Official Power Sound Audio Subwoofer Thread - Page 603 - AVS | Home Theater Discussions And Reviews
post #18061 of 18083 Old Today, 03:14 AM
Blaine Morrissey's Avatar
Quoted: 33 Post(s)
Originally Posted by jhughy2010 View Post
I was able to see the reverb view but it didn't have a before/after for the sub. It did have one for the rest of the speakers though.
I guess I'd use the mode that says it EQ's the sub. I'm going to try that mode when I do mine. The details of mine don't list that it EQ's the sub but I think from some reading I have done it maybe does in that same mode you mentioned. Yours is also a current model so that probably adds some features.
Pioneer Elite SC-63
OPPO 103D
PSA v1500
GR Research A/V-3
AV123 Surrounds
Epson 3020,Dragonfly 120 Screen
Blaine Morrissey is online now
post #18062 of 18083 Old Today, 03:50 AM
bear123's Avatar
Quoted: 585 Post(s)
Liked: 1083
Originally Posted by UNCMT9 View Post
Looks like I'll have to chat with Tom. I've got everything set per the PSA user manual and still nothing. Gain up to 12:00. Unplugged and re plugged multiple times. Crossover at 150. Switched both ends of sub cable. When I pull it out of the receiver and touch the end, it does make a loud hum from the sub. It still says "no" for subwoofer after running Audyssey. It's like its not recognizing.
I hope you get your issue resolved. However, I can tell you that plugging an unplugging equipment with the power on is a sure fire way to ensure you continue to have problems.
oneeyeblind likes this.
bear123 is online now
post #18063 of 18083 Old Today, 06:38 AM
jhughy2010's Avatar
Quoted: 400 Post(s)
Liked: 115
Originally Posted by Blaine Morrissey View Post
Going wireless would really just add one more option and that would place the sub kind if in a high trafic area. My room is about 16.5 feet wide and 33ish feet long. The back half of the room is kind of a lounge area with a couch and TV back there. I have a big 4 seat bar right in the middle of the room pointing towards the screen with media seats right in front of that. So there's a small walkway on both sides of the bar/couch. I took a panoramic photo of it once when I first got it done I should try to track that down. Here's a pic of where I ended up yesterday, about 6 inches from where I started. I'm kind of thinking about moving my speakers in a foot or so and putting it clear in the front left corner but I'm not sure how that will work out.
I ended up with 6 filters...I'll have to keep that in mind when I redo it...hopefully tomorrow.
That's a nice looking set-up. I wish I had the room for a projector (living room is just too bright).
Gear: Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center).
PSA V1500 (x2)
HTPC/server (MB3), Fire TV Stick, Chromecast
OTA Winegard HD7698P
Sharp LC-60SQ15U (HCFR calibrated)
jhughy2010 is online now
post #18064 of 18083 Old Today, 06:43 AM
Quoted: 33 Post(s)
Tomorrow I'm going to try moving my main speaker there in the photo to the right about a foot or slightly more. That should allow people on the back row to still see the screen. Then I'm going to slide the sub over to the left in front of that verticle bulkhead. I'll have a little room to move it around here and there over there. I'm hoping that makes a difference. I don't have a cable that long yet but for now I'll use a coupler to make one that long.
jhughy2010 likes this.
Pioneer Elite SC-63
OPPO 103D
PSA v1500
GR Research A/V-3
AV123 Surrounds
post #18065 of 18083 Old Today, 07:14 AM
Alan P's Avatar
Quoted: 1710 Post(s)
Liked: 848
Try turning off the filters one by one in the REW EQ panel to see if they are really needed or not....sometimes REW creates filters that are really superfluous.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #18066 of 18083 Old Today, 08:18 AM
Tom Vodhanel's Avatar
Quoted: 691 Post(s)
Liked: 1897
1)In the receiver setup menu, please be *sure* you have ALL speakers set to small/80hz. And the subwoofer set to ON/YES
2)Try playing some bassy music or a bassy movie scene.
If the subwoofer works, then we know the problem is with the AUDY setup. If the subwoofer doesn't work can you try plugging a portable music playing directly into one of the subwoofer inputs?
Also, as mentioned, you should always power down every component before connecting or disconnecting cables or wires. You are basically showing that component a momentary short circuit otherwise. This can lead to all sorts of problems/damage.
Tom V.
Power Sound Audio
Tom Vodhanel is online now
post #18067 of 18083 Old Today, 08:24 AM
basshead81's Avatar
Quoted: 67 Post(s)
Liked: 2047
X2!
I think the mini dsp should be a last resort approach. The first thing a new sub owner should do is read up on REW and start measuring. Exhaust all placement and setup options first, then if the response still leaves something to be desired add the mini dsp in the chain.
Getting Started with REW: A Step by Step Guide --> http://www.mediafire.com/view/aolmz2..._101_v3.92.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #18068 of 18083 Old Today, 08:31 AM
Quoted: 33 Post(s)
Originally Posted by basshead81 View Post
X2!
I agree with you for sure. I'm hoping to make some improvements with what really is my only other good placement option. I'll reduce it down to 2-3 filters at most if I can. I think my next placement option might be a little better...at least I'm telling myself that now.
Pioneer Elite SC-63
OPPO 103D
PSA v1500
GR Research A/V-3
AV123 Surrounds
post #18069 of 18083 Old Today, 08:34 AM
Alan P's Avatar
Liked: 848
X2!
Nothing against Tom, but with all the issues you and I (and many others) have had with the MiniDSP and then ended up not using it, I think Tom is asking for a lot of headaches from customer issues by including the MiniDSP....just my 2 cents.
Audyssey 101
Audyssey FAQ
post #18070 of 18083 Old Today, 08:35 AM
Alan P's Avatar
Liked: 848
Where's Jeff?? I wanna see more graphs!!
Audyssey 101
Audyssey FAQ
post #18071 of 18083 Old Today, 09:24 AM
Quoted: 33 Post(s)
I gotta say though my 'issues' were user error. I just didn't see that button at the top right and never thought about it defaulting to off. The device itself and interface work pretty easy.
Let me ask a REW question. When you take your measurements do you use the 90 degree calibration file and point the mic straight up or do you use the other file and have the mic level?
Pioneer Elite SC-63
OPPO 103D
PSA v1500
GR Research A/V-3
AV123 Surrounds
post #18072 of 18083 Old Today, 09:46 AM
Alan P's Avatar
Liked: 848
90 degree, straight up.
The issues with the MiniDSP I eluded to are with output voltage and clipping of the sub, not really set up issues.
Audyssey 101
Audyssey FAQ
post #18073 of 18083 Old Today, 10:02 AM
Hopinater's Avatar
Quoted: 295 Post(s)
Liked: 929
Originally Posted by ahblaza View Post
Some one please help me to post my graphs from REW, I tried everything and don'y know what I'm doing.
Hey that's great Jeff you got your first graphs with REW. As the other guys pointed out now the work begins as you can now see what you need to fix (But your speakers look pretty darn good). Once you figure out what's causing that dip you should be great.
Hopinater is offline
post #18074 of 18083 Old Today, 10:02 AM
Quoted: 691 Post(s)
Liked: 1897
Actually I just refer them to you and basshead..
Seriously though, thanks to everyone who spends time in this thread helping out others. There is *no* way I would have the time to answer all of the questions that pop up here.
Also, we're going to evaluate the anti-modes too. It may not work quite as well as a optimized miniDSP setup but I'd guess 95% of our customers would prefer a plug-play solution that gives them most of what the miniDSP+REW5 does.
Tom V.
Power Sound Audio
Alan P and jhughy2010 like this.
post #18075 of 18083 Old Today, 10:17 AM
Quoted: 33 Post(s)
Tom V.
Power Sound Audio
To me those looked like they had potential for those of us who just want to push a button Actually now that I feel like I can take measurements ok it is kinda fun...even though my room sucks.
Pioneer Elite SC-63
OPPO 103D
PSA v1500
GR Research A/V-3
AV123 Surrounds
post #18076 of 18083 Old Today, 10:18 AM
Alan P's Avatar
Liked: 848
Tom V.
Power Sound Audio
I think the Antimode would cause you less headaches, that's for sure.
Audyssey 101
Audyssey FAQ
post #18077 of 18083 Old Today, 10:20 AM
Quoted: 691 Post(s)
Liked: 1897
Being able to take accurate audio measurements in your system will prove invaluable over the years. And REW5 is very powerful for free software too.
Tom V.
Power Sound Audio
post #18078 of 18083 Old Today, 10:25 AM
Quoted: 691 Post(s)
Liked: 1897
Here is the electrical of our "Room Size" control.
The top curve(virtually flat) is the control set to LARGE.
The bottom curve(with the greatest attenuation) is the control set to SMALL.
Everything in-between is everything in-between on the dial..
Tom V.
Power Sound Audio
post #18079 of 18083 Old Today, 10:50 AM
jhughy2010's Avatar
Quoted: 400 Post(s)
Liked: 115
I had originally thought that Audyssey XT32 did all the sub EQing and correction?
PSA V1500 (x2)
post #18080 of 18083 Old Today, 11:01 AM
Alan P's Avatar
Liked: 848
Well, it does some EQing of the sub...but some folks need more, hence the MiniDSP (and other EQ solutions).
Audyssey 101
Audyssey FAQ
post #18081 of 18083 Old Today, 12:23 PM
nalthien's Avatar
Quoted: 134 Post(s)
Liked: 112
I imagine it makes sense to take multiple measurements: go with un-EQ'd and then go with post-Audyssey. Once you've done that, you'll see the differences Audyssey was able to make. Depending on your room, you'll see whether or not that was "enough." My understanding is that the MiniDSP can help tame really nasty modes in which certain frequencies are lifted way too high. But, much like Audyssey, it can't really help a null; you'll need to explore different positions for that.
Marantz AV7702 | Emotiva XPA-5 | Martin Logan Theos | Ps3 | Roku 3 | Apple TV
nalthien is online now
post #18082 of 18083 Old Today, 12:31 PM
ggallaway's Avatar
A few things. I performed the following to dial in my subs:
1) connect both subs to the MiniDSP and subwoofer output on my Onkyo 705 Reciever
2) bring up calibration tones on onkyo and set sub to 0db
3) Mute one sub and calibrate using amp gain and minidsp to 75db
3) Mute other sub and calibrate to 75db
4) Run Audysey (which brought combined sub output cut to -6db at the onkyo) also it set the sub to 8ft (even though subs are placed in opposing corners across the room, one in back and one up front)
5) Run REW and see crazy dips just below and above 80hz
6) Play with delay on V1500 until REW shows "relatively flat" response with just one big bump at 100hz, export MiniDSP file to tame the bump
7) import file into MiniDSP (luckly saved my settings from before didn't know it would wipe them out if I hadn't )
8)verify with REW that graph looks smooth without the 100hz bump
Anything I missed here? should I have done things in a different order? also, slightly unrelated what kind of power draw does the V1500 have when idle? I know it has the "auto" setting but I have never really cared for how they operate (sometimes shutting off if there is not sufficient bass in the movie) anyone have thoughts on that?
Thanks Much!
G
ggallaway is online now
post #18083 of 18083 Old Today, 12:36 PM
nalthien's Avatar
Quoted: 134 Post(s)
Liked: 112
This is one area with which I am entirely unfamiliar. I'm not sure what measurements are going to correspond to needing to change the delay and how to accurately dial that in. Would love to hear from people more knowledgable--I understand the purpose of the control; just, nothing about how to use it.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
