Official Power Sound Audio Subwoofer Thread - Page 951 - AVS Forum | Home Theater Discussions And Reviews
 18527Likes
post #28501 of 28522 Old Today, 05:57 AM
joeyvaz's Avatar
Quoted: 66 Post(s)
Liked: 29
Another thought: what is the proper (or most agreed upon) steps for calibration? Sub placement, AVR calibration, REW, room treatment in that order? Or is there a different, more agreed upon, route to take?
Thanks again!!!
joeyvaz is offline
post #28502 of 28522 Old Today, 06:04 AM
Brian Fineberg's Avatar
Quoted: 3357 Post(s)
Liked: 3217
Thanks again!!!
place sub...take REW measurements...move sub repeat...find the best location for the sub...THEN run AVR calibration.
room treatments for bass need to be 4-6 feet deep to make any real impact to the subwoofer frequencies...so worry about broadband room treatments....but that isnt for this thread
joeyvaz and brahman12 like this.
JVC RS400 4K PJ | Denon x7200WA 7.2.4 ATMOS/DTS-X |Emotiva XPA-200 gen2 | DIY 1099's LCR| (4) VOLT 6 sidesurrounds/Back Surrounds | (4) VOLT 6 ATMOS | (2) DIY SI-HT18 sealed (2) DIY SI18 DS4 sealed| (2) inuke6000dp | Samsung K8500 4k UHD BDP | 16x11x7.5 sealed HT SadieMax theater...my first DIY build and ongoing projects
Brian Fineberg is online now
post #28503 of 28522 Old Today, 06:06 AM
joeyvaz's Avatar
Quoted: 66 Post(s)
Liked: 29
Thanks! Makes complete sense. Much appreciated.
Brian Fineberg likes this.
joeyvaz is offline
post #28504 of 28522 Old Today, 07:17 AM
moussaka's Avatar
Quoted: 39 Post(s)
Liked: 55
Can't you just put the sub in the MLP and move the mic around to different possible sub locations? Or does it not work like that?
Panasonic 60VT60 | Denon x2000 | EMP E55Ti | E56Ci | E55Wi | PSA XS30 x2
moussaka is online now
post #28505 of 28522 Old Today, 07:20 AM
Liked: 3217
you could i suppose...but for me..i would rather the sub be exactly where it would end up....moving the mic an inch or two can change its readings....so imho mic at MLP and moving the sub is the best approach
moussaka likes this.
post #28506 of 28522 Old Today, 07:25 AM
climber07's Avatar
Quoted: 312 Post(s)
Liked: 1308
Not really. You will lose boundary gain and the comb filtering (room modes) will be different. The sub's distance from objects directly influences the room interaction due to the length of the waves.
climber07 is online now
post #28507 of 28522 Old Today, 07:27 AM
moussaka's Avatar
Quoted: 39 Post(s)
Liked: 55
That makes sense. In my current situation I only really have 2 open spots for both subs to live so I have to put them there, but in the future, this is good to know.
post #28508 of 28522 Old Today, 07:41 AM
basshead81's Avatar
Quoted: 139 Post(s)
Liked: 4230
you get those 3000i's yet?
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #28509 of 28522 Old Today, 07:42 AM
moussaka's Avatar
Quoted: 39 Post(s)
Liked: 55
I'm actually about to get on the site and talk to Tom right now!
post #28510 of 28522 Old Today, 08:11 AM
joeyvaz's Avatar
Quoted: 66 Post(s)
Liked: 29
Wouldn't the same be true with the sub crawl then? Just curious because doing the sub crawl yielded very little for me. Corners all sound good, but everywhere else I heard little to no bass. BUT, putting the sub beside one speaker as suggested, I have good bass in the MLP. If I relied exclusively on the sub crawl, I would never have placed the sub there.
joeyvaz is offline
post #28511 of 28522 Old Today, 08:30 AM
moussaka's Avatar
Quoted: 39 Post(s)
Liked: 55
Done and done... They'll be here Thursday.
post #28512 of 28522 Old Today, 08:34 AM
climber07's Avatar
Quoted: 312 Post(s)
Liked: 1308
That is the purpose of the sub crawl. To find the location in the room where the sub/room interaction provides the best response. This is how you find a home for the sub to reduce or eliminate nulls or peaks at the MLP. The mains also effect the sub even with the crossover set due to the fact that crossovers are not brick walls and allow freqs on either side to pass somewhat. This is usually the cause of nulls or dips at the crossover freq. Bass is a fickle beast and some get lucky with their "aesthetic" placements.
joeyvaz likes this.
post #28513 of 28522 Old Today, 09:01 AM
Hopinater's Avatar
Quoted: 1449 Post(s)
Liked: 3631
There are a lot of problems with the sub crawl. The biggest being that our ears aren't the best measuring devices. So if we play some material and hear a decent boom when it hits a particular bass range (say 45 to 60 Hz), it sticks out in our brain and we assume that it's a good place for the sub, even though what we really heard was a peak and in reality there are dips and nulls above and below where the peak is. Then if you put your sub there you end up with a one note wonder.
Brian Fineberg and joeyvaz like this.
HT: PSA dual V3600's - PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds - Denon 3313CI - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Living Room: PSA XV15se - PSB Image T5 L/R - PSB Image B5 Center - Marantz SR5006 - Panasonic BDT210 - Panamax M4300 - Direct TV - Apple TV - Sony Wii
Hopinater is offline
post #28514 of 28522 Old Today, 09:17 AM
Hopinater's Avatar
Liked: 3631
Here's my personal REW lesson:
Allow me to go back a number of years… I originally placed my first real sub using the sub crawl and I had it there for about 18 months and I kept convincing myself I had great bass but deep down inside I knew it wasn't. Then I got the XV15. I put the sub in the same location. The bass was better because the sub was better but it still was lacking. Then after saying for a year I was going to get REW I finally did and what I learned was shocking. I had two major dips one between 35 to 45 Hz and one around 70 Hz. That's a lot of bass I was missing out on. By moving my sub a foot or so and using the phase knob properly, things changed dramatically… for the better. Once I saw what was going on things got a lot easier.
post #28515 of 28522 Old Today, 09:27 AM
Tom Vodhanel's Avatar
Quoted: 1418 Post(s)
Liked: 3996
This is true. I always try to remember to suggest using a variety of demo scenes---both music and movies for each location check. Keep notes over say 4-5 songs and 4-5 movie scenes. Then try the 2-3 positions that ended up with the highest cumulative score.
Tom V.
Power Sound Audio
joeyvaz and oneeyeblind like this.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten" --- Ben Franklin
Tom Vodhanel is online now
post #28516 of 28522 Old Today, 09:36 AM
bgtighe23's Avatar
Quoted: 1277 Post(s)
Liked: 644
I would say there are a lot of potential problems with the sub crawl. Veteran enthusiasts who advise on this method usually say to test with a bunch of material and locations, rather than just a single song.
The sub crawl is a great method if used correctly. Just like a lot of other methods throughout the setup process.
It's good that you pointed out what to be aware of though to avoid a bad sub crawl.
brahman12 and dsrussell like this.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #28517 of 28522 Old Today, 09:57 AM
Homebrew101's Avatar
Quoted: 51 Post(s)
Liked: 60
Originally Posted by Tom Vodhanel View Post
Anyone happen to know the frequencies for the "door knocking" in Pink Floyd's One of These Days?
Tom V.
Power Sound Audio
Which version are you talking about?
Original vinyl?
Original Japanese vinyl?
MFSL UD?
MFSL UDII?
the Doug Sax 1994 remaster?
the James Guthrie remaster?
Homebrew101 is offline
post #28518 of 28522 Old Today, 10:27 AM
Charles R's Avatar
Liked: 448
I'm sure it's far from perfect but you can use REW's Room Simulation. I found it spot on after x measurements (even though my room isn't actually rectangular - it has a bump out and in). Plus it's a lot less work (and time) than moving subs, measuring and repeating untold times.
ID:	1618417   Click image for larger version
| 120" 16x9 Screen | Mitsubishi HC7900DW Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | NVIDIA Shield | 20TB Media Server : LG 65EG9600 OLED TV | TiVo | Shield
Charles R is offline
post #28519 of 28522 Old Today, 12:52 PM
Liked: 3996
Original vinyl?
MFSL UD?
MFSL UDII?
Yeah, right? I found out how many versions there were after a little more homework..
Really good demo stuff though. I need to expand my mind and its not even Friday...
Tom V.
Power Sound Audio
post #28520 of 28522 Old Today, 02:21 PM
cmdrdredd's Avatar
Quoted: 1527 Post(s)
Liked: 1410
Thanks again!!!
I recommend
1) Proper placement
2) REW or other EQ measurements of the sub(move if necessary) and apply adjustments to the DSP if applicable
3) AVR calibration using the sub's new EQ settings and location so it can calculate distance and delay based on the flatter response the EQ gives
Samsung 55JS9000, Denon AVR-X2200w 5.1.2, PS4, Gaming PC(SLI 970s), Philips BDP7501 UHD Player
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is online now
post #28521 of 28522 Old Today, 02:25 PM
Marc Alexander's Avatar
Quoted: 227 Post(s)
Liked: 170
Marc Alexander is online now
post #28522 of 28522 Old Today, 02:29 PM
Quoted: 227 Post(s)
Liked: 170
Originally Posted by Marc Alexander View Post
Spoiler!
dsrussell likes this.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
