Official Power Sound Audio Subwoofer Thread - Page 871 - AVS Forum | Home Theater Discussions And Reviews
 22535Likes
post #26101 of 31513 Old 04-30-2016, 01:00 PM
pclausen's Avatar
Quoted: 137 Post(s)
Liked: 105
Very much looking forward to playing with the new s3600i come Wednesday!
In the meantime, I can always go down into my main HT in the basement and get my bass fix.
jsmiddleton4 likes this.
pclausen is offline
post #26102 of 31513 Old 04-30-2016, 04:56 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
Originally Posted by pclausen View Post
Just placed an order for a s3600i. Just a single one for now, lol.
It will be replacing a 15 year old Klipsch KSW 15. Do you guys think I'll notice a difference?
If you are blind and deaf, probably not. Actually, you probably still would. So yeah.
basshead81 likes this.
bear123 is offline
post #26103 of 31513 Old 04-30-2016, 06:37 PM
jsmiddleton4's Avatar
Quoted: 590 Post(s)
Liked: 200
I am getting around to doing audio calibration on my new S1500. Need some help in understanding what needs to be adjusted.
MCACC on a Pioneer 1124.
Reports SW is 22 feet away when its about 10. Yes I know, that's not really a problem given the how the measurement is made, it is adjusting it after all, etc.
In terms of the SW amp adjustments I also understand the Room Size and Delay impact this measurement.
But which way?
Bigger room size make distance shorter? Delay?
I don't know which options on the amp would bring the distance measurement closer to actual distance.
What do I check on the PSA S1500 to dial that distance in?
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #26104 of 31513 Old 04-30-2016, 06:42 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
But which way?
I would leave the distance as is unless you have a null at the MLP. The DSP in the sub amp causes delay which is interpreted by the AVR calibration as distance. It is normal.
Hopinater likes this.
climber07 is offline
post #26105 of 31513 Old 04-30-2016, 06:47 PM
Quoted: 590 Post(s)
Liked: 200
"It is normal."
I'm okay with that. I'm just trying to understand what the settings on the SW do and how they impact things like the distance setting.
The dynamics between the receiver's auto calibration stuff and having settings on the amp are still unclear to me. Seemed like this was a good real world measurement that allows me to understand the impact of those settings.
post #26106 of 31513 Old 04-30-2016, 07:47 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5227
AVR distance setting is just another term for delay. The calibration adjusts this setting accordingly so the speakers and sub deliver there intended frequency range being played back on time to the LP.
ICE amp Room size control adjusts the amount of attenuation or roll off to the frequency response below 30hz. Large means no attenuation, small means full attenuation up to -12db.
ICE amp time delay is the same thing as the subwoofer distance control in the AVR. However if you have multiple subs, this feature could be beneficial in getting your subs in phase with each other at all frequencies.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #26107 of 31513 Old 04-30-2016, 08:38 PM
Quoted: 590 Post(s)
Liked: 200
Thanks but that's not exactly what I'm asking.
So if I turn which setting on the SW and which way will I see the distance in the AVR get shorter? Get longer?
And if I set the room size to anything, I run MCACC, does MCACC reset it anyway?
So when using MCACC, YPAO, Audessey, jsut set room size to large and let the AVR do its thing?
I'm not asking about the individual settings on the SW.
I'm asking about the dynamic interplay between those settings and what MCACC is doing.
post #26108 of 31513 Old 04-30-2016, 09:22 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
The more delay (clockwise on the delay knob) the further the distance in the AVR cal.
The less delay (counter-clockwise) the closer the distance in the AVR cal.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
post #26109 of 31513 Old 04-30-2016, 10:00 PM
Quoted: 590 Post(s)
Liked: 200
Thanks. Now I need to see how the things MCACC reports like Reverb, S Wave, etc., equate to what's on the sub woofer. Should would be nice if terms for like things used the same term across the board.
post #26110 of 31513 Old 05-01-2016, 05:55 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5227
What climber said...and you want to run calibration with the room control set to large. Then you can adjust it post calibration if you feel the need.
post #26111 of 31513 Old 05-01-2016, 06:48 AM
Quoted: 590 Post(s)
Liked: 200
Thanks basshead. I did precisely that. Set the room setting to Large and than reran MCACC. Running the full blown MCACC for the reverb, pro eq, etc., takes some time. My wife was patient as I messed with some things knowing Live Free or Die Hard and Aliens was on deck to test the bass.
Real world in my home means the subwoofer is not ideally located nor is my home theater setup in the most bass friendly room. It is what it is. I'm not able to hang bass traps, rearrange furniture, etc., just for subwoofer response.
Trying to understand the options on the SW, what I see in MCACC, dialing adjustments in, is not as easy as it seems, at least to me, with the way terms are named, the variables that MCACC tossing in, etc.
There's also the missing piece regarding "when you hear this...you need to change that this way..." information.
I am trying to read through the thread on using MCACC step by step. Which is great information. So far I haven't come across what I'm looking for.
"That grenade explosion was a bit subdued. You need to change MCACC to the Time Projection of 80ms and set the room size to medium on the SW and re-run MCACC...." kind of direction.
There is an endless amount of information about one piece of the picture. There, at least in my humble opinion, is almost no information that addresses the dynamic interplay, or variables, of these automatic calibration algorithms and SW settings with DSP stuff being built in.
The good news is alien blowing up grenades, Ripley's "Get away from her bitch" scene and Sgt. McClane's semi-truck getting blown to bits by a F35 sounded amazing. With our SVS PB12-SVS it sounded good. With the S1500 our couch vibrated. Was really enjoyable.
post #26112 of 31513 Old 05-01-2016, 10:28 AM
bgtighe23's Avatar
Quoted: 1509 Post(s)
Liked: 844
PSA XS15se: how does it compare to the rest in its price range?
I know it's discontinued, but there's a pair locally for sale.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #26113 of 31513 Old 05-01-2016, 10:50 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Buy them at a good price and then stay away from this forum you will be happy haha
Holiday121 is offline
post #26114 of 31513 Old 05-01-2016, 11:59 AM
Hopinater's Avatar
Quoted: 1783 Post(s)
Liked: 4394
I think it's very similar to the 15S. If they are around $800 or less for each I would seriously consider them. What's the asking price?
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #26115 of 31513 Old 05-01-2016, 12:53 PM
bgtighe23's Avatar
Liked: 844
The XS15se was priced at $799 new.
post #26116 of 31513 Old 05-01-2016, 02:36 PM
brahman12's Avatar
Quoted: 166 Post(s)
Liked: 290
Taking the Plunge!!!
Just bought two v3600i's from Tom....we chatted for about 20 mins...my final questions answered...and the rest is history, lol. Hopefully I receive them in the middle of the week...will be setting up the rest of my new theater space before that and then when heckyll and jeckyll arrive...I should be ready to rock...I haven't watched a movie in my theater room for over two months since I moved to the new place. Can't wait....whata weekend...NFL draft followed by home theater nirvana....
brahman12 is offline
post #26117 of 31513 Old 05-01-2016, 03:38 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5227
Pretty much identical to the 15s other then it has a Bash amp instead of ICE.
post #26118 of 31513 Old 05-01-2016, 03:45 PM
brahman12's Avatar
Quoted: 166 Post(s)
Liked: 290
Thanks AVS Family
Toe, Hopinator, Digler, Allan and all the other bros that chimed in...your input did make a difference and it was all greatly appreciated. I was almost captivated by the new JTR Captivator 4000 ULF, the JTR Orbit Shifter, and dual Submersive HP's....in the end, this thread, your posts and responses, and Tom's patience with me sealed the deal. Gracias to you all....whenever I get that "oh yeah, this is awesome" feeling....I will be sharing it with you. The hi-fi high is coming to town baby...gotta dial them in the best that I can with the anti-mode (gonna try to do the bass crawl too, but may be difficult by myself. Perhaps I'll use the svs subs during the crawl and then place the PSA's in the places discovered with the svs pc subs...or would the output/power differrences not be a good match for this adjusted technique? I believe I read something similar in this thread or another subwoofer thread.
Toe, Mike Butny, ahblaza and 1 others like this.
post #26119 of 31513 Old 05-01-2016, 04:46 PM
Hopinater's Avatar
Liked: 4394
That low? I thought that was the XS15 wasn't it? The XS15se was more expensive IIRC, but I could very well be wrong. Well, either way he ought to be able to get a great deal on them now then.
post #26120 of 31513 Old 05-01-2016, 04:59 PM
Hopinater's Avatar
Liked: 4394
Congratulations and welcome to the PSA family (and you're more than welcome for the posts). In my humble opinion this thread is one of the best one's on AVS. The guys here are super helpful and supportive and will go to almost any length to help others out. It's part of the reason I love being part of this tight group of guys.
If you do the sub crawl with your smaller subs then those locations should work for the Big Boys once they arrive. On a side note if you get a SPL meter that will help you locate those locations better than the sub crawl. And if you really want to dial it all in then REW is the way to go.
Mike Butny and brahman12 like this.
post #26121 of 31513 Old 05-01-2016, 05:00 PM
bgtighe23's Avatar
Liked: 844
That low? I thought that was the XS15 wasn't it? The XS15se was more expensive IIRC. Well either way he ought to be able to get a great deal on them now then.
On mobile, so I'll just upload the screenshot I took.
post #26122 of 31513 Old 05-01-2016, 05:06 PM
Hopinater's Avatar
Liked: 4394
Well that answers that. A little research goes a long way I guess.
post #26123 of 31513 Old 05-01-2016, 06:59 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5227
Actually the XS15 was 749.00 and the XV15 was 799.00.
post #26124 of 31513 Old 05-01-2016, 07:16 PM
bgtighe23's Avatar
Liked: 844
While you're right, it doesn't pertain to the discussion about the XS15se's price.
I would edit out the word actually in your post, basshead (26,168)
post #26125 of 31513 Old 05-01-2016, 07:51 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5227
why? It pertains to the thread and is about PSA products.
post #26126 of 31513 Old 05-02-2016, 12:45 AM
bgtighe23's Avatar
Liked: 844
Dunno. Curious if you would
post #26127 of 31513 Old 05-02-2016, 06:03 AM
Hopinater's Avatar
Liked: 4394
What?
Mike Butny likes this.
post #26128 of 31513 Old 05-02-2016, 08:19 AM
Toe
Toe's Avatar
Quoted: 1467 Post(s)
Liked: 1833
Congrats and report back once you get them up and running!
brahman12 likes this.
Toe is online now
post #26129 of 31513 Old 05-02-2016, 08:20 AM
bgtighe23's Avatar
Liked: 844
Idk I messed up somewhere....
Sunday's are my Monday's (work nights).
Still reading up some the XS15se subs
post #26130 of 31513 Old 05-02-2016, 04:08 PM
ahblaza's Avatar
Quoted: 1497 Post(s)
Liked: 1596
Hey guys, I know this is a PSA sub thread but I'm in the market for a new BD player with DVD-A playback and SACD and a good two channel analog output section for stereo listening. I have a Panny 500 now and it's very good for what it does but it's old and after hearing especially from Toe how great multi-channel music sounds I'm hooked....TIA
ahblaza is offline
Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , v1500 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
