heavy bass music (Black Eyed Peas)... These digital... erm, class D amps are very efficient. My XPA-2 draws a bunch of watts being class AB...
Chemical smell? That's conformal coating... Being an electronics technician, my nose is very in tune with that smell. That and the smell of the Genie (o-zone and blue smoke) from burnt components. Overly cautious is my mantra!
Old 07-25-2014, 01:31 PM
Reefdvr27's Avatar
Quoted: 1572 Post(s)
Liked: 1053
I have not been around here lately as I have had my hands full. My question is are the new SE drivers better than the 1st gen Triax drivers? Not sure if the current Triax drivers are the same now or not. I completely fine and have no desire to change anything, but just curious.
Reefdvr27 is offline
Old 07-25-2014, 01:49 PM
Liked: 5110
Yeah, the whole system is pretty efficient. The enclosure design and driver sens also factor into the equation. It is really about total system synergy. Tremendous performance doesn't mean much if the system is unstable, doesn't self limit, is just *huge* in size, or simply costs too much. When we look at what the XV15se offers in performance, stability, etc....all combined with a reasonable size.....it's a winner in my book..
Tom V.
Power Sound Audio
ahblaza likes this.
Old 07-25-2014, 02:01 PM
Liked: 5110
The Triax has shipped with only one driver model. The 15" *Q* variant from Scott Atwell(Fi). We are always experimenting with different ideas but at the moment we don't have any set plans to change the Triax design.
The original driver we had planned for the Triax never worked out due to vendor issues (incompetence).
Comparing the current SE drivers to the "incomp" drivers that we never used......the SE drivers do measure better in the Triax design.
Tom V.
Power Sound Audio
Old 07-25-2014, 04:48 PM
Quoted: 885 Post(s)
Liked: 831
Tom V.
Power Sound Audio
Ever since I read this at work I've been dying to get home and lightly press on the driver to see if it scratches.... Glad to report nothing of the sort.
Also a new tip of the day sounds great, you know, for those of is with measly 3lb brains.
Old 07-25-2014, 04:53 PM
Liked: 5110
This type of damage is usually *very* audible. It can put the amp into "protect" mode(or worse) and you will usually hear very distinct noise(s) from the subwoofer when in use.
Tom V.
Power Sound Audio
Old 07-25-2014, 05:06 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
watched two movies on my new PSA XS15se now and I'm digging it. Not only does this puppy dig DEEP but the quality of bass is much nicer than that of my Klipsch.
I ran Audyssey XT32 and the AVR set the trim to -8.5 on one(PSA) and -7 on the other(Klipsch). Running them 6db hot doesn't seem enough bass for me. 10db is too much. I'll end up somewhere in between there. Keep in mind I listen at -25db to -15db depending on whether the wife is watching with me or not.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
Old 07-25-2014, 05:40 PM
basshead81's Avatar
Quoted: 222 Post(s)
Liked: 6044
I can gurantee there is nothing wrong with your subs. I have worked mine like $2 whores and they are flawless. They will take much mkre abuse then Tom leads on. He is just being conservative so the customer does not get upset when he does not cover a warranty claim for sine wave testing. That being said stick to REW sweeps and lay off the steady state tones.
basshead81 is offline
Old 07-25-2014, 06:18 PM
ahblaza's Avatar
Quoted: 1610 Post(s)
Liked: 1731
I run my four XV15SEs dual corner stacked upfront L&R at about 7dB hot and my pant legs are flapping and I feel like I just got a face lift every time I've watched a BD movie. These subs have about 12 hours of playing time on them as I've spent a month trying to find the right location for them and the solution was right in front of my eyes. It's also tough since I just had my second total hip replacement surgery July 1st. These are just quick setups manually with SPL meter and test tones. Will calibrate and dial them in soon. Also getting ready ( I am a patient man Tom and Jim) for my signature series autographed by Tom Vohanel and Jim Farina serial #1 made in the USA exclusively for Jeffrey L Nordi.. Lots to do yet but it just keeps getting better and better, I wanted to sell the four (or trade ) XV15SEs for dual XV30FSEs because I've been trying to duplicate the 30s sound as this is the only sub that has not taken residence in my home, thanks to Jim I decided to keep the Four15s dual stacked as they still have four drivers and each driver has more amp power per driver than the XV30, again thanks yo my friend Jim for this. I can honestly say that this an addiction, I am a recovering alcoholic with lot of sober time but with PSA subs and speakers it is difficult, I should start a SSA meeting (subwoofers speakers anonymous), problem is I won't stop using.
Cheers to all, Jeffrey Nordi
ahblaza is offline
Old 07-25-2014, 08:02 PM
Quoted: 885 Post(s)
Liked: 831
Haha thanks! I'll have to download REW sometime and possibly get mic... Along with mini dsp... So much to do.
Old 07-25-2014, 08:33 PM
climber07's Avatar
Quoted: 338 Post(s)
Liked: 1349
So few things to buy, so much money... scratch that, reverse it. LOL
Old 07-25-2014, 10:42 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Unreal man, 6 days after the amp in my xv15se locked up, I got my replacement. It lasted less than 10 minutes. Same exact issue as the first one. This is extremely frustrating. =/
berstuck is offline
Old 07-26-2014, 06:17 AM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Tom V.
Power Sound Audio
So how do the current SE drivers compare to the current drivers used in the Triax?
Saturn94 is offline
Old 07-26-2014, 07:55 AM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
soooo torn if I should keep xs15 or upgrade to xv15....
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
Old 07-26-2014, 09:42 AM
climber07's Avatar
Quoted: 338 Post(s)
Liked: 1349
Summer of Bass man... The worst thing that could happen is you like it better and have to sell the XS15.
Or you could keep it and make a separate 2.1 music system.
Old 07-26-2014, 10:30 AM
Hopinater's Avatar
Quoted: 2032 Post(s)
Liked: 4966
That's not good. So sorry to hear about your misfortune. I wonder what's causing the issue with the amps. I have had my XV15se running for close to three months and haven't experienced any problems. I hope PSA hasn't made any changes to the amps they've been using.
Hopinater is online now
Old 07-26-2014, 10:31 AM
Hopinater's Avatar
Liked: 4966
That's a tough one. But I can tell you that the XV15 is a real nice sub.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
