Official Power Sound Audio Subwoofer Thread - Page 526 - AVS Forum | Home Theater Discussions And Reviews
 22509Likes
Old 12-22-2014, 09:48 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
im going to try the Y-spliter at each sub today to see if that works...fingers crossed...Ill report back
Brian Fineberg is offline
Old 12-22-2014, 10:57 AM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Originally Posted by Brian Fineberg View Post
not to get too far off topic,
Also I have sait it a ton of times...if they never came out with another BR with Atmos the upgrade is worth it just for DSU. Its so much more immersive, and way bigger of an upgrade than going from 5.1 to 7.1
they are but ATMOS moveis outnumbers AURO about 3 to 1
and for HT on bluRay there are 4 out for ATMOS with 3 more annouced...and zero for auro
Brian, I have heard DSU is a great enhancement, but if Atmos doesn't stick, how many generations will receivers continue to have DSU as an option on future receivers? I have thought about putting Def Tech PM800s or 1000s on the ceiling, but not sure if the dispersion will be good enough. Also, the Dolby rep told me there designs are for monopole speakers. So I am debating whether to change out my SR8080s and lower them. What are you using for surrounds and how high off the ground are they.
Also, what are the 3 more announced Blurays with Atmos?
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
Old 12-22-2014, 10:58 AM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
If I remember you were doing that with MiniDSP. Was it for clipping issues. REW tells me I am clipping at higher volumes, will a Y-splitter help that.
Lowell
LowellG is offline
Old 12-22-2014, 11:04 AM
Liked: 3514
Gravity (re-release)
John Wick
Lucy
yes it was for clipping....according to Tom yes it will help with it...if not back to Radio shack go the splitters and bye bye minidsp lol
Old 12-22-2014, 12:27 PM
mnc
mnc's Avatar
Quoted: 543 Post(s)
Liked: 469
Originally Posted by ahblaza View Post
My miniDSP 2X4 is still in the box. So you guys are saying that XT32 SUB EQ is the real deal as when I use XT I end up shutting it off. I don't know what to do now about upgrading a receiver, get Atmos or not. I really wanted to stay with Onkyo but with their proprietary room EQ I don't know. I'm really leary about buying refurbs especially Denon. I could get a really good deal on a new Onkyo TX-NR1010 with XT32 Sub EQ, at my age I don't think I will be messing with Atmos, too much work putting in ceiling speakers. What do you guys think.
Cheers Jeff
Don't know about going from XT to XT32 but going from an old version of YPAO to XT32 was HUGE! Made my system sound FAR better in every way. And yes there was a very noticeable improvement in bass.
ahblaza likes this.
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
Old 12-22-2014, 12:56 PM
Liked: 3514
I can attest to going from xt to xt32. Huge uograde
ahblaza likes this.
Old 12-22-2014, 01:39 PM
falzpozitive's Avatar
Quoted: 35 Post(s)
Liked: 31
+1
For me it took downthe big hump below the port tune that many vented subs seem to have...
ahblaza likes this.
falzpozitive is offline
Old 12-22-2014, 01:51 PM
Liked: 3514
Mission accomplished. Minidsp back in the chain. The y splitter is what was needed!!
Here are the responses:
Pink was audussey no minidsp in chain
Blue is y splitters no minidsp
Green is y splitters minidsp + filters
ahblaza likes this.
Old 12-22-2014, 02:07 PM
Homebrew101's Avatar
Quoted: 53 Post(s)
Liked: 63
I just bought the boom mic
What is the attachment I need for both umik and the one for audyssey mic??
am I the only one that uses duct tape?
ahblaza likes this.
Homebrew101 is offline
Old 12-22-2014, 02:51 PM
raynist's Avatar
Quoted: 1257 Post(s)
Liked: 1196
Probably just the only one who admits it
ahblaza likes this.
raynist is offline
Old 12-22-2014, 05:00 PM
Hopinater's Avatar
Quoted: 1781 Post(s)
Liked: 4390
Hey that's awesome. So the minidsp is working well now. Good to know.
How exactly are you guys using the y-splitter?
Hopinater is offline
Old 12-22-2014, 05:03 PM
Liked: 3514
From avr--minidsp--rca cable to y-splitter to both inputs on the sub
I did this for both subs. No clipping. Fantastic flat bass response = happy camper
ahblaza likes this.
Old 12-22-2014, 05:07 PM
Hopinater's Avatar
Liked: 4390
Oh ok I see now. Cool I'm glad you got everything working right again.
Old 12-22-2014, 05:09 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
If you can raise up that 10 dB dip in front of 20Hz I would be all over this minidsp. I have a 15 dB dip there that is nearly a straight drop off then it climbs back up.
Congrats on figuring out a solutions.
Red99 is offline
Old 12-22-2014, 05:20 PM
zeus33's Avatar
Quoted: 1333 Post(s)
Liked: 989
Big dips like that are usually nulls in the room. It's not a good idea to boost the signal that much (or try to) as it will eat into your amplifiers headroom and usually drive it into clipping when cranked up. It's always a better practice to bring down peaks and then play with room placement and utilize room treatments to correct big dips in your frequency response.
zeus33 is online now
Old 12-22-2014, 05:27 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
The only problem that is for me I have already did a road tour with my sub in my family room, moving the sub around and taking measurements after not much success with the sub crawl, and nothing changes my dip. And from what I read, room treatments for that low of a FR may not work. So, I guess I am just stuck with it.
Red99 is offline
Old 12-22-2014, 06:41 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 579
see, now you are just trying to create problems....i have xt, thought about 32 but figured to upgrade once atmos made more of an impact. now some are saying atmos is a format war....not sure if going with a now cheaper xt32 format for that big 'difference', or just wait until everything sorts itself out and upgrade then. by comparison, i never jumped on the 3d bandwagon...just don't care for it....so am i wasting time waiting for atmos instead of just going with a solid xt32 receiver?
ahblaza likes this.
digler84 is offline
Old 12-22-2014, 07:00 PM
Liked: 3514
For me it's not a null just no room gain. I don't have any walls as of now. That will come when I build the room . I was flat to 11hz in my old room
ahblaza likes this.
Old 12-22-2014, 07:08 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
remember every 3db of boost below 30hz effectively cuts amplifier power in half. So a 10db boost at 20hz would effectively turn a 550 watt amp into 125watts. The reason being you will be asking for full amplifier power at 20hz when the rest of the frequency range above that may only be getting 125watts of power. To sum it up, if you could get 115db out of your subs above 30hz, then you will only have 105db available above 30hz after the boost. sure you might be a flat 105db from 16-100hz with the eq boost, but I would rather have 115db available from 30hz on up and only 95db at 16hz. you need to have the headroom available first, then worry about extension. If you want both then you need more subs for A) more output and B) a smoother response.
audiofan1 likes this.
basshead81 is offline
Old 12-22-2014, 07:18 PM
ahblaza's Avatar
Quoted: 1495 Post(s)
Liked: 1596
Brian are you saying because of no room gain you had to turn the sub gain up and the mini couldn't drive the amps and the Y splitters offered that 6dB gain to avoid the clipping? Or that the mini didn't have the voltage to drive the sub amps without clipping. Is this a common ocurence with the mini, the clipping?
Cheers Jeff
ahblaza is offline
Old 12-22-2014, 07:33 PM
ahblaza's Avatar
Liked: 1596
Could someone tell me what this means, I have REW downloaded but the computer I want to use it with is showing this when I download it. I try to do something in the sound card and this shows up. I try to download the current version and this show up also. I have no problems with downloading on the other two computers but the one I want to use keeps telling me this error, please help. Do you think until I configure it that could be the problem? TIA
Cheers Jeff
ahblaza is offline
Old 12-22-2014, 07:49 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
Is this from trying to download it, install it, or opening it up?
Red99 is offline
Old 12-22-2014, 07:51 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
Maybe this is a good reason why some of the 18 inch subs has 4000 watts?
Red99 is offline
Old 12-22-2014, 08:06 PM
Liked: 3514
The mini didn't have the voltage so was clipping the signal. I have heard of this before with the minidsp but never had it happen til now
The room gain is only for my extension. Nothing more. I think with my new sealed room I will be getting single digit response. Since my old room was more open.
ahblaza likes this.
Old 12-22-2014, 08:12 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Cheers Jeff
If I remember correctly (it's been some time) that looks like the message I got when I opened REW without my UMIK-1 attached.
Edit: Yep, I just checked, that message comes up if I launch REW without the mic attached.
Saturn94 is offline
Old 12-22-2014, 08:18 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
I can open REW on my desktop and there is no mic or anything hooked up. Need to understand where this message is coming up. From trying to download, install, or open the application.
Red99 is offline
Old 12-22-2014, 08:21 PM
ahblaza's Avatar
Liked: 1596
Thank you Saturn, I also think that's the problem as well, it's only on the sound card option of REW when I click preferences, I was just checking things out in REW without any devices connected or anything else for that matter. I get all the other functions like SPL meter etc. Thanks, I will try and see if that's the problem. Or just use the laptop and try to understand 8.1, very unfamiliar with it.
Cheers Jeff
ahblaza is offline
Old 12-22-2014, 08:22 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
Cheers Jeff
Are you using a Mac or a PC?
Red99 is offline
Old 12-22-2014, 08:30 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Cheers Jeff
I hope that helped. Btw, the laptop I'm using with REW is running Windows Vista SP2.
Saturn94 is offline
Old 12-22-2014, 08:34 PM
ahblaza's Avatar
Liked: 1596
I'm using a PC and a laptop, I have no problems with opening REW on them or downloading the newer version on those two devices but when I use the PC that I want to use with REW, I open it and that error comes up, when I try to download the newer version I get the same error. Maybe I have to have a mic or something connected. I don't see that mixer on my laptop 8.1 but I do see the mixer on my other PC vista, I've tried everything looking for that mixer in the computers hardware and can't find it, on the newer PC it's there. I don't think I even need that though as I won't be using the sound card with HDMI correct?
ahblaza is offline
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
