Official Power Sound Audio Subwoofer Thread - Page 523 - AVS Forum
post #15661 of 15678 Unread Yesterday, 06:09 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
Originally Posted by tvuong View Post
Alan, how about some compression sweeps?
I did some today, but I didn't run out of headroom before REW refused to measure any higher (~115db).
Anyone know how to get REW to measure higher??
Alan P is offline
post #15662 of 15678 Unread Yesterday, 06:25 PM
climber07's Avatar
Quoted: 144 Post(s)
Liked: 1024
Move your laptop from the coffee table to a ladder.
Sorry man, I had to. I couldn't resist.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #15663 of 15678 Unread Yesterday, 06:34 PM
tvuong's Avatar
Quoted: 282 Post(s)
Liked: 128
Change the level to -3dBSF instead of -12 when measuring and/or reduce mic volume in window. The Umm6 mic will be a few db off when its volume is reduced in window. Check Jerry's guide for the off db level. Include the distortion graph while you at it. Make sure to up your LFE to 250hz and run sweeps from 5-250hz.
tvuong is online now
post #15664 of 15678 Unread Yesterday, 06:45 PM
t231's Avatar
Quoted: 22 Post(s)
Originally Posted by mnc View Post
I wonder if dual XS30's would be right in between?
I have two XS30se's and below you'll find my REW results -room is around 4-5k cubic ft. This may or may not be a good indicator of what they'd do in Alan's room, but should give you a rough idea of what they're capable of. Note I set the test tone reference to 75dB so my overall output in the graph is lower, rest assured I have plenty of headroom above what the graph shows.
Top line is +3 dB's hot on the sub, bottom is how Audyssey would have kept it. Graph has 1/12 octave smoothing.
t231 is offline
post #15665 of 15678 Unread Yesterday, 07:14 PM
Red99's Avatar
Quoted: 60 Post(s)
Now they're both set to linear...we want logarithmic.
You can tell you got it right when the vertical lines aren't spaced evenly.
Lol... OK, then this has to be it.
Name:	left sub compression log.jpg
ID:	430321   Click image for larger version
Name:	both subs log.jpg
SOUND: Marantz AV-7702 Pre/Pro, McIntosh MC1706 Amp,
Klipsch RF7-II's, Klipsch RC64-II (Soon), Klipsch RS62-II (Soon), (2) XS15se subs.
VIDEO:
Samsung PN64F8500 Plasma TV, Oppo 103D Blue Ray Player
Red99 is online now
post #15666 of 15678 Unread Yesterday, 08:31 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
Yup, that's it Red!
Now, remind me....what were we looking at these graphs for??
Alan P is offline
post #15667 of 15678 Unread Yesterday, 08:40 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
I had the level at -3db and the MV at 0 and REW complained at me. I'll have to try the mic lvl trick tomorrow.
Should I measure just the LFE while doing this (CH4)?
Alan P is offline
post #15668 of 15678 Unread Yesterday, 08:49 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
Calibrate the UMM-6 at a higher level in REW. Somewhere around -10 should work. After I calibrate my mic at that level REW says I have enough headroom for a 140db sweep.
basshead81 is offline
post #15669 of 15678 Unread Yesterday, 08:49 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
Originally Posted by LowellG View Post
OK, I see suggestions for MiniDSP everywhere in this thread. What exactly is it. Would it replace my XT32?
Lowell,
I can't believe you don't know about the MiniDSP yet....it's a very useful tool, especially if you use REW.
It will allow you to use EQ (slick interface with REW), delay and gain for up to 4 individual subs (2x4 version). It won't replace XT32 but it can be a great compliment if XT32 can't solve all your issues.
Check this thread.
And here's the MiniDSP site.
Alan P is offline
post #15670 of 15678 Unread Yesterday, 08:51 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
Sweet! That sounds like the easiest way to go about it....but wouldn't the db level be off then?? I suppose you just subtract the 10db then? But wouldn't you end up at the same place?
Alan P is offline
post #15671 of 15678 Unread Yesterday, 08:57 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
You do not subtract anything...open up rew, click calibrate, pink noise should play, turn the MV up to -10, place the spl meter next to the mic, make sure they match, click calibrate. Should give you more headroom to work with...at least it does on my version of rew.
post #15672 of 15678 Unread Yesterday, 09:13 PM
Alan P's Avatar
Quoted: 931 Post(s)
Liked: 470
Ahhh...I remember now. We've been through this before and the newer versions of REW don't allow you to do that....I'll give it a shot tomorrow though.
Alan P is offline
post #15673 of 15678 Unread Yesterday, 09:22 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
Glad to hear the T-18's have the extra headroom you needed. If I recall sound quality was never a issue anyway correct?
post #15674 of 15678 Unread Yesterday, 09:39 PM
Red99's Avatar
Quoted: 60 Post(s)
Yup, that's it Red!
I guess nothing.....
VIDEO:
Red99 is online now
post #15675 of 15678 Unread Yesterday, 09:47 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
Your graph looks pretty good to me red. The green and yellow line anyway. Are you happy with the sound?
post #15676 of 15678 Unread Yesterday, 10:55 PM
Red99's Avatar
Quoted: 60 Post(s)
It sounds good I guess but I have nothing to compare it too. I was expecting a little better extension. I don't like how it drops off like a rock off a cliff as soon as it passes 20 Hz. I wish I knew how to get that dip out or what is causing it. My room is so open I dont know if room treatments would do anything.
VIDEO:
Red99 is online now
post #15677 of 15678 Unread Yesterday, 11:28 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
Not sure I would not worry about it...enjoy your subs and do not obsess over graphs. Your subs will very rarely play anything below 20hz anyways, unless you keep a demo disk on hand or you play bass music that have a lot of sub 20hz content.
post #15678 of 15678 Unread Yesterday, 11:32 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1733
Looks like your room offers little roo. gain. You could probably boost the 20hz area 2-3 db with a mini dsp to flatten out the low end but I probably leave it be if you do not want to lose any mid upper bass headroom.
post #15679 of 15678 Unread Yesterday, 11:52 PM
tvuong's Avatar
Quoted: 282 Post(s)
Liked: 128
Yes, CH4.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
