Official Power Sound Audio Subwoofer Thread - Page 507 - AVS Forum
post #15181 of 15188 Unread Today, 09:23 AM
neutro's Avatar
Quoted: 139 Post(s)
Liked: 519
Originally Posted by Alan P View Post
Yeah, I'm a little worried about the wiring in my circa 1961 house....
That's actually a good question I think. I don't have this problem really but with two 4kW subs what do you guys do? Are they on 15A circuits? I guess you use two separate 15A circuits? Each will have a max RMS power of 1800W; that is well below the RMS rating of the Triax' amp. That being said, in audio it's mostly transients and the circuit can provide much higher peaks.
So do you plan on upgrading to dual 20A circuits?
Originally Posted by ahblaza View Post
@morbidcorpse , do you have a home buttom on your 818 remote, if so hit it and you should get a couple of options, click on audio and you should see trim adjustment for sub and center channel, bump your sub trim up and then hit HOME button again and it's gone, you don't have to worry about setting the trim level back again for movies once you power down the 818 it reverts back to the original Audyssey trim set.
Wow I have an 818 too and didn't even know that ajusting the trim levels in the options was only temporary. This is awesome, thanks.
Originally Posted by perfectevolution View Post
So running some movie and music samples it was obvious I was getting more 20 Hz and lower bass which was definitely awesome. Which brings me to my next issue, the right side of my theater room has three doors and is basically a rattle trap. So my next adventure is figuring out how to eliminate some rattles.
Good luck with that... some rattles are rather easy to tame but I think the ones in my room are caused by the air ducts in the (finished) ceiling. Fixing that would be... complex.
neutro is offline
post #15182 of 15188 Unread Today, 09:47 AM
jhughy2010's Avatar
Quoted: 226 Post(s)
Liked: 78
Originally Posted by Tom Vodhanel View Post
I'd give them a try(the dual XS15se). I think the XS15se model is often a bit under-rated simple based on pricing. Look over the data from Josh's review. Add 6dB to the cea-2010(for duals). Then study the other measurements (impulse, group delay, stored ringing, FR). If you find anything better at $1499...jump on it...
Tom V.
Power Sound Audio
Thanks for the great advice Tom. I think I like the idea of what we talked about earlier.... getting a single XS30se now and then later on, possibly getting another. An XS30se's dimensions are only slightly larger than the XV15, however, I think the footprint would be less because I wouldn't have to make room for the port.
Living room theater set-up:
AVR: Pioneer VSX-1124-K.
Speakers/Sub: (4) NHT Classic Two and an NHT TwoC center + PSA-XV15 subwoofer.
HTPC: z97 mobo, 16GB mem, i5-4440, SSD+HD, LG BD drive, Win 8.1 pro w/WMC + MB3.
Content sources: OTA Winegard HD7698P, Amazon Fire TV Stick, Netflix etc.
HDTV: Sharp LC-60SQ15U (ehhh).
jhughy2010 is online now
post #15183 of 15188 Unread Today, 10:31 AM
Hopinater's Avatar
Quoted: 142 Post(s)
Liked: 669
Hop are you reading Jerry's guide? You can download the ASIO drivers at www.asio4all.com, I would also suggest installing dropbox as you can store all your REW files in there for easy access. www.dropbox.com
Cheers Jeff
I am reading Jerry's guide and as I read farther I saw that the ASIO drivers were needed for the HDMI. Thanks for the links Jeff, much appreciated.
Hopinater is offline
post #15184 of 15188 Unread Today, 12:03 PM
Tom Vodhanel's Avatar
Quoted: 398 Post(s)
Liked: 1217
The performance of a single XS30se will be similar to dual XS15se. The main advantage for the dual XS15se would be the potential for smoothing room induced peaks/dips. The main advantage for the single XS30se is it leaves you an easy upgrade path....just add a second.
Tom V.
Power Sound Audio
Randall.White and jhughy2010 like this.
Tom Vodhanel is offline
post #15185 of 15188 Unread Today, 02:31 PM
mnc
mnc's Avatar
Quoted: 91 Post(s)
Liked: 76
I'm Thinking about doing an at home comparison between the XS30se and an SVS PC-12 Plus.
jhughy2010 likes this.
NHT speakers, Denon 4520, 65VT50
mnc is online now
post #15186 of 15188 Unread Today, 05:31 PM
jhughy2010's Avatar
Quoted: 226 Post(s)
Liked: 78
That sounds like fun, however, I am wondering why you would chose to compare the PC-12 plus (which is ported I believe) against a sealed subwoofer design?
I think it'd be an interesting comparison to check out the SB13-ultra and the XS30se.
oneeyeblind likes this.
post #15187 of 15188 Unread Today, 06:26 PM
mnc
mnc's Avatar
Quoted: 91 Post(s)
Liked: 76
Similar price and don't forget the PC-12+ can be sealed. Also want to compare sealed vs ported in my room.
mnc is online now
post #15188 of 15188 Unread Today, 06:31 PM
jhughy2010's Avatar
Quoted: 226 Post(s)
Liked: 78
Oh I see that makes sense. I didn't know that the PC-12 could be sealed. That sounds like a neat idea... would be interested in hearing your impressions on the both of them. My initial thought is that the SVS will likely create more output and probably will have a smoother bass response.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
