Official Power Sound Audio Subwoofer Thread - Page 529 - AVS Forum | Home Theater Discussions And Reviews
 22471Likes
post #15841 of 31478 Old 12-25-2014, 04:54 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Brian Fineberg is offline
post #15842 of 31478 Old 12-25-2014, 04:56 PM
jsc79's Avatar
Quoted: 36 Post(s)
Liked: 25
Duct tape is very universal!
Zip ties would probably work too.
jsc79 is offline
post #15843 of 31478 Old 12-25-2014, 04:58 PM
jsc79's Avatar
Quoted: 36 Post(s)
Liked: 25
jsc79 is offline
post #15844 of 31478 Old 12-26-2014, 07:12 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
You shouldn't need a adapter bracket for the UMM-6 or UMIK mic on the boom stand. But you will need the adapter for the Audessy mic. Or duct tape or something. But the camera adapter bracket for the Audessy mic is cheap.
Name:	Boom Stand1.jpg
ID:	443314   Click image for larger version
Name:	Boom Stand3.jpg
Red99 is offline
post #15845 of 31478 Old 12-27-2014, 11:29 AM
jsc79's Avatar
Quoted: 36 Post(s)
Liked: 25
I just ordered up the stand and the adapter. Thanks for the help!
On another note, does anyone have a side by side photo of a xs15se and a xv15se? I am curious of the size difference when they are next to each other vs just reading the measurements and doing measurements in the air with a tape measure.
jsc79 is offline
post #15846 of 31478 Old 12-28-2014, 09:21 AM
FattyMcButterPants's Avatar
Quoted: 875 Post(s)
Liked: 813
They are pretty different subs and I doubt any single person is likely to have both. Your best bet might be to do cardboard cutouts of the dimensions and place them side by side.
FattyMcButterPants is offline
post #15847 of 31478 Old 12-28-2014, 11:25 AM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 579
or chat with tom and ask him to take a pic of them side by side. believe it or not he probably has both sitting there in the warehouse.
ahblaza likes this.
digler84 is offline
post #15848 of 31478 Old 12-30-2014, 01:32 PM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
Tom is this meant to be the xv30f on top
JAMES MCHUGHES is offline
post #15849 of 31478 Old 12-30-2014, 01:38 PM
jsc79's Avatar
Quoted: 36 Post(s)
Liked: 25
That would be waaay to easy!
On another note, there is no way I would be able to get by with a bigger sub that my XS15SE anyways. The wife wasn't too thrilled with this, let alone something noticeably bigger.
jsc79 is offline
post #15850 of 31478 Old 12-30-2014, 01:42 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
Yes, however that chart is composed of mixing and matching data sets. Not saying it is 100% incorrect but I would use data-bass.com numbers for better accuracy.
basshead81 is offline
post #15851 of 31478 Old 12-30-2014, 01:55 PM
Quoted: 153 Post(s)
Liked: 52
Thx bass head yes looking now just learned of that site
post #15852 of 31478 Old 12-30-2014, 02:49 PM
duckylgpn5700's Avatar
Quoted: 25 Post(s)
Proud Owner of 2 XS15se's - Help with Integration!
Hi everyone -
I'm a proud owner of Dual XS15se's. Tom and PSA did a fantastic job rushing out my subs before Christmas and I've spent countless hours sense setting everything up!
I chose to order 2 XS15se's to smooth out frequency response throughout the listening area (and to eliminate the ability to locate the subs).
I have a 6000 cubic foot room, oddly shaped, includes dining room and kitchen. Subs are 8 feet and 15 feet away (non symettrical). One is next to the corner, other is next to a wall.
Using Aud XT32 with their dual sub calibration, my REW curve is below.
I was hoping to get some feedback on the response, any thoughts would be helpful. Let me know if I should consider EQ or anything else? Or, if the curve is great, I can finally just relax! FYI, can't do bass traps as I barely survived the wrath of integrating 2 subs into my living area .
Name:	12-30-2014 1-39-59 PM.jpg
climber07 likes this.
duckylgpn5700 is offline
post #15853 of 31478 Old 12-30-2014, 02:55 PM
Liked: 3514
you could defintly benefit from some EQ. your respoinse looks good in the fact that you would need freqeuncey cutting not boosting....using 75db as a baseline ....it could drop down from 25 and 50 and from 50 to 70 and it would be very flat
either way congrats!! glad you are enjoying them!!
post #15854 of 31478 Old 12-30-2014, 03:35 PM
Quoted: 25 Post(s)
Thanks Brian - would I need an EQ for each sub? Any recommendations on cost effective EQ's?
post #15855 of 31478 Old 12-30-2014, 03:44 PM
Alan P's Avatar
Quoted: 4696 Post(s)
Liked: 3322
This is after XT32??
I would say you still have some work to do regarding placement.
Where is your crossover set? If it's at 70hz it looks like you could benefit from the sub distance tweak.
Are the subs properly gain-matched?
Is this graph un-smoothed?
BTW, you don't have to create a screenshot...see that camera icon in the upper left corner of the REW interface? Click that to create a grab of your graphs.
Alan P is offline
post #15856 of 31478 Old 12-30-2014, 03:52 PM
Liked: 3514
I agree placement is the first defense if that is even an option. But if they are on the only possible location grab a minidsp (psa sells them on their site for just over 100$) and will Eq both subs. In fact REW cab create the filters and send them directly to the minidsp and you can see the changes in real time. Nice tool!
post #15857 of 31478 Old 12-30-2014, 04:20 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
Agreed! Other then the dip at 70hz that is not that bad of a response...heck I could probably live with it once the 70hz is fixed. If you want to really tweak you can do as Brian suggested and cut a few areas to flatten it out more.
post #15858 of 31478 Old 12-30-2014, 04:46 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Don't be afraid to make a gain adjustment on one of the subs to see what kind of effect it has on your FR. It helped eliminate a null in my FR before I applied eq.
bear123 is online now
post #15859 of 31478 Old 12-30-2014, 06:38 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Originally Posted by Alan P View Post
Are you saying you flipped the mic upside down? You must have bought that mic boom after all.
To answer your question - yes, just a few inches can make a big difference in FR, depends on your room/sub placement/MLP location. With dual XS30s though, with proper sub placement you should be able to create a fairly large "sweet zone". The above tells me that you do not have your subs in their optimum positions for your room. Either that, or your room really, really sucks for bass and you need more than 2 subs to smooth the response.
Or, you're still using a pillow for your Audyssey/REW mics.
Alan, so my mic boom came in and pretty much no change. I will do some of the other things you suggested, but I don't understand the input output screen you showed me in the REW setup. What should I have the ASIO output set to. Right now it's HDMI 1 and I have the choice of up to 8.
First graph is without mic boom second graph with. Second graph is subs and mains only dark line is with XT32 lighter without.
Name:	yellow left sub, blue right sub, red both, all at -30db x4000.jpg
ID:	450930   Click image for larger version
Name:	fronts subs only black with xt32, blue wo xt32.jpg
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #15860 of 31478 Old 12-30-2014, 06:50 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
^^ HDMI1 is left speaker, 2 is right speaker, 3 is center, 4 is sub. So if those graphs are with hdmi1, then you measured your left speaker plus subs if the subs were on which seem they are. Your 70hz dip can be resolved/reduced by adjusting subs distance from your x4000. What are the sub1 and 2 distances set by Audessey, what is your crossover?
tvuong is online now
post #15861 of 31478 Old 12-30-2014, 07:14 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
The subs are 15.5 and 14.9. My mains are crossed at 250 the CC at 40. Subs are LFE +Main. I changed them both to 80, see results in graph below. I know I need to run the audessey sub distance tweak. Will have to do it tomorrow. I had been running it before changing both distances at the same time. Tomorrow will do it one at a time.
Name:	blue 250 and 40  yellow 80 and 80.jpg
Lowell
LowellG is offline
post #15862 of 31478 Old 12-30-2014, 07:34 PM
tvuong's Avatar
Liked: 875
^^ try subs as LFE only. LFE+main could cause cancellation. Are the graph measured with hdmi1? If so, you measured ONLY left speakers and subs, no center was measured. I don't understand what you meant by 250, 40 and 80, 80 on graph. For distance tweak, use either hdmi3 (center) or hdmi1 AND hdmi2 (Both left and right). Try to reduce sub distances to 13 and 12.4 and measure/post graph.
post #15863 of 31478 Old 12-30-2014, 07:49 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
^^ try subs as LFE only. LFE+main could cause cancellation. Are the graph measured with hdmi1? For distance tweak, use either hdmi3 (center) or hdmi1 AND hdmi2 (Both left and right). Try to reduce sub distances to 13 and 12.4 and measure/post graph.
I couldn't figure out how to change decimal points so I moved it by feet. I changed it to 13.5 and 12.9 and out of curiosity I changed it to 11.5 and left it 12.9. I never changed them individually before. Look at the jump.
It's getting to late to play tonight, but let me see if I have my sequence right for tomorrow.
1. Recalibrate with XT32
2. Check levels with hand held SPL
3. Run Sub Distance tweak with XT32 on? or Off?
Name:	yellow 13.5 and 12.9 red 11.5 and 12.9.jpg
Lowell
LowellG is offline
post #15864 of 31478 Old 12-30-2014, 07:54 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
One other question. Does this mean I am running my subs to hot?
Name:	are subs too high.jpg
Lowell
LowellG is offline
post #15865 of 31478 Old 12-30-2014, 07:59 PM
tvuong's Avatar
Liked: 875
^^ your last graph has 20db vertical scale. You can change distance to decimal point by going to your avr distance menu, at the very top, change it to 0.1ft then go down to sub 1 and 2 to change them by 0.1ft. Always measure with Audessey ON for subs distance tweak. Try to measure with hdmi3 output and have your center xovered at 80hz. I edited my post above while you replied with yours
post #15866 of 31478 Old 12-30-2014, 08:00 PM
Liked: 3514
Please set your graphs so they sre in 5db increments. Right now you have then in 20db so they are looking more flat then they really are.
But yes it looks like your subs are ridiculously hot. I still think something is wrong with your measurement process. The graphs just don't look right.
post #15867 of 31478 Old 12-30-2014, 08:01 PM
tvuong's Avatar
Liked: 875
Seem way too hot or there is something wrong as your subs are more than 20db higher than your left speaker (if hdmi1 was used for that graph). You should try the subs gain match technique if you have not.
post #15868 of 31478 Old 12-30-2014, 08:03 PM
raynist's Avatar
Quoted: 1257 Post(s)
Liked: 1196
Looks like the little you changed the subs distanced made a huge difference in the yellow graph. You eliminated a 25db null at 80hz.
raynist is online now
post #15869 of 31478 Old 12-30-2014, 08:19 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Where do I change that at?
I am running my subs hot, I have the gain way up because I liked the chest impact. However, the next XT32 run I will use the sub calibration again.
Lowell
LowellG is offline
post #15870 of 31478 Old 12-30-2014, 08:22 PM
tvuong's Avatar
Liked: 875
^^ set your limit in REW to bottom=50, top=115. When running subs hot, up them in the avr sub trims and NEVER the subs gain knobs after Auddesey calibration.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
