Official Power Sound Audio Subwoofer Thread - Page 724 - AVS Forum | Home Theater Discussions And Reviews
 31504Likes
post #21691 of 37127 Old 08-12-2015, 06:37 PM
JT78681's Avatar
Quoted: 1478 Post(s)
Liked: 1005
Originally Posted by kluken View Post
Yes, but then I don't have my V1800s yet so not sure how much lower than 16Hz I want to go :-)
As long as you are getting solid output down to at least 16hz you should be golden and I'm confident the V1800's will deliver just that.
ahblaza, sk373 and Hopinater like this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #21692 of 37127 Old 08-12-2015, 06:56 PM
chucky7's Avatar
Quoted: 1795 Post(s)
Liked: 1976
@ kluken,
If I were you, I wouldn't even consider anything else for 2 V1800s @ pre-order price. ( $500 in discount!!!) Well, if I could get 2 S1500s @ pre-order price, then I might. But the pre-order discount for 2 S1500s is only $200.
Look at it this way, your 2 V1800s will still be golden even if you use a bigger room for HT down the road. I can't say the same for a pair of S1500s.
ahblaza and Hopinater like this.
Panasonic TC-P55UT50
Pioneer SC-1222-K
Polk Audio LSiM703 / LSiM706c / RTiA3
JTR Captivator 1400
chucky7 is offline
post #21693 of 37127 Old 08-12-2015, 08:18 PM
ahblaza's Avatar
Quoted: 1875 Post(s)
Liked: 2083
@Alan , maybe you should leave well enough alone. It just sounds like a connectivity issue to me. Maybe the receptacles are older I don't know, but the wiggling is suspect to something amiss. Take the wall plate off and visually inspect the wire connections, sometimes they get a little loose and wiggling them may work for a while but it's not a permanent fix. Since they're both on the same circuit even if one is loose it will effect both outlets as they come from the same junction box. Visually check them out, it can't hurt.
I'm not a certified electrician but I've replaced numerous outlets in my older home because of the same problem you're having, I decided to put two 20 amp dedicated circuits in my room thus eliminating any other connected devices on the same line. Speaking of connected devices in line, it could be the mini and this could be happening before getting to the subs.
If everything looks good try my 3 in 1 oil tweak, I used to get a lot of arcing or like a static charge when plugging and unplugging components. Or you can just keep reading by candle light all night and let the 18s sit there looking good
Cheers Jeffrey
lizrussspike likes this.
ahblaza is offline
post #21694 of 37127 Old 08-12-2015, 08:23 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
Take the prongs on the power cords and bend them in slightly so the connection is snug...problem solved.
basshead81 is offline
post #21695 of 37127 Old 08-12-2015, 08:26 PM
ahblaza's Avatar
Liked: 2083
Why not do it right and replace the outlet........
kluken and oneeyeblind like this.
ahblaza is offline
post #21696 of 37127 Old 08-12-2015, 09:04 PM
FattyMcButterPants's Avatar
Quoted: 946 Post(s)
Liked: 950
Originally Posted by Brian Fineberg View Post
Httyd 2 is terrible for bass
For animated bass movies:
9
Incredibles
Finding nemo
Httyd
Thanks Brian, I thought both HTTYD movies had good bass, but for the life of me I can't remember why lol. I'll have to look into the others, I love Finding Nemo and Incredibles so those are great additions! Never seen 9 but I'll have to check it out.
Also thanks to everyone for talking Oblivion up so much. Already have that one and just need to queue it up - sounds like I'm in for a treat.
FattyMcButterPants is offline
post #21697 of 37127 Old 08-13-2015, 04:34 AM
Quoted: 393 Post(s)
Liked: 333
This is worse than being 8 and on xmas eve, my V1800s are on a FedEx truck roaming around town out for delivery...
8/13/2015 - Thursday
4:23 am On FedEx vehicle for delivery KENNESAW, GA
What's worse is I likely won't have time to do anything other than stare at them until Saturday even when they do show up ;-(
oneeyeblind, gbreda and Hopinater like this.
LG 65C7P
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #21698 of 37127 Old 08-13-2015, 04:39 AM
Quoted: 393 Post(s)
Liked: 333
Yup, outlet is very inexpensive, figure out what circuit breaker and turn it off then replace the outlet. Poor connections can create resistance or open circuit, which creates heat which in the end is not good. Last thing you want is unstable power with the swings in draw a sub pulls.
I ran 2 new 20amp dedicated lines one for each sub because I was not willing to screw around with not giving the subs all the clean power they want. Putting a line conditioner in between to make sure no spike or brown outs hurt them and all set.
LG 65C7P
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #21699 of 37127 Old 08-13-2015, 05:34 AM
JT78681's Avatar
Liked: 1005
9 has excellent bass and is well done. I'm sure you will enjoy it.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #21700 of 37127 Old 08-13-2015, 07:52 AM
Alan P's Avatar
Quoted: 5088 Post(s)
Liked: 3773
Cheers Jeffrey
Thanks again Jeff!
Tried that, made no difference...at least when I wiggle the plug (they are silent "at rest" now, so maybe that's what fixed that).
This is what I'm gonna do....what are they, like $3 each?
I can confirm that HTTYD2 is very weak in the bass department, especially compared to the first one.
Alan P is offline
post #21701 of 37127 Old 08-13-2015, 08:16 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
Because it is something easy to try before you take the next step which would be replacing the receptacle.
Sounds like Alan tried that already, so now it's time to replace the receptacle.
ahblaza likes this.
post #21702 of 37127 Old 08-13-2015, 11:17 AM
Quoted: 393 Post(s)
Liked: 333
Santa's Elves (FedEx) arrived!! He earned the tip I gave him, as you can see from my driveway ;-)
These things are huge, the listed dimensions do not let you realize how big they are, and heavy! Over 110bs each! I am so itching to at least fire one of these up tonight!
Thank you Santa (Tom)!! Can't wait to try them and give you all feedback!
If I am looking at serial number do I have V1800s #8 and #9 ?
ID:	884666   Click image for larger version
Name:	V1800 Boxes.jpg
ID:	884674   Click image for larger version
chucky7, Toe, ahblaza and 7 others like this.
LG 65C7P
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #21703 of 37127 Old 08-13-2015, 11:27 AM
lizrussspike's Avatar
Quoted: 660 Post(s)
Liked: 795
Please let us know what you think of the V1800s. Duals are the way to go. Well Done Sir!
lizrussspike is offline
post #21704 of 37127 Old 08-13-2015, 11:37 AM
chucky7's Avatar
Liked: 1976
The cheapest ones are $0.69 each or 10 for $4.90 at Home Depot...
Alan P likes this.
Pioneer SC-1222-K
JTR Captivator 1400
chucky7 is offline
post #21705 of 37127 Old 08-13-2015, 11:37 AM
Hopinater's Avatar
Quoted: 2294 Post(s)
Liked: 5712
Very Nice!.. It's always a good day when the PSA subs arrive!
westsdad likes this.
Hopinater is online now
post #21706 of 37127 Old 08-13-2015, 12:02 PM
Quoted: 393 Post(s)
Liked: 333
I will set one up in about an hour, but the size is intimidating ;-) Thinking the dual S1500 or V1500s would have been better fit from a l look perspective at least, but once I get blown out of my seat I will forget what they look like ;-)
They are going to dwarf my Klipsch RP-280Fs, going to need RF-7iis to be proportional
LG 65C7P
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #21707 of 37127 Old 08-13-2015, 12:21 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
Funny thing about size. The quality and impressiveness of the sound shrinks the sub size in many a person’s eye . I remember full well when I bought the XS30, I thought, “Man is this thing big, especially compared to my SB13.” Now, I think it’s not big at all and is a comfortable size.
Enjoy the audition!
Billy p, ahblaza, gbreda and 1 others like this.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #21708 of 37127 Old 08-13-2015, 12:45 PM
zeus33's Avatar
Quoted: 1549 Post(s)
Liked: 1393
Yep, it ranked 364th on the bass movie list versus 17th for the original.
zeus33 is offline
post #21709 of 37127 Old 08-13-2015, 12:46 PM
gbreda's Avatar
Quoted: 461 Post(s)
Liked: 706
Same thing went through my mind when I went from a BA PV600 to the XS30 and it happened again when I went to dual S3000i.
They get smaller the longer you own them.
Enjoy the new gear !
gbreda is offline
post #21710 of 37127 Old 08-13-2015, 01:43 PM
Hopinater's Avatar
Liked: 5712
Enjoy the audition!
Dsrussell speaks the the truth. The better a large sub performs the smaller it get in one's eyes (but not the wife's).
For example...Now when I look at my V3600 it doesn't look very big at all. Now it only looks like a compact refrigerator instead of a compact car.
I also agree with grebda. I suspect in another month or so the V3600 won't look much larger than a toaster.
ahblaza, gbreda, dsrussell and 1 others like this.
post #21711 of 37127 Old 08-13-2015, 01:45 PM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Now if only PSA subwoofers would keep our beers cold... better get on top of that, Tom and Jim!
Yippee-ki-yay...
cesar123 is offline
post #21712 of 37127 Old 08-13-2015, 01:47 PM
Hopinater's Avatar
Liked: 5712
That's why mine sits next to my kegerator. Best of both worlds.
oneeyeblind, ahblaza and westsdad like this.
post #21713 of 37127 Old 08-13-2015, 01:58 PM
perfectevolution's Avatar
Liked: 25
Call it the Sub Zero Woofridge!
Alan P, ahblaza, gbreda and 1 others like this.
perfectevolution is offline
post #21714 of 37127 Old 08-13-2015, 02:29 PM
Quoted: 393 Post(s)
Liked: 333
OK I could not resist getting at least one V1800 set up and tuned up. Excuse the rushed phone pic. I ran a few movie scenes and then a few initial songs. Nothing very critical yet. A few things, it does sound tighter down low compared to my PC-Ultra, not sure if that is the difference of down firing corner loaded vs front firing ported in additional to the bigger driver working so little.
I ran a quick 6 position Audyssey and noticed as expected due to the size of this driver I had to have the gain almost at zero and still Audyessy set sub to -11.5db. I think I should get some 12db attenuators as from what I have read they wind up being closer to 6db anyway.
Next and getting the duals set up will help this I hope, but the sweet spot has moved it seems. My PC-Ultra was in same exact spot and my seating is about 13-14 feet in front of right speaker. While the bass is good there if you to the left directly in the front line of the sub the gain is huge (you feel it in your chest) and also a bit boomy, very surprising as the sub is pointed directly into that left sofa and it was not that much with the Ultra in same position. I was thinking of leaving them ion the corners, but now surely want to bring them next to the credenza and push the R/L fronts further apart.
I could not resist running the Edge of Tomorrow opening and the V1800 handled it very well, I did hear the driver flutter, but that is likely just the 10Hz sound of the driver. It never dropped/rolled off so bad I could not hear it, but it was likely not very clean. Other scenes felt richer and seemed to have more depth.
I will spend more time this weekend with it, running it through more paces movies and music. This thing is a beast, thank goodness for furniture super sliders ;-)
LG 65C7P
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #21715 of 37127 Old 08-13-2015, 03:49 PM
Alan P's Avatar
Liked: 3773
What you talking about? That thing looks tiny!
Yeah, you should move your mains away from the stand regardless. It's not good to have the front baffles of your speakers level with the front of the stand (that goes for your CC as well, pull it out a couple inches if you can). I'd try the subs next to the stands and the mains further apart...and toed in.
mnc, oneeyeblind, ahblaza and 4 others like this.
Alan P is offline
post #21716 of 37127 Old 08-13-2015, 06:22 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Wow Tom... absolutely great job on the veneer options for the S1500 and S3000i!!!! I'm looking forward to seeing how good the MT-110 and MTM-210 look with the veneer options you have. Keep up the great work!
oneeyeblind likes this.
jhughy2010 is offline
post #21717 of 37127 Old 08-13-2015, 06:26 PM - Thread Starter
oneeyeblind's Avatar
Quoted: 262 Post(s)
Liked: 482
From facebook
The popular S1500 is now available in real wood, furniture grade veneer finishes. The available colors are (from left to right) espresso, cordovan, American cherry, and natural cherry. Also available, but not pictured is the black ash finish.
Prices start at $1,249.99 with Anti-Mode packages generously discounted. Lead times for all wood veneers are typically 2 weeks.
http://www.powersoundaudio.com/products/s1500
Facebook link
https://www.facebook.com/powersoundaudio?fref=nf
Prices: $1249.99 single veneered sub / $2399.99 (dual veneered subs)
ShaunH
oneeyeblind is offline
post #21718 of 37127 Old 08-13-2015, 06:28 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
A few thoughts... having the V1800 corner loaded doesn't make it sound "boomy"? I like your set-up a lot. I wonder if you wouldn't benefit from a wider sound stage by having your floor standing speakers as far apart as possible and then placing the V1800 equally between the TV stand and the left front speaker. This might still benefit from corner loading the sub but I think it could help it sound less boomy (if you are having the effect as I have) and also you'd benefit from a wider sound stage with the front mains.
oneeyeblind and ahblaza like this.
post #21719 of 37127 Old 08-13-2015, 06:37 PM
Hopinater's Avatar
Liked: 5712
I agree. Move the speakers out and toe them in a little (it might take some playing around to get it right). IMO having the mains a bit wider helps cast a better sound stage as well.
I would try the putting the subs where the speakers are and see how that works.
Enjoy, the sub looks beautiful.
post #21720 of 37127 Old 08-13-2015, 06:43 PM
Hopinater's Avatar
Liked: 5712
I like those veneers a lot. They are absolutely beautiful.
Oneeyeblind...I appreciate the way you let us see what's getting posted on the PSA Facebook page because I never think of visiting it so I would be missing out on all that current info if it wasn't for you. Thank you.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s7201 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
