Official Power Sound Audio Subwoofer Thread - Page 817 - AVS Forum | Home Theater Discussions And Reviews
 24324Likes
post #24481 of 32728 Old 12-14-2015, 05:52 PM
moussaka's Avatar
Quoted: 44 Post(s)
Liked: 69
Originally Posted by Alan P View Post
Yeah, you should measure CC+subs (HDMI output 3 with bass management engaged) if you are mostly movies, Mains+subs (HDMI output 1 & 2 with bass management engaged) if mostly music.
The CC+subs and Mains+subs graphs will show you how well the crossover splice is working...Audyssey gets it wrong most of the time requiring you to do the sub distance tweak to bring it back into line.
So here is the subs+CC. I have it crossed at 100Hz. I have that dip around 90Hz pretty consistently throughout all my measurements so I dont think that is a result of the crossover doing something wonky. I messed with the sub distance and up or down it makes a worse graph so I think this is about as good as I'll get.
One thing I'm a bit confused about though. When I measure with just subs, they're pretty even across 100dB. When i add the CC in it drops ~10dB with pretty much the exact same graph. Any reason for that?
Panasonic 60VT60 | Denon x2000 | EMP E55Ti | E56Ci | E55Wi | PSA S3000i x2
moussaka is online now
post #24482 of 32728 Old 12-14-2015, 06:16 PM
vausen's Avatar
Liked: 9
Order for two V3600i has been placed for our church's new digital pipe organ. 32' pipe produces a 16Hz tone. Tom has been just a phone call away giving his advice on the system. Impressive and definitely helped him get the sale.
I'll update when we perform the install and let you all know what the congregation thinks. Here are the speakers we are replacing:
4 - FR1
2 - SW6
We're replacing the mains with 4 - JBL SRX835P
Merry Christmas!
Deacon Tate
Christ Church Santa Clarita
vausen is offline
post #24483 of 32728 Old 12-14-2015, 07:37 PM
checker9's Avatar
Quoted: 1119 Post(s)
Liked: 177
How do you you measure just subwoofer or subwoofer and center? Do you physically disconnect speakers or do some receivers have the ability to cut output to certain speakers without disconnect the wires?
rossandwendy likes this.
checker9 is online now
post #24484 of 32728 Old 12-14-2015, 08:58 PM
basshead81's Avatar
Quoted: 201 Post(s)
Liked: 5634
Yes most newer avr's allow you to turn off different channels.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #24485 of 32728 Old 12-14-2015, 09:01 PM
moussaka's Avatar
Quoted: 44 Post(s)
Liked: 69
read the getting started with REW link in Alan P's sig.
If you use the ASIO4ALL drivers and HDMI you can just select which plays. If you use Java you'll have to unplug. I think*
post #24486 of 32728 Old 12-14-2015, 09:25 PM
checker9's Avatar
Liked: 177
Do you know what the option would be called? I find nothing in my AVR's receiver nor browsing through its settings that would do it.
post #24487 of 32728 Old 12-14-2015, 09:27 PM
checker9's Avatar
Liked: 177
I noticed in your signature that you have a Denon X2000W. I have X2200W so it should be close to same in settings. Do you know of a setting to turn off channels?
post #24488 of 32728 Old 12-15-2015, 04:26 AM
lizrussspike's Avatar
Quoted: 547 Post(s)
Liked: 665
4 - FR1
2 - SW6
Merry Christmas!
Deacon Tate
WOW! Where exactly is your church located? I would stop by for a worship set for sure!
Merry Christmas, and God Bless!
Russ
brahman12 likes this.
lizrussspike is offline
post #24489 of 32728 Old 12-15-2015, 05:49 AM
Hopinater's Avatar
Quoted: 1920 Post(s)
Liked: 4720
4 - FR1
2 - SW6
Merry Christmas!
Deacon Tate
Congratualtions to your entire congregation, they should be loving the addition of that V3600 during the worship music.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
post #24490 of 32728 Old 12-15-2015, 06:13 AM
moussaka's Avatar
Quoted: 44 Post(s)
Liked: 69
No, I just use REW to isolate channels
post #24491 of 32728 Old 12-15-2015, 07:03 AM
basshead81's Avatar
Quoted: 201 Post(s)
Liked: 5634
on my Yamaha 1040 I go to in the option where you select speaker size and select Large, Small, or None.
post #24492 of 32728 Old 12-15-2015, 07:17 AM
checker9's Avatar
Liked: 177
Thanks. I checked that, I can turn center and surrounds to 'none' but fronts only have small or large choice. I guess I can just unplug those two and turn the others to 'none.'
post #24493 of 32728 Old 12-15-2015, 07:19 AM
vausen's Avatar
Liked: 9
4 - FR1
2 - SW6
Merry Christmas!
Deacon Tate
Russ
Anyone who wants to hear two V3600i's put to good use in a large venue is welcome to stop by. We have an amazing organist and are hoping to have the system installed before the Christmas eve service where we will be singing many traditional Christmas hymns. Just Google Christ Church Santa Clarita for our website.
Pax,
Deacon Tate
vausen is offline
post #24494 of 32728 Old 12-15-2015, 09:39 AM
Alan P's Avatar
Quoted: 4882 Post(s)
Liked: 3505
Looks like in your case, Audyssey got the splice right...you're good to go! Nice looking graph BTW.
The LFE channel (REW HDMI CH4) outputs 10dB higher than all other channels.
What is the LFE channel?
If you are using REW with HDMI; to measure just the subwoofer, use HDMI CH4 (LFE, will measure 10dB higher)...to measure CC+sub use CH3 (CC) with bass management engaged (CC set to "small").
For reference:
CH1 = FL
CH2 = FR
CH3 = CC
CH4 = LFE
moussaka likes this.
Alan P is offline
post #24495 of 32728 Old 12-15-2015, 10:03 AM
moussaka's Avatar
Quoted: 44 Post(s)
Liked: 69
Haha, well that makes sense then!
Thanks again for your input, I really appreciate it.
post #24496 of 32728 Old 12-15-2015, 11:46 AM
checker9's Avatar
Liked: 177
For reference:
CH1 = FL
CH2 = FR
CH3 = CC
CH4 = LFE
Thanks. So with subwoofer "on" in bass management and that speaker set to small, any channel will be that speaker + sub right?
Also, can I use the java driver to do that, or do I have to use ASIO4ALL?
post #24497 of 32728 Old 12-15-2015, 12:00 PM
Alan P's Avatar
Liked: 3505
Correct, as long as you're not in Direct or Pure Direct mode (they omit the subwoofer...usually).
Yes you can use Java (but why would you if you have HDMI??), but if you want to measure FL or FR separately, you'll have to disconnect speaker cables.
Alan P is offline
post #24498 of 32728 Old 12-15-2015, 12:37 PM
checker9's Avatar
Liked: 177
I had a problem installing the ISO drivers before. So what speaker choices, in isolation, would you have with the java drivers?
post #24499 of 32728 Old 12-15-2015, 12:51 PM
JT78681's Avatar
Quoted: 1391 Post(s)
Liked: 922
^^^ I don't miss going through some of this BS myself earlier in the year when I too was trying to get REW and my mic setup. No more measuring for me now I'm just kicking back enjoying my system. There is only so much tinkering one should do.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #24500 of 32728 Old 12-16-2015, 06:24 AM
Tom Vodhanel's Avatar
Quoted: 1647 Post(s)
Liked: 4766
Hi all,
I mentioned earlier that the V1500 is out-of-stock until January. I should have also taken the time to point out the new 15V model is nearly a "no compromise" plan B. From about 18-20hz and up, these two models are most/less identical. Only in the very narrow bandwidth of 15-20hz will the V1500 show any advantage at all. This is due to the larger enclosure+slightly lower tuning point. But, overall, I bet 99% of the time we wouldn't be able to tell one from the other in a listening session. The 15V uses the same ICE amplifier module+custom DSP and the same 15" driver as the V1500. Even though we won't begin shipping until next week I'm betting this will be our biggest seller in 2016. The price/performance/size ratio is just about ideal as we can get.
http://www.powersoundaudio.com/products/15v
Once new 15V owners start posting their thoughts my biggest concern is our cabinet vendor keeping up..
Tom V.
Power Sound Audio
kelly.mcaloney likes this.
Tom Vodhanel is online now
post #24501 of 32728 Old 12-16-2015, 09:13 AM
Alan P's Avatar
Liked: 3505
You can isolate any speaker, just depends on how many wires you want to disconnect.
Alan P is offline
post #24502 of 32728 Old 12-16-2015, 09:23 AM
checker9's Avatar
Liked: 177
I can turn off the surrounds and center and subwoofer via AVR. Only the fronts cannot be turned off, so I guess I can disconnect them, then turn others off as needed. Besides the manually hassle, are there any other downsides in doing it that way versus the asio drivers (I would prefer not to install them)?
post #24503 of 32728 Old 12-16-2015, 09:40 AM
Parrish's Avatar
Quoted: 26 Post(s)
Hello all-
Has anyone here had any success combining t-18s with v3600is using dual core antimode? if running the sealed subs and the vented subs separately through the antimode shouldn't it be able to equalize?
Coton de Tulear-IndyFab-Kuro-XBR8-Sharp Elite-LG OLED - Current Loves of my life.
Parrish is offline
post #24504 of 32728 Old 12-16-2015, 01:45 PM
Alan P's Avatar
Liked: 3505
That will work just fine.
Are you scared of ASIO or something??
Alan P is offline
post #24505 of 32728 Old 12-16-2015, 01:48 PM
Alan P's Avatar
Liked: 3505
Originally Posted by Parrish View Post
Hello all-
In order to successfully integrate sealed subs with vented subs I'm afraid it's going to take more than an Antimode. You would need a way to separately and carefully EQ each subwoofer (i.e. REW + MiniDSP).
Do you already have the T-18s or the V3600s? What are your reasons for wanting to integrate the two?
Alan P is offline
post #24506 of 32728 Old 12-16-2015, 08:11 PM
cviper's Avatar
Quoted: 25 Post(s)
Liked: 40
Well the day has finally arrived! My v3600i arrived early this afternoon, man that packing job is no joke. Tom, awesome job! The guy who dropped it off thought it was a fridge of some sort. This thing is a beast, I knew it was going to be big, but dang! Its quite impressive to witness in person. And the build quality is first class. I haven't had much time today to do anything but hook it up and listen to a few songs and parts of some bass heavy movies. First impression.. Insanity.. Its just pure effortless power my RSW-15 never knew. Its not even a fair fight, night and day difference, and this is just with an initial hook up with very little tweaking, calibration, and no sub crawl. I'll have some time tomorrow to tinker with everything.
Thanks again Tom for taking the time to answer questions, and being available to help. You make a top notch quality product sir!
Just for fun, here's a few pics.
Speakers: Klipsch RF-7 II, RC-64 II, RS-62 II, RB-81 II, PSA v3600i
Audio: Denon 4520ci with B&K Reference 200.7
Video: Samsung PN648500
Misc: PlayStation 4, Xbox One, Wii U, Apple TV, Chromecast
cviper is offline
post #24507 of 32728 Old 12-17-2015, 03:55 AM
Quoted: 547 Post(s)
Liked: 665
cviper,
What a beautiful sub! I understand what you are saying, because the V3600 is such a big and awesome beast! Let us know what you think after you get thru your weekend! It is as you said, effortless for the V3600! Happy Holidays!
Russ
cviper likes this.
post #24508 of 32728 Old 12-17-2015, 05:34 AM
JT78681's Avatar
Liked: 922
@cviper
You know it's big when you see pictures and know the dimensions, but it's always bigger in person. Reminds me of when I got my first real sub the Outlaw LFM-1 EX. All I could do was just laugh at the sheer size of it because I was coming from a little 8" Pioneer sub that I thought was the sh**.
P.S.
I just re-read that first sentence and that's what she said.
cviper, basshead81 and Roadwar like this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #24509 of 32728 Old 12-17-2015, 06:22 AM
Hopinater's Avatar
Liked: 4720
@cviper … I'm glad you were able to get that bad boy delivered before the weekend so you can have time to get it dialed in and play around with it. As you have already noticed it has pure effortless bass. My prediction is you will spend much of this weekend sitting in your HT giggling with delight as you hear what the V3600 can do. Time to re-watch your favorite bass movies.
cviper and brahman12 like this.
post #24510 of 32728 Old 12-17-2015, 07:33 AM
Liked: 4766
The fun part is, 90% of those who pop into chat/call me would consider the rsw15 to be *huge*. On AVS...the V3600i is considered a nice size...
Be sure to let us know if you bump into any setup or calibration questions,
Tom V.
Power Sound Audio
Mike Butny, oneeyeblind and gbreda like this.
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
