Official Power Sound Audio Subwoofer Thread - Page 626 - AVS | Home Theater Discussions And Reviews
 4312Likes
post #18751 of 18765 Old Yesterday, 12:06 PM
pony9134's Avatar
Quoted: 46 Post(s)
Liked: 42
Originally Posted by Alan P View Post
ch1 = fl
ch2 = fr
ch3 = cc
ch4 = lfe
ch5 = sl
ch6 = sr
ch7 = sbl
ch8 = sbr
Thanks again, last? Am I supposed to run the mains with the sub when doing a sweep if so how is that possible when you can only pick one output?
pony9134 is online now
post #18752 of 18765 Old Yesterday, 12:20 PM
tvuong's Avatar
Quoted: 584 Post(s)
Liked: 242
^^ if you have speakers set to small which is recommended, running sweep on them will also include the sub(s).
tvuong is online now
post #18753 of 18765 Old Yesterday, 01:02 PM
tang7969's Avatar
Quoted: 73 Post(s)
Liked: 52
Originally Posted by mnc View Post
I just calculated that I can order my second XS30se in fifteen weeks!
I have a better idea....Use Paypal credit and you can get the sub right away!!
-SAMSUNG UN607150/OPPO BDP 103D
-ENERGY RC-50 FRONTS
-ENERGY RC-LCR CENTER
-ENERGY RC-10 SURROUNDS
-ONKYO TX-NR3010
http://www.avsforum.com/forum/209-au...5se-725-a.html
tang7969 is online now
post #18754 of 18765 Old Yesterday, 01:34 PM
mnc
mnc's Avatar
Quoted: 347 Post(s)
Liked: 212
That's actually how I'm paying for this one!
Mike Butny likes this.
NHT speakers, Denon 4520, Panasonic 65VT50, PSA XS30SE
mnc is offline
post #18755 of 18765 Old Yesterday, 02:15 PM
Alan P's Avatar
Quoted: 1890 Post(s)
Liked: 945
Not very intuitive, but you choose the second output channel with the "Timing Reference Output" dropdown.
You want to measure FL+sub(s), FR+sub(s) and CC+sub(s)....never FR+FL+sub(s). The most important measurement (if your system is used mainly for movies) is the CC+sub(s).
As tvuong mentioned, as long as you have bass management engaged, all of these "+sub(s)" measurements only require you to output to one channel (FR, FL, CC).
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #18756 of 18765 Old Yesterday, 04:52 PM
nalthien's Avatar
Quoted: 255 Post(s)
Liked: 268
Ha...I approve of this suggestion.
A: Marantz AV7702 | Emotiva XPA-5 | Martin Logan Theos | Martin Logan Motif X | PSA S3000i (x2)
V: Vizio P702UI-b3 | Ps3 | Roku 3 | AppleTV
nalthien is online now
post #18757 of 18765 Old Yesterday, 04:52 PM
pony9134's Avatar
Quoted: 46 Post(s)
Liked: 42
thanks Alan and tvuong, gonna give it another go tonight, when people post graphs on here, is it with front and center, or just sub, o
post #18758 of 18765 Old Yesterday, 05:39 PM
ahblaza's Avatar
Quoted: 572 Post(s)
Liked: 477
Compression Sweep
Guys here's the compression sweep I started but had to stop cause I thought I was going to blow something up, I stopped at -20 I think. I might had the output to high when I started
I included 2nd graph (subs only) with Audy 3rd before Audy
The last graph is before and after Audy speakers, I don't see any improvements.
Is there a way to check your UMIK-1 to know if it's working properly, my speakers can't be this bad
My subs are looking a little better yes?
Name:	Comp Sweeps stopped -20.jpg
ID:	676529   Click image for larger version
Name:	SUBS ONLY NS AUDY 19.jpg
ID:	676545   Click image for larger version
Name:	SUBS FRONT WALL.jpg
ID:	676553   Click image for larger version
Name:	Ch 1 + subs Gold Audy Blue 0 audy 19.jpg
ID:	676561   Click image for larger version
Name:	CH 1 + 2 + subs Blue Audy 19.jpg
Name:	Blue Full audy 19.jpg
ahblaza is online now
post #18759 of 18765 Old Yesterday, 05:45 PM
Brian Fineberg's Avatar
Quoted: 1335 Post(s)
Liked: 1280
Well first off your speakers aren't bad. Your room is. You need treatments. Badly. Also need to move your mlp
And you also need to post your graphs properly. They are very hard to make comparisons so differently
When posting subs only the graph should only go to 300hz not to 20000hz
Also they have to be in 5db increments not 10
Brian Fineberg is offline
post #18760 of 18765 Old Yesterday, 05:56 PM
mnc
mnc's Avatar
Quoted: 347 Post(s)
Liked: 212
Hey is it true that I can use the UMIK-1 with my iPad?
mnc is offline
post #18761 of 18765 Old Yesterday, 06:11 PM
ahblaza's Avatar
Quoted: 572 Post(s)
Liked: 477
Thanks Brian, I think I have two or three posted correctly.................
I think I need a radical re-setup
Name:	CH 2 FULL AUDY 19.jpg
ID:	676665   Click image for larger version
Name:	CH 1 2 3 FULL AUDY 19.jpg
ID:	676673   Click image for larger version
post #18762 of 18765 Old Yesterday, 07:38 PM
tvuong's Avatar
Quoted: 584 Post(s)
Liked: 242
^^ you also need to name your measurements. You will not remember if you just left them as the date/time stamps. As I mentioned before, concentrate on subs and/or center + subs in the 7-150hz region. Your speakers FR look good. On your compression sweeps, we need to know how much higher on your MV from one graph to another. You could name your measurements as -15MV, -10MV, etc...You mentioned you stopped at -20MV on sweeps, your FR on this sweep should be centered around 95dbs if measured with-3db FS in REW. Your highest sweep seems to be centered around 105-110db unless you run your subs 10db hotter or audyssey didnot set your subs level correctly.
post #18763 of 18765 Old Today, 07:51 AM
cesar123's Avatar
Quoted: 130 Post(s)
Liked: 160
ahblaza, you're getting some nice extension there. I think, as Brian mentioned, it is time to add some room treatments.
I did that about a year ago - a few foam squares to start, and noticed a small difference. After treating it a bit more, it was a dramatic difference, really.
Head over to ATS, GIK Acoustics or Real Traps. You can make the treatments yourself (Owen Corning 703, for example, and a trip to home depot for lumber) or simply buy them, ready to go. Some can be expensive, but they are very, very worth it.
Don't discourage! You have some fantastic gear... just add some acoustic treatments
Yippee-ki-yay...
cesar123 is online now
post #18764 of 18765 Old Today, 11:24 AM
sinisanav's Avatar
Quoted: 20 Post(s)
I did the same this year, in my new HT, 300$ worth of acoustical treatments made wonders for the clarity of sound.
I had to fiddle with settings, turn center channel hot to be able to hear/understand the spoken word, bass was boomy, but with some absorption and bass trapping, everything cleared up.
Best 300 $ you can use on your space, and another thing, people often chase the better and better sound, and dont like how their sub or speakers work and go for an upgrade, at the same time not treating the room and acoustics place such a big role in what we hear.
Check the pics of my room in my sign line. I used GIK acoustics.
Change is the only constant.
My HT: http://www.avsforum.com/forum/19-ded...l#post32691273
sinisanav is online now
post #18765 of 18765 Old Today, 12:26 PM
Aliens's Avatar
Quoted: 427 Post(s)
Liked: 630
Thanks. I submitted pics and details on their acoustic advice form.
Aliens is offline
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
