Official Power Sound Audio Subwoofer Thread - Page 719 - AVS Forum | Home Theater Discussions And Reviews
post #21541 of 21564 Old 08-02-2015, 07:07 PM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
Hopinator,
Thanks. I will do more tuning next week. This was my first time with REW and I will dig deeper as I find more time. One thing I really liked was how clean the SVS was with such low distortion. When I look at PSA and Rythmik subs on data-bass I see much more distortion in those measurements which concerns me a little. This is what made PSA and easier choice over Rythmik (final two choices) was that I have risk free trial and can listen and measure to see how they compare.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Klipsch RP-280F / RC-62ii / RS-35 / RS-25
SVS PC13-Ultra
kluken is online now
post #21542 of 21564 Old 08-02-2015, 09:53 PM
lizrussspike's Avatar
Quoted: 38 Post(s)
Liked: 73
Originally Posted by DCMlover View Post
I just don't think I want to have a giant single sub taking up that much space. I guess I don't know how lod reference is, maybe I better wait until I finish construction to pull the trigger.
Don' think of it as a big single sub...I look at the V3600 as a Monster double, it really seems that way when the grill is off
Marantz SR7008, Emotiva XPA5,PSA V3600I,Dual PSA XV15SE's
PS3 Phat, PS3 Slim, Sony BDP-370,Toshiba HD-A2
Polk Monitor 70's,Polk CSiA6,Polk R50's,Polk F/XiA4's,Polk OWM3's,
Sharp 60 LED 640U,Optoma HD25-LV,Belkin PureAV Home Theater Console
lizrussspike is offline
post #21543 of 21564 Old Yesterday, 08:14 AM
Tom Vodhanel's Avatar
Quoted: 963 Post(s)
Liked: 2777
Originally Posted by kluken View Post
Hopinator,
Which measurement graph and which subs are you comparing?
I bet you would find a single V1500 performs very similar to your Ultra with one port blocked.
So dual V1500s at $1999 would be a very audible upgrade...even at -10dB master levels.
1)Which receiver are you using?
2)Do you have the bass levels *hot*?
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #21544 of 21564 Old Yesterday, 08:20 AM
Alan P's Avatar
Quoted: 2197 Post(s)
Liked: 1168
As I still procrastinating on my sub decision, I have a pair of V1800s on pre-order, but am wondering if I am making the right decision. I finally got a UMIK-1 and REW set up and ran some experiments on my existing SVS PC13-Ultra. First disclosure this is my first time using REW. Next Audyssey was was previous set up for the sub with all ports open, I did NOT re-run Audyssey between each test as I was just looking to get some SPL and FR numbers to see if dual sealed subs can work for me. These are all with my PC-Ultra with the older BASH amp.
A few interesting observations for a novice, first and foremost while not in the graphs I am uploading) the distortion numbers for this sub were mind boggling low at all frequencies for the first 10 harmonics. I did include the sealed 20Hz as it seems impressive to me. The second thing was how well the FR curve was for sealed mode, it was solid down to 7Hz. I did loose gain compared to all ports open and as I have read you can hear the gain once you get upward of 30Hz. I am wondering how well Audyssey will flatten that out. I did some manual testing to see what it would take to get 110db down around 5Hz and below and had to crank the REW signal generator to -3db from -10db and then the sub went silent ;-). Clearly the BASH was at it's limit because the fuse on the sub blew. First time in 7 years of ownership and fortunately still had the 2 spare fuses SVS shipped with the sub.
What I can not explain is why the sub rolls off over 80Hz the AVR is set to LPF at 120Hz and the speaker crossovers are 100Hz yet in every scenarios the sub rolls fast at 80Hz? Any thoughts on why? Makes me think I am missing content in the 80-100Hz range with the AVR sending below 100Hz and the sub not handling it.
Based on these graphs I am inclined to think that Audyssey might clean up the dip in the 10-30Hz range then sealed is a definite possibly, especially with dual sealed subs!
Am I nuts to go 2 V1800s based on this performance? Would a pair of S1500s be better or just V1500s?
I do watch moves on my Denon at -10db or sometimes a tad louder.
Any thoughts and feedback is welcome as I procrastinate on my sub decision.
RE: Distortion - from your first graph, it looks to me like distortion is rising very fast under 20hz so I'm not sure what you mean when you say "the distortion numbers for this sub were mind boggling low at all frequencies for the first 10 harmonics".
RE: 80hz roll off - Do you have the crossover on the sub amp maxed out? If so, I would venture to guess that you have a null at 80hz. If your sub is close to your mains, measurements of the main speakers would verify that.
ahblaza likes this.
Alan P is online now
post #21545 of 21564 Old Yesterday, 09:50 AM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
Most subs are horrible distortion under 20Hz, but looking at data-bass charts many decent subs are still high distortion up through 31.5 Hz, so I was impressed how clean my sub was.
Sub crossover is maxed all other options are disabled. Someone suggested I hit a null spot and I should move the mic around. Still odd what a drop it has even at 90Hz.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21546 of 21564 Old Yesterday, 09:56 AM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
Tom V.
Power Sound Audio
1) Denon X7200WA
2) I run the AVR with sub about 6db hot.
I did suspect dual V1500s would be the right answer, but since the pre-order pricing of the V1800s is so attractive I will probably stick with those and if for some reason they are way overkill we'll talk about V1500. What about dual S1500, how do you think they woudl stack up seeing my output form the PC-Ultra. Also I assume corner loading is giving me large gain, so pulling them inward toward center credenza will hurt I assume. I am enclosing pic of current layout, room is 15 wide 20 long and 8 foot ceilings.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21547 of 21564 Old Yesterday, 10:10 AM
Quoted: 963 Post(s)
Liked: 2777
1) Denon X7200WA
1)With Audyssey do you keep *Dynamic EQ* set to on? (it defaults to on).
2)6dB hot....oh boy..
So with Master levels up to -10, that is really -4(from ref).
Also, If you have Dyn-EQ on, that will boost your bass levels significantly at lower volume levels as well. I'll include a chart showing this I found on the net somewhere in the past.
3)A single S1500 will have similar headroom (to the ultra in sealed mode) from about 20-60hz. Under 20hz the S1500 will have an edge. In the 60-120hz range the S1500 will have 2-4dB more headroom.
Tom V.
Power Sound Audio
Name:	dyneq correction.png
oneeyeblind likes this.
post #21548 of 21564 Old Yesterday, 10:26 AM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
Tom V.
Power Sound Audio
Yup 6db hot and I love reference lows ;-)
All Dynamic EQ/Vol is off.
I assume you meant under 20Hz the V1500 would have egde?
While we are talking how are V1800 fulfillments going? ;-)
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21549 of 21564 Old Yesterday, 11:57 AM
Alan P's Avatar
Liked: 1168
Ooops....didn't notice that your measurement was at 110db.
I retract my earlier statement.
post #21550 of 21564 Old Yesterday, 12:06 PM
Quoted: 963 Post(s)
Liked: 2777
No, the S1500. I know I know, if you ask a few guys that judge subwoofer performance solely based on driver "specs", amp "specs" box size, there would be no way a S1500 could match the 13Ultras(in sealed mode)..
But the reality is the way the driver, amplifier and box volume all interact is very complex and the simplistic manners in which these variables are often presented at AVS is really doing a disservice to anyone reading along on some threads. Jim and I have a combined 30(ish) years of experience building and measuring speakers and subwoofers. And we're still surprised a good bit of the time but the way certain systems do *not* act the way they are supposed to once we start the measurement process. Honestly though, this keeps it fun!
Anyway, I'll include a snapshot of the XS15se compared to the Ultra13(sealed mode) from 3rd party measurements(Josh). This the CEA-2010 output comparison. The S1500 is similar to the XS15se in this type of data-set.
Tom V.
Power Sound Audio
oneeyeblind and ahblaza like this.
post #21551 of 21564 Old Yesterday, 12:10 PM
Quoted: 963 Post(s)
Liked: 2777
Also, forgot. The V1800s production schedule in on track at the moment. We should have most/all pre orders fulfilled by the end of this week..
Tom V.
Power Sound Audio
post #21552 of 21564 Old Yesterday, 12:31 PM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
I suspect I am getting a large amount of room gain, basically a rectangle with a single 30 inch opening at back corner. There were peaks of 117db in some of my runs.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21553 of 21564 Old Yesterday, 01:11 PM
ahblaza's Avatar
Quoted: 782 Post(s)
Liked: 689
Hey Guys, I need your help with putting my classified listing in my sig, PLEASE HELP, TIA
ahblaza is offline
post #21554 of 21564 Old Yesterday, 01:16 PM
Brian Fineberg's Avatar
Quoted: 1931 Post(s)
Liked: 1736
Alan P. Hooked you up in the other thread. Here is what he wrote:
Go to your for sale thread
Highlight the title of your thread, copy it (Ctrl-C)
Go to edit your sig and paste the title (Ctrl-V)
Go back to your for sale thread and highlight the URL in the address bar, copy it
Go back to edit your sig and highlight the title of your thread that you pasted in your sig earlier
Select the Insert Link icon above the edit window (looks like a globe with a chain link)
Past the URL you copied in step 5 and hit Enter
Done!
Alan P and oneeyeblind like this.
Brian Fineberg is online now
post #21555 of 21564 Old Yesterday, 02:15 PM
Quoted: 963 Post(s)
Liked: 2777
I might not have been 100% clear earlier Kluken but per your inquiry on the S1500s---I'd except you to feel dual S1500i subs offer several key advantages over a single 13Ultra in sealed mode..
1)Slightly deeper extension.
2)Approximately double the headroom(5-6dB difference) over most of the operating range and even increasing to near triple at either ends of the frequency spectrum(<20hz and >70hz).
3)Potential for dual subs to minimize the negative effects of the room boundaries---peaks and dips at the seating.
4)Your receiver has XT32 AND SUB EQ HT so it is almost a shame not to run duals..
5)I believe you'll be shocked by the size/performance balance on the S1500s.
Anyway, at $1799 you'd be saving $700 too---which would be a lot of new Blu-Rays!
Tom V.
Power Sound Audio
ahblaza likes this.
post #21556 of 21564 Old Yesterday, 03:13 PM
kluken's Avatar
Quoted: 142 Post(s)
Liked: 147
Tom V.
Power Sound Audio
too many damn decisions
What about the loss of corner loading? Will that not likely offset any gains over the PC-Ultra?
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21557 of 21564 Old Yesterday, 04:23 PM
bear123's Avatar
Quoted: 1034 Post(s)
Liked: 1560
...no one ever said "boy, I wish my subwoofer wasn't so powerful..."..
Tom V.
Power Sound Audio
Best quote ever. Tom, you have just won the internet. Signature worthy.
skip61, ahblaza and Hopinater like this.
bear123 is online now
post #21558 of 21564 Old Yesterday, 05:07 PM
ahblaza's Avatar
Quoted: 782 Post(s)
Liked: 689
I have dual PSA sealed subs in my home that are corner loaded to take advantage of room gain. I have them pulled out somewhat from the corners to avoid the boomy and muddy sound that can occur, I have measured excellent low end extension in the single digits, it is felt more than heard. The real plus is the mid bass slam 40-100 Hz, this is the area of the chest slam factor.
With one corner loaded sub the output was there but not evenly spread across all seats, adding the second smoothed out the FR at all locations. Adding dual subs will not give you deeper extension but it will have more output down low with plenty of headroom. I have XT32 SUBEQ HT and like Tom said so do you, why not use it........
ahblaza is offline
post #21559 of 21564 Old Yesterday, 06:59 PM
Hopinater's Avatar
Quoted: 619 Post(s)
Liked: 1640
Like I said, once you experience dual subs there's really no looking back!
ahblaza likes this.
Hopinater is online now
post #21560 of 21564 Old Yesterday, 07:04 PM
undsioux7's Avatar
So I have been playing around with the position of my 2 xv15's and finally tried them stacked in the corner. Wow is all I can say. Definitely more output.
audiofan1 and climber07 like this.
undsioux7 is offline
post #21561 of 21564 Old Yesterday, 08:36 PM
climber07's Avatar
Quoted: 211 Post(s)
Liked: 1128
Yessir! I tried half a dozen positions and dual stacked in the corner won hands down. I got lucky and the room null was in the middle of the room where no one sits.
lizrussspike and audiofan1 like this.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #21562 of 21564 Old Today, 12:27 AM
Quoted: 38 Post(s)
Liked: 73
Quote from Gunny:
Gunny suggested that to me as well, and have my duals XV15s stacked, and never looked back. Since the arrival of the V3600, I have them stacked in a corner.....
Now where is the reviews of all those who recently received their V3600s?
Last edited by lizrussspike; Today at 12:29 AM. Reason: didn't multi quote properly
post #21563 of 21564 Old Today, 04:44 AM
bad1550's Avatar
Quoted: 35 Post(s)
Liked: 25
Review hopefully soon
Just received yesterday
Movers scheduled to come today
Bob
oneeyeblind and Hopinater like this.
bad1550 is online now
post #21564 of 21564 Old Today, 05:19 AM
Hopinater's Avatar
Quoted: 619 Post(s)
Liked: 1640
Bob
WOW…dual 3600's. I'm very much looking forward to your impressions.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
