Official Power Sound Audio Subwoofer Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 22530Likes
post #1621 of 31511 Old 02-21-2013, 10:44 PM
ttnuagmada's Avatar
Quoted: 112 Post(s)
Liked: 110
I've done a little more playing around with my XS30, but I seem to be having an Audyssey issue. Originally, I had it in a corner, and after running Audyssey, the lower bass was killer, but there seemed to be almost no mid-bass at all, even with the LPF set to 150 on my receiver. I ended up moving it to the front wall next to the TV, and reset Audyssey. After doing this, mid-bass was excellent, low-end was still there, but not as powerful. I wasn't going to run Audyssey again until I had a chance to do a sub-crawl or mess with REW, but I ended up running it this afternoon.
Well, I got similar results to having the sub in the corner. Low-end bass is killer, but there NO mid-bass punch at all. There's a video game as well as some music that was kicking me in the chest the other day with just the default receiver settings, but once I run audyssey, the mid-bass completely disappears,
Can anyone speculate as to why this might be happening? I have the sub gain at about 2 o'clock, and the LPF set to max. The receivers LPF is also at 150. Is my mic bad maybe, or am I missing something else important?
ttnuagmada is offline
post #1622 of 31511 Old 02-22-2013, 02:27 AM
raynist's Avatar
Quoted: 1263 Post(s)
Liked: 1198
Can anyone speculate as to why this might be happening? I have the sub gain at about 2 o'clock, and the crossover set to max. The receivers LPF is also at 150. Is my mic bad maybe, or am I missing something else important?
Could it be that with audyssey engaged you have flat bass across the frequency range whereas before certain frequencies could have been exaggerated to make you feel the hit in the chest? Do you have any way of taking some measurements at various frequencies?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #1623 of 31511 Old 02-22-2013, 02:46 AM
ttnuagmada's Avatar
Quoted: 112 Post(s)
Liked: 110
I plan to play with REW this weekend. Though I don't have a good mic, I'm just going to use my Audyssey mic just to get a feel for it.
Also, I cant imagine this to be the case, especially in comparison to lower frequencies. I played some music that I know has some kickin double-bass, and it sounded like the sub wasn't even on. In contrast, this same music would make my chest feel like it was being punched on the 2 JL Audio 10w3's that I used to have in my car. I'm not an audio guru by any means, and I'm fairly new to home audio, but I've owned car systems before, and I'm not one to go artificially boosting frequencies, I like to try and keep things flat, and just let sheer volume take care of everything.
Also, I ran Audyssey a few months ago when I first got my speakers, and without a sub I'm fairly certain that they were hitting the midbass notes harder. Also, stuff that I expect to be punchy in movies, just sounds kinda boomy instead. For example, the first fight between Batman and Bane, all I could hear with Audyssey on were the lower frequencies, and instead of feeling the punches, I was just hearing what sounded like the lower frequency portion of the punches, and it sounded more boomy than anything.
post #1624 of 31511 Old 02-22-2013, 08:45 AM
SmokenAshes's Avatar
Liked: 53
Originally Posted by walke108 View Post
Wasn't trying to be disrespectful, you said a week which made me think of the drill week. Thanks for your service! smile.gif
SmokenAshes is offline
post #1625 of 31511 Old 02-22-2013, 09:18 AM
TJEli's Avatar
I may be making a purchase from PSA as it sounds like my MFW is on the way out. Can anyone give me a comparison between the XS30 and an XV15? My current room is not that big but it will not be the room my theater is in forever. How does an XV15 cvompare to a stock MFW-15? How about the XS30 against the MFW?
Thanks for your help guys,
-Eli
AV Nut
TJEli is offline
post #1626 of 31511 Old 02-22-2013, 10:12 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
TJEli, i would suggest sending Tom a pm and ask him. He's all over this thread so you should be able to find his user. He'll tell you exactly what you need to hear.
jbrown15 is offline
post #1627 of 31511 Old 02-22-2013, 11:12 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Originally Posted by SmokenAshes View Post
So nobody liked my pic except one guy? frown.gif Man I spent allot of time on that :P
Badass. And thank you for your service!!!
Brian Fineberg is offline
post #1628 of 31511 Old 02-22-2013, 12:14 PM
walke108's Avatar
Liked: 25
I just swapped out my receiver from the Denon 1911 to the Denon 1913 and was having the exact same issue...my midbass was gone and it sure as heck was there on the 1911. Knowing it was there, I started digging into Audyssey...and found it was the culprit. The Dynamic Volume to be exact. Make sure you go in and turn that baby off. It was killing all of the bass in my XS30. It defaulted to Medium Compression on all of my inputs, so I have had to go in to each input and turn it off. Major difference. I did keep the Dynamic EQ on which helps the mid bass punch a little bit. Hope that helps some!
walke108 is offline
post #1629 of 31511 Old 02-23-2013, 12:08 AM
Compusmack's Avatar
Originally Posted by Tom Vodhanel View Post
Email me at support@powersoundaudio.com and I'll be able to give you a good idea when your order will ship. As luck would have it we had quite a few orders last Wednesday. If it was earlier in the day it may ship within 3-4 business days. If it was later in the evening....it might be a two week wait at this point.
Tom V.
Power Sound Audio
I sent an email, hopefully I'm on the good side of the stock line.
Compusmack is offline
post #1630 of 31511 Old 02-23-2013, 04:02 AM
ttnuagmada's Avatar
Quoted: 112 Post(s)
Liked: 110
Well, after doing a little more poking around, it appears as though my fronts and center channel were getting crossed-over at 40hz for some reason. The center is rated -3dB @ 60hz and the mains are -3 @ 48hz. I know that room gain can improve response, but I'm quite certain they aren't getting that low. I'll have to run it again tomorrow with the crossover set higher and see if that fixes things, though I'm somewhat convinced that i'm dealing with a larger problem, as there is more wrong with the sound than the missing mid-bass.
Something appears to have happened between now and the last time I used Audyssey. I used it when I got my speakers a few months ago, and have been very pleased with the results. However, now it's giving me nothing but problems. For example; if I do a reset on the receiver, everything sounds pretty good without me having to change any settings from default. The speakers have a nice full sound, and the sub plays everything very cleanly and blends well with the rest of the speakers. But, if I run Audyssey, it seems to suck the life out of the sound above 40hz.
The strangest part though, is that the sub volume goes up dramatically, and not in a good way. It's as if Audyssey boosts a small frequency range by a very large amount, and it makes the bass sound extremely muddy/boomy. Audyssey even turns the sub level down a little compared to default, yet it's still twice as loud as it is with just the default settings. It gives me lifeless sound, and a sub that just plays a really loud 30hz note anytime there's any bass to play. I would compare it to listening to a table-top radio during a thunderstorm.
I'll run Audyssey again tomorrow with the cross-over set higher, but I have a feeling that it's just going to give me even more one-note bass. The wire for the mic is pretty long and thin, I wonder if maybe it has a short or something.
post #1631 of 31511 Old 02-23-2013, 05:40 AM
suresh6877's Avatar
After running audyssey, have you checked the sub and other speaker levels ? Try manually adjusting all speaker levels to 75 db including sub. If you prefer, you can run sub 2 to 5 db hot. Then try adjusting the speaker crossover to 80hz. You could also try experimenting different cross over levels and find what best suits.
Just my .2 cents !
My equipment: Panasonic PT-AE7000u | DIY 2.35:1 Screen 150" (AT screen - Dual layer milliskin white over black) | Onkyo TX-NR807 | PSA XS30 - Dual subs | JBL Venue Series Stadium Front towers | JBL ES25 Center | JBL N26 Surrounds | Sony BDP-S560 | Roku 2 XS | XBMC Media player
suresh6877 is offline
post #1632 of 31511 Old 02-23-2013, 06:37 AM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
You can also tweak your crossover settings after you run Audyssey.
Audyssey set my crossovers at 40 hz for all of my speakers, but I increased it to 80 hz afterward and the bass is much better. More full sounding.
You can run Audyssey again if you want, but it will just re-set your crossovers again, and then you'll have to change them again. Also, if Audyssey is setting your crossovers that low, then it may be categorizing some or all of your speakers as, "large". If this is the case, you'll need to change them to "small" in order for the bass management to work properly.
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS4, PS3, Sony BDP-S6200,
Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
post #1633 of 31511 Old 02-23-2013, 07:15 AM
ttnuagmada's Avatar
Quoted: 112 Post(s)
Liked: 110
It marks them all as small.
Changing them to 80hz does give more bass, but the way Audyssey is filtering the sub, just makes the bass sound bad. It seems to reproduce any signal it receives, as an exaggerated, boomy 40hz rumble. It blends horribly with everything else, and trying to adjust the sub level doesn't really help, because that one narrow frequency range overpowers everything regardless of the volume.
post #1634 of 31511 Old 02-23-2013, 07:54 AM
GrooveRite's Avatar
Anyone listen to Drum and Bass here with their PSA sub(s)? How does it handle the sub-bass because my puny MLT-2 sub just gets suffocated, lol!
Gamertag: BaneAssassin
PSN: BaneAssassin
GrooveRite is offline
post #1635 of 31511 Old 02-23-2013, 08:18 AM
Liked: 53
I think this is why like my Yamaha. Ignorance is bliss.
post #1636 of 31511 Old 02-23-2013, 08:47 AM
walke108's Avatar
Liked: 25
I would recommend posting in the Audyssey thread(s). Those guys have a wealth of knowledge! Seems very strange to say the least?
walke108 is offline
post #1637 of 31511 Old 02-23-2013, 08:50 AM
walke108's Avatar
Liked: 25
I listen to drum and bass from Pandora with my XS30. It sounds okay, but I am just not digging the streaming music as of late compared to DVD or Blu Ray audio. The streaming seems too compressed and seems to filter out a lot of the lows IMO!
walke108 is offline
post #1638 of 31511 Old 02-23-2013, 09:00 AM
BeeMan458's Avatar
Liked: 813
In my opinion, the destructive nature of streamed audio is such that it forces one who cares, into buying CD's. eek.gif
BeeMan458 is offline
post #1639 of 31511 Old 02-23-2013, 10:53 AM
ttnuagmada's Avatar
Quoted: 112 Post(s)
Liked: 110
I went ahead and posted in the faq thread since it didn't really seem to be an issue with the subwoofer. Kbarnes couldn't see anything wrong with with my Audyssey usage, and is leaning towards the mic. Another guy also said he had similar issues that were corrected by a different mic. So I guess that's what I'll try next!
post #1640 of 31511 Old 02-23-2013, 12:39 PM
GrooveRite's Avatar
Would you allow me to lead you to some quality mixes online so you can listen/test with your XS30? I'm sure you're going to get unbelievable results with your powerful sub, lol!
PSN: BaneAssassin
post #1641 of 31511 Old 02-23-2013, 12:42 PM
Liked: 3514
^yes please
post #1642 of 31511 Old 02-23-2013, 12:50 PM
walke108's Avatar
Liked: 25
Of course!!
walke108 is offline
post #1643 of 31511 Old 02-23-2013, 01:05 PM
GrooveRite's Avatar
Originally Posted by Brian Fineberg View Post
^yes please
Hey Brian, I believe you have the XV15 right?! I'm looking to get it myself once I get my tax refund. If it handles low end stuff like on Drum and Bass, which I'm not much of a fan of (slowly changing, lol) except for listening at the gym for my high energy / high intensity cardio training, I know I'll be happy with it! There is some WICKED low bass drops in DNB that I want to experience here in my apartment. Please let me know how it sounds with your sub!! smile.gif
Of course!!
I'm a House head at heart! Been listening to it for 18 years. I like the jazzy stuff like Deep House. Been getting into DNB just recently for my cardio training at the gym. When I play DNB with my system, my sub is NON EXISTENT, lol! So, I could use a nice, deep hitting sub like a XV15.
This is the website I get DJ Mixes from....... HouseMixes.com
Please go to this DJ's website and download from his Neurofunk/Techstep & Jump Up Drum and Bass Mixes..............his mixes are AMAZING!!!! Hes from the UK.
Please let us know how the low ends in the mixes sound on your sub!! smile.gif
PSN: BaneAssassin
post #1644 of 31511 Old 02-23-2013, 01:48 PM
walke108's Avatar
Liked: 25
I believe I read something recently regarding a faulty mic. That definitely would explain the erratic behavior! Hope that does the trick and let us know if that works!
walke108 is offline
post #1645 of 31511 Old 02-23-2013, 04:12 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
If trying a different mic doesn't fix the problem, the only other thing I can think of would be to do a full microprocessor reset.
That one's probably a last resort, unless you have the ability to save your settings and restore them afterward.
Chronic masticator.
tboe77 is offline
post #1646 of 31511 Old 02-25-2013, 08:26 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
I haven't seen all your posts on the subject, but - are you using a tripod for the Audyssey mic? After Audyssey, what is your sub level? Have you done any measuring (i.e. REW) pre-Audyssey?
Alan P is online now
post #1647 of 31511 Old 02-25-2013, 08:30 AM
BeeMan458's Avatar
Liked: 813
A curiosity question, is one better served using a calibrated microphone such as the one used for REW room measurements over the provided Audyssey microphone?
post #1648 of 31511 Old 02-25-2013, 09:15 AM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Audyssey recommends that you always use the microphone supplied with your receiver.
Chronic masticator.
tboe77 is offline
post #1649 of 31511 Old 02-25-2013, 09:24 AM
BeeMan458's Avatar
Liked: 813
post #1650 of 31511 Old 02-25-2013, 04:55 PM
Liked: 53
Can I suggest using the Music Unlimited app on the PS3. It now streams in high quality audio, much better than Pandora. If your AVR has it use the music compression enhancer. It really brings out the bass in the music.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
