Official Power Sound Audio Subwoofer Thread - Page 524 - AVS Forum
post #15691 of 15707 Unread Today, 10:35 AM
tvuong's Avatar
Quoted: 292 Post(s)
Liked: 129
What I would do is set your horizontal limit to 5 and 250hz (Your subs can go alot lower than 20hz shown on your graph). You then place your cursor at each of the frequency you want to know for distortion, then look at the 2nd, 3rd harmonic, THD, etc... down below your graph. Post that graph with cursor and legend. The lower frequency you select, the more likely distortion rises. You said you had it parked at 22Hz. I would go much lower to see the lowest Hz your subs can play along with seeing the output they produce without distortion. Run sweeps with Aud ON.
Originally Posted by Alan P View Post
Let me know how you guys interpret these...since that last sweep is averaging around 117db and the LFE channel is 10db hot, does that mean I'm good to only 107db?
Not sure why you said that. If you have 117db with Subs 10db hot, then you are good to 117db.
tvuong is online now
post #15692 of 15707 Unread Today, 11:06 AM
Hopinater's Avatar
Quoted: 177 Post(s)
Liked: 701
Originally Posted by Red99 View Post
It sounds good I guess but I have nothing to compare it too. I was expecting a little better extension. I don't like how it drops off like a rock off a cliff as soon as it passes 20 Hz. I wish I knew how to get that dip out or what is causing it. My room is so open I dont know if room treatments would do anything.
Originally Posted by basshead81 View Post
Not sure I would not worry about it...enjoy your subs and do not obsess over graphs. Your subs will very rarely play anything below 20hz anyways, unless you keep a demo disk on hand or you play bass music that have a lot of sub 20hz content.
Red this is the exact same problem I ran into. I found the best place for my subs and even moved the MLP a little forward which helped a bit with the lower end but I still drop off after 20Hz.
My options to fix this are
1.Move the MLP forward to a point that looks ridiculous (This option is free)
2. Buy a third XV15 (a $900 option)
3. Buy a minidsp and bring up the lower end a little and smooth out a hump (a $105 option)
I plan on going with option number three. But I agree 100% with what basshead said, don't stress over the graphs to the point that you're not enjoying your subs and the material below 20Hz is out there but there's not a ton of it.
basshead81 likes this.
Hopinater is online now
post #15693 of 15707 Unread Today, 11:31 AM
Hopinater's Avatar
Quoted: 177 Post(s)
Liked: 701
Hey guys I just wanted to share that I tested the new placement of the subs the other night with one of my favorite LFE scenes (the rocket launch from Ender's Game) and the difference between the way my setup played that before and how it plays it now is radically different.
I'm now getting much more tactile feel even though I'm on a concrete slab and the house was rattling everywhere; to the point that as I was doing this my wife came running down the stairs and asked me what I was doing. I casually responded I was testing the subwoofers. I asked her what she thought and she said: "I would say you're testing the structural integrity of the house". I should note, this is the first time my wife has very come down stairs to ask me what I was doing.
My guess as to why they seem to be shaking the house more is because both subs are corner loaded now. One in front and one in back and they are positioned in opposite corners from one another. Anyone have any thoughts on this?
My graphs tell me I'm getting the content I was missing before and my rattling house confirms that things are much better now. Anyway, I still have some work to do but things are really moving in the right direction.
post #15694 of 15707 Unread Today, 11:34 AM
Brian Fineberg's Avatar
Quoted: 588 Post(s)
Liked: 763
anyone have a thought of putting my two xs30's on each side wall halfway up the wall? about 3 ft from MLP?
im gonna play with placement today I think...Ill report back
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Denon x4100 ATMOS 5.2.4| Emotiva XPA-5 | PSA MT110 x 3 FL/C/FR | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp | Buttkicker LFE
the SadieMax HT build thread - my first build
Brian Fineberg is online now
post #15695 of 15707 Unread Today, 12:16 PM
Alan P's Avatar
Quoted: 938 Post(s)
Liked: 475
I said that because when you output to CH4 (LFE) with REW, it's 10db louder than all the other channels. Is my thinking wrong here?
Anyways, new compression sweeps! Audyssey on, MV0.
I got it to compress at -5 measurement level. Mostly down low though.
And here is the distortion....looks pretty ugly to me when the level gets up there, but you let me know.
Check out what EOT at reference is doing to my wall clock! It's actually turning back time!!!
https://www.youtube.com/watch?v=kzyu...ature=youtu.be
Alan P is online now
post #15696 of 15707 Unread Today, 12:46 PM
Quoted: 588 Post(s)
Liked: 763
Hahah that awesome!
post #15697 of 15707 Unread Today, 01:08 PM
tvuong's Avatar
Quoted: 292 Post(s)
Liked: 129
Correct. Your concern was...?
I cannot see those numbers below on those distortion graphs. They are blurry. Can you increase the image width when capturing? Can you post both Aud ON and OFF FR graph. As you and I know from reading the other thread, your XT AVR does not do anything for subs. You are still -5db from 30 to 20Hz, -10db from 20 to 12Hz, and -15db from 30 to 12Hz
That is insane
post #15698 of 15707 Unread Today, 01:16 PM
tvuong's Avatar
Quoted: 292 Post(s)
Liked: 129
Glad that you are happier now. Option 2 does not provide better exention. You will definitely get more headroom. FR may or may not be better.
Option 3 is the cheapest but be careful boosting down low as it eats up headroom quickly. As folks often say 'There is no free lunch'
There are actually lots of movies with content at 20Hz and below. IMO, I would shoot for 16Hz with useful output at the minimum. I played with this by setting a highpass at 20Hz and at 14Hz while watching a movie clip. The difference is substantial.
post #15699 of 15707 Unread Today, 01:56 PM
Red99's Avatar
Quoted: 62 Post(s)
Is the return frame for PSA 30 days from the day it's ordered, shipped, or delivered?
And the 30 day the day it's shipped or delivered back at PSA?
Red99 is online now
post #15700 of 15707 Unread Today, 02:13 PM
Alan P's Avatar
Quoted: 938 Post(s)
Liked: 475
Heck, I dunno. Guess I'm over thinking it.
Is this better?
Well, it does something just not much. You want compression graphs with Audyssey off? I already did that a few posts ago. Or are you saying you want overlayed?? If so, here that is:
Are you saying this is a good thing or a bad thing? Earlier (yesterday) when I was using the MiniDSP to boost the low end (actually bringing down the middle and boosting overall) it didn't sound as good as it does now. Now it just sounds incredible.
post #15701 of 15707 Unread Today, 02:14 PM
Hopinater's Avatar
Quoted: 177 Post(s)
Liked: 701
LOL! Now that is some powerful bass, you actually discovered the secret to turning back time.
Hey Alan, send me back to 1985 please. It was my senior year in high school and I had a blast that year.
post #15702 of 15707 Unread Today, 02:16 PM
Hopinater's Avatar
Quoted: 177 Post(s)
Liked: 701
Yeah Brian I would be very interested in your findings. I've read that the mid point on the side walls is supposed to be one of the "go to" places to set your subs. However when I recently tried that my graphs sucked so it doesn't hold true in my room.
post #15703 of 15707 Unread Today, 02:32 PM
tvuong's Avatar
Quoted: 292 Post(s)
Liked: 129
Is this better?
So much better. Can you repost those distortion graphs with this resolution? Try with your cursors at 20, 14, 12, 10, 7Hz and post those graphs.
This is what I was looking for. XT does so little on yours and nothing down low.
It is just not as flat as it could possibly be but how they sound is more important.
post #15704 of 15707 Unread Today, 02:51 PM
Quoted: 588 Post(s)
Liked: 763
here it is with the new placement...mid you I dont even have walls lol...this is by far my best response for flatness...but not so good for extension (will get much better when i enclose the room:
no smoothing
two responses just t show what audyssey did and the slight adding of 2 filters for dsp
post #15705 of 15707 Unread Today, 04:18 PM
Alan P's Avatar
Quoted: 938 Post(s)
Liked: 475
How about I just give you the MDAT.
https://www.dropbox.com/s/owujuape3b...%202.mdat?dl=0
post #15706 of 15707 Unread Today, 04:34 PM
t231's Avatar
Quoted: 23 Post(s)
I agree Brian, but 1/12 smooth does not really hide anything...1/6,1/3, 1/1 smoothing tends to hide dips and peaks though.
I agree with basshead, don't think 1/12th smoothing is really hiding much of anything -and PSA uses it on a lot of their graphs so I followed suit. Sorry if this was bad practice on the forum!
See below for the response without smoothly applied -subs are +3 hot in below graph.
t231 is online now
post #15707 of 15707 Unread Today, 04:43 PM
basshead81's Avatar
Quoted: 42 Post(s)
Liked: 1736
You are good...Mark Seaton has even mentioned in the past 1/12 smoothing is fine. Generally no smoothing is you want for measuring subs, but I actually think 1/12 makes the graph a bit easier to read without masking any problem area.
basshead81 is offline
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
