Official Power Sound Audio Subwoofer Thread - Page 528 - AVS Forum
post #15811 of 15821 Unread Today, 07:33 PM
ahblaza's Avatar
Quoted: 373 Post(s)
Liked: 364
Could someone tell me what this means, I have REW downloaded but the computer I want to use it with is showing this when I download it. I try to do something in the sound card and this shows up. I try to download the current version and this show up also. I have no problems with downloading on the other two computers but the one I want to use keeps telling me this error, please help. Do you think until I configure it that could be the problem? TIA
Cheers Jeff
Name:	message REW errors 002.jpg
j_nordi
ahblaza is online now
post #15812 of 15821 Unread Today, 07:49 PM
Red99's Avatar
Quoted: 77 Post(s)
Is this from trying to download it, install it, or opening it up?
SOUND: Marantz AV-7702 Pre/Pro, McIntosh MC1706 Amp,
Klipsch RF7-II's, Klipsch RC64-II (Soon), Klipsch RS62-II (Soon), (2) XS15se subs.
VIDEO:
Samsung PN64F8500 Plasma TV, Oppo 103D Blue Ray Player
Red99 is online now
post #15813 of 15821 Unread Today, 07:51 PM
Red99's Avatar
Quoted: 77 Post(s)
Originally Posted by basshead81 View Post
remember every 3db of boost below 30hz effectively cuts amplifier power in half. So a 10db boost at 20hz would effectively turn a 550 watt amp into 125watts. The reason being you will be asking for full amplifier power at 20hz when the rest of the frequency range above that may only be getting 125watts of power. To sum it up, if you could get 115db out of your subs above 30hz, then you will only have 105db available above 30hz after the boost. sure you might be a flat 105db from 16-100hz with the eq boost, but I would rather have 115db available from 30hz on up and only 95db at 16hz. you need to have the headroom available first, then worry about extension. If you want both then you need more subs for A) more output and B) a smoother response.
Maybe this is a good reason why some of the 18 inch subs has 4000 watts?
VIDEO:
Red99 is online now
post #15814 of 15821 Unread Today, 08:06 PM
Brian Fineberg's Avatar
Quoted: 613 Post(s)
Liked: 780
The mini didn't have the voltage so was clipping the signal. I have heard of this before with the minidsp but never had it happen til now
The room gain is only for my extension. Nothing more. I think with my new sealed room I will be getting single digit response. Since my old room was more open.
ahblaza likes this.
Brian Fineberg is online now
post #15815 of 15821 Unread Today, 08:12 PM
Saturn94's Avatar
Quoted: 72 Post(s)
Liked: 384
Cheers Jeff
If I remember correctly (it's been some time) that looks like the message I got when I opened REW without my UMIK-1 attached.
Edit: Yep, I just checked, that message comes up if I launch REW without the mic attached.
Saturn94 is online now
post #15816 of 15821 Unread Today, 08:18 PM
Red99's Avatar
Quoted: 77 Post(s)
I can open REW on my desktop and there is no mic or anything hooked up. Need to understand where this message is coming up. From trying to download, install, or open the application.
VIDEO:
Red99 is online now
post #15817 of 15821 Unread Today, 08:21 PM
ahblaza's Avatar
Quoted: 373 Post(s)
Liked: 364
Thank you Saturn, I also think that's the problem as well, it's only on the sound card option of REW when I click preferences, I was just checking things out in REW without any devices connected or anything else for that matter. I get all the other functions like SPL meter etc. Thanks, I will try and see if that's the problem. Or just use the laptop and try to understand 8.1, very unfamiliar with it.
Cheers Jeff
j_nordi
post #15818 of 15821 Unread Today, 08:22 PM
Red99's Avatar
Quoted: 77 Post(s)
Cheers Jeff
Are you using a Mac or a PC?
VIDEO:
Red99 is online now
post #15819 of 15821 Unread Today, 08:30 PM
Saturn94's Avatar
Quoted: 72 Post(s)
Liked: 384
Cheers Jeff
I hope that helped. Btw, the laptop I'm using with REW is running Windows Vista SP2.
post #15820 of 15821 Unread Today, 08:34 PM
ahblaza's Avatar
Quoted: 373 Post(s)
Liked: 364
I'm using a PC and a laptop, I have no problems with opening REW on them or downloading the newer version on those two devices but when I use the PC that I want to use with REW, I open it and that error comes up, when I try to download the newer version I get the same error. Maybe I have to have a mic or something connected. I don't see that mixer on my laptop 8.1 but I do see the mixer on my other PC vista, I've tried everything looking for that mixer in the computers hardware and can't find it, on the newer PC it's there. I don't think I even need that though as I won't be using the sound card with HDMI correct?
j_nordi
post #15821 of 15821 Unread Today, 08:58 PM
Red99's Avatar
Quoted: 77 Post(s)
Are you using the lastest Beta version?
VIDEO:
Red99 is online now
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
