Official Power Sound Audio Subwoofer Thread - Page 506 - AVS Forum
post #15151 of 15162 Old 11-21-2014, 10:31 PM
Alan P's Avatar
Quoted: 743 Post(s)
Liked: 400
Sounds like you're planning on getting REW up and running though....? That's good, it's really the best thing you can do to learn what's going on in your room and how to fix it.
Yes, that's what I was asking....you really shouldn't be getting any localization. If you are, that's telling me that you have a nasty peak somewhere and the only way to find it is with REW.
Alan P is offline
post #15152 of 15162 Old Yesterday, 08:26 AM
t231's Avatar
I also have the Pioneer Andrew Jones 5.1 setup (gave the sub away) and feel they're punching significantly above their price point. I cross my center and surrounds at 100hz and my towers at 90hz. Works quite well in my room, localization isn't an issue unless you consider the couch near the PSA sub shakes a bit more than other seating positions.
t231 is offline
post #15153 of 15162 Old Yesterday, 09:05 AM
Saturn94's Avatar
Quoted: 47 Post(s)
Liked: 379
Originally Posted by tvuong View Post
The key is regardless of what others say/do, Audyssey or YPAO knows what your speaker is capable of IN YOUR ROOM. Never lower the xover than what set. There are many benefits in raising the xover as long as it does not become localize: 1.your sub does a MUCH MUCH better job. 2. Your receiver does not have to work as hard. 3. It release stress on your speaker allowing it to deliver clean/clear sound in what it is capable of doing. My main can go low to 25hz measured in my room. I have them xovered at 80 and planning to raise to 100 for the stated reasons.
+1
Btw, I have crossover set to 120hz with no issues. I'm using small NHT bookshelf speakers for surrounds.
Originally Posted by ahblaza View Post
@ Alan, with the original Triax box it had straps over the top of the box, cut those and just lift the lid of the box off and the sides will fall down exposing your beautiful beast, real easy, no lifting. I would imagine it's the same for the T-18, maybe not as the T-18 is close to 70 pounds lighter than the Triax 15s were.
Cheers Jeff
+1
Alan, do not flip the box over. As ahblaza said, just lift the upper box off. The sub is fairly easy to slide sitting in the box base. It will really help if you can get someone to help. Having help moving my original Triax made things much easier. Perhaps the reduction in weight will make it more manageable though.
Saturn94 is offline
post #15154 of 15162 Old Yesterday, 09:50 AM
Liked: 2
Went to see FURY at the theatre last night. It will have an amazing sound effects when it comes out on blu ray!! Great movie too.
Brker19 is offline
post #15155 of 15162 Old Yesterday, 10:34 AM
Hopinater's Avatar
Quoted: 134 Post(s)
Liked: 665
Ahhh yes, couch shaking bass... is there anything better? That's the best way to have localization of bass. That and watching your pant legs flap around, that's fun too.
Hopinater is offline
post #15156 of 15162 Old Yesterday, 10:51 AM
rangers's Avatar
Quoted: 22 Post(s)
Liked: 25
Yeah, I already preordered it, it is a great war movie. Gonna be awesome on Bluray
JTR Noesis 228 (LCR)
Polk Audio LSiM 703 (Surrounds)
Seaton SubMersive HP Plus and Minus (Subs)
Denon 3312 (Receiver)
Sherbourn PA 7-350 (Amp)
Oppo BDP-103 (BluRay Player)
Sharp 80" 3D
rangers is offline
post #15157 of 15162 Old Yesterday, 12:18 PM
Hopinater's Avatar
Quoted: 134 Post(s)
Liked: 665
Sweet! UMIK is here. Now the fun begins. I have to take care of some things this afternoon but after that the learning begins as I dive into the world of REW and see what's really going on in my HT.
post #15158 of 15162 Old Yesterday, 02:06 PM
bear123's Avatar
Quoted: 271 Post(s)
Liked: 779
Excellent! And be glad you already have two subs(measuring usually leads to buying a 2nd sub. )
If you don't have a miniDSP yet, might as well plan on that soon.
AVR:       Yamaha RXV-375
Display:  Panasonic  TH-50PC77U
LCR:       Hsu HB1.2  HC1.2
Sub:       (2) PSA XV15se
Blu Ray:  Sony BDP-S5100
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #15159 of 15162 Old Yesterday, 03:16 PM
t231's Avatar
I haven't seen or felt pant leg flapping bass. Not sure if I haven't demoed the right material at the right volume or I have too much space for the phenomenon... Anyone in the OH area want to demo pant shaking bass for me?
t231 is offline
post #15160 of 15162 Old Yesterday, 05:00 PM
Hopinater's Avatar
Quoted: 134 Post(s)
Liked: 665
Yeah I thought I would hold off on that until after I do the measuring just on the outside chance that all could be solved without it. But I'm sure you are right, I'll end up with it soon enough.
post #15161 of 15162 Old Yesterday, 05:00 PM
Hopinater's Avatar
Quoted: 134 Post(s)
Liked: 665
Just experienced it the other night when I played the rocket launch scene in Enders Game.
post #15162 of 15162 Old Yesterday, 08:04 PM
digler84's Avatar
Quoted: 77 Post(s)
Liked: 117
such an awesome scene. if you want to truly test your sub woofrage, run that scene....you will find out your limitations. that and the end scene with the planet. booooooooooooooommmmmminnnnggggg!
digler84 is offline
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
