Official Power Sound Audio Subwoofer Thread - Page 463 - AVS Forum | Home Theater Discussions And Reviews
 22439Likes
post #13861 of 31463 Old 09-22-2014, 11:18 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Originally Posted by mjmcmahon67 View Post
Continuing my history of silly questions, I'm back with a new and exciting one!
So I bought a 50 ft sub cable last week thinking that I might want to move my XS15se into a near-field position. Of course, in the intervening days I've managed to tweak the settings so it's sounding fantastic in the location I'd originally selected. It has a 30-some foot cable on it now, but I think the cable may be poorly designed or damaged because the receiver setting for the distance was off by a good amount. Which leads me to the question: can cable length cause enough signal degradation or delay to cause the room eq to over-estimate the distance? A 15 ft cable would be sufficient for my current need, so do I...
A. return the new cable in favor of a shorter distance,
B. Keep the new cable, because the monoprice is likely better than the Monster crap,
C. Keep the existing cable because it works, and/or
D. Stop worrying about silly minutiae
Multiple choice!
Thx, Mike
The distance offset is most likely due to the DSP in the amp. Is it off by 5 feet or so?
climber07 is offline
post #13862 of 31463 Old 09-22-2014, 11:34 PM
mjmcmahon67's Avatar
Quoted: 138 Post(s)
Liked: 61
Yes, it was about 5 ft off. Adjusting it down to the correct (measured) distance made a significant difference in sound quality from the sub!
mjmcmahon67 is offline
post #13863 of 31463 Old 09-23-2014, 02:37 AM
justbenice's Avatar
Quoted: 114 Post(s)
Liked: 51
It sound like crazy because the diffirence price, but anyone here can tell me will the XS30SE out perform the Velodyne DD 15 ? I am thinking of purchafe a XS30SE after got a beautifull XV15SE .
justbenice is offline
post #13864 of 31463 Old 09-23-2014, 07:54 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Originally Posted by ClawAndTalon View Post
Seriously?
Thanks 'basshead' that's why I was building off of the 'if you just won the lottery' canard. But you're right, it's vastly more expensive than the Triax, thanks for helping us with that- we had no idea. <sarcasm>
The topic of the JL Audio sub was brought up initially by Tommy V himself, after you accused his measurements of being 'too inflated.' I guess Tommy V should go shack up in the JL Audio thread too, right? For what it's worth, I just purchased a XS15se, and I explained why I chose it over the ESub.
They were not measurements just guesstimates.
you completely missed my sarcasm...I know you prurchased a XS15.
basshead81 is offline
post #13865 of 31463 Old 09-23-2014, 08:17 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 899
^^^^ Someone get me some popcorn.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #13866 of 31463 Old 09-23-2014, 08:33 AM
Alan P's Avatar
Quoted: 4695 Post(s)
Liked: 3321
The actual physical distance to your sub is rarely the correct distance setting in the AVR. The differences are due to a multitude of factors (i.e. interaction with your room, DSP).
The proper way to find the best distance setting is with the sub distance tweak.
oneeyeblind and ClawAndTalon like this.
Alan P is online now
post #13867 of 31463 Old 09-23-2014, 10:16 AM
Tom Vodhanel's Avatar
Quoted: 1565 Post(s)
Liked: 4479
Right, the DSP imparts a small latency on the signal as it is processed. 4-5 feet sounds about right.
Tom V.
Power Sound Audio
Tom Vodhanel is online now
post #13868 of 31463 Old 09-23-2014, 10:23 AM
Liked: 4479
Goto data-bass and compare the Vel 18 to the xs15se. Take off about 2-3dB on the vel 18 and you'll get an accurate indicator of the vel 15. Then add 3-4dB to the XS15se and you have a very good idea of what the XS30se would show. It looks really close from about 15hz to 40hz. Above 40hz and the XS30se will have the advantage. From 45-100hz looks to be more than double the output capabilities on average.
Tom V.
Power Sound Audio
post #13869 of 31463 Old 09-23-2014, 11:29 AM
Quoted: 138 Post(s)
Liked: 61
Thanks all - I've got a UMIK on the way from Tom and it should be here Friday. I'll do some testing with it and REW and see what I can come up with for the proper distance setting. I will say that setting the sub distance in the AVR to the measured distance made quite a bit of difference in the bass response. Sounds like you're saying that I should leave it at the YPAO setting, though, at least until I can run more accurate tests with both the Center and Sub in REW - or am I misunderstanding?
post #13870 of 31463 Old 09-23-2014, 11:37 AM
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
My order for an XS-15se is in, now the wait begins.
I feel like a kid a week before Christmas
oneeyeblind likes this.
Last edited by ClawAndTalon; 09-23-2014 at 11:54 AM. Reason: 10 Minutes after posting this I get a 'shipped email!' WOOT!
ClawAndTalon is offline
post #13871 of 31463 Old 09-23-2014, 12:25 PM
Quoted: 138 Post(s)
Liked: 61
Enjoy Claw! I know I'm certainly enjoying mine!
post #13872 of 31463 Old 09-23-2014, 12:29 PM
Alan P's Avatar
Liked: 3321
Nope, not saying to trust YPAO. In your room, the actual physical distance may be the correct setting...you won't know for sure until you get REW up and running.
Until then, whatever distance setting produces the highest SPL at the MLP (with the sub cal noise in your AVR) is as close as you can get without measuring equipment.
basshead81 likes this.
post #13873 of 31463 Old 09-23-2014, 12:36 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
The XS-15se is so good, that you'll want to add a second one.
Multiple subwoofers will help reduce the occurrence of room resonances and improve the overall quality of bass throughout your room.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #13874 of 31463 Old 09-23-2014, 12:46 PM
Quoted: 138 Post(s)
Liked: 61
Thanks Alan - since I'm only a few days from getting the UMIK I'll likely wait for further adjustments until I can play with it and REW. My wife is fairly patient on this, but that patience only goes so far.
Alan P likes this.
post #13875 of 31463 Old 09-23-2014, 01:02 PM - Thread Starter
oneeyeblind's Avatar
Quoted: 256 Post(s)
Liked: 466
Just a heads up. All the veneer options on the Triax are sold out right now. Your can still get a single or dual Triax's in satin black. If you looking to buy a Triax with veneer best talk to PSA directly.
ShaunH
oneeyeblind is offline
post #13876 of 31463 Old 09-23-2014, 04:54 PM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Speaking of which...
neutro is offline
post #13877 of 31463 Old 09-23-2014, 05:00 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Ohhhhh snap!!!
Get her set up and report back...stat!!
Brian Fineberg is offline
post #13878 of 31463 Old 09-23-2014, 05:15 PM
FattyMcButterPants's Avatar
Quoted: 875 Post(s)
Liked: 813
Congrats man! I wish you the same joy my PSA subs bring me
FattyMcButterPants is offline
post #13879 of 31463 Old 09-23-2014, 06:02 PM
Quoted: 875 Post(s)
Liked: 813
I know that feeling all too well, congrats on the purchase!
post #13880 of 31463 Old 09-23-2014, 06:06 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Supplier problem?
Love the look of my Cordovan Cherry Triax.
Saturn94 is offline
post #13881 of 31463 Old 09-23-2014, 06:30 PM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Originally Posted by Brian Fineberg View Post
Ohhhhh snap!!!
What? I can't hear you, I'm setting up my sub!
Naaah not really in fact the AVR is still in its box Though I hope to at least open the box before I go to bed. In the meantime I have speakers to wall mount and wire up and it's not going as smoothly as I hoped...
neutro is offline
post #13882 of 31463 Old 09-23-2014, 06:37 PM
Quoted: 875 Post(s)
Liked: 813
Ha! For some reason or another it never does.
gbreda likes this.
post #13883 of 31463 Old 09-23-2014, 07:00 PM - Thread Starter
Quoted: 256 Post(s)
Liked: 466
Originally Posted by Saturn94 View Post
Supplier problem?
I'm guessing a simple issue of not having anymore cabinets for sale, until they order more. Seeing as the Triax is likely one of their most niche products and their most expensive.It wouldn't surprise me if they don't order many of the evener cabinets at one time. which are likely low volume and not as commonly ordered. I'm sure PSA will tell us if there is a problem with getting more.
I bet you do. I love it to, can I barrow it...
ShaunH
post #13884 of 31463 Old 09-23-2014, 09:00 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Any word on XS30 and XV15 testing by Josh Ricci? Last I heard it was suppose to be by summers end.
post #13885 of 31463 Old 09-24-2014, 09:18 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Here's a proof of unpacking
First impressions are that the thing is a tad bigger and heavier than I thought it would be. I said before it could be used as a bench in a pinch for the kids but it turns out it would be a perfect bench for adults or a cool end table. It does fit under the table where I wanted it but I'm happy I didn't order the XV15 after all. The finish is better than I thought -- I like it a lot. The sub looks really sturdy overall and I really like the curved corners, it does give a classy touch to an otherwise rather spartan design.
Of course now I really look forward to try it but I had more pressing issues last night.
oneeyeblind, ahblaza and AC2011 like this.
neutro is offline
post #13886 of 31463 Old 09-24-2014, 09:46 AM
Liked: 3514
i noticed they have added a PSA badge! thats a nice touch...my xv15 didnt have it nor my xs30's
post #13887 of 31463 Old 09-24-2014, 10:04 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Not that I disklike the badge or the logo but I do think it breaks the "black monolith" look a bit though. I wonder if it can be safely removed without leaving glue residue that would be hard to clean on the bumpy finish.
neutro is offline
post #13888 of 31463 Old 09-24-2014, 10:36 AM
Liked: 3514
or you could do the big time mod to get rid of it....
turn that side away from viewing angle hahaha
ahblaza and neutro like this.
post #13889 of 31463 Old 09-24-2014, 10:42 AM
Liked: 4479
Yeah, just peel away slowly and carefully and you should be fine. A touch of windex is there is any residue.
Tom V.
Power Sound Audio
post #13890 of 31463 Old 09-24-2014, 10:47 AM
Quoted: 349 Post(s)
Liked: 232
Tom V.
Power Sound Audio
Your logo is cool, as is the Spartan black monolith look.
Decisions decisions...
I'm just ready for FedEx to get here! TOMORROW!
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
