Official Power Sound Audio Subwoofer Thread - Page 748 - AVS Forum | Home Theater Discussions And Reviews
 24200Likes
Old 09-18-2015, 05:56 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
Originally Posted by lizrussspike View Post
Thanks for your help Bass. I was wondering about that. I would need a 8033 to accomplish that? I see that I can do a 2.2, but I guess I need to read up on how to connect that sequence, as the mains are running off an amplifier. I have 9 speakers, but would like to integrate the mains. Did you use the AMDC to do both the mains and multiple subs?
No Audyssey should take care of that. The AMDC goal here is to get both subs playing nice together, then audyssey should blend the mains with the subs.
You can use REW to take a combined measurement to verify the response or if it sounds good then leave it as is.
ahblaza likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-18-2015, 06:23 PM
lizrussspike's Avatar
Quoted: 542 Post(s)
Liked: 662
Got it Bass. I ran the storm scene from MMFR and was not let down. I am happy with the current sound. I will demo more tomorrow when the girls are gone, maybe throw down some Tron or FotP!
ahblaza likes this.
lizrussspike is offline
Old 09-18-2015, 06:33 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
There you go!! Try switching the AMDC from active to bypass on those scenes so you can hear the difference.
ahblaza likes this.
Old 09-18-2015, 07:32 PM
zoepup's Avatar
Quoted: 125 Post(s)
Liked: 38
starting my calibration now
Marantz SR6010
2 PSA XSse30's
Room is 26x24.
set AVR to 80hz
Anti-Mode 8033
I had subs in almost opposite corners. The response kept getting better the closer I moved them. Now they are about 8ft apart. Controls face the back wall and grills face each other.
Running REW with no smoothing I get no bass below 28hz with AM in bypass mode... IT doesn't get above 80db until about 48Hz. Then it stays above... hmmmmm
after calibrating with AM I get a couple bigger nulls and some smoothing. 35db lift looks best but it still looks better with AM in Bypass.
Still learning
MY Build in Progress >>> My Home Theater Build
Living Room: Samsung PN60F8500, KEF 3005 5.1, Marantz SR6003
HT: Marantz SR6010 AVR, 2-PSA XS30se subs, Samsung 65" JS8500 4k, Sonus Faber Venere 2.5, Venere Center and Walls, Sony 77es CD changer, Sony BDP-BX2 Blue Ray
In storage: Mirage M7si, Mirage LF-150, Marantz SR7200
zoepup is offline
Old 09-18-2015, 08:45 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
The base anti-mode is not designed for dual subs. So unless you have them placed equidistant from the LP then it is probably not doing to do a very good job. If you have them equidistant then it will eq them as one just like audyssey does.
Old 09-19-2015, 05:27 AM
zoepup's Avatar
Quoted: 125 Post(s)
Liked: 38
That's odd. Il have to talk to Tom. He sold me the complete package. I don't recall him saying they had to be equidistant. But my memory could be bad
Any reason I have almost no bass below 28hz? Even after moving subs 20+ times. These things are heavy
zoepup is offline
Old 09-19-2015, 06:40 AM
Tom Vodhanel's Avatar
Quoted: 1643 Post(s)
Liked: 4740
Marantz SR6010
2 PSA XSse30's
Room is 26x24.
set AVR to 80hz
Anti-Mode 8033
Still learning
Start by integrating one sub with the system. Once you have that nailed it is usually easy to get the second dialed in. Also, an easy way to sanity check the measurement rig is to place the mic a few inches from one cone on one of the subs. You should see a FR pretty smooth down to the 12-15hz range.
Tom V.
Power Sound Audio
oneeyeblind and ahblaza like this.
Tom Vodhanel is offline
Old 09-19-2015, 06:41 AM
Liked: 4740
They don't have to be equidistant. That is a nice to have for sure but with home audio there will always be compromises in place. Would spending much more on the dual core be of benefit? Possibly. But I bet once you have the 8033 dialed in the differences would be subtle.
Tom V.
Power Sound Audio
Old 09-19-2015, 07:29 AM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
The base anti-mode does not set individual delays for each sub. So if they are not equidistant then most likely you will have a phase issue at some frequencies. The nice thing with the ICE amp is you can adjust the time delay on one sub to get both subs in alignment. REW would be really helpful for verifying the changes.
Old 09-19-2015, 07:31 AM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
Tom V.
Power Sound Audio
Oh, I thought you told me they needed to be equidistant when we discussed which Anti-mode to go with?
PS I sent you a email and never got a reply.
Old 09-19-2015, 11:27 AM
Liked: 4740
Originally Posted by Dr bud View Post
Just out of curiousity..has anyone here had or owned a def tech trinity sub that could compare a psa sub to????
Sent from my SM-N910V using Tapatalk
The DT(and GE) subs seem to prioritize tiny enclosures over performance for the most part. I've seen the measurements for a bunch of DT stuff(4000,6000,8000 and a couple others) and one or two GE subs published and they all performed poorly. You could probably take the 8000 data and 2x it to get an idea of what the trinity would do?
Tom V.
Power Sound Audio
oneeyeblind likes this.
Old 09-19-2015, 11:29 AM
Liked: 4740
Equidistant is ideal. But you can compensate for that with the time delay/phase setting on one sub too. It is just a matter of how much time is available for tweaking. Also, the dual core is significantly more powerful and flexible. I just try to steer folks to the least expensive option that I feel will provide the best value.
My bad on that email. Been one of those weeks...I'll circle back now.
Tom V.
Power Sound Audio
ahblaza and basshead81 like this.
Old 09-19-2015, 12:00 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
Yea the ICE amp offers a lot of flexibility with the Time Delay feature. I agree he should be able to get things dialed in pretty good with the base anti-mode since both subs have independent time delays. I am still stuck in the past with Bash components.
ahblaza likes this.
Old 09-19-2015, 12:15 PM
Mike Butny's Avatar
Quoted: 349 Post(s)
Liked: 624
You should trade your subs in for 3 V1800's. I know you're reference right now in the mid to high teens but more output and headroom never hurt anyone . If you ever build a dedicated room you can always add another or use them as a trade in. Just a thought.
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & XS30SE subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is offline
Old 09-19-2015, 12:55 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
Dang it...stop feeding my brain such temptation!! Logging off now...bye.
Old 09-19-2015, 12:58 PM
Dr bud's Avatar
Quoted: 83 Post(s)
Liked: 78
Tom V.
Power Sound Audio
Yes there subs did and do kinda lack.the trinity and the supercube reference are the only good ones they ever made.
Dr bud is offline
Old 09-19-2015, 04:48 PM
Liked: 4740
FYI,
We're doing another production run for the XS15se and XV15se in a few weeks. We should have the website updated tonight so anyone can place their orders. If anyone has been waiting(and I must have gotten 50! inquires about these recently......PLEASE don't hesitate to order. There is going to be a 3-4 week lead time but once this production run is sold out it may be a LONG time before we can fit another one into the cabinet schedule.
Tom V.
Power Sound Audio
Old 09-19-2015, 05:52 PM
Defcon's Avatar
Quoted: 1117 Post(s)
Liked: 581
FYI,
Tom V.
Power Sound Audio
Hi Tom, this is great news. I was told in the chat that there's also a chance the XV/XS will show up in the outlet, is that still the case?
Defcon is offline
Old 09-19-2015, 06:42 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
I sent a email to Tom just to see what I would be looking at to trade. After a few emails it was determined that the upgrade would not be worth the cost. The V1800 is only 1.4db up on a XV15se in the 16-25hz range, but has 4-5db more above 30hz. The V1500 actually has a tad more output then the 1800 in the 16-25hz.
IMO it would only be worth upgrading to gain a bit more output down in the lowest bass. I already have more then enough upper bass for my room.
Tom confirmed that the AMDC was a better investment because I can boost the low end on my current setup and net some deeper extension.
Here is the new comparison charts.
Old 09-19-2015, 06:45 PM
Dr bud's Avatar
Quoted: 83 Post(s)
Liked: 78
Holy crap.i did not expect those numbers from the s3600.i knew it would be good. I figured 2 to 3 dbs over the s3000i...deal sealed. I have to go s3600.holy balls
Dr bud is offline
Old 09-19-2015, 07:15 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
Yes the V3600 is a BEAST!!
lizrussspike likes this.
Mike Butny's Avatar
Quoted: 349 Post(s)
Liked: 624
Bass: It looks like you need to trade 2 of your xv15se in for 1 v3600i and after the Wife gets over the shock (6-9 months) you trade in the last xv15se for another V3600i and enjoy the next 10 years not worring about bass :grinning:
Old 09-19-2015, 07:55 PM
Hopinater's Avatar
Quoted: 1909 Post(s)
Liked: 4695
LOL...The V3600 makes a nice addition to any family. Just set it in place and suddenly you have a new best friend.
Mike Butny and lizrussspike like this.
Hopinater is offline
Old 09-19-2015, 08:03 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
I must admit a pair of V3600's would be the end of the road for bass. I could not imagine another 6-10db of headroom across the board. Be reference capable down into the 12hz range.
Mike Butny and ahblaza like this.
Old 09-19-2015, 08:33 PM
Dr bud's Avatar
Quoted: 83 Post(s)
Liked: 78
I missread.thought that was the s3600i.sorry
Dr bud is offline
Old 09-19-2015, 08:35 PM - Thread Starter
oneeyeblind's Avatar
Quoted: 256 Post(s)
Liked: 467
The S3600I still kicks ass.
Taken from
http://www.powersoundaudio.com/products/s3600i
Mike Butny likes this.
ShaunH
oneeyeblind is offline
Old 09-19-2015, 08:40 PM
Dr bud's Avatar
Quoted: 83 Post(s)
Liked: 78
I did expect the 16 to 25hz to be at least 3dbs more than the 3000..either way. I know I'm obsessed with numbers.i think the v3600 would leave me doubtless.but the 3000 would prolly be enough. So I'll stay middle ground I think and stick with the s3600i decision unless tom thinks otherwise
Dr bud is offline
Old 09-19-2015, 09:00 PM - Thread Starter
Quoted: 256 Post(s)
Liked: 467
I forgot to add. The obligatory T-18 needs an upgrade more power, bigger drivers and so on. But at this point to get more would likely require bigger drivers.
ShaunH
Old 09-19-2015, 10:12 PM
basshead81's Avatar
Quoted: 200 Post(s)
Liked: 5615
T-21 Terminator.
Old 09-19-2015, 10:18 PM
Mike Butny's Avatar
Quoted: 349 Post(s)
Liked: 624
A T-24 would be killer.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
