Official Power Sound Audio Subwoofer Thread - Page 504 - AVS Forum
post #15091 of 15096 Old Today, 11:13 AM
Brian Fineberg's Avatar
Quoted: 405 Post(s)
Liked: 663
correct.
also move the mic around the immediate seating area and compare the responses. this will help know that if they dont differ greatly you can just use the MLP readings to adjust any DSP you may use
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Denon x4100 ATMOS 5.2.4| Emotiva XPA-5 | PSA MT110 x 3 FL/C/FR | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp | Buttkicker LFE
PSB Imagine B for sale:http://www.hometheatershack.com/foru...tml#post987985
Brian Fineberg is online now
post #15092 of 15096 Old Today, 11:54 AM
Quoted: 221 Post(s)
Liked: 194
Originally Posted by Hopinater View Post
Thanks Jeff, I will definitely be checking this out later today and reading through everything.
Okay, there has been so much discussion on where to point the mic and calibration of 0 degrees or 90 degrees that I just want to follow up and verify that I still have this right. The over all agreed upon methodology for measuring bass in a room using a UMIK is to set the mic at the MLP and point the mic at the ceiling. Is that pretty much accurate?
Yes, for all the reasons @neutro so eloquently posted at the end of his last response
FattyMcButterPants is offline
post #15093 of 15096 Old Today, 12:17 PM
Hopinater's Avatar
Quoted: 125 Post(s)
Liked: 660
Got it...Very good. Thanks to all.
Hopinater is offline
post #15094 of 15096 Old Today, 02:09 PM
Liked: 2
I missed my delievery today becuase i am at work, booooooo>>>>>>> Whats a good starting point when setting up a XV15se?
Brker19 is online now
post #15095 of 15096 Old Today, 02:12 PM
Tom Vodhanel's Avatar
Quoted: 396 Post(s)
Liked: 1202
You should be able to sign in(online) at fedex and pick up the sub at the local fedex terminal on your way home if you prefer.
Tom V.
Power Sound Audio
Tom Vodhanel is online now
post #15096 of 15096 Old Today, 02:19 PM
jbrown15's Avatar
Quoted: 1137 Post(s)
Liked: 1168
Sorry Hop, that was me causing the confusion. If you go with a UMIK-1 mic from PSA which they get from miniDSP the mic was calibrated to be used in a zero degree application. Meaning pointing directly at what you're measuring, it doesn't mean that you can't have it pointed 90 degrees.
It honestly might not make that big of a difference but if you're trying to measure as accurately as possibly you'd want to do it correctly.
I have a Cross Spectrum mic and if I'm using 90 degrees for taking measurements I load the calibration file for 90 degrees, if I was going to take a measurement at 0 degrees I would load the 0 degree calibration file that came with my mic.
jbrown15 is online now
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
