Official Power Sound Audio Subwoofer Thread - Page 550 - AVS Forum | Home Theater Discussions And Reviews
 23656Likes
Old 01-20-2015, 07:49 AM
Alan P's Avatar
Quoted: 4808 Post(s)
Liked: 3434
Originally Posted by Alan P View Post
Taking a note from Jefferey and his minor placement/orientation tweaks, I decided to move my T-18s out of the rear corners (about 30") and towards the center of the wall.
The results were good.
Less "boomy", more "controlled"...and I think I'm getting more extension. Gonna take some measurements tonight, it was too late last night.
The right rear sub is now literally 6" from my seat*.
*Can't locate it at all though.
Well, this didn't turn out well at all.
Gonna put 'em back in the corners tonight.
The FR doesn't look too bad, but OMG THE RINGING!!
Ringing was much more constrained with subs in the corners.
The strange thing is, it sounded pretty good (didn't measure though) when I first pushed the subs out of the corners...when I re-ran Audyssey everything went to hell.
Maybe I'll try re-calibrating with them in the corners, move them out again and see where they measure.
ID:	490530   Click image for larger version
Alan P is offline
Old 01-20-2015, 07:52 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Originally Posted by basshead81 View Post
Even with the subs doing the heavy lifting, many speakers out there are not capable of clean reference playback...it takes a very capable tweeter and midrange to play reference with no compression. The highs are hurting your ears from the compression which makes them harsh. Get some MTM-110's and reference will become regular on blu-ray night.
Well I can't say I have exceptionally good ears so I can't really say if I get compression or not in the highs and mids. But the sound seems exceptionally clear to me. It's just that crashes (e.g. windows breaking, etc.) are just uncomfortably loud at reference. When it's only once or twice in a movie it's no big deal but with continuous action scenes it gets tiring fast. That being said it could be me: I have hearing problems, so I'm missing most of the highs anyway (my own FR begins to drop fast past 2 kHz) and got a light tinnitus that seems to somehow interact with the highs.
As for equipment, I *think* I have the necessary gear. Using Energy RC-70 mains and an RC-LCR center, they're rated for 250W and I'm using waaay below that (my AVR is a Denon X4000 with 125wpc max, and it's not even hot to the touch when doing reference-level demos) so I'd be surprised if I was hitting the limits of those speakers. Furthermore I'm in a relatively small room (1680 cu ft) and not too far from the speakers (about 9-10 ft).
For sure I'd like to try HT speakers like the MTM-110s or Catalysts or the JTR ones. But I don't really see that coming short-term nor mid-term. Perhaps I should do compression sweeps with REW on the whole range for a change...
neutro is offline
Old 01-20-2015, 07:53 AM
basshead81's Avatar
Quoted: 194 Post(s)
Liked: 5482
Alan, just put the gear in closet and enjoy your subs already.
(At least for 2 weeks)
ahblaza and Hopinater like this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 01-20-2015, 08:00 AM
basshead81's Avatar
Quoted: 194 Post(s)
Liked: 5482
No aluminum dome tweeter is capable of reference level without some form of compression. There is a reason why you seen horns and compression drivers being used in Pro Audio, Big Theaters, and most High Efficiency speaker designs.. Compression does not inherently mean you will hear audible distortion. The dynamics are squashing which causes a bright/harsh sound and that causes the "ear fatigue" you are describing.
ahblaza likes this.
Old 01-20-2015, 08:10 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Interesting, I'll look into that -- but still, I think it is a bit too general a statement. I mean technically, if I'm getting, say, 93 dB SPL without compressing 12 ft away from my aluminum dome tweeter, then I'd get 99 dB SPL 6 ft away, and 105 dB SPL 3 ft away. So there is a distance at which the speakers can produce reference level without compressing.
Now I have no idea, as I said before, if I'm compressing or not, but it seems to me that in a small room, not too far from the speakers, reference level should be relatively easily attainable with mid-end gear, regardless of the technology.
I agree that in a larger room, further from the MLP, you quickly need way more in terms of equipment (after all, the difference between 100 W and 1000 W fed to a speaker that can take it, is 10 dB, which is only twice as loud to the ear).
So if I wanted to verify this, compression sweeps are the same in the highs than for a sub right? I might have to purchase hearing protection for this
neutro is offline
Old 01-20-2015, 10:23 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Alan, it probably sounds good because most of the ringing appears to be below 20hz. So you probably won't be hearing any of that.
jbrown15 is offline
Old 01-20-2015, 10:30 AM
Alan P's Avatar
Liked: 3434
You have no idea how pissed I was last night after I heard the results after I ran Audyssey....I was steaming mad.
Really wish I would have saved the previous calibration before I started....oh well, hoping I can get back to where I was tonight.
Alan P is offline
Old 01-20-2015, 10:36 AM
Alan P's Avatar
Liked: 3434
You talking about the second graph? Yes, I agree.
Alan P is offline
Old 01-20-2015, 10:43 AM
audiofan1's Avatar
Quoted: 1661 Post(s)
Liked: 1688
Broadband acoustic panels help as well
audiofan1 is online now
Old 01-20-2015, 10:53 AM
tvuong's Avatar
Quoted: 1578 Post(s)
Liked: 911
I always make sure I save Audessey everytime I rerun it. I assume you already know you can do that in the save/load view device webpage in window.
tvuong is online now
Old 01-20-2015, 10:57 AM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
I'm glad for you bear, I'm roughly in the same situation. In a few months, both of my kids will be at the kindergarten, and at that time, if I happen to catch an unfortunate cold and must take a day off, I'll have the house to myself
Last time I watched a whole movie above -10 was 2 years ago, resting from a minor surgery. I had a blast, 5 movies in 2 days
You might be surprised: since the subs do the heavy lifting power-wise, it takes little AVR power to fly up to reference level. Anyway, -10 to -6 is the loudest I can take for a whole action movie. The highs hurt my ears too much at reference.
Nobody in here must have BP7000's
JAMES MCHUGHES is offline
Old 01-20-2015, 11:17 AM
Alan P's Avatar
Liked: 3434
Yup, I know....just didn't do it.
Alan P is offline
Old 01-20-2015, 11:27 AM
tvuong's Avatar
Liked: 911
I had power outage one time and didn't realize all of my distances and levels were reset to default values until I noticed it sounded kind of out of whack. Loaded the config.dat file back in and I was golden again. At least now you know to make sure to save everytime to prevent being mad.
Old 01-20-2015, 11:36 AM
Alan P's Avatar
Liked: 3434
Oh yeah, that's what I was steamed about and I was only steamed at my own stupidity.
Alan P is offline
Old 01-20-2015, 11:48 AM
tvuong's Avatar
Liked: 911
^^ ***** happens sometime. By the way, how far are you to Bismarck, ND? If it is not too far, I will be in Bismarck the last week of March and would like to meet you and check out your system. You seem to be a likable guy
ahblaza likes this.
Old 01-20-2015, 11:59 AM
Alan P's Avatar
Liked: 3434
I'm about 5 hours from Bismark. If you're gonna be in my neighborhood, you're more than welcome to come over for a demo!
Alan P is offline
Old 01-20-2015, 12:04 PM
tvuong's Avatar
Liked: 911
^^ hey, thanks. That is 10hrs back and forth and I will be there to work, so I have to pass this time. I will hit you up when work sends me closer next time.
Old 01-20-2015, 02:04 PM
Reddig's Avatar
Quoted: 169 Post(s)
Liked: 309
Decided to check out some PSA gear finally so I ordered dual XV-15se for my theater. Getting real excited to take delivery of them on Thursday! Ill post some impressions probably by this weekend. Ive been eyeing this company for a few years now and I think Tom V. has done a heck of a job with it. I respect him very much so this is a no brainer. Coming from dual HSU VTF-2 MK3s which cry for uncle trying to keep up with my big JBL Cinema mains when letting loose. I have a feeling the XVs should do a better job Can't wait to play with new gear!!!
ahblaza likes this.
JBL Pro Cinema/PSA subs/Crown power/Sony SXRD projection/Elite screen/Seatcraft Granadas
MANCHESTER UNITED!!
Reddig is offline
Old 01-20-2015, 02:05 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Awesome!! Congrats. Looking forward to hearing your thoughts. Nothing better than getting new gear! I'll have that same feeling next week
Reddig likes this.
Brian Fineberg is offline
Old 01-20-2015, 02:57 PM
Reddig's Avatar
Quoted: 169 Post(s)
Liked: 309
Thanks bro!!
Aint that the truth!! Congrats to you as well!
MANCHESTER UNITED!!
Reddig is offline
Old 01-20-2015, 03:00 PM
tvuong's Avatar
Liked: 911
Awesome!! I'll have that same feeling next week
and you are not going tell us what gear(s)?
Old 01-20-2015, 03:06 PM
jbrown15's Avatar
Liked: 1993
I think Brian got the new slanted PSA surrounds.
jbrown15 is offline
Old 01-20-2015, 03:18 PM
Alan P's Avatar
Liked: 3434
Brian's building some DIY subs.
ahblaza likes this.
Alan P is offline
Old 01-20-2015, 03:30 PM
jbrown15's Avatar
Liked: 1993
Oh okay, wasn't he in on the UXL group buy though? Because he won't be getting those drivers for months if he is.
jbrown15 is offline
Old 01-20-2015, 03:57 PM
Alan P's Avatar
Liked: 3434
Guess that's not the goodies he's talking about then.
Brian?
ahblaza likes this.
Alan P is offline
Old 01-20-2015, 04:07 PM
basshead81's Avatar
Quoted: 194 Post(s)
Liked: 5482
dual 1" dome tweeters definitely helps split the load...I would say those are capable. Although for the price I would take some JTR's or PSA speakers.
ahblaza likes this.
Old 01-20-2015, 04:08 PM
basshead81's Avatar
Quoted: 194 Post(s)
Liked: 5482
Brian?
Brian ordered new mtm110 surrounds.
Old 01-20-2015, 04:18 PM
Liked: 3515
Your all correct!!
Haha
However next week will be new surrounds
Diy subs will be more like June/july
oneeyeblind and Reddig like this.
Old 01-20-2015, 07:54 PM
ahblaza's Avatar
Quoted: 1516 Post(s)
Liked: 1630
Alan, I think the T-18s are meant for corner duties............
ahblaza is offline
Old 01-20-2015, 08:02 PM
Alan P's Avatar
Liked: 3434
Got 'em there right now...re-running Audyssey.
Alan P is offline
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
